[U-Boot] [RFC] Program net device MAC addresses after initializing
Add a new function to the eth_device struct for programming a network controller's hardware address.
After all network devices have been initialized and the proper MAC address for each has been determined, make a device driver call to program the address into the device. Only device instances with valid unicast addresses will be programmed.
This is a significant departure from existing U-boot behavior, but costs very little in startup time and addresses a very common complaint among developers.
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- include/net.h | 1 + net/eth.c | 4 ++++ 2 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/include/net.h b/include/net.h index 3f6a5d1..a180881 100644 --- a/include/net.h +++ b/include/net.h @@ -105,6 +105,7 @@ struct eth_device { #ifdef CONFIG_MCAST_TFTP int (*mcast) (struct eth_device*, u32 ip, u8 set); #endif + int (*write_hwaddr) (struct eth_device*); struct eth_device *next; void *priv; }; diff --git a/net/eth.c b/net/eth.c index b650a20..ee7678a 100644 --- a/net/eth.c +++ b/net/eth.c @@ -241,6 +241,10 @@ int eth_initialize(bd_t *bis)
memcpy(dev->enetaddr, env_enetaddr, 6); } + if (dev->write_hwaddr && + is_valid_ether_addr(dev->enetaddr)) { + dev->write_hwaddr(dev); + }
eth_number++; dev = dev->next;
Hello Ben,
Acked-by: Heiko Schocher hs@denx.de
bye Heiko
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Heiko Schocher Sent: Tuesday, April 06, 2010 12:49 PM To: Ben Warren Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [RFC] Program net device MAC addresses after initializing
Hello Ben,
a network
program the address
addresses will be
programmed.
Acked-by: Prafulla Wadaskar prafulla@marvell.com
Regards.. Prafulla . .
bye Heiko -- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Ben Warren,
In message 1270450929-17004-1-git-send-email-biggerbadderben@gmail.com you wrote:
The thing is that this _is_ a violation of the design rules, and we should not make assumptions that such an initialization is harmless for all systems.
From the patch it is not clear to me who is supposed to implement
write_hwaddr() - it should be made clear that this should be be done only when absolutely necessary, and then best in board specific code,
The patch should add such a description to the documentation.
Also, we should remove / adapt existing code that performs basicly the same action.
Thanks.
Hi Wolfgang,
On 4/6/2010 5:57 AM, Wolfgang Denk wrote:
Dear Ben Warren,
In message1270450929-17004-1-git-send-email-biggerbadderben@gmail.com you wrote:
I know this differs from the existing design rules. I'm not trying to be subtle or create a loophole, I'm trying to change policy. You'll notice that by itself, this patch does nothing other than chew up a few CPU cycles and bytes of flash.
From the patch it is not clear to me who is supposed to implement write_hwaddr() - it should be made clear that this should be be done only when absolutely necessary, and then best in board specific code,
The new function is part of the 'eth_device struct', so will be implemented in the network drivers. As designed, MAC addresses will be programmed on all controllers that have a valid entry either in their NVRAM or the environment. If somebody goes to the effort of putting a valid address in one of these places, we should assume that he or she wanted it to be used. If there is no such entry or the driver doesn't implement this method, nothing happens. I have an idea for providing a board-level 'opt-out' ability, but doubt that it would be used much.
I'm interested in knowing use cases where programming a MAC address is harmful, keeping in mind that this new code only programs valid MAC addresses.
Absolutely. This is an RFC and if we can reach agreement that it's a good thing, all the appropriate documentation will be revised.
Most if not all drivers currently have a private function for programming MAC addresses. We can either modify them as time goes by, or I'll take on the effort of fixing them all up with the obvious caveat that very little testing will be performed by me.
Thanks.
regards, Ben
Hi Ben,
Thanks for picking up this thread again.
As I have discovered, there are a few device drivers _currently_ doing this. So actually we will close the gap of documentation/current practice/design goals.
I second this effort - actually I had a patch looking very much the same in my repository. I wanted to attach it to an existing driver before posting it, but this is just as good.
As stated above, I also would have implemented it inside of a netword driver and thus not at a board level.
From my perspective, I would wait for such a case and _then_ provide an
opt-out. This may seem pragmatic, but it also follows the KISS principle.
While looking at all this, I came to the conclusion that this is quite a lot to fix, so I would vote for incremental changes on a per-driver level. Maybe provide a deprecated #warning or something comparable to NET_MULTI.
In any case -
Acked-by: Detlev Zundel dzu@denx.de
And I will surely help you transform drivers that I can test!
Cheers Detlev
Dear Ben Warren,
I think such an 'opt-out' ability is important.
There are zillions of different Ethernet controllers out there. To be able to program the MAC you might need to - map the respective memory area first, i. e. twiddle memory controller settings - power of the Ethernet controller (which might be kept powered off or otherwise disable normally to minimize power consumption) - take the controller out of reset - configure clocks needed to breath life into the controller ...
I don;t have a specific example in mind where it would actually cause harm, but we might run into such situations and should be prepared to handle them gracefully.
On 4/9/2010 12:58 PM, Wolfgang Denk wrote:
Dear Ben Warren,
OK. The next spin will have an easy opt-out, apart from 'setenv eth1addr 00:00:00:00:00:00'
regards, Ben
Dear Ben Warren,
Thanks - setting an invalid MAC address is something that makes little sense to me: valid MAC address information might be needed anyway, for example to passs it on to some OS we are booting.
participants (5)
Ben Warren
Detlev Zundel
Heiko Schocher
Prafulla Wadaskar
