[U-Boot] [PATCH 01/17] tricorder: rewrite tricordereeprom command
From: Andreas Bießmann andreas.devel@googlemail.com
This rewrite uses lately promoted eeprom_init(int) function to choose the right I2C bus when writing data to the EEPROM.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- board/corscience/tricorder/tricorder-eeprom.c | 36 +++++++-------------------- 1 file changed, 9 insertions(+), 27 deletions(-)
diff --git a/board/corscience/tricorder/tricorder-eeprom.c b/board/corscience/tricorder/tricorder-eeprom.c index 1c74a0f..340a009 100644 --- a/board/corscience/tricorder/tricorder-eeprom.c +++ b/board/corscience/tricorder/tricorder-eeprom.c @@ -77,17 +77,13 @@ static int handle_eeprom_v1(struct tricorder_eeprom *eeprom)
int tricorder_get_eeprom(int addr, struct tricorder_eeprom *eeprom) { -#ifdef CONFIG_SYS_EEPROM_BUS_NUM unsigned int bus = i2c_get_bus_num(); i2c_set_bus_num(CONFIG_SYS_EEPROM_BUS_NUM); -#endif
memset(eeprom, 0, TRICORDER_EEPROM_SIZE);
i2c_read(addr, 0, 2, (unsigned char *)eeprom, TRICORDER_EEPROM_SIZE); -#ifdef CONFIG_SYS_EEPROM_BUS_NUM i2c_set_bus_num(bus); -#endif
if (be32_to_cpu(eeprom->magic) != TRICORDER_EEPROM_MAGIC) { warn_wrong_value("magic", TRICORDER_EEPROM_MAGIC, @@ -138,9 +134,6 @@ int tricorder_eeprom_write(unsigned devaddr, const char *name, int ret; unsigned char *p; int i; -#ifdef CONFIG_SYS_EEPROM_BUS_NUM - unsigned int bus; -#endif
memset(eeprom, 0, TRICORDER_EEPROM_SIZE); memset(eeprom_verify, 0, TRICORDER_EEPROM_SIZE); @@ -172,33 +165,23 @@ int tricorder_eeprom_write(unsigned devaddr, const char *name, print_buffer(0, &eeprom, 1, sizeof(eeprom), 16); #endif
-#ifdef CONFIG_SYS_EEPROM_BUS_NUM - bus = i2c_get_bus_num(); - i2c_set_bus_num(CONFIG_SYS_EEPROM_BUS_NUM); -#endif + eeprom_init(CONFIG_SYS_EEPROM_BUS_NUM);
- /* do page write to the eeprom */ - for (i = 0, p = (unsigned char *)&eeprom; - i < sizeof(eeprom); - i += 32, p += 32) { - ret = i2c_write(devaddr, i, CONFIG_SYS_I2C_EEPROM_ADDR_LEN, - p, min(sizeof(eeprom) - i, 32)); - if (ret) - break; - udelay(5000); /* 5ms write cycle timing */ - } + ret = eeprom_write(devaddr, 0, (unsigned char *)&eeprom, + TRICORDER_EEPROM_SIZE); + if (ret) + printf("Tricorder: Could not write EEPROM content!\n");
- ret = i2c_read(devaddr, 0, 2, (unsigned char *)&eeprom_verify, + ret = eeprom_read(devaddr, 0, (unsigned char *)&eeprom_verify, TRICORDER_EEPROM_SIZE); + if (ret) + printf("Tricorder: Could not read EEPROM content!\n");
if (memcmp(&eeprom, &eeprom_verify, sizeof(eeprom)) != 0) { printf("Tricorder: Could not verify EEPROM content!\n"); ret = 1; }
-#ifdef CONFIG_SYS_EEPROM_BUS_NUM - i2c_set_bus_num(bus); -#endif return ret; }
@@ -206,7 +189,7 @@ int do_tricorder_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { if (argc == 3) { ulong dev_addr = simple_strtoul(argv[2], NULL, 16); - eeprom_init(); + if (strcmp(argv[1], "read") == 0) { int rcode;
@@ -220,7 +203,6 @@ int do_tricorder_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) char *version = argv[4]; char *serial = argv[5]; char *interface = NULL; - eeprom_init();
if (argc == 7) interface = argv[6];
Just move the code around so that the forward declarations are not necessary. Also zap a few checkpatch issues where applicable and zap the use of #ifdef CONFIG_CMD_EEPROM in the code, since this is always true.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 168 ++++++++++++++++++++++------------------------------ 1 file changed, 70 insertions(+), 98 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index e9904cd..4335079 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -25,94 +25,55 @@ #include <command.h> #include <i2c.h>
-extern void eeprom_init (void); -extern int eeprom_read (unsigned dev_addr, unsigned offset, - uchar *buffer, unsigned cnt); -extern int eeprom_write (unsigned dev_addr, unsigned offset, - uchar *buffer, unsigned cnt); -#if defined(CONFIG_SYS_EEPROM_WREN) -extern int eeprom_write_enable (unsigned dev_addr, int state); +#ifndef CONFIG_SYS_I2C_SPEED +#define CONFIG_SYS_I2C_SPEED 50000 #endif
- +/* Maximum number of times to poll for acknowledge after write */ #if defined(CONFIG_SYS_EEPROM_X40430) - /* Maximum number of times to poll for acknowledge after write */ #define MAX_ACKNOWLEDGE_POLLS 10 #endif
-/* ------------------------------------------------------------------------- */ - -#if defined(CONFIG_CMD_EEPROM) -static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - const char *const fmt = - "\nEEPROM @0x%lX %s: addr %08lx off %04lx count %ld ... "; - -#if defined(CONFIG_SYS_I2C_MULTI_EEPROMS) - if (argc == 6) { - ulong dev_addr = simple_strtoul (argv[2], NULL, 16); - ulong addr = simple_strtoul (argv[3], NULL, 16); - ulong off = simple_strtoul (argv[4], NULL, 16); - ulong cnt = simple_strtoul (argv[5], NULL, 16); -#else - if (argc == 5) { - ulong dev_addr = CONFIG_SYS_DEF_EEPROM_ADDR; - ulong addr = simple_strtoul (argv[2], NULL, 16); - ulong off = simple_strtoul (argv[3], NULL, 16); - ulong cnt = simple_strtoul (argv[4], NULL, 16); -#endif /* CONFIG_SYS_I2C_MULTI_EEPROMS */ - -# if !defined(CONFIG_SPI) || defined(CONFIG_ENV_EEPROM_IS_ON_I2C) - eeprom_init (); -# endif /* !CONFIG_SPI */ - - if (strcmp (argv[1], "read") == 0) { - int rcode; - - printf (fmt, dev_addr, argv[1], addr, off, cnt); - - rcode = eeprom_read (dev_addr, off, (uchar *) addr, cnt); - - puts ("done\n"); - return rcode; - } else if (strcmp (argv[1], "write") == 0) { - int rcode; - - printf (fmt, dev_addr, argv[1], addr, off, cnt); - - rcode = eeprom_write (dev_addr, off, (uchar *) addr, cnt); - - puts ("done\n"); - return rcode; - } - } - - return CMD_RET_USAGE; -} -#endif - -/*----------------------------------------------------------------------- - * +/* * for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 2 (16-bit EEPROM address) offset is * 0x000nxxxx for EEPROM address selectors at n, offset xxxx in EEPROM. * * for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 (8-bit EEPROM page address) offset is * 0x00000nxx for EEPROM address selectors and page number at n. */ - #if !defined(CONFIG_SPI) || defined(CONFIG_ENV_EEPROM_IS_ON_I2C) -#if !defined(CONFIG_SYS_I2C_EEPROM_ADDR_LEN) || CONFIG_SYS_I2C_EEPROM_ADDR_LEN < 1 || CONFIG_SYS_I2C_EEPROM_ADDR_LEN > 2 +#if !defined(CONFIG_SYS_I2C_EEPROM_ADDR_LEN) || \ + (CONFIG_SYS_I2C_EEPROM_ADDR_LEN < 1) || \ + (CONFIG_SYS_I2C_EEPROM_ADDR_LEN > 2) #error CONFIG_SYS_I2C_EEPROM_ADDR_LEN must be 1 or 2 #endif #endif
+#if defined(CONFIG_SYS_EEPROM_WREN) +extern int eeprom_write_enable (unsigned dev_addr, int state); +#endif + +void eeprom_init(void) +{ + /* SPI EEPROM */ +#if defined(CONFIG_SPI) && !defined(CONFIG_ENV_EEPROM_IS_ON_I2C) + spi_init_f (); +#endif + + /* I2C EEPROM */ +#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SYS_I2C_SOFT) + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif +} + int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { unsigned end = offset + cnt; unsigned blk_off; int rcode = 0;
- /* Read data until done or would cross a page boundary. + /* + * Read data until done or would cross a page boundary. * We must write the address again when changing pages * because the next page may be in a different device. */ @@ -174,15 +135,6 @@ int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt return rcode; }
-/*----------------------------------------------------------------------- - * - * for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 2 (16-bit EEPROM address) offset is - * 0x000nxxxx for EEPROM address selectors at n, offset xxxx in EEPROM. - * - * for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 (8-bit EEPROM page address) offset is - * 0x00000nxx for EEPROM address selectors and page number at n. - */ - int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { unsigned end = offset + cnt; @@ -200,7 +152,8 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn #if defined(CONFIG_SYS_EEPROM_WREN) eeprom_write_enable (dev_addr,1); #endif - /* Write data until done or would cross a write page boundary. + /* + * Write data until done or would cross a write page boundary. * We must write the address again when changing pages * because the address counter only increments within a page. */ @@ -363,8 +316,7 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn }
#if !defined(CONFIG_SPI) || defined(CONFIG_ENV_EEPROM_IS_ON_I2C) -int -eeprom_probe (unsigned dev_addr, unsigned offset) +int eeprom_probe(unsigned dev_addr, unsigned offset) { unsigned char chip;
@@ -382,30 +334,52 @@ eeprom_probe (unsigned dev_addr, unsigned offset) } #endif
-/*----------------------------------------------------------------------- - * Set default values - */ -#ifndef CONFIG_SYS_I2C_SPEED -#define CONFIG_SYS_I2C_SPEED 50000 -#endif - -void eeprom_init (void) +static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { + const char *const fmt = + "\nEEPROM @0x%lX %s: addr %08lx off %04lx count %ld ... ";
-#if defined(CONFIG_SPI) && !defined(CONFIG_ENV_EEPROM_IS_ON_I2C) - spi_init_f (); -#endif -#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SYS_I2C_SOFT) - i2c_init (CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); -#endif -} +#if defined(CONFIG_SYS_I2C_MULTI_EEPROMS) + if (argc == 6) { + ulong dev_addr = simple_strtoul (argv[2], NULL, 16); + ulong addr = simple_strtoul (argv[3], NULL, 16); + ulong off = simple_strtoul (argv[4], NULL, 16); + ulong cnt = simple_strtoul (argv[5], NULL, 16); +#else + if (argc == 5) { + ulong dev_addr = CONFIG_SYS_DEF_EEPROM_ADDR; + ulong addr = simple_strtoul (argv[2], NULL, 16); + ulong off = simple_strtoul (argv[3], NULL, 16); + ulong cnt = simple_strtoul (argv[4], NULL, 16); +#endif /* CONFIG_SYS_I2C_MULTI_EEPROMS */
-/*----------------------------------------------------------------------- - */ +# if !defined(CONFIG_SPI) || defined(CONFIG_ENV_EEPROM_IS_ON_I2C) + eeprom_init (); +# endif /* !CONFIG_SPI */
-/***************************************************/ + if (strcmp (argv[1], "read") == 0) { + int rcode; + + printf (fmt, dev_addr, argv[1], addr, off, cnt);
-#if defined(CONFIG_CMD_EEPROM) + rcode = eeprom_read (dev_addr, off, (uchar *) addr, cnt); + + puts ("done\n"); + return rcode; + } else if (strcmp (argv[1], "write") == 0) { + int rcode; + + printf (fmt, dev_addr, argv[1], addr, off, cnt); + + rcode = eeprom_write (dev_addr, off, (uchar *) addr, cnt); + + puts ("done\n"); + return rcode; + } + } + + return CMD_RET_USAGE; +}
#ifdef CONFIG_SYS_I2C_MULTI_EEPROMS U_BOOT_CMD( @@ -424,5 +398,3 @@ U_BOOT_CMD( " - read/write `cnt' bytes at EEPROM offset `off'" ) #endif /* CONFIG_SYS_I2C_MULTI_EEPROMS */ - -#endif
Hello Marek,
Am 10.11.2015 um 20:53 schrieb Marek Vasut:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
- if (argc == 6) {
-#else
- if (argc == 5) {
eeprom_init ();
int rcode;
puts ("done\n");
return rcode;
int rcode;
puts ("done\n");
return rcode;
-} -#endif
- for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 2 (16-bit EEPROM address) offset is
- 0x000nxxxx for EEPROM address selectors at n, offset xxxx in EEPROM.
- for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 (8-bit EEPROM page address) offset is
- 0x00000nxx for EEPROM address selectors and page number at n.
- (CONFIG_SYS_I2C_EEPROM_ADDR_LEN < 1) || \
- (CONFIG_SYS_I2C_EEPROM_ADDR_LEN > 2) #error CONFIG_SYS_I2C_EEPROM_ADDR_LEN must be 1 or 2 #endif #endif
- /* SPI EEPROM */
- spi_init_f ();
- /* I2C EEPROM */
- i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);
+#endif +}
- int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { unsigned end = offset + cnt; unsigned blk_off; int rcode = 0;
- We must write the address again when changing pages
- because the next page may be in a different device.
- because the address counter only increments within a page.
- Set default values
- spi_init_f ();
- if (argc == 6) {
+#else
- if (argc == 5) {
eeprom_init ();
int rcode;
puts ("done\n");
return rcode;
int rcode;
puts ("done\n");
return rcode;
-#endif
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de Reviewed-by: Heiko Schocher hs@denx.de
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 69 ++++++++++++++++++----------------------- include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/PMC440.h | 1 - include/configs/TQM834x.h | 1 - include/configs/acadia.h | 1 - include/configs/am335x_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/axs101.h | 1 - include/configs/bamboo.h | 1 - include/configs/canyonlands.h | 1 - include/configs/icon.h | 1 - include/configs/intip.h | 1 - include/configs/katmai.h | 1 - include/configs/km/km-powerpc.h | 1 - include/configs/km/km_arm.h | 1 - include/configs/luan.h | 1 - include/configs/m28evk.h | 1 - include/configs/motionpro.h | 1 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/p1_twr.h | 1 - include/configs/pcm051.h | 1 - include/configs/pengwyn.h | 1 - include/configs/sequoia.h | 1 - include/configs/t3corp.h | 1 - include/configs/tricorder.h | 1 - include/configs/walnut.h | 1 - include/configs/yosemite.h | 1 - 30 files changed, 30 insertions(+), 68 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 4335079..0b59bea 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -338,50 +338,50 @@ static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { const char *const fmt = "\nEEPROM @0x%lX %s: addr %08lx off %04lx count %ld ... "; + char * const *args = &argv[2]; + int rcode; + ulong dev_addr, addr, off, cnt; + + switch (argc) { +#ifdef CONFIG_SYS_DEF_EEPROM_ADDR + case 5: + dev_addr = CONFIG_SYS_DEF_EEPROM_ADDR; + break; +#endif + case 6: + dev_addr = simple_strtoul(*args++, NULL, 16); + break; + default: + return CMD_RET_USAGE; + }
-#if defined(CONFIG_SYS_I2C_MULTI_EEPROMS) - if (argc == 6) { - ulong dev_addr = simple_strtoul (argv[2], NULL, 16); - ulong addr = simple_strtoul (argv[3], NULL, 16); - ulong off = simple_strtoul (argv[4], NULL, 16); - ulong cnt = simple_strtoul (argv[5], NULL, 16); -#else - if (argc == 5) { - ulong dev_addr = CONFIG_SYS_DEF_EEPROM_ADDR; - ulong addr = simple_strtoul (argv[2], NULL, 16); - ulong off = simple_strtoul (argv[3], NULL, 16); - ulong cnt = simple_strtoul (argv[4], NULL, 16); -#endif /* CONFIG_SYS_I2C_MULTI_EEPROMS */ + addr = simple_strtoul(*args++, NULL, 16); + off = simple_strtoul(*args++, NULL, 16); + cnt = simple_strtoul(*args++, NULL, 16);
# if !defined(CONFIG_SPI) || defined(CONFIG_ENV_EEPROM_IS_ON_I2C) - eeprom_init (); + eeprom_init (); # endif /* !CONFIG_SPI */
- if (strcmp (argv[1], "read") == 0) { - int rcode; - - printf (fmt, dev_addr, argv[1], addr, off, cnt); - - rcode = eeprom_read (dev_addr, off, (uchar *) addr, cnt); + if (strcmp (argv[1], "read") == 0) { + printf(fmt, dev_addr, argv[1], addr, off, cnt);
- puts ("done\n"); - return rcode; - } else if (strcmp (argv[1], "write") == 0) { - int rcode; + rcode = eeprom_read(dev_addr, off, (uchar *) addr, cnt);
- printf (fmt, dev_addr, argv[1], addr, off, cnt); + puts ("done\n"); + return rcode; + } else if (strcmp (argv[1], "write") == 0) { + printf(fmt, dev_addr, argv[1], addr, off, cnt);
- rcode = eeprom_write (dev_addr, off, (uchar *) addr, cnt); + rcode = eeprom_write(dev_addr, off, (uchar *) addr, cnt);
- puts ("done\n"); - return rcode; - } + puts ("done\n"); + return rcode; }
return CMD_RET_USAGE; }
-#ifdef CONFIG_SYS_I2C_MULTI_EEPROMS U_BOOT_CMD( eeprom, 6, 1, do_eeprom, "EEPROM sub-system", @@ -389,12 +389,3 @@ U_BOOT_CMD( "eeprom write devaddr addr off cnt\n" " - read/write `cnt' bytes from `devaddr` EEPROM at offset `off'" ) -#else /* One EEPROM */ -U_BOOT_CMD( - eeprom, 5, 1, do_eeprom, - "EEPROM sub-system", - "read addr off cnt\n" - "eeprom write addr off cnt\n" - " - read/write `cnt' bytes at EEPROM offset `off'" -) -#endif /* CONFIG_SYS_I2C_MULTI_EEPROMS */ diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 2754016..193ffbc 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -267,7 +267,6 @@ extern unsigned long get_sdram_size(void);
/* I2C EEPROM */ #define CONFIG_CMD_EEPROM -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 54dcf3b..4b0e5f1 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -463,7 +463,6 @@ combinations. this should be removed later
/* enable read and write access to EEPROM */ #define CONFIG_CMD_EEPROM -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 94f991b..c76d05f 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -420,7 +420,6 @@ /* I2C EEPROM */ /* enable read and write access to EEPROM */ #define CONFIG_CMD_EEPROM -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 81b0855..8a137d0 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -660,7 +660,6 @@ extern unsigned long get_sdram_size(void); #endif /* enable read and write access to EEPROM */ #define CONFIG_CMD_EEPROM -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index 0227649..26a1444 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -159,7 +159,6 @@ #define CONFIG_SYS_I2C_PPC4XX_SPEED_1 400000 #define CONFIG_SYS_I2C_PPC4XX_SLAVE_1 0x7F
#define CONFIG_SYS_I2C_EEPROM_ADDR 0x54 #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 0b046d1..9f6bd0f 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -183,7 +183,6 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* 16 bit */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* 32 bytes/write */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 /* 10ms +/- 20% */ -#define CONFIG_SYS_I2C_MULTI_EEPROMS /* more than one eeprom */
/* I2C RTC */ #define CONFIG_RTC_DS1337 /* use ds1337 rtc via i2c */ diff --git a/include/configs/acadia.h b/include/configs/acadia.h index 4dd5720..2f53d73 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -120,7 +120,6 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index d58816d..a4b8e0f 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -213,7 +213,6 @@ #define CONFIG_ENV_EEPROM_IS_ON_I2C #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Main EEPROM */ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -#define CONFIG_SYS_I2C_MULTI_EEPROMS
/* PMIC support */ #define CONFIG_POWER_TPS65217 diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index d93e3e7..5821137 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -36,7 +36,6 @@ #define CONFIG_ENV_EEPROM_IS_ON_I2C #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Main EEPROM */ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -#define CONFIG_SYS_I2C_MULTI_EEPROMS
/* Power */ #define CONFIG_POWER diff --git a/include/configs/axs101.h b/include/configs/axs101.h index 450291c..e921f19 100644 --- a/include/configs/axs101.h +++ b/include/configs/axs101.h @@ -91,7 +91,6 @@ /* * EEPROM configuration */ -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xA8 >> 1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 1 diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index 6ba4aaf..5b8b22f 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -139,7 +139,6 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index ed790cc..e136824 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -248,7 +248,6 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/icon.h b/include/configs/icon.h index bbe9b59..d9a3671 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -107,7 +107,6 @@
#define CONFIG_SYS_SPD_BUS_NUM 0 /* The I2C bus for SPD */
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/intip.h b/include/configs/intip.h index a676a20..60c9e2c 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -214,7 +214,6 @@ */ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/katmai.h b/include/configs/katmai.h index fa72eb0..664896b 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -109,7 +109,6 @@ #define IIC0_BOOTPROM_ADDR 0x50 #define IIC0_ALT_BOOTPROM_ADDR 0x54
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0x50) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/km/km-powerpc.h b/include/configs/km/km-powerpc.h index eb85a74..2b0b9dc 100644 --- a/include/configs/km/km-powerpc.h +++ b/include/configs/km/km-powerpc.h @@ -21,7 +21,6 @@ #define CONFIG_KM_COMMON_ETH_INIT
/* EEprom support 24C08, 24C16, 24C64 */ -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 /* 8 Byte write page */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index b89af53..798c9a7 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -215,7 +215,6 @@ int get_scl(void); #define CONFIG_SYS_I2C_SOFT_SPEED 100000
/* EEprom support 24C128, 24C256 valid for environment eeprom */ -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_EEPROM_PAGE_WRITE_ENABLE #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 /* 64 Byte write page */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 diff --git a/include/configs/luan.h b/include/configs/luan.h index 15e4a7e..e22d0e8 100644 --- a/include/configs/luan.h +++ b/include/configs/luan.h @@ -119,7 +119,6 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 29c60b7..f9fc66f 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -92,7 +92,6 @@
/* EEPROM */ #ifdef CONFIG_CMD_EEPROM -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 #endif
diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index 97c614b..a8cf201 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -285,7 +285,6 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 1 /* 2 bytes per write cycle */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 /* 2ms/cycle + 3ms extra */ -#define CONFIG_SYS_I2C_MULTI_EEPROMS 1 /* 2 EEPROMs (addr:50,52) */
/* * RTC configuration diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 433c409..e039af4 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -701,7 +701,6 @@
/* enable read and write access to EEPROM */ #define CONFIG_CMD_EEPROM -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index d83daa0..3089969 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -262,7 +262,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
/* enable read and write access to EEPROM */ #define CONFIG_CMD_EEPROM -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 275e952..64cfd81 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -115,7 +115,6 @@ #define CONFIG_ENV_EEPROM_IS_ON_I2C #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Main EEPROM */ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -#define CONFIG_SYS_I2C_MULTI_EEPROMS
#define CONFIG_SYS_BAUDRATE_TABLE { 110, 300, 600, 1200, 2400, \ 4800, 9600, 14400, 19200, 28800, 38400, 56000, 57600, 115200 } diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index ccb5dd3..b057539 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -112,7 +112,6 @@ #define CONFIG_ENV_EEPROM_IS_ON_I2C #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -#define CONFIG_SYS_I2C_MULTI_EEPROMS
/* SPL */ #define CONFIG_SPL_POWER_SUPPORT diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 1f1beea..f32459b 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -151,7 +151,6 @@ */ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/t3corp.h b/include/configs/t3corp.h index 502e795..7942865 100644 --- a/include/configs/t3corp.h +++ b/include/configs/t3corp.h @@ -307,7 +307,6 @@ */ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 02b0e63..e453151 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -112,7 +112,6 @@
/* EEPROM */ -#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_CMD_EEPROM #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 #define CONFIG_SYS_EEPROM_BUS_NUM 1 diff --git a/include/configs/walnut.h b/include/configs/walnut.h index 8b803a2..dd6b519 100644 --- a/include/configs/walnut.h +++ b/include/configs/walnut.h @@ -80,7 +80,6 @@ */ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
-#define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index 8508a80..0cffab8 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -122,7 +122,6 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000
Hello Marek,
bye, Heiko
- char * const *args = &argv[2];
- int rcode;
- ulong dev_addr, addr, off, cnt;
- switch (argc) {
- case 5:
break;
- case 6:
break;
- default:
- if (argc == 6) {
-#else
- if (argc == 5) {
eeprom_init ();
- eeprom_init (); # endif /* !CONFIG_SPI */
int rcode;
puts ("done\n");
return rcode;
int rcode;
puts ("done\n");
return rcode;
puts ("done\n");
return rcode;
puts ("done\n");
return rcode;
- EEPROM configuration
- RTC configuration
Now that the only user of CONFIG_SYS_EEPROM_X40430 was removed, remove this unused code from cmd_eeprom.c
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 94 ----------------------------------------------------- 1 file changed, 94 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 0b59bea..266f954 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -29,11 +29,6 @@ #define CONFIG_SYS_I2C_SPEED 50000 #endif
-/* Maximum number of times to poll for acknowledge after write */ -#if defined(CONFIG_SYS_EEPROM_X40430) -#define MAX_ACKNOWLEDGE_POLLS 10 -#endif - /* * for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 2 (16-bit EEPROM address) offset is * 0x000nxxxx for EEPROM address selectors at n, offset xxxx in EEPROM. @@ -141,14 +136,6 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn unsigned blk_off; int rcode = 0;
-#if defined(CONFIG_SYS_EEPROM_X40430) - uchar contr_r_addr[2]; - uchar addr_void[2]; - uchar contr_reg[2]; - uchar ctrl_reg_v; - int i; -#endif - #if defined(CONFIG_SYS_EEPROM_WREN) eeprom_write_enable (dev_addr,1); #endif @@ -213,88 +200,7 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn #if defined(CONFIG_SPI) && !defined(CONFIG_ENV_EEPROM_IS_ON_I2C) spi_write (addr, alen, buffer, len); #else -#if defined(CONFIG_SYS_EEPROM_X40430) - /* Get the value of the control register. - * Set current address (internal pointer in the x40430) - * to 0x1ff. - */ - contr_r_addr[0] = 9; - contr_r_addr[1] = 0xff; - addr_void[0] = 0; - addr_void[1] = addr[1]; -#ifdef CONFIG_SYS_I2C_EEPROM_ADDR - contr_r_addr[0] |= CONFIG_SYS_I2C_EEPROM_ADDR; - addr_void[0] |= CONFIG_SYS_I2C_EEPROM_ADDR; -#endif - contr_reg[0] = 0xff; - if (i2c_read (contr_r_addr[0], contr_r_addr[1], 1, contr_reg, 1) != 0) { - rcode = 1; - } - ctrl_reg_v = contr_reg[0];
- /* Are any of the eeprom blocks write protected? - */ - if (ctrl_reg_v & 0x18) { - ctrl_reg_v &= ~0x18; /* reset block protect bits */ - ctrl_reg_v |= 0x02; /* set write enable latch */ - ctrl_reg_v &= ~0x04; /* clear RWEL */ - - /* Set write enable latch. - */ - contr_reg[0] = 0x02; - if (i2c_write (contr_r_addr[0], 0xff, 1, contr_reg, 1) != 0) { - rcode = 1; - } - - /* Set register write enable latch. - */ - contr_reg[0] = 0x06; - if (i2c_write (contr_r_addr[0], 0xFF, 1, contr_reg, 1) != 0) { - rcode = 1; - } - - /* Modify ctrl register. - */ - contr_reg[0] = ctrl_reg_v; - if (i2c_write (contr_r_addr[0], 0xFF, 1, contr_reg, 1) != 0) { - rcode = 1; - } - - /* The write (above) is an operation on NV memory. - * These can take some time (~5ms), and the device - * will not respond to further I2C messages till - * it's completed the write. - * So poll device for an I2C acknowledge. - * When we get one we know we can continue with other - * operations. - */ - contr_reg[0] = 0; - for (i = 0; i < MAX_ACKNOWLEDGE_POLLS; i++) { - if (i2c_read (addr_void[0], addr_void[1], 1, contr_reg, 1) == 0) - break; /* got ack */ -#if defined(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS) - udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); -#endif - } - if (i == MAX_ACKNOWLEDGE_POLLS) { - puts ("EEPROM poll acknowledge failed\n"); - rcode = 1; - } - } - - /* Is the write enable latch on?. - */ - else if (!(ctrl_reg_v & 0x02)) { - /* Set write enable latch. - */ - contr_reg[0] = 0x02; - if (i2c_write (contr_r_addr[0], 0xFF, 1, contr_reg, 1) != 0) { - rcode = 1; - } - } - /* Write is enabled ... now write eeprom value. - */ -#endif #if defined(CONFIG_SYS_I2C_EEPROM_BUS) i2c_set_bus_num(CONFIG_SYS_I2C_EEPROM_BUS); #endif
Hello Marek,
bye, Heiko
- uchar ctrl_reg_v;
- int i;
-#endif
* to 0x1ff.
addr_void[0] = 0;
-#endif
rcode = 1;
rcode = 1;
rcode = 1;
rcode = 1;
* operations.
contr_reg[0] = 0;
-#endif
rcode = 1;
rcode = 1;
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Heiko Schocher hs@denx.de Reviewed-by: Heiko Schocher hs@denx.de
Remove this function as it's no longer used.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 19 ------------------- include/common.h | 3 --- 2 files changed, 22 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 266f954..ea1d447 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -221,25 +221,6 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn return rcode; }
-#if !defined(CONFIG_SPI) || defined(CONFIG_ENV_EEPROM_IS_ON_I2C) -int eeprom_probe(unsigned dev_addr, unsigned offset) -{ - unsigned char chip; - - /* Probe the chip address - */ -#if CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 && !defined(CONFIG_SPI_X) - chip = offset >> 8; /* block number */ -#else - chip = offset >> 16; /* block number */ -#endif /* CONFIG_SYS_I2C_EEPROM_ADDR_LEN, CONFIG_SPI_X */ - - chip |= dev_addr; /* insert device address */ - - return (i2c_probe (chip)); -} -#endif - static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { const char *const fmt = diff --git a/include/common.h b/include/common.h index 09a131d..ceb1ad3 100644 --- a/include/common.h +++ b/include/common.h @@ -476,9 +476,6 @@ void fdc_hw_init (void);
/* $(BOARD)/eeprom.c */ void eeprom_init (void); -#ifndef CONFIG_SPI -int eeprom_probe (unsigned dev_addr, unsigned offset); -#endif int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt);
Hello Marek,
bye, Heiko
-#else
-} -#endif
This macro is no longer used, so just reap it.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Heiko Schocher hs@denx.de --- README | 5 ----- common/cmd_eeprom.c | 8 ++++---- 2 files changed, 4 insertions(+), 9 deletions(-)
diff --git a/README b/README index ef8d437..8fb81e9 100644 --- a/README +++ b/README @@ -2705,11 +2705,6 @@ CBFS (Coreboot Filesystem) support Enables the driver for SPI controller on SuperH. Currently only SH7757 is supported.
- CONFIG_SPI_X - - Enables extended (16-bit) SPI EEPROM addressing. - (symmetrical to CONFIG_I2C_X) - CONFIG_SOFT_SPI
Enables a software (bit-bang) SPI driver rather than diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index ea1d447..728606e 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -78,7 +78,7 @@ int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt unsigned maxlen; #endif
-#if CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 && !defined(CONFIG_SPI_X) +#if CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 uchar addr[2];
blk_off = offset & 0xFF; /* block offset */ @@ -95,7 +95,7 @@ int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt addr[1] = offset >> 8; /* upper address octet */ addr[2] = blk_off; /* lower address octet */ alen = 3; -#endif /* CONFIG_SYS_I2C_EEPROM_ADDR_LEN, CONFIG_SPI_X */ +#endif /* CONFIG_SYS_I2C_EEPROM_ADDR_LEN */
addr[0] |= dev_addr; /* insert device address */
@@ -151,7 +151,7 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn unsigned maxlen; #endif
blk_off = offset & 0xFF; /* block offset */ @@ -168,7 +168,7 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn addr[1] = offset >> 8; /* upper address octet */ addr[2] = blk_off; /* lower address octet */ alen = 3; -#endif /* CONFIG_SYS_I2C_EEPROM_ADDR_LEN, CONFIG_SPI_X */ +#endif /* CONFIG_SYS_I2C_EEPROM_ADDR_LEN */
Hello Marek,
bye, Heiko
CONFIG_SPI_X
CONFIG_SOFT_SPI
Pull out the code which does the I2C or SPI read/write, so that the beefy ifdef around it is contained in a single function.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 50 +++++++++++++++++++++++++++++++------------------- 1 file changed, 31 insertions(+), 19 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 728606e..7797d0e 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -61,6 +61,34 @@ void eeprom_init(void) #endif }
+static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, + uchar *buffer, unsigned len, bool read) +{ + int ret = 0; + + /* SPI */ +#if defined(CONFIG_SPI) && !defined(CONFIG_ENV_EEPROM_IS_ON_I2C) + if (read) + spi_read(addr, alen, buffer, len); + else + spi_write(addr, alen, buffer, len); +#else /* I2C */ + +#if defined(CONFIG_SYS_I2C_EEPROM_BUS) + i2c_set_bus_num(CONFIG_SYS_I2C_EEPROM_BUS); +#endif + + if (read) + ret = i2c_read(addr[0], offset, alen - 1, buffer, len); + else + ret = i2c_write(addr[0], offset, alen - 1, buffer, len); + + if (ret) + ret = 1; +#endif + return ret; +} + int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { unsigned end = offset + cnt; @@ -114,15 +142,8 @@ int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt len = maxlen; #endif
-#if defined(CONFIG_SPI) && !defined(CONFIG_ENV_EEPROM_IS_ON_I2C) - spi_read (addr, alen, buffer, len); -#else -#if defined(CONFIG_SYS_I2C_EEPROM_BUS) - i2c_set_bus_num(CONFIG_SYS_I2C_EEPROM_BUS); -#endif - if (i2c_read(addr[0], offset, alen - 1, buffer, len)) - rcode = 1; -#endif + rcode = eeprom_rw_block(offset, addr, alen, buffer, len, 1); + buffer += len; offset += len; } @@ -197,17 +218,8 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn len = maxlen; #endif
-#if defined(CONFIG_SPI) && !defined(CONFIG_ENV_EEPROM_IS_ON_I2C) - spi_write (addr, alen, buffer, len); -#else + rcode = eeprom_rw_block(offset, addr, alen, buffer, len, 0);
-#if defined(CONFIG_SYS_I2C_EEPROM_BUS) - i2c_set_bus_num(CONFIG_SYS_I2C_EEPROM_BUS); -#endif - if (i2c_write(addr[0], offset, alen - 1, buffer, len)) - rcode = 1; - -#endif buffer += len; offset += len;
Hello Marek,
bye, Heiko
- int ret = 0;
- /* SPI */
- if (read)
- else
+#else /* I2C */
- if (read)
- else
- if (ret)
ret = 1;
- return ret;
-#endif
rcode = 1;
-#endif
- buffer += len; offset += len; }
-#else
-#endif
rcode = 1;
Pull out the code computing the EEPROM address into separate function so that it's not duplicated.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 64 ++++++++++++++++++++++------------------------------- 1 file changed, 26 insertions(+), 38 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 7797d0e..5979993 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -61,6 +61,28 @@ void eeprom_init(void) #endif }
+static int eeprom_addr(unsigned dev_addr, unsigned offset, uchar *addr) +{ + unsigned blk_off; + int alen; + + blk_off = offset & 0xff; /* block offset */ +#if CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 + addr[0] = offset >> 8; /* block number */ + addr[1] = blk_off; /* block offset */ + alen = 2; +#else + addr[0] = offset >> 16; /* block number */ + addr[1] = offset >> 8; /* upper address octet */ + addr[2] = blk_off; /* lower address octet */ + alen = 3; +#endif /* CONFIG_SYS_I2C_EEPROM_ADDR_LEN */ + + addr[0] |= dev_addr; /* insert device address */ + + return alen; +} + static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, uchar *buffer, unsigned len, bool read) { @@ -94,6 +116,7 @@ int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt unsigned end = offset + cnt; unsigned blk_off; int rcode = 0; + uchar addr[3];
/* * Read data until done or would cross a page boundary. @@ -106,26 +129,8 @@ int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt unsigned maxlen; #endif
-#if CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 - uchar addr[2]; - - blk_off = offset & 0xFF; /* block offset */ - - addr[0] = offset >> 8; /* block number */ - addr[1] = blk_off; /* block offset */ - alen = 2; -#else - uchar addr[3]; - blk_off = offset & 0xFF; /* block offset */ - - addr[0] = offset >> 16; /* block number */ - addr[1] = offset >> 8; /* upper address octet */ - addr[2] = blk_off; /* lower address octet */ - alen = 3; -#endif /* CONFIG_SYS_I2C_EEPROM_ADDR_LEN */ - - addr[0] |= dev_addr; /* insert device address */ + alen = eeprom_addr(dev_addr, offset, addr);
len = end - offset;
@@ -156,6 +161,7 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn unsigned end = offset + cnt; unsigned blk_off; int rcode = 0; + uchar addr[3];
#if defined(CONFIG_SYS_EEPROM_WREN) eeprom_write_enable (dev_addr,1); @@ -172,26 +178,8 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn unsigned maxlen; #endif
-#if CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 1 - uchar addr[2]; - blk_off = offset & 0xFF; /* block offset */ - - addr[0] = offset >> 8; /* block number */ - addr[1] = blk_off; /* block offset */ - alen = 2; -#else - uchar addr[3]; - - blk_off = offset & 0xFF; /* block offset */ - - addr[0] = offset >> 16; /* block number */ - addr[1] = offset >> 8; /* upper address octet */ - addr[2] = blk_off; /* lower address octet */ - alen = 3; -#endif /* CONFIG_SYS_I2C_EEPROM_ADDR_LEN */ - - addr[0] |= dev_addr; /* insert device address */ + alen = eeprom_addr(dev_addr, offset, addr);
len = end - offset;
Hello Marek,
bye, Heiko
- unsigned blk_off;
- int alen;
- blk_off = offset & 0xff; /* block offset */
- alen = 2;
+#else
- alen = 3;
- return alen;
- static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, uchar *buffer, unsigned len, bool read) {
uchar addr[3];
- Read data until done or would cross a page boundary.
uchar addr[2];
alen = 2;
-#else
uchar addr[3];
alen = 3;
len = end - offset;
uchar addr[3];
uchar addr[2];
alen = 2;
-#else
uchar addr[3];
alen = 3;
len = end - offset;
Make this function weak and implement it's weak implementation so that the boards can just reimplement it. This zaps the horrid CONFIG_SYS_EEPROM_WREN macro.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 5979993..040ab5f 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -44,9 +44,10 @@ #endif #endif
-#if defined(CONFIG_SYS_EEPROM_WREN) -extern int eeprom_write_enable (unsigned dev_addr, int state); -#endif +__weak int eeprom_write_enable(unsigned dev_addr, int state) +{ + return 0; +}
void eeprom_init(void) { @@ -163,9 +164,8 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn int rcode = 0; uchar addr[3];
-#if defined(CONFIG_SYS_EEPROM_WREN) - eeprom_write_enable (dev_addr,1); -#endif + eeprom_write_enable(dev_addr, 1); + /* * Write data until done or would cross a write page boundary. * We must write the address again when changing pages @@ -215,9 +215,9 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); #endif } -#if defined(CONFIG_SYS_EEPROM_WREN) - eeprom_write_enable (dev_addr,0); -#endif + + eeprom_write_enable(dev_addr, 0); + return rcode; }
Hello Marek,
bye, Heiko
-#endif
- eeprom_write_enable(dev_addr, 1);
- Write data until done or would cross a write page boundary.
-#endif
- eeprom_write_enable(dev_addr, 0);
- return rcode; }
Pull this macro to the beginning of the cmd_eeprom.c and remove another nasty ifdef from the code. Note that this is legal, since udelay(0) changes the behavior only such that it pings the WDT if WDT is enabled and otherwise does not wait.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 040ab5f..8451d63 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -29,6 +29,10 @@ #define CONFIG_SYS_I2C_SPEED 50000 #endif
+#ifndef CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 0 +#endif + /* * for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 2 (16-bit EEPROM address) offset is * 0x000nxxxx for EEPROM address selectors at n, offset xxxx in EEPROM. @@ -211,9 +215,7 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn buffer += len; offset += len;
-#if defined(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS) udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); -#endif }
Hello Marek,
bye, Heiko
Just suck the ugly ifdef around eeprom_init() call into eeprom_init() function itself. This puts all of the ifdef mess into one place.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 8451d63..c38c534 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -57,7 +57,7 @@ void eeprom_init(void) { /* SPI EEPROM */ #if defined(CONFIG_SPI) && !defined(CONFIG_ENV_EEPROM_IS_ON_I2C) - spi_init_f (); + spi_init_f(); #endif
/* I2C EEPROM */ @@ -248,9 +248,7 @@ static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) off = simple_strtoul(*args++, NULL, 16); cnt = simple_strtoul(*args++, NULL, 16);
-# if !defined(CONFIG_SPI) || defined(CONFIG_ENV_EEPROM_IS_ON_I2C) - eeprom_init (); -# endif /* !CONFIG_SPI */ + eeprom_init();
if (strcmp (argv[1], "read") == 0) { printf(fmt, dev_addr, argv[1], addr, off, cnt);
Hello Marek,
bye, Heiko
- spi_init_f ();
/* I2C EEPROM */
- eeprom_init ();
eeprom_init();
Implement default value of 8 for this macro and pull out all of this macro out of the code. The default value of 8 actually does implement exactly the same behavior as the previous code which was in the #else clause of the ifdef.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index c38c534..162a05c 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -33,6 +33,13 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 0 #endif
+#ifndef CONFIG_SYS_EEPROM_PAGE_WRITE_BITS +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 8 +#endif + +#define EEPROM_PAGE_SIZE (1 << CONFIG_SYS_EEPROM_PAGE_WRITE_BITS) +#define EEPROM_PAGE_OFFSET(x) ((x) & (EEPROM_PAGE_SIZE - 1)) + /* * for CONFIG_SYS_I2C_EEPROM_ADDR_LEN == 2 (16-bit EEPROM address) offset is * 0x000nxxxx for EEPROM address selectors at n, offset xxxx in EEPROM. @@ -194,15 +201,8 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn */ #if !defined(CONFIG_SYS_I2C_FRAM)
-#if defined(CONFIG_SYS_EEPROM_PAGE_WRITE_BITS) - -#define EEPROM_PAGE_SIZE (1 << CONFIG_SYS_EEPROM_PAGE_WRITE_BITS) -#define EEPROM_PAGE_OFFSET(x) ((x) & (EEPROM_PAGE_SIZE - 1)) - maxlen = EEPROM_PAGE_SIZE - EEPROM_PAGE_OFFSET(blk_off); -#else - maxlen = 0x100 - blk_off; -#endif + if (maxlen > I2C_RXTX_LEN) maxlen = I2C_RXTX_LEN;
Hello Marek,
bye, Heiko
-#else
-#endif
- if (maxlen > I2C_RXTX_LEN) maxlen = I2C_RXTX_LEN;
Pull out the code which computes the length of the transfer into separate code and clean it up a little. This again trims down the code duplication.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 66 ++++++++++++++++++++--------------------------------- 1 file changed, 25 insertions(+), 41 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 162a05c..b39ca5d 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -95,6 +95,29 @@ static int eeprom_addr(unsigned dev_addr, unsigned offset, uchar *addr) return alen; }
+static int eeprom_len(unsigned offset, unsigned end) +{ + unsigned len = end - offset; + + /* + * For a FRAM device there is no limit on the number of the + * bytes that can be ccessed with the single read or write + * operation. + */ +#if !defined(CONFIG_SYS_I2C_FRAM) + unsigned blk_off = offset & 0xff; + unsigned maxlen = EEPROM_PAGE_SIZE - EEPROM_PAGE_OFFSET(blk_off); + + if (maxlen > I2C_RXTX_LEN) + maxlen = I2C_RXTX_LEN; + + if (len > maxlen) + len = maxlen; +#endif + + return len; +} + static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, uchar *buffer, unsigned len, bool read) { @@ -126,7 +149,6 @@ static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { unsigned end = offset + cnt; - unsigned blk_off; int rcode = 0; uchar addr[3];
@@ -137,27 +159,10 @@ int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt */ while (offset < end) { unsigned alen, len; -#if !defined(CONFIG_SYS_I2C_FRAM) - unsigned maxlen; -#endif
- blk_off = offset & 0xFF; /* block offset */ alen = eeprom_addr(dev_addr, offset, addr);
- len = end - offset; - - /* - * For a FRAM device there is no limit on the number of the - * bytes that can be ccessed with the single read or write - * operation. - */ -#if !defined(CONFIG_SYS_I2C_FRAM) - maxlen = 0x100 - blk_off; - if (maxlen > I2C_RXTX_LEN) - maxlen = I2C_RXTX_LEN; - if (len > maxlen) - len = maxlen; -#endif + len = eeprom_len(offset, end);
@@ -171,7 +176,6 @@ int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { unsigned end = offset + cnt; - unsigned blk_off; int rcode = 0; uchar addr[3];
@@ -185,30 +189,10 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn
- len = end - offset; - - /* - * For a FRAM device there is no limit on the number of the - * bytes that can be accessed with the single read or write - * operation. - */ -#if !defined(CONFIG_SYS_I2C_FRAM) - - maxlen = EEPROM_PAGE_SIZE - EEPROM_PAGE_OFFSET(blk_off); - - if (maxlen > I2C_RXTX_LEN) - maxlen = I2C_RXTX_LEN; - - if (len > maxlen) - len = maxlen; -#endif + len = eeprom_len(offset, end);
Hello Marek,
bye, Heiko
- unsigned len = end - offset;
* operation.
- unsigned blk_off = offset & 0xff;
- unsigned maxlen = EEPROM_PAGE_SIZE - EEPROM_PAGE_OFFSET(blk_off);
- if (len > maxlen)
len = maxlen;
- return len;
unsigned maxlen;
-#endif
len = end - offset;
* operation.
if (len > maxlen)
len = maxlen;
-#endif
unsigned maxlen;
-#endif
len = end - offset;
* operation.
if (len > maxlen)
len = maxlen;
-#endif
Unify the code for doing read/write into single function, since the code for both the read and write is almost identical. This again trims down the code duplication.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 51 +++++++++++++++++++++------------------------------ 1 file changed, 21 insertions(+), 30 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index b39ca5d..d0942ef 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -146,38 +146,44 @@ static int eeprom_rw_block(unsigned offset, uchar *addr, unsigned alen, return ret; }
-int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) +static int eeprom_rw(unsigned dev_addr, unsigned offset, uchar *buffer, + unsigned cnt, bool read) { unsigned end = offset + cnt; + unsigned alen, len; int rcode = 0; uchar addr[3];
- /* - * Read data until done or would cross a page boundary. - * We must write the address again when changing pages - * because the next page may be in a different device. - */ while (offset < end) { - unsigned alen, len; - alen = eeprom_addr(dev_addr, offset, addr);
- rcode = eeprom_rw_block(offset, addr, alen, buffer, len, 1); + rcode = eeprom_rw_block(offset, addr, alen, buffer, len, read);
buffer += len; offset += len; + + if (!read) + udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); }
return rcode; }
-int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) +int eeprom_read(unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { - unsigned end = offset + cnt; - int rcode = 0; - uchar addr[3]; + /* + * Read data until done or would cross a page boundary. + * We must write the address again when changing pages + * because the next page may be in a different device. + */ + return eeprom_rw(dev_addr, offset, buffer, cnt, 1); +} + +int eeprom_write(unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) +{ + int ret;
@@ -186,25 +192,10 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn * We must write the address again when changing pages * because the address counter only increments within a page. */ - - while (offset < end) { - unsigned alen, len; - - alen = eeprom_addr(dev_addr, offset, addr); - - len = eeprom_len(offset, end); - - rcode = eeprom_rw_block(offset, addr, alen, buffer, len, 0); - - buffer += len; - offset += len; - - udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); - } + ret = eeprom_rw(dev_addr, offset, buffer, cnt, 1);
eeprom_write_enable(dev_addr, 0); - - return rcode; + return ret; }
Hello Marek,
bye, Heiko
{ unsigned end = offset + cnt;unsigned cnt, bool read)
- unsigned alen, len; int rcode = 0; uchar addr[3];
unsigned alen, len;
if (!read)
return rcode; }
- int rcode = 0;
- uchar addr[3];
- return eeprom_rw(dev_addr, offset, buffer, cnt, 1);
int ret;
unsigned alen, len;
buffer += len;
offset += len;
- return rcode;
return ret; }
Add bus argument to eeprom_init(), so that it can select the I2C bus number on which the eeprom resides. Any negative value of the $bus argument will preserve the old behavior. This is in place so that old code does not randomly break.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 6 ++++-- common/env_eeprom.c | 4 ++-- include/common.h | 2 +- 3 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index d0942ef..9247036 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -60,7 +60,7 @@ __weak int eeprom_write_enable(unsigned dev_addr, int state) return 0; }
-void eeprom_init(void) +void eeprom_init(int bus) { /* SPI EEPROM */ #if defined(CONFIG_SPI) && !defined(CONFIG_ENV_EEPROM_IS_ON_I2C) @@ -69,6 +69,8 @@ void eeprom_init(void)
/* I2C EEPROM */ #if defined(CONFIG_HARD_I2C) || defined(CONFIG_SYS_I2C_SOFT) + if (bus >= 0) + i2c_set_bus_num(bus); i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); #endif } @@ -223,7 +225,7 @@ static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) off = simple_strtoul(*args++, NULL, 16); cnt = simple_strtoul(*args++, NULL, 16);
- eeprom_init(); + eeprom_init(-1);
if (strcmp (argv[1], "read") == 0) { printf(fmt, dev_addr, argv[1], addr, off, cnt); diff --git a/common/env_eeprom.c b/common/env_eeprom.c index eea169d..72b1373 100644 --- a/common/env_eeprom.c +++ b/common/env_eeprom.c @@ -91,7 +91,7 @@ void env_relocate_spec(void) uchar rdbuf[64], flags[2]; int i, crc_ok[2] = {0, 0};
- eeprom_init(); /* prepare for EEPROM read/write */ + eeprom_init(-1); /* prepare for EEPROM read/write */
off_env[0] = CONFIG_ENV_OFFSET; off_env[1] = CONFIG_ENV_OFFSET_REDUND; @@ -154,7 +154,7 @@ void env_relocate_spec(void) ulong crc, len, new; uchar rdbuf[64];
/* read old CRC */ eeprom_bus_read(CONFIG_SYS_DEF_EEPROM_ADDR, diff --git a/include/common.h b/include/common.h index ceb1ad3..39ba5c9 100644 --- a/include/common.h +++ b/include/common.h @@ -475,7 +475,7 @@ void reset_phy (void); void fdc_hw_init (void);
/* $(BOARD)/eeprom.c */ -void eeprom_init (void); +void eeprom_init (int bus); int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt);
Hello Marek,
bye, Heiko
- if (bus >= 0)
i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); #endif }i2c_set_bus_num(bus);
- eeprom_init();
eeprom_init(-1);
On Mon, Nov 16, 2015 at 12:32:18PM +0100, Heiko Schocher wrote:
Hello Marek,
[snip]
- if (bus >= 0)
i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);i2c_set_bus_num(bus);
#endif }
Note that we need to wrap this call in CONFIG_SYS_I2C as CONFIG_HARD_I2C doesn't provide this function. Fixing up and testing again locally.
Add additional parameter into the eeprom command to select the I2C bus on which the eeprom resides.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 15 +++++++++++---- 1 file changed, 11 insertions(+), 4 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 9247036..13c946e 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -207,14 +207,21 @@ static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) char * const *args = &argv[2]; int rcode; ulong dev_addr, addr, off, cnt; + int bus_addr;
switch (argc) { #ifdef CONFIG_SYS_DEF_EEPROM_ADDR case 5: + bus_addr = -1; dev_addr = CONFIG_SYS_DEF_EEPROM_ADDR; break; #endif case 6: + bus_addr = -1; + dev_addr = simple_strtoul(*args++, NULL, 16); + break; + case 7: + bus_addr = simple_strtoul(*args++, NULL, 16); dev_addr = simple_strtoul(*args++, NULL, 16); break; default: @@ -225,7 +232,7 @@ static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) off = simple_strtoul(*args++, NULL, 16); cnt = simple_strtoul(*args++, NULL, 16);
- eeprom_init(-1); + eeprom_init(bus_addr);
if (strcmp (argv[1], "read") == 0) { printf(fmt, dev_addr, argv[1], addr, off, cnt); @@ -247,9 +254,9 @@ static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
U_BOOT_CMD( - eeprom, 6, 1, do_eeprom, + eeprom, 7, 1, do_eeprom, "EEPROM sub-system", - "read devaddr addr off cnt\n" - "eeprom write devaddr addr off cnt\n" + "read <bus> <devaddr> addr off cnt\n" + "eeprom write <bus> <devaddr> addr off cnt\n" " - read/write `cnt' bytes from `devaddr` EEPROM at offset `off'" )
Hello Marek,
bye, Heiko
int bus_addr;
bus_addr = -1;
bus_addr = -1;
break;
case 7:
- eeprom_init(-1);
U_BOOT_CMD(
- eeprom, 7, 1, do_eeprom, "EEPROM sub-system",
- "read <bus> <devaddr> addr off cnt\n"
- "eeprom write <bus> <devaddr> addr off cnt\n" " - read/write `cnt' bytes from `devaddr` EEPROM at offset `off'" )
Cosmetic fixes to the file, make it checkpatch clean.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de --- common/cmd_eeprom.c | 19 ++++++++++--------- 1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 13c946e..376c57d 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -49,8 +49,8 @@ */ #if !defined(CONFIG_SPI) || defined(CONFIG_ENV_EEPROM_IS_ON_I2C) #if !defined(CONFIG_SYS_I2C_EEPROM_ADDR_LEN) || \ - (CONFIG_SYS_I2C_EEPROM_ADDR_LEN < 1) || \ - (CONFIG_SYS_I2C_EEPROM_ADDR_LEN > 2) + (CONFIG_SYS_I2C_EEPROM_ADDR_LEN < 1) || \ + (CONFIG_SYS_I2C_EEPROM_ADDR_LEN > 2) #error CONFIG_SYS_I2C_EEPROM_ADDR_LEN must be 1 or 2 #endif #endif @@ -183,7 +183,8 @@ int eeprom_read(unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) return eeprom_rw(dev_addr, offset, buffer, cnt, 1); }
-int eeprom_write(unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) +int eeprom_write(unsigned dev_addr, unsigned offset, + uchar *buffer, unsigned cnt) { int ret;
@@ -234,19 +235,19 @@ static int do_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
- if (strcmp (argv[1], "read") == 0) { + if (strcmp(argv[1], "read") == 0) { printf(fmt, dev_addr, argv[1], addr, off, cnt);
- rcode = eeprom_read(dev_addr, off, (uchar *) addr, cnt); + rcode = eeprom_read(dev_addr, off, (uchar *)addr, cnt);
- puts ("done\n"); + puts("done\n"); return rcode; - } else if (strcmp (argv[1], "write") == 0) { + } else if (strcmp(argv[1], "write") == 0) { printf(fmt, dev_addr, argv[1], addr, off, cnt);
- rcode = eeprom_write(dev_addr, off, (uchar *) addr, cnt); + rcode = eeprom_write(dev_addr, off, (uchar *)addr, cnt);
- puts ("done\n"); + puts("done\n"); return rcode; }
Hello Marek,
bye, Heiko
{ int ret;uchar *buffer, unsigned cnt)
- if (strcmp(argv[1], "read") == 0) { printf(fmt, dev_addr, argv[1], addr, off, cnt);
puts ("done\n");
return rcode;puts("done\n");
- } else if (strcmp(argv[1], "write") == 0) { printf(fmt, dev_addr, argv[1], addr, off, cnt);
puts ("done\n");
return rcode; }puts("done\n");
Hello Marek,
From: Andreas Bießmann andreas.devel@googlemail.com
This rewrite uses lately promoted eeprom_init(int) function to choose the right I2C bus when writing data to the EEPROM.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de
board/corscience/tricorder/tricorder-eeprom.c | 36 +++++++-------------------- 1 file changed, 9 insertions(+), 27 deletions(-)
Thanks for this cleanup! ... eeprom code is really ugly ...
bye, Heiko
diff --git a/board/corscience/tricorder/tricorder-eeprom.c b/board/corscience/tricorder/tricorder-eeprom.c index 1c74a0f..340a009 100644 --- a/board/corscience/tricorder/tricorder-eeprom.c +++ b/board/corscience/tricorder/tricorder-eeprom.c @@ -77,17 +77,13 @@ static int handle_eeprom_v1(struct tricorder_eeprom *eeprom)
int tricorder_get_eeprom(int addr, struct tricorder_eeprom *eeprom) { -#ifdef CONFIG_SYS_EEPROM_BUS_NUM unsigned int bus = i2c_get_bus_num(); i2c_set_bus_num(CONFIG_SYS_EEPROM_BUS_NUM); -#endif
memset(eeprom, 0, TRICORDER_EEPROM_SIZE);
i2c_read(addr, 0, 2, (unsigned char *)eeprom, TRICORDER_EEPROM_SIZE); -#ifdef CONFIG_SYS_EEPROM_BUS_NUM i2c_set_bus_num(bus); -#endif
if (be32_to_cpu(eeprom->magic) != TRICORDER_EEPROM_MAGIC) { warn_wrong_value("magic", TRICORDER_EEPROM_MAGIC, @@ -138,9 +134,6 @@ int tricorder_eeprom_write(unsigned devaddr, const char *name, int ret; unsigned char *p; int i; -#ifdef CONFIG_SYS_EEPROM_BUS_NUM
- unsigned int bus;
-#endif
memset(eeprom, 0, TRICORDER_EEPROM_SIZE); memset(eeprom_verify, 0, TRICORDER_EEPROM_SIZE); @@ -172,33 +165,23 @@ int tricorder_eeprom_write(unsigned devaddr, const char *name, print_buffer(0, &eeprom, 1, sizeof(eeprom), 16); #endif
- bus = i2c_get_bus_num();
- i2c_set_bus_num(CONFIG_SYS_EEPROM_BUS_NUM);
-#endif
- eeprom_init(CONFIG_SYS_EEPROM_BUS_NUM);
- /* do page write to the eeprom */
- for (i = 0, p = (unsigned char *)&eeprom;
i < sizeof(eeprom);
i += 32, p += 32) {
ret = i2c_write(devaddr, i, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
p, min(sizeof(eeprom) - i, 32));
if (ret)
break;
udelay(5000); /* 5ms write cycle timing */
- ret = eeprom_write(devaddr, 0, (unsigned char *)&eeprom,
- if (ret)
printf("Tricorder: Could not write EEPROM content!\n");
- ret = i2c_read(devaddr, 0, 2, (unsigned char *)&eeprom_verify,
ret = eeprom_read(devaddr, 0, (unsigned char *)&eeprom_verify, TRICORDER_EEPROM_SIZE);
if (ret)
printf("Tricorder: Could not read EEPROM content!\n");
if (memcmp(&eeprom, &eeprom_verify, sizeof(eeprom)) != 0) { printf("Tricorder: Could not verify EEPROM content!\n"); ret = 1; }
- i2c_set_bus_num(bus);
-#endif return ret; }
@@ -206,7 +189,7 @@ int do_tricorder_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { if (argc == 3) { ulong dev_addr = simple_strtoul(argv[2], NULL, 16);
eeprom_init();
- if (strcmp(argv[1], "read") == 0) { int rcode;
@@ -220,7 +203,6 @@ int do_tricorder_eeprom(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) char *version = argv[4]; char *serial = argv[5]; char *interface = NULL;
eeprom_init();
if (argc == 7) interface = argv[6];
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: Heiko Schocher hs@denx.de Reviewed-by: Heiko Schocher hs@denx.de
Heiko Schocher
