[PATCH v3 0/3] i2c: stm32: cleanup & stop handling fix
This series corrects the handling of the stop condition and cleanup few bits in the driver stm32f7_i2c.c
v3: fix stop handling in patch 3/3 v2: update commit message in patch 3/3
Alain Volmat (3): i2c: stm32: fix comment and remove unused AUTOEND bit i2c: stm32: remove unused stop parameter in start & reload handling i2c: stm32: do not set the STOP condition on error
drivers/i2c/stm32f7_i2c.c | 20 +++++++++----------- 1 file changed, 9 insertions(+), 11 deletions(-)
Comment within stm32_i2c_message_start is misleading, indicating that AUTOEND bit is setted while it is actually cleared. Moreover, the bit is actually never setted so there is no need to clear it hence get rid of this bit clear and the bit macro as well.
Signed-off-by: Alain Volmat alain.volmat@foss.st.com Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com --- drivers/i2c/stm32f7_i2c.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index bf2a6c9b4b..78d7156492 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -57,7 +57,6 @@ struct stm32_i2c_regs { #define STM32_I2C_CR1_PE BIT(0)
/* STM32 I2C control 2 */ -#define STM32_I2C_CR2_AUTOEND BIT(25) #define STM32_I2C_CR2_RELOAD BIT(24) #define STM32_I2C_CR2_NBYTES_MASK GENMASK(23, 16) #define STM32_I2C_CR2_NBYTES(n) ((n & 0xff) << 16) @@ -304,9 +303,8 @@ static void stm32_i2c_message_start(struct stm32_i2c_priv *i2c_priv, cr2 |= STM32_I2C_CR2_SADD7(msg->addr); }
- /* Set nb bytes to transfer and reload or autoend bits */ - cr2 &= ~(STM32_I2C_CR2_NBYTES_MASK | STM32_I2C_CR2_RELOAD | - STM32_I2C_CR2_AUTOEND); + /* Set nb bytes to transfer and reload (if needed) */ + cr2 &= ~(STM32_I2C_CR2_NBYTES_MASK | STM32_I2C_CR2_RELOAD); if (msg->len > STM32_I2C_MAX_LEN) { cr2 |= STM32_I2C_CR2_NBYTES(STM32_I2C_MAX_LEN); cr2 |= STM32_I2C_CR2_RELOAD;
Hi Alain
- /* Set nb bytes to transfer and reload (if needed) */
- cr2 &= ~(STM32_I2C_CR2_NBYTES_MASK | STM32_I2C_CR2_RELOAD); if (msg->len > STM32_I2C_MAX_LEN) { cr2 |= STM32_I2C_CR2_NBYTES(STM32_I2C_MAX_LEN); cr2 |= STM32_I2C_CR2_RELOAD;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Functions stm32_i2c_message_start and stm32_i2c_handle_reload both get a stop boolean indicating if the transfer should end with a STOP or not. However no specific handling is needed in those functions hence remove the parameter.
Signed-off-by: Alain Volmat alain.volmat@foss.st.com Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com --- drivers/i2c/stm32f7_i2c.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index 78d7156492..0ec67b5c12 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -282,7 +282,7 @@ static int stm32_i2c_check_device_busy(struct stm32_i2c_priv *i2c_priv) }
static void stm32_i2c_message_start(struct stm32_i2c_priv *i2c_priv, - struct i2c_msg *msg, bool stop) + struct i2c_msg *msg) { struct stm32_i2c_regs *regs = i2c_priv->regs; u32 cr2 = readl(®s->cr2); @@ -325,7 +325,7 @@ static void stm32_i2c_message_start(struct stm32_i2c_priv *i2c_priv, */
static void stm32_i2c_handle_reload(struct stm32_i2c_priv *i2c_priv, - struct i2c_msg *msg, bool stop) + struct i2c_msg *msg) { struct stm32_i2c_regs *regs = i2c_priv->regs; u32 cr2 = readl(®s->cr2); @@ -431,7 +431,7 @@ static int stm32_i2c_message_xfer(struct stm32_i2c_priv *i2c_priv, /* Add errors */ mask |= STM32_I2C_ISR_ERRORS;
- stm32_i2c_message_start(i2c_priv, msg, stop); + stm32_i2c_message_start(i2c_priv, msg);
while (msg->len) { /* @@ -469,7 +469,7 @@ static int stm32_i2c_message_xfer(struct stm32_i2c_priv *i2c_priv, mask = msg->flags & I2C_M_RD ? STM32_I2C_ISR_RXNE : STM32_I2C_ISR_TXIS | STM32_I2C_ISR_NACKF;
- stm32_i2c_handle_reload(i2c_priv, msg, stop); + stm32_i2c_handle_reload(i2c_priv, msg); } else if (!bytes_to_rw) { /* Wait until TC flag is set */ mask = STM32_I2C_ISR_TC;
Hi Alain
} else if (!bytes_to_rw) { /* Wait until TC flag is set */ mask = STM32_I2C_ISR_TC;stm32_i2c_handle_reload(i2c_priv, msg);
Thanks Patrice
Current function stm32_i2c_message_xfer is sending a STOP whatever the result of the transaction is. This can cause issues such as making the bus busy since the controller itself is already sending automatically a STOP when a NACK is generated.
Thanks to Jorge Ramirez-Ortiz for diagnosing and proposing a first fix for this. [1]
[1] https://lore.kernel.org/u-boot/20220815145211.31342-2-jorge@foundries.io/
Reported-by: Jorge Ramirez-Ortiz, Foundries jorge@foundries.io Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io Signed-off-by: Alain Volmat alain.volmat@foss.st.com --- drivers/i2c/stm32f7_i2c.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index 0ec67b5c12..2db7f44d44 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -483,9 +483,9 @@ static int stm32_i2c_message_xfer(struct stm32_i2c_priv *i2c_priv, } }
- /* End of transfer, send stop condition */ - mask = STM32_I2C_CR2_STOP; - setbits_le32(®s->cr2, mask); + /* End of transfer, send stop condition if appropriate */ + if (!ret && !(status & (STM32_I2C_ISR_NACKF | STM32_I2C_ISR_ERRORS))) + setbits_le32(®s->cr2, STM32_I2C_CR2_STOP);
return stm32_i2c_check_end_of_message(i2c_priv); }
Hi Alain,
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com Tested-by: Patrick Delaunay patrick.delaunay@foss.st.com [stm32mp157c-dk2]
No regression detection on ST Microelectonics board.
- No error trace on boot
- I2C probe command is OK
STM32MP> i2c probe Valid chip addresses: 28 33
- And other tests done with the 2 I2C devices STPMIC1 & STUSB1600 are ok: regulalor command
pmic status command
USB type C connection/deconnection
@Jorge: can you test also for your use-case, thanks
Thanks Patrick
On 12/09/22, Patrick DELAUNAY wrote:
Hi Alain,
- /* End of transfer, send stop condition if appropriate */
- if (!ret && !(status & (STM32_I2C_ISR_NACKF | STM32_I2C_ISR_ERRORS)))
return stm32_i2c_check_end_of_message(i2c_priv); }setbits_le32(®s->cr2, STM32_I2C_CR2_STOP);
regulalor command
pmic status command
yes I did test a few hours ago and it is good on my end. can add my tested tag if needed
Tested-by: Jorge Ramirez-Ortiz jorge@foundries.io
btw I also sent a patch to fix the way some dts properties are handled. shall I submit separately or will it be includeed in this set?
Thanks Patrick
Hi Jorge,
Hi Alain,
regulalor command
pmic status command
Thanks for the test
but sorry I don't see your message when I made my pull request for v2022.10-rc5
so I don't add your tag "Tested-by" when I merge this commit in serie V4.
Yes pushed by Alain in V4 = http://patchwork.ozlabs.org/project/uboot/list/?series=317940&state=*
See[v4,4/4] i2c: stm32: fix usage of rise/fall device tree properties
http://patchwork.ozlabs.org/project/uboot/patch/20220912084201.1826979-5-ala...
it is part of my last pull request = u-boot-stm32-20220915
it is now merged in master branch and part of the next v2022.10-rc5
Thanks Patrick
Hi Alain
Thanks Patrice
Alain Volmat
Patrice CHOTARD
Patrick DELAUNAY
