[PATCH v3 0/5] m68k: add ColdFire watchdog driver
This patch allows to reach 0 warning for the m68k family. Watchdog driver was the last one producing the "conversion to DM" warning,
Angelo Dureghello (5): drivers: watchdog: add mcf watchdog support m68k: move watchdog functions in mcf_wdt driver m68k: dts: add watchdog node configs: m68k: add watchdog driver MAINTAINERS: add myself as mcf_wdt.c maintainer
MAINTAINERS | 1 + arch/m68k/cpu/mcf523x/cpu.c | 42 -------- arch/m68k/cpu/mcf52x2/cpu.c | 47 +-------- arch/m68k/cpu/mcf532x/cpu.c | 44 --------- arch/m68k/dts/M5208EVBE.dts | 5 + arch/m68k/dts/mcf5208.dtsi | 6 ++ arch/m68k/dts/mcf523x.dtsi | 6 ++ arch/m68k/dts/mcf5271.dtsi | 6 ++ arch/m68k/dts/mcf5275.dtsi | 6 ++ arch/m68k/dts/mcf5282.dtsi | 6 ++ arch/m68k/dts/mcf5329.dtsi | 6 ++ arch/m68k/dts/mcf537x.dtsi | 6 ++ configs/M5208EVBE_defconfig | 2 + configs/astro_mcf5373l_defconfig | 4 +- configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + drivers/watchdog/Kconfig | 7 ++ drivers/watchdog/Makefile | 1 + drivers/watchdog/mcf_wdt.c | 135 ++++++++++++++++++++++++++ 19 files changed, 198 insertions(+), 134 deletions(-) create mode 100644 drivers/watchdog/mcf_wdt.c
This watchdog driver applies to the following mcf families:
- mcf52x2 (5271 5275 5282) - mcf532x (5329 5373) - mcf523x (5235)
Cpu's not listed for each family does not have WDT module.
Note, after some attempts testing by qemu on 5208 i finally abandoned, watchdog seems not implemented properly.
The driver has been tested in a real M5282EVM.
Signed-off-by: Angelo Dureghello angelo@kernel-space.org --- Changes for v2: - remove unnecessary hardcoded timeouts - remove unnecessary hw_watchdog_xxx stuff - rewrite wdog module reg calculation - using IS_ENABLED() where possible Changes for v3: - remove hardcoded 4s test --- drivers/watchdog/Kconfig | 7 ++ drivers/watchdog/Makefile | 1 + drivers/watchdog/mcf_wdt.c | 135 +++++++++++++++++++++++++++++++++++++ 3 files changed, 143 insertions(+) create mode 100644 drivers/watchdog/mcf_wdt.c
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 646663528a..07fc4940e9 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -178,6 +178,13 @@ config WDT_MAX6370 help Select this to enable max6370 watchdog timer.
+config WDT_MCF + bool "ColdFire family watchdog timer support" + depends on WDT + help + Select this to enable ColdFire watchdog timer, + which supports mcf52x2 mcf532x mcf523x families. + config WDT_MESON_GXBB bool "Amlogic watchdog timer support" depends on WDT diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index fd5d9c7376..eef786f5e7 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -31,6 +31,7 @@ obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o obj-$(CONFIG_WDT_FTWDT010) += ftwdt010_wdt.o obj-$(CONFIG_WDT_GPIO) += gpio_wdt.o obj-$(CONFIG_WDT_MAX6370) += max6370_wdt.o +obj-$(CONFIG_WDT_MCF) += mcf_wdt.o obj-$(CONFIG_WDT_MESON_GXBB) += meson_gxbb_wdt.o obj-$(CONFIG_WDT_MPC8xxx) += mpc8xxx_wdt.o obj-$(CONFIG_WDT_MT7620) += mt7620_wdt.o diff --git a/drivers/watchdog/mcf_wdt.c b/drivers/watchdog/mcf_wdt.c new file mode 100644 index 0000000000..b36488bb5b --- /dev/null +++ b/drivers/watchdog/mcf_wdt.c @@ -0,0 +1,135 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * mcf_wdt.c - driver for ColdFire on-chip watchdog + * + * Author: Angelo Dureghello angelo@kernel-space.org + * + */ + +#include <common.h> +#include <dm.h> +#include <hang.h> +#include <asm/io.h> +#include <wdt.h> +#include <linux/bitops.h> + +#define DIVIDER_5XXX 4096 +#define DIVIDER_5282 8192 + +#define WCR_EN BIT(0) +#define WCR_HALTED BIT(1) +#define WCR_DOZE BIT(2) +#define WCR_WAIT BIT(3) + +struct watchdog_regs { + u16 wcr; /* Control */ + u16 wmr; /* Service */ + u16 wcntr; /* Counter */ + u16 wsr; /* Reset Status */ +}; + +static void mcf_watchdog_reset(struct watchdog_regs *wdog) +{ + if (!IS_ENABLED(CONFIG_WATCHDOG_RESET_DISABLE)) { + writew(0x5555, &wdog->wsr); + writew(0xaaaa, &wdog->wsr); + } +} + +static void mcf_watchdog_init(struct watchdog_regs *wdog, u32 fixed_divider, + u64 timeout_msecs) +{ + u32 wdog_module, cycles_per_sec; + + cycles_per_sec = CFG_SYS_CLK / fixed_divider; + + wdog_module = cycles_per_sec * ((u32)timeout_msecs / 1000); + wdog_module += (cycles_per_sec / 1000) * ((u32)timeout_msecs % 1000); + + /* Limit check, max 16 bits */ + if (wdog_module > 0xffff) + wdog_module = 0xffff; + + /* Set timeout and enable watchdog */ + writew((u16)wdog_module, &wdog->wmr); + writew(WCR_EN, &wdog->wcr); + + mcf_watchdog_reset(wdog); +} + +struct mcf_wdt_priv { + void __iomem *base; + u32 fixed_divider; +}; + +static int mcf_wdt_expire_now(struct udevice *dev, ulong flags) +{ + hang(); + + return 0; +} + +static int mcf_wdt_reset(struct udevice *dev) +{ + struct mcf_wdt_priv *priv = dev_get_priv(dev); + + mcf_watchdog_reset(priv->base); + + return 0; +} + +static int mcf_wdt_start(struct udevice *dev, u64 timeout, ulong flags) +{ + struct mcf_wdt_priv *priv = dev_get_priv(dev); + + /* Timeout from fdt (timeout) comes in milliseconds */ + mcf_watchdog_init(priv->base, priv->fixed_divider, timeout); + + return 0; +} + +static int mcf_wdt_stop(struct udevice *dev) +{ + struct mcf_wdt_priv *priv = dev_get_priv(dev); + struct watchdog_regs *wdog = (struct watchdog_regs *)priv->base; + + setbits_be16(&wdog->wcr, WCR_HALTED); + + return 0; +} + +static int mcf_wdt_probe(struct udevice *dev) +{ + struct mcf_wdt_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOENT; + + priv->fixed_divider = (u32)dev_get_driver_data(dev); + + return 0; +} + +static const struct wdt_ops mcf_wdt_ops = { + .start = mcf_wdt_start, + .stop = mcf_wdt_stop, + .reset = mcf_wdt_reset, + .expire_now = mcf_wdt_expire_now, +}; + +static const struct udevice_id mcf_wdt_ids[] = { + { .compatible = "fsl,mcf5208-wdt", .data = DIVIDER_5XXX }, + { .compatible = "fsl,mcf5282-wdt", .data = DIVIDER_5282 }, + {} +}; + +U_BOOT_DRIVER(mcf_wdt) = { + .name = "mcf_wdt", + .id = UCLASS_WDT, + .of_match = mcf_wdt_ids, + .probe = mcf_wdt_probe, + .ops = &mcf_wdt_ops, + .priv_auto = sizeof(struct mcf_wdt_priv), + .flags = DM_FLAG_PRE_RELOC, +};
- mcf523x (5235)
Thanks, Stefan
Changes for v2:
Changes for v3:
+config WDT_MCF
- bool "ColdFire family watchdog timer support"
- depends on WDT
- help
- config WDT_MESON_GXBB bool "Amlogic watchdog timer support" depends on WDT
- mcf_wdt.c - driver for ColdFire on-chip watchdog
- Author: Angelo Dureghello angelo@kernel-space.org
- u16 wcr; /* Control */
- u16 wmr; /* Service */
- u16 wcntr; /* Counter */
- u16 wsr; /* Reset Status */
- if (!IS_ENABLED(CONFIG_WATCHDOG_RESET_DISABLE)) {
u64 timeout_msecs)
- u32 wdog_module, cycles_per_sec;
- cycles_per_sec = CFG_SYS_CLK / fixed_divider;
- wdog_module = cycles_per_sec * ((u32)timeout_msecs / 1000);
- wdog_module += (cycles_per_sec / 1000) * ((u32)timeout_msecs % 1000);
- /* Limit check, max 16 bits */
- if (wdog_module > 0xffff)
- /* Set timeout and enable watchdog */
- writew((u16)wdog_module, &wdog->wmr);
- writew(WCR_EN, &wdog->wcr);
- mcf_watchdog_reset(wdog);
- void __iomem *base;
- u32 fixed_divider;
- hang();
- struct mcf_wdt_priv *priv = dev_get_priv(dev);
- mcf_watchdog_reset(priv->base);
- /* Timeout from fdt (timeout) comes in milliseconds */
- mcf_watchdog_init(priv->base, priv->fixed_divider, timeout);
- struct watchdog_regs *wdog = (struct watchdog_regs *)priv->base;
- setbits_be16(&wdog->wcr, WCR_HALTED);
- priv->base = dev_read_addr_ptr(dev);
- if (!priv->base)
return -ENOENT;
- priv->fixed_divider = (u32)dev_get_driver_data(dev);
- .start = mcf_wdt_start,
- .stop = mcf_wdt_stop,
- .reset = mcf_wdt_reset,
- .expire_now = mcf_wdt_expire_now,
- { .compatible = "fsl,mcf5208-wdt", .data = DIVIDER_5XXX },
- { .compatible = "fsl,mcf5282-wdt", .data = DIVIDER_5282 },
- .name = "mcf_wdt",
- .id = UCLASS_WDT,
- .of_match = mcf_wdt_ids,
- .probe = mcf_wdt_probe,
- .ops = &mcf_wdt_ops,
- .priv_auto = sizeof(struct mcf_wdt_priv),
- .flags = DM_FLAG_PRE_RELOC,
Viele Grüße, Stefan Roese
Move watchdog functions inside a separate watchdog driver.
Signed-off-by: Angelo Dureghello angelo@kernel-space.org --- Changes for v2: - none Changes for v3: - none --- arch/m68k/cpu/mcf523x/cpu.c | 42 --------------------------------- arch/m68k/cpu/mcf52x2/cpu.c | 47 +------------------------------------ arch/m68k/cpu/mcf532x/cpu.c | 44 ---------------------------------- 3 files changed, 1 insertion(+), 132 deletions(-)
diff --git a/arch/m68k/cpu/mcf523x/cpu.c b/arch/m68k/cpu/mcf523x/cpu.c index ba2c228911..bef67767b4 100644 --- a/arch/m68k/cpu/mcf523x/cpu.c +++ b/arch/m68k/cpu/mcf523x/cpu.c @@ -12,7 +12,6 @@ #include <init.h> #include <net.h> #include <vsprintf.h> -#include <watchdog.h> #include <command.h> #include <netdev.h> #include <asm/global_data.h> @@ -62,47 +61,6 @@ int print_cpuinfo(void) }; #endif /* CONFIG_DISPLAY_CPUINFO */
-#if defined(CONFIG_WATCHDOG) -/* Called by macro WATCHDOG_RESET */ -void watchdog_reset(void) -{ - wdog_t *wdp = (wdog_t *) (MMAP_WDOG); - - /* Count register */ - out_be16(&wdp->sr, 0x5555); - asm("nop"); - out_be16(&wdp->sr, 0xaaaa); -} - -int watchdog_disable(void) -{ - wdog_t *wdp = (wdog_t *) (MMAP_WDOG); - - /* UserManual, once the wdog is disabled, wdog cannot be re-enabled */ - /* halted watchdog timer */ - setbits_be16(&wdp->cr, WTM_WCR_HALTED); - - puts("WATCHDOG:disabled\n"); - return (0); -} - -int watchdog_init(void) -{ - wdog_t *wdp = (wdog_t *) (MMAP_WDOG); - u32 wdog_module = 0; - - /* set timeout and enable watchdog */ - wdog_module = ((CFG_SYS_CLK / CONFIG_SYS_HZ) * CONFIG_WATCHDOG_TIMEOUT_MSECS); - wdog_module |= (wdog_module / 8192); - out_be16(&wdp->mr, wdog_module); - - out_be16(&wdp->cr, WTM_WCR_EN); - puts("WATCHDOG:enabled\n"); - - return (0); -} -#endif /* CONFIG_WATCHDOG */ - #if defined(CONFIG_MCFFEC) /* Default initializations for MCFFEC controllers. To override, * create a board-specific function called: diff --git a/arch/m68k/cpu/mcf52x2/cpu.c b/arch/m68k/cpu/mcf52x2/cpu.c index d7cbf11e25..5042a38b3e 100644 --- a/arch/m68k/cpu/mcf52x2/cpu.c +++ b/arch/m68k/cpu/mcf52x2/cpu.c @@ -17,7 +17,6 @@ #include <init.h> #include <net.h> #include <vsprintf.h> -#include <watchdog.h> #include <command.h> #include <asm/global_data.h> #include <asm/immap.h> @@ -53,51 +52,7 @@ int print_cpuinfo(void) return 0; }; #endif /* CONFIG_DISPLAY_CPUINFO */ - -#if defined(CONFIG_WATCHDOG) -/* Called by macro WATCHDOG_RESET */ -void watchdog_reset(void) -{ - wdog_t *wdt = (wdog_t *)(MMAP_WDOG); - - out_be16(&wdt->sr, 0x5555); - out_be16(&wdt->sr, 0xaaaa); -} - -int watchdog_disable(void) -{ - wdog_t *wdt = (wdog_t *)(MMAP_WDOG); - - /* reset watchdog counter */ - out_be16(&wdt->sr, 0x5555); - out_be16(&wdt->sr, 0xaaaa); - /* disable watchdog timer */ - out_be16(&wdt->cr, 0); - - puts("WATCHDOG:disabled\n"); - return (0); -} - -int watchdog_init(void) -{ - wdog_t *wdt = (wdog_t *)(MMAP_WDOG); - - /* disable watchdog */ - out_be16(&wdt->cr, 0); - - /* set timeout and enable watchdog */ - out_be16(&wdt->mr, - (CONFIG_WATCHDOG_TIMEOUT_MSECS * CONFIG_SYS_HZ) / (32768 * 1000) - 1); - - /* reset watchdog counter */ - out_be16(&wdt->sr, 0x5555); - out_be16(&wdt->sr, 0xaaaa); - - puts("WATCHDOG:enabled\n"); - return (0); -} -#endif /* #ifdef CONFIG_WATCHDOG */ -#endif /* #ifdef CONFIG_M5208 */ +#endif /* #ifdef CONFIG_M5208 */
#ifdef CONFIG_M5271 #if defined(CONFIG_DISPLAY_CPUINFO) diff --git a/arch/m68k/cpu/mcf532x/cpu.c b/arch/m68k/cpu/mcf532x/cpu.c index 548cbca36a..18d20a8926 100644 --- a/arch/m68k/cpu/mcf532x/cpu.c +++ b/arch/m68k/cpu/mcf532x/cpu.c @@ -12,7 +12,6 @@ #include <init.h> #include <net.h> #include <vsprintf.h> -#include <watchdog.h> #include <command.h> #include <netdev.h> #include <asm/global_data.h> @@ -102,49 +101,6 @@ int print_cpuinfo(void) }; #endif /* CONFIG_DISPLAY_CPUINFO */
-#if defined(CONFIG_WATCHDOG) -/* Called by macro WATCHDOG_RESET */ -void watchdog_reset(void) -{ - wdog_t *wdp = (wdog_t *) (MMAP_WDOG); - - /* Count register */ - out_be16(&wdp->sr, 0x5555); - out_be16(&wdp->sr, 0xaaaa); -} - -int watchdog_disable(void) -{ - wdog_t *wdp = (wdog_t *) (MMAP_WDOG); - - /* UserManual, once the wdog is disabled, wdog cannot be re-enabled */ - /* halted watchdog timer */ - setbits_be16(&wdp->cr, WTM_WCR_HALTED); - - puts("WATCHDOG:disabled\n"); - return (0); -} - -int watchdog_init(void) -{ - wdog_t *wdp = (wdog_t *) (MMAP_WDOG); - u32 wdog_module = 0; - - /* set timeout and enable watchdog */ - wdog_module = ((CFG_SYS_CLK / 1000) * CONFIG_WATCHDOG_TIMEOUT_MSECS); -#ifdef CONFIG_M5329 - out_be16(&wdp->mr, wdog_module / 8192); -#else - out_be16(&wdp->mr, wdog_module / 4096); -#endif - - out_be16(&wdp->cr, WTM_WCR_EN); - puts("WATCHDOG:enabled\n"); - - return (0); -} -#endif /* CONFIG_WATCHDOG */ - #if defined(CONFIG_MCFFEC) /* Default initializations for MCFFEC controllers. To override, * create a board-specific function called:
Thanks, Stefan
Changes for v2:
- none
Changes for v3:
- none
- asm("nop");
- return (0);
- return (0);
- create a board-specific function called:
- return (0);
- return (0);
- return (0);
-#else
-#endif
- return (0);
Add watchdog node for the implemented mcf_wdt driver.
Signed-off-by: Angelo Dureghello angelo@kernel-space.org --- Changes for v2: - remove unnecessary big-endian property Changes for v3: - none --- arch/m68k/dts/M5208EVBE.dts | 5 +++++ arch/m68k/dts/mcf5208.dtsi | 6 ++++++ arch/m68k/dts/mcf523x.dtsi | 6 ++++++ arch/m68k/dts/mcf5271.dtsi | 6 ++++++ arch/m68k/dts/mcf5275.dtsi | 6 ++++++ arch/m68k/dts/mcf5282.dtsi | 6 ++++++ arch/m68k/dts/mcf5329.dtsi | 6 ++++++ arch/m68k/dts/mcf537x.dtsi | 6 ++++++ 8 files changed, 47 insertions(+)
diff --git a/arch/m68k/dts/M5208EVBE.dts b/arch/m68k/dts/M5208EVBE.dts index 1c32718af4..ec203e8b69 100644 --- a/arch/m68k/dts/M5208EVBE.dts +++ b/arch/m68k/dts/M5208EVBE.dts @@ -15,6 +15,11 @@ }; };
+&wdog0 { + timeout-sec = <32>; + status = "okay"; +}; + &uart0 { bootph-all; status = "okay"; diff --git a/arch/m68k/dts/mcf5208.dtsi b/arch/m68k/dts/mcf5208.dtsi index 9392facfa8..c61dbf3557 100644 --- a/arch/m68k/dts/mcf5208.dtsi +++ b/arch/m68k/dts/mcf5208.dtsi @@ -16,6 +16,12 @@ #address-cells = <1>; #size-cells = <1>;
+ wdog0: watchdog@fc08c000 { + compatible = "fsl,mcf5208-wdt"; + reg = <0xfc08c000 0x10>; + status = "disabled"; + }; + uart0: uart@fc060000 { compatible = "fsl,mcf-uart"; reg = <0xfc060000 0x40>; diff --git a/arch/m68k/dts/mcf523x.dtsi b/arch/m68k/dts/mcf523x.dtsi index 41c7b9b2d1..cae7b4f861 100644 --- a/arch/m68k/dts/mcf523x.dtsi +++ b/arch/m68k/dts/mcf523x.dtsi @@ -23,6 +23,12 @@ ranges = <0x00000000 0x40000000 0x40000000>; reg = <0x40000000 0x40000000>;
+ wdog0: watchdog@140000 { + compatible = "fsl,mcf5208-wdt"; + reg = <0x140000 0x10>; + status = "disabled"; + }; + uart0: uart@200 { compatible = "fsl,mcf-uart"; reg = <0x200 0x40>; diff --git a/arch/m68k/dts/mcf5271.dtsi b/arch/m68k/dts/mcf5271.dtsi index fc82bd3c24..5acf6994af 100644 --- a/arch/m68k/dts/mcf5271.dtsi +++ b/arch/m68k/dts/mcf5271.dtsi @@ -23,6 +23,12 @@ ranges = <0x00000000 0x40000000 0x40000000>; reg = <0x40000000 0x40000000>;
+ wdog0: watchdog@140000 { + compatible = "fsl,mcf5208-wdt"; + reg = <0x140000 0x10>; + status = "disabled"; + }; + uart0: uart@200 { compatible = "fsl,mcf-uart"; reg = <0x200 0x40>; diff --git a/arch/m68k/dts/mcf5275.dtsi b/arch/m68k/dts/mcf5275.dtsi index 402517cdec..3df17b445c 100644 --- a/arch/m68k/dts/mcf5275.dtsi +++ b/arch/m68k/dts/mcf5275.dtsi @@ -24,6 +24,12 @@ ranges = <0x00000000 0x40000000 0x40000000>; reg = <0x40000000 0x40000000>;
+ wdog0: watchdog@140000 { + compatible = "fsl,mcf5208-wdt"; + reg = <0x140000 0x10>; + status = "disabled"; + }; + uart0: uart@200 { compatible = "fsl,mcf-uart"; reg = <0x200 0x40>; diff --git a/arch/m68k/dts/mcf5282.dtsi b/arch/m68k/dts/mcf5282.dtsi index 883c0d0324..640c1a32e4 100644 --- a/arch/m68k/dts/mcf5282.dtsi +++ b/arch/m68k/dts/mcf5282.dtsi @@ -23,6 +23,12 @@ ranges = <0x00000000 0x40000000 0x40000000>; reg = <0x40000000 0x40000000>;
+ wdog0: watchdog@140000 { + compatible = "fsl,mcf5282-wdt"; + reg = <0x140000 0x10>; + status = "disabled"; + }; + uart0: uart@200 { compatible = "fsl,mcf-uart"; reg = <0x200 0x40>; diff --git a/arch/m68k/dts/mcf5329.dtsi b/arch/m68k/dts/mcf5329.dtsi index 7501cc4b01..991985e48c 100644 --- a/arch/m68k/dts/mcf5329.dtsi +++ b/arch/m68k/dts/mcf5329.dtsi @@ -16,6 +16,12 @@ #address-cells = <1>; #size-cells = <1>;
+ wdog0: watchdog@fc098000 { + compatible = "fsl,mcf5208-wdt"; + reg = <0xfc08c000 0x10>; + status = "disabled"; + }; + uart0: uart@fc060000 { compatible = "fsl,mcf-uart"; reg = <0xfc060000 0x40>; diff --git a/arch/m68k/dts/mcf537x.dtsi b/arch/m68k/dts/mcf537x.dtsi index 338b8b4583..4fa0f4bc3d 100644 --- a/arch/m68k/dts/mcf537x.dtsi +++ b/arch/m68k/dts/mcf537x.dtsi @@ -16,6 +16,12 @@ #address-cells = <1>; #size-cells = <1>;
Thanks, Stefan
Changes for v2:
Changes for v3:
- none
+&wdog0 {
- timeout-sec = <32>;
- status = "okay";
- &uart0 { bootph-all; status = "okay";
- uart0: uart@fc060000 { compatible = "fsl,mcf-uart"; reg = <0xfc060000 0x40>;
Add config options for mcf_wdt driver.
Signed-off-by: Angelo Dureghello angelo@kernel-space.org --- Changes for v2: - none Changes for v3: - none --- configs/M5208EVBE_defconfig | 2 ++ configs/astro_mcf5373l_defconfig | 4 ++-- configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + 4 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 0c5afe869b..aa054f753f 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -50,3 +50,5 @@ CONFIG_MCFFEC=y CONFIG_MII=y CONFIG_MCFUART=y CONFIG_WATCHDOG_TIMEOUT_MSECS=5000 +CONFIG_WDT=y +CONFIG_WDT_MCF=y diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index aade1f98be..f4dad3bcc8 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -46,5 +46,5 @@ CONFIG_DM_RTC=y CONFIG_MCFRTC=y CONFIG_SYS_MCFRTC_BASE=0xFC0A8000 CONFIG_MCFUART=y -CONFIG_WATCHDOG=y -CONFIG_WATCHDOG_TIMEOUT_MSECS=3355 +CONFIG_WDT=y +CONFIG_WDT_MCF=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index 24edecb510..2873322598 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -52,3 +52,4 @@ CONFIG_MII=y CONFIG_DM_RTC=y CONFIG_RTC_DS1338=y CONFIG_MCFUART=y +CONFIG_WDT=y diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 44e22eb01d..bd780034ba 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -50,3 +50,4 @@ CONFIG_MII=y CONFIG_DM_RTC=y CONFIG_RTC_DS1338=y CONFIG_MCFUART=y +CONFIG_WDT=y
Thanks, Stefan
Changes for v2:
- none
Changes for v3:
- none
Signed-off-by: Angelo Dureghello angelo@kernel-space.org --- Changes for v2: - none Changes for v3: - none --- MAINTAINERS | 1 + 1 file changed, 1 insertion(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 87991cccdd..2b157214cb 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -867,6 +867,7 @@ S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-coldfire.git F: arch/m68k/ F: doc/arch/m68k.rst +F: drivers/watchdog/mcf_wdt.c
CYCLIC M: Stefan Roese sr@denx.de
Thanks, Stefan
Changes for v2:
- none
Changes for v3:
- none
Angelo Dureghello
Stefan Roese
