[U-Boot] [PATCH] rockchip: Clean up CPU selection
In preparation for RK3368 and RK3399, which need to select ARM64, don't select CPU_V7 at the ARCH_ROCKCHIP level but at the SoC level instead.
Cc: Kever Yang kever.yang@rock-chips.com Signed-off-by: Andreas Färber afaerber@suse.de --- arch/arm/Kconfig | 1 - arch/arm/mach-rockchip/Kconfig | 2 ++ 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3237a74..124ee21 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -841,7 +841,6 @@ config ARCH_ROCKCHIP select SUPPORT_SPL select SPL select OF_CONTROL - select CPU_V7 select DM
config TARGET_THUNDERX_88XX diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 2a8afac..d3f5ffd 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -2,6 +2,7 @@ if ARCH_ROCKCHIP
config ROCKCHIP_RK3288 bool "Support Rockchip RK3288" + select CPU_V7 help The Rockchip RK3288 is a ARM-based SoC with a quad-core Cortex-A17 including NEON and GPU, 1MB L2 cache, Mali-T7 graphics, two @@ -11,6 +12,7 @@ config ROCKCHIP_RK3288
config ROCKCHIP_RK3036 bool "Support Rockchip RK3036" + select CPU_V7 help The Rockchip RK3036 is a ARM-based SoC with a dual-core Cortex-A7 including NEON and GPU, Mali-400 graphics, several DDR3 options
Applied to u-boot-rockchip, thanks!
Andreas Färber
