[U-Boot] [PATCH v4] cmd: usb: add blk devices to ignore list in tree graph
add blk child devices to ignore list while displaying usb tree graph, otherwise usb tree and info commands may cause crash treating blk as usb device.
Signed-off-by: Suneel Garapati suneelglinux@gmail.com ---
Changes v4: - do not set preamble if child is block device for mass storage Changes v3: - remove 'check on parent uclass' in description Changes v2: - remove check on parent uclass Changes v1: - add separate check on blk uclass - modify description - add separate check on parent uclass as usb
cmd/usb.c | 21 ++++++++++++++++++--- 1 file changed, 18 insertions(+), 3 deletions(-)
diff --git a/cmd/usb.c b/cmd/usb.c index d95bcf5..d64561e 100644 --- a/cmd/usb.c +++ b/cmd/usb.c @@ -349,6 +349,16 @@ static void usb_show_tree_graph(struct usb_device *dev, char *pre) printf(" %s", pre); #ifdef CONFIG_DM_USB has_child = device_has_active_children(dev->dev); + if (device_get_uclass_id(dev->dev) == UCLASS_MASS_STORAGE) { + struct udevice *child; + + for (device_find_first_child(dev->dev, &child); + child; + device_find_next_child(&child)) { + if (device_get_uclass_id(child) == UCLASS_BLK) + has_child = 0; + } + } #else /* check if the device has connected children */ int i; @@ -414,8 +424,12 @@ static void usb_show_tree_graph(struct usb_device *dev, char *pre)
udev = dev_get_parent_priv(child);
- /* Ignore emulators, we only want real devices */ - if (device_get_uclass_id(child) != UCLASS_USB_EMUL) { + /* + * Ignore emulators and block child devices, we only want + * real devices + */ + if ((device_get_uclass_id(child) != UCLASS_USB_EMUL) && + (device_get_uclass_id(child) != UCLASS_BLK)) { usb_show_tree_graph(udev, pre); pre[index] = 0; } @@ -605,7 +619,8 @@ static void usb_show_info(struct usb_device *udev) for (device_find_first_child(udev->dev, &child); child; device_find_next_child(&child)) { - if (device_active(child)) { + if (device_active(child) && + (device_get_uclass_id(child) != UCLASS_BLK)) { udev = dev_get_parent_priv(child); usb_show_info(udev); }
Hi Suneel,
On Thu, Sep 21, 2017 at 10:17 AM, Suneel Garapati suneelglinux@gmail.com wrote:
Changes v4:
Thanks for working on this.
Changes v3:
Changes v2:
Changes v1:
child;
has_child = 0;
* real devices
I hate this, but sorry I just managed to test this patch on Sandbox. This should also check UCLASS_USB_EMUL otherwise sandbox 'usb info' still crashes.
diff --git a/cmd/usb.c b/cmd/usb.c index d64561e..907debe 100644 --- a/cmd/usb.c +++ b/cmd/usb.c @@ -620,6 +620,7 @@ static void usb_show_info(struct usb_device *udev) child; device_find_next_child(&child)) { if (device_active(child) && + (device_get_uclass_id(child) != UCLASS_USB_EMUL) && (device_get_uclass_id(child) != UCLASS_BLK)) { udev = dev_get_parent_priv(child); usb_show_info(udev);
With the above changes, I tested on both Intel MinnowMax and Sandbox, it works fine.
You can include my tags:
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
to the v5. Really sorry about that!
Regards, Bin
Hi Bin,
On Wed, Sep 20, 2017 at 8:35 PM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Suneel,
Changes v4:
Changes v3:
Changes v2:
Changes v1:
child;
has_child = 0;
* real devices
Thanks for quick testing.
Will send v5.
Regards, Suneel
Regards, Bin
Bin Meng
Suneel Garapati
