[U-Boot] [PATCH] keystone2: use appropriate HD field for destination port
K2L and L2E have different from K2HK EthSS version, which uses tag_info field for destination slave port. This commit adds the dest_port_info field to the struct pktdma_cfg, to configure which HD filed tag_info or pkt_info shall be used to configure descriptor.
Before that commit the swinfo[2] was used for that purpose. Even if that worked on K2HK devices, the correct field for K2HK is the pkt_info.
The netcp_send() configure appropriate HD info field depending on the direct_info of the currently using netcp.
Signed-off-by: Vitaly Andrianov vitalya@ti.com Acked-by: Murali Karicheri m-karicheri2@ti.com --- arch/arm/include/asm/ti-common/keystone_nav.h | 9 ++++++++- drivers/dma/keystone_nav.c | 12 ++++++++++-- drivers/net/keystone_net.c | 3 +-- 3 files changed, 19 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/ti-common/keystone_nav.h b/arch/arm/include/asm/ti-common/keystone_nav.h index 696d8c6..5a0e391 100644 --- a/arch/arm/include/asm/ti-common/keystone_nav.h +++ b/arch/arm/include/asm/ti-common/keystone_nav.h @@ -152,6 +152,11 @@ struct rx_flow_regs { u32 thresh[3]; };
+enum dest_port_info { + PKT_INFO, + TAG_INFO +}; + struct pktdma_cfg { struct global_ctl_regs *global; struct tx_chan_regs *tx_ch; @@ -167,6 +172,7 @@ struct pktdma_cfg { u32 tx_snd_q;
u32 rx_flow; /* flow that is used for RX */ + enum dest_port_info dest_port_info;/* HD fiels for dest port bits */ };
extern struct pktdma_cfg netcp_pktdma; @@ -184,7 +190,8 @@ struct rx_buff_desc {
int ksnav_close(struct pktdma_cfg *pktdma); int ksnav_init(struct pktdma_cfg *pktdma, struct rx_buff_desc *rx_buffers); -int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, u32 swinfo2); +int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, + u32 dest_port); void *ksnav_recv(struct pktdma_cfg *pktdma, u32 **pkt, int *num_bytes); void ksnav_release_rxhd(struct pktdma_cfg *pktdma, void *hd);
diff --git a/drivers/dma/keystone_nav.c b/drivers/dma/keystone_nav.c index dfca75a..64b1cee 100644 --- a/drivers/dma/keystone_nav.c +++ b/drivers/dma/keystone_nav.c @@ -278,7 +278,8 @@ int ksnav_close(struct pktdma_cfg *pktdma) return QM_OK; }
-int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, u32 swinfo2) +int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, + u32 dest_port) { struct qm_host_desc *hd;
@@ -286,8 +287,15 @@ int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, u32 swinfo2) if (hd == NULL) return QM_ERR;
+ dest_port &= 0xf; hd->desc_info = num_bytes; - hd->swinfo[2] = swinfo2; + if (pktdma->dest_port_info == PKT_INFO) { + hd->packet_info = qm_cfg->qpool_num | (dest_port << 16); + } else { + hd->packet_info = qm_cfg->qpool_num; + hd->tag_info = dest_port; + } + hd->packet_info = qm_cfg->qpool_num;
qm_buff_push(hd, pktdma->tx_snd_q, pkt, num_bytes); diff --git a/drivers/net/keystone_net.c b/drivers/net/keystone_net.c index 0c5fdee..e2adb67 100644 --- a/drivers/net/keystone_net.c +++ b/drivers/net/keystone_net.c @@ -381,8 +381,7 @@ int32_t cpmac_drv_send(u32 *buffer, int num_bytes, int slave_port_num) if (num_bytes < EMAC_MIN_ETHERNET_PKT_SIZE) num_bytes = EMAC_MIN_ETHERNET_PKT_SIZE;
- return ksnav_send(&netcp_pktdma, buffer, - num_bytes, (slave_port_num) << 16); + return ksnav_send(&netcp_pktdma, buffer, num_bytes, slave_port_num); }
/* Eth device open */
Hi, Vitaly
I suppose it's better to decide in upper driver how to use swinfo field. Like in drivers/net/keystone_net.c
The keystone navigator supposed to be used as a tool for communicating between different IPs, and each of them decide how to use swinfo fields. It's protocol specific information and should be known only in sending parts. What if tomorrow you will decide to send some packet to PA?, you will rewrite this function again?
It's not the place for such kind information.
Even more, this is the h/w specific decision and no need to check this for each sent packet. You better statically assign how to use this field depending on h/w revision, using #if.
- PKT_INFO,
- TAG_INFO
- struct pktdma_cfg { struct global_ctl_regs *global; struct tx_chan_regs *tx_ch;
void *ksnav_recv(struct pktdma_cfg *pktdma, u32 **pkt, int *num_bytes); void ksnav_release_rxhd(struct pktdma_cfg *pktdma, void *hd);u32 dest_port);
{ struct qm_host_desc *hd;u32 dest_port)
- dest_port &= 0xf; hd->desc_info = num_bytes;
} else {
On 07/08/2015 12:38 PM, Ivan Khoronzhuk wrote:
Hi, Vitaly
- PKT_INFO,
- TAG_INFO
- enum dest_port_info dest_port_info;/* HD fiels for dest port
bits */ };
} else {
hd->packet_info = qm_cfg->qpool_num; qm_buff_push(hd, pktdma->tx_snd_q, pkt, num_bytes);
Hi Ivan,
I agree with you. And probably we will need to implement your proposal in future commits. This commit is to fix the bug, which is in existing driver.
Thanks, Vitaly
Vitaly,
Hi, Vitaly
- PKT_INFO,
- TAG_INFO
bits */ };
void *ksnav_recv(struct pktdma_cfg *pktdma, u32 **pkt, intu32 dest_port);
} else {
- return ksnav_send(&netcp_pktdma, buffer, num_bytes,
slave_port_num); }
Hi Ivan,
Thanks, Vitaly
Sorry, I supposed that first msg was not sent. It's better to fix it in drivers/net/keystone_net.c
On 07/08/2015 01:05 PM, Ivan Khoronzhuk wrote:
Vitaly,
Hi, Vitaly
- PKT_INFO,
- TAG_INFO
bits */ };
} else {
slave_port_num); }
Hi Ivan,
Thanks, Vitaly
Ivan,
I don't understand your proposal. The network driver doesn't know anything about CPPI DMA engine internals. That is the navigator's job to fill appropriate packet BD fields and it only takes care about HW version differences.
Thanks, Vitaly
Vitaly,
Vitaly,
Hi, Vitaly
- PKT_INFO,
- TAG_INFO
bits */ };
} else {
slave_port_num); }
Hi Ivan,
Thanks, Vitaly
Ivan,
You have Eth h/w, you have pktDMA engine to communicate through, you have network driver that knows how to use pktDMA to communicate with Ethernet switch. CPII DMA engine can be used to communicate with different h/w, not only with Ethernet switch. This can be used to send packets to PA, to SA, to QMSS PDSPs, to PA PDSPs and others parts, I don't talk even about AIF, SRIO, FFTC and others IPs that have Pktdma on board.
Each of them can use swinfo for different purposes.
In the chain to communicate directly with Eth you use net driver in the way keystone_net -> keystone_nav -> h/w pktdma -> eht You can use it also like keystone_srio -> keystone_nav -> h/w pktdma -> srio. etc.
pktdma engine it's like a bus used to communicate with a h/w. So, it's not correct to fix driver specific issues in the bus s/w, that is used by different drivers.
Thanks, Vitaly _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On 07/08/2015 01:50 PM, ivan.khoronzhuk wrote:
Vitaly,
Vitaly,
Hi, Vitaly
- PKT_INFO,
- TAG_INFO
bits */ };
} else {
slave_port_num); }
Hi Ivan,
Thanks, Vitaly
Ivan,
OK. What is your proposal? How to fix the issue in the keystone_net.c, which doesn't have any idea about structure of buffer descriptors. And actually doesn't have to know about it.
The proposed patch fixes the bug of existing upstreamed driver and allow K2E and K2L users to work. It is fully tested on all supported devices.
The PA PDSP and SA drivers currently doesn't exist in u-boot and I don't have any information whether anybody is going to develop them in the nearest future.
Vitaly,
Vitaly,
Vitaly,
Hi, Vitaly
On 08.07.15 18:45, Vitaly Andrianov wrote: > K2L and L2E have different from K2HK EthSS version, which uses > tag_info > field for destination slave port. This commit adds the > dest_port_info > field > to the struct pktdma_cfg, to configure which HD filed tag_info or > pkt_info > shall be used to configure descriptor. > > Before that commit the swinfo[2] was used for that purpose. Even if > that > worked on K2HK devices, the correct field for K2HK is the pkt_info. > > The netcp_send() configure appropriate HD info field depending on > the > direct_info of the currently using netcp. > > Signed-off-by: Vitaly Andrianov vitalya@ti.com > Acked-by: Murali Karicheri m-karicheri2@ti.com > --- > arch/arm/include/asm/ti-common/keystone_nav.h | 9 ++++++++- > drivers/dma/keystone_nav.c | 12 ++++++++++-- > drivers/net/keystone_net.c | 3 +-- > 3 files changed, 19 insertions(+), 5 deletions(-) > > diff --git a/arch/arm/include/asm/ti-common/keystone_nav.h > b/arch/arm/include/asm/ti-common/keystone_nav.h > index 696d8c6..5a0e391 100644 > --- a/arch/arm/include/asm/ti-common/keystone_nav.h > +++ b/arch/arm/include/asm/ti-common/keystone_nav.h > @@ -152,6 +152,11 @@ struct rx_flow_regs { > u32 thresh[3]; > }; > > +enum dest_port_info { > + PKT_INFO, > + TAG_INFO > +}; > + > struct pktdma_cfg { > struct global_ctl_regs *global; > struct tx_chan_regs *tx_ch; > @@ -167,6 +172,7 @@ struct pktdma_cfg { > u32 tx_snd_q; > > u32 rx_flow; /* flow that is used for RX */ > + enum dest_port_info dest_port_info;/* HD fiels for dest > port > bits */ > }; > > extern struct pktdma_cfg netcp_pktdma; > @@ -184,7 +190,8 @@ struct rx_buff_desc { > > int ksnav_close(struct pktdma_cfg *pktdma); > int ksnav_init(struct pktdma_cfg *pktdma, struct rx_buff_desc > *rx_buffers); > -int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, > u32 swinfo2); > +int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, > + u32 dest_port); > void *ksnav_recv(struct pktdma_cfg *pktdma, u32 **pkt, int > *num_bytes); > void ksnav_release_rxhd(struct pktdma_cfg *pktdma, void *hd); > > diff --git a/drivers/dma/keystone_nav.c b/drivers/dma/keystone_nav.c > index dfca75a..64b1cee 100644 > --- a/drivers/dma/keystone_nav.c > +++ b/drivers/dma/keystone_nav.c > @@ -278,7 +278,8 @@ int ksnav_close(struct pktdma_cfg *pktdma) > return QM_OK; > } > > -int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, > u32 swinfo2) > +int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, > + u32 dest_port) > { > struct qm_host_desc *hd; > > @@ -286,8 +287,15 @@ int ksnav_send(struct pktdma_cfg *pktdma, u32 > *pkt, int num_bytes, u32 swinfo2) > if (hd == NULL) > return QM_ERR; > > + dest_port &= 0xf; > hd->desc_info = num_bytes; > - hd->swinfo[2] = swinfo2; > + if (pktdma->dest_port_info == PKT_INFO) { > + hd->packet_info = qm_cfg->qpool_num | (dest_port << 16); > + } else { > + hd->packet_info = qm_cfg->qpool_num; > + hd->tag_info = dest_port; > + } > + > hd->packet_info = qm_cfg->qpool_num; > > qm_buff_push(hd, pktdma->tx_snd_q, pkt, num_bytes); > diff --git a/drivers/net/keystone_net.c b/drivers/net/keystone_net.c > index 0c5fdee..e2adb67 100644 > --- a/drivers/net/keystone_net.c > +++ b/drivers/net/keystone_net.c > @@ -381,8 +381,7 @@ int32_t cpmac_drv_send(u32 *buffer, int > num_bytes, > int slave_port_num) > if (num_bytes < EMAC_MIN_ETHERNET_PKT_SIZE) > num_bytes = EMAC_MIN_ETHERNET_PKT_SIZE; > > - return ksnav_send(&netcp_pktdma, buffer, > - num_bytes, (slave_port_num) << 16); > + return ksnav_send(&netcp_pktdma, buffer, num_bytes, > slave_port_num); > } > > /* Eth device open */ >
Hi Ivan,
Thanks, Vitaly
Ivan,
It doesn't matter exist those drivers or not. It's a structured model. If, for instance, you are going to fix some errata in I2C RTC, what will you do? fix it in I2C driver? But better place is RTC driver.
It's partly an API issue. It should be allowed to assign protocol specific flags field in packet_info and allow others to use swinfo in the same time.
It be better to add to pktdma_config field like protocol_flags.
in keystone_nav send function do: hd->packet_info = qm_cfg->qpool_num | (qm_cfg->protocol_flags) & 0xf << 16;
and in keystone_net, statically: #if (REVISION == REVISION_WITH_BUG) qm_cfg->protocol_flags = dest_port; #else qm_cfg->protocol_flags = 0;
But I'm not sure about one thing. Do you have revisions that use swinfo for port number and cannot use packet_info for this goal? In this case you should support version when software field is used also.
On 08.07.15 22:22, ivan.khoronzhuk wrote:
Vitaly,
Vitaly,
Vitaly,
On 07/08/2015 12:38 PM, Ivan Khoronzhuk wrote: > Hi, Vitaly > > I suppose it's better to decide in upper driver how to use swinfo > field. > Like in drivers/net/keystone_net.c > > The keystone navigator supposed to be used as a tool for > communicating > between different IPs, and each of them decide how to use swinfo > fields. > It's protocol specific information and should be known only in > sending > parts. What if tomorrow you will decide to send some packet to PA?, > you > will rewrite this function again? > > It's not the place for such kind information. > > Even more, this is the h/w specific decision and no need to check > this > for each sent packet. You better statically assign how to use this > field > depending on h/w revision, using #if. > > On 08.07.15 18:45, Vitaly Andrianov wrote: >> K2L and L2E have different from K2HK EthSS version, which uses >> tag_info >> field for destination slave port. This commit adds the >> dest_port_info >> field >> to the struct pktdma_cfg, to configure which HD filed tag_info or >> pkt_info >> shall be used to configure descriptor. >> >> Before that commit the swinfo[2] was used for that purpose. Even if >> that >> worked on K2HK devices, the correct field for K2HK is the pkt_info. >> >> The netcp_send() configure appropriate HD info field depending on >> the >> direct_info of the currently using netcp. >> >> Signed-off-by: Vitaly Andrianov vitalya@ti.com >> Acked-by: Murali Karicheri m-karicheri2@ti.com >> --- >> arch/arm/include/asm/ti-common/keystone_nav.h | 9 ++++++++- >> drivers/dma/keystone_nav.c | 12 ++++++++++-- >> drivers/net/keystone_net.c | 3 +-- >> 3 files changed, 19 insertions(+), 5 deletions(-) >> >> diff --git a/arch/arm/include/asm/ti-common/keystone_nav.h >> b/arch/arm/include/asm/ti-common/keystone_nav.h >> index 696d8c6..5a0e391 100644 >> --- a/arch/arm/include/asm/ti-common/keystone_nav.h >> +++ b/arch/arm/include/asm/ti-common/keystone_nav.h >> @@ -152,6 +152,11 @@ struct rx_flow_regs { >> u32 thresh[3]; >> }; >> >> +enum dest_port_info { >> + PKT_INFO, >> + TAG_INFO >> +}; >> + >> struct pktdma_cfg { >> struct global_ctl_regs *global; >> struct tx_chan_regs *tx_ch; >> @@ -167,6 +172,7 @@ struct pktdma_cfg { >> u32 tx_snd_q; >> >> u32 rx_flow; /* flow that is used for RX */ >> + enum dest_port_info dest_port_info;/* HD fiels for dest >> port >> bits */ >> }; >> >> extern struct pktdma_cfg netcp_pktdma; >> @@ -184,7 +190,8 @@ struct rx_buff_desc { >> >> int ksnav_close(struct pktdma_cfg *pktdma); >> int ksnav_init(struct pktdma_cfg *pktdma, struct rx_buff_desc >> *rx_buffers); >> -int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, >> u32 swinfo2); >> +int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, >> + u32 dest_port); >> void *ksnav_recv(struct pktdma_cfg *pktdma, u32 **pkt, int >> *num_bytes); >> void ksnav_release_rxhd(struct pktdma_cfg *pktdma, void *hd); >> >> diff --git a/drivers/dma/keystone_nav.c >> b/drivers/dma/keystone_nav.c >> index dfca75a..64b1cee 100644 >> --- a/drivers/dma/keystone_nav.c >> +++ b/drivers/dma/keystone_nav.c >> @@ -278,7 +278,8 @@ int ksnav_close(struct pktdma_cfg *pktdma) >> return QM_OK; >> } >> >> -int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, >> u32 swinfo2) >> +int ksnav_send(struct pktdma_cfg *pktdma, u32 *pkt, int num_bytes, >> + u32 dest_port) >> { >> struct qm_host_desc *hd; >> >> @@ -286,8 +287,15 @@ int ksnav_send(struct pktdma_cfg *pktdma, u32 >> *pkt, int num_bytes, u32 swinfo2) >> if (hd == NULL) >> return QM_ERR; >> >> + dest_port &= 0xf; >> hd->desc_info = num_bytes; >> - hd->swinfo[2] = swinfo2; >> + if (pktdma->dest_port_info == PKT_INFO) { >> + hd->packet_info = qm_cfg->qpool_num | (dest_port << >> 16); >> + } else { >> + hd->packet_info = qm_cfg->qpool_num; >> + hd->tag_info = dest_port; >> + } >> + >> hd->packet_info = qm_cfg->qpool_num; >> >> qm_buff_push(hd, pktdma->tx_snd_q, pkt, num_bytes); >> diff --git a/drivers/net/keystone_net.c >> b/drivers/net/keystone_net.c >> index 0c5fdee..e2adb67 100644 >> --- a/drivers/net/keystone_net.c >> +++ b/drivers/net/keystone_net.c >> @@ -381,8 +381,7 @@ int32_t cpmac_drv_send(u32 *buffer, int >> num_bytes, >> int slave_port_num) >> if (num_bytes < EMAC_MIN_ETHERNET_PKT_SIZE) >> num_bytes = EMAC_MIN_ETHERNET_PKT_SIZE; >> >> - return ksnav_send(&netcp_pktdma, buffer, >> - num_bytes, (slave_port_num) << 16); >> + return ksnav_send(&netcp_pktdma, buffer, num_bytes, >> slave_port_num); >> } >> >> /* Eth device open */ >> > Hi Ivan,
Thanks, Vitaly
Ivan,
Or even better to add new structure like pkt_data with vars: struct pkt_data { int protocol_flags; u32 tags; u32 swinfo[2]; char *data; (that is pkt) int num_bytes; };
and int ksnav_send(struct pktdma_cfg *pktdma, struct pkt_data *pkt) { .... hd->packet_info = qm_cfg->qpool_num | ((pkt->protocol_flags) & 0xf) << 16; hd->tag_info = tags; .... }
and in keystone_net, statically: #if (REVISION == REVISION_WITH_BUG) pkt->protocol_flags = dest_port; #else pkt->protocol_flags = 0; pkt->tags = dest_port;
In this case each driver will be doing what it's allowed to. It can be done with two patches.
Hi, Vitaly
The keystone navigator supposed to be used as a tool for communicating between different IPs, and each of them decide how to use swinfo fields. It's protocol specific information and should be known only for sending parts. What if tomorrow will be decided to send some packet to PA?, rewrite this function again?
This is the h/w specific static decision and no need to check this for each sent packet. It be better to statically assign how to use this field depending on h/w revision, using macro configs, for instance:
CONFIG_SOC_K2HK CONFIG_KSNET_NETCP_V1_0 CONFIG_KSNET_NETCP_V1_5
- PKT_INFO,
- TAG_INFO
} else {
Ivan Khoronzhuk
ivan.khoronzhuk
Vitaly Andrianov
