[U-Boot] [PATCH] blk: Remove various places that do flush cache after read
All these places seem to inherit the codes from the MMC driver where a FIXME was put in the comment. However the correct operation after read should be cache invalidate, not flush.
The underlying drivers should be responsible for the cache operation. Remove these codes completely.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 15 --------------- board/toradex/common/tdx-cfg-block.c | 2 -- cmd/mmc.c | 2 -- drivers/block/blk-uclass.c | 3 --- drivers/block/blk_legacy.c | 3 --- drivers/net/fm/fm.c | 2 -- drivers/net/phy/cortina.c | 2 -- drivers/qe/qe.c | 2 -- 8 files changed, 31 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c index 24ddb5d..bbf8bba 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c @@ -107,9 +107,6 @@ int ppa_init(void) return -EIO; }
- /* flush cache after read */ - flush_cache((ulong)fitp, cnt * 512); - ret = fdt_check_header(fitp); if (ret) { free(fitp); @@ -134,9 +131,6 @@ int ppa_init(void) } debug("Read PPA header to 0x%p\n", ppa_hdr_ddr);
- /* flush cache after read */ - flush_cache((ulong)ppa_hdr_ddr, cnt * 512); - ppa_esbc_hdr = (uintptr_t)ppa_hdr_ddr; #endif
@@ -164,9 +158,6 @@ int ppa_init(void) return -EIO; }
- /* flush cache after read */ - flush_cache((ulong)ppa_fit_addr, cnt * 512); - #elif defined(CONFIG_SYS_LS_PPA_FW_IN_NAND) struct fdt_header fit;
@@ -208,9 +199,6 @@ int ppa_init(void) } debug("Read PPA header to 0x%p\n", ppa_hdr_ddr);
- /* flush cache after read */ - flush_cache((ulong)ppa_hdr_ddr, fw_length); - ppa_esbc_hdr = (uintptr_t)ppa_hdr_ddr; #endif
@@ -232,9 +220,6 @@ int ppa_init(void) CONFIG_SYS_LS_PPA_FW_ADDR); return -EIO; } - - /* flush cache after read */ - flush_cache((ulong)ppa_fit_addr, fw_length); #else #error "No CONFIG_SYS_LS_PPA_FW_IN_xxx defined" #endif diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 328c4c0..f850a3c 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -129,8 +129,6 @@ static int tdx_cfg_block_mmc_storage(u8 *config_block, int write) ret = -EIO; goto out; } - /* Flush cache after read */ - flush_cache((ulong)(unsigned char *)config_block, 512); } else { /* Just writing one 512 byte block */ if (blk_dwrite(mmc_get_blk_desc(mmc), blk_start, 1, diff --git a/cmd/mmc.c b/cmd/mmc.c index 00697fc..5def4ea 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -293,8 +293,6 @@ static int do_mmc_read(cmd_tbl_t *cmdtp, int flag, curr_device, blk, cnt);
n = blk_dread(mmc_get_blk_desc(mmc), blk, cnt, addr); - /* flush cache after read */ - flush_cache((ulong)addr, cnt * 512); /* FIXME */ printf("%d blocks read: %s\n", n, (n == cnt) ? "OK" : "ERROR");
return (n == cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE; diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index 3aec569..e5f00dc 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -294,9 +294,6 @@ ulong blk_read_devnum(enum if_type if_type, int devnum, lbaint_t start, if (IS_ERR_VALUE(n)) return n;
- /* flush cache after read */ - flush_cache((ulong)buffer, blkcnt * desc->blksz); - return n; }
diff --git a/drivers/block/blk_legacy.c b/drivers/block/blk_legacy.c index 981872e..16d3bfe 100644 --- a/drivers/block/blk_legacy.c +++ b/drivers/block/blk_legacy.c @@ -232,9 +232,6 @@ ulong blk_read_devnum(enum if_type if_type, int devnum, lbaint_t start, if (IS_ERR_VALUE(n)) return n;
diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index 451dfde..261f1b9 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -405,8 +405,6 @@ int fm_init_common(int index, struct ccsr_fman *reg) mmc_init(mmc); (void)mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, addr); - /* flush cache after read */ - flush_cache((ulong)addr, cnt * 512); } #elif defined(CONFIG_SYS_QE_FMAN_FW_IN_REMOTE) void *addr = (void *)CONFIG_SYS_FMAN_FW_ADDR; diff --git a/drivers/net/phy/cortina.c b/drivers/net/phy/cortina.c index e0e9ed9..637d89a 100644 --- a/drivers/net/phy/cortina.c +++ b/drivers/net/phy/cortina.c @@ -177,8 +177,6 @@ void cs4340_upload_firmware(struct phy_device *phydev) mmc_init(mmc); (void)mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, addr); - /* flush cache after read */ - flush_cache((ulong)addr, cnt * 512); } #endif
diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 24e764d..931c9d9 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -221,8 +221,6 @@ void u_qe_init(void) mmc_init(mmc); (void)mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, addr); - /* flush cache after read */ - flush_cache((ulong)addr, cnt * 512); } #endif u_qe_upload_firmware(addr);
} else { /* Just writing one 512 byte block */ if (blk_dwrite(mmc_get_blk_desc(mmc), blk_start, 1,flush_cache((ulong)(unsigned char *)config_block, 512);
- return n; }
- return n; }
} #elif defined(CONFIG_SYS_QE_FMAN_FW_IN_REMOTE) void *addr = (void *)CONFIG_SYS_FMAN_FW_ADDR;flush_cache((ulong)addr, cnt * 512);
} #endifflush_cache((ulong)addr, cnt * 512);
} #endif u_qe_upload_firmware(addr);flush_cache((ulong)addr, cnt * 512);
Did you experience any problems with the "incorrect" code in the MMC driver?
Without looking into the underlying driver, your explanation makes perfect sense and flushing is wrong after a read of course. So:
Thanks, Stefan
Hi Stefan,
#endif @@ -164,9 +158,6 @@ int ppa_init(void) return -EIO; }ppa_esbc_hdr = (uintptr_t)ppa_hdr_ddr;
- #elif defined(CONFIG_SYS_LS_PPA_FW_IN_NAND) struct fdt_header fit; @@ -208,9 +199,6 @@ int ppa_init(void) } debug("Read PPA header to 0x%p\n", ppa_hdr_ddr);
#endif @@ -232,9 +220,6 @@ int ppa_init(void) CONFIG_SYS_LS_PPA_FW_ADDR); return -EIO; }ppa_esbc_hdr = (uintptr_t)ppa_hdr_ddr;
#else #error "No CONFIG_SYS_LS_PPA_FW_IN_xxx defined" #endifflush_cache((ulong)ppa_fit_addr, fw_length);
diff --git a/cmd/mmc.c b/cmd/mmc.c index 00697fc..5def4ea 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -293,8 +293,6 @@ static int do_mmc_read(cmd_tbl_t *cmdtp, int flag, curr_device, blk, cnt); n = blk_dread(mmc_get_blk_desc(mmc), blk, cnt, addr);
flush_cache((ulong)addr, cnt * 512); /* FIXME */ printf("%d blocks read: %s\n", n, (n == cnt) ? "OK" : "ERROR"); return (n == cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE;
} diff --git a/drivers/block/blk_legacy.c b/drivers/block/blk_legacy.creturn n;
} diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.creturn n;
#elif defined(CONFIG_SYS_QE_FMAN_FW_IN_REMOTE) void *addr = (void *)CONFIG_SYS_FMAN_FW_ADDR;flush_cache((ulong)addr, cnt * 512); }
#endif diff --git a/drivers/qe/qe.c b/drivers/qe/qe.cflush_cache((ulong)addr, cnt * 512); }
#endif u_qe_upload_firmware(addr);flush_cache((ulong)addr, cnt * 512); }
No, since I have been mostly working on x86, and on x86 cache flush/invalidate is a nop, so no problems were seen.
Yes, I doubt how these codes were working on other platforms where cache operations are really needed. I just noticed that when I was working on NVMe stuff.
Regards, Bin
NACK here.
Hold on for ppa.c. We need to flush the cache after reading PPA image and it header after loading. These images need to be flushed into main memory. I will need to confirm with our team if we can remove flushing here.
York
Hi York,
NACK here.
#endifppa_esbc_hdr = (uintptr_t)ppa_hdr_ddr;
For the first 3 parts in this ppa.c file, I see they are all reading PPA image from MMC while MMC driver is using DMA so this is wrong (as I mentioned in the commit message I suspect they are all copy/paste from the MMC driver).
The only questionable change is the last one which is reading something from NAND and if NAND driver is not using DMA, that cache flush is needed as you pointed out.
Regards, Bin
On 08/22/2017 03:53 PM, Bin Meng wrote:
Hi York,
NACK here.
Bin,
Our internal team agrees with the removing flushing for MMC. Give me some time to test NAND.
York
+Yangbo
Best Regards Qiang Zhao
-----Original Message----- From: York Sun Sent: Wednesday, August 23, 2017 12:49 AM To: Bin Meng bmeng.cn@gmail.com; Grygorii Strashko grygorii.strashko@ti.com; Michal Simek michal.simek@xilinx.com; Angelo Dureghello angelo@sysam.it; Kever Yang kever.yang@rock-chips.com; Jaehoon Chung jh80.chung@samsung.com; Albert Aribaud albert.u.boot@aribaud.net; Marcel Ziswiler marcel.ziswiler@toradex.com; Markus Niebel Markus.Niebel@tq-group.com; Z.q. Hou zhiqiang.hou@nxp.com; Sumit Garg sumit.garg@nxp.com; Joe Hershberger joe.hershberger@ni.com; Stefan Roese sr@denx.de; Wenbin Song wenbin.song@nxp.com; Qiang Zhao qiang.zhao@nxp.com; Simon Glass sjg@chromium.org; Max Krummenacher max.krummenacher@toradex.com; Masahiro Yamada yamada.masahiro@socionext.com; Tomas Melin tomas.melin@vaisala.com; Q.y. Gong qianyu.gong@nxp.com; Tom Rini trini@konsulko.com; U-Boot Mailing List u-boot@lists.denx.de Subject: Re: [PATCH] blk: Remove various places that do flush cache after read
NACK here.
York
cmd/mmc.c
Maybe SD controller on some vendor platforms doesn't support SNOOP. flush_cache() is required to sync between DDR and cache. Should be careful to remove this.
-----Original Message----- From: Qiang Zhao Sent: Wednesday, August 23, 2017 11:14 AM To: Y.b. Lu; York Sun; Bin Meng; Grygorii Strashko; Michal Simek; Angelo Dureghello; Kever Yang; Jaehoon Chung; Albert Aribaud; Marcel Ziswiler; Markus Niebel; Z.q. Hou; Sumit Garg; Joe Hershberger; Stefan Roese; Wenbin Song; Simon Glass; Max Krummenacher; Masahiro Yamada; Tomas Melin; Q.y. Gong; Tom Rini; U-Boot Mailing List Subject: RE: [PATCH] blk: Remove various places that do flush cache after read
+Yangbo
NACK here.
here.
York
Hi Yangbo,
On Wed, Aug 23, 2017 at 11:29 AM, Y.b. Lu yangbo.lu@nxp.com wrote:
cmd/mmc.c
Please do not top-posting.
What you mentioned if snoop is not supported, flush_cache() is required, is true, however that's not the issue I am trying to fix here. The flush_cache() here after a DMA read will cause issues because stale data in the cache will overwrite the correct data in the RAM that is DMAed by hardware (in this case, MMC controller).
Regards, Bin
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Wednesday, August 23, 2017 1:29 PM To: Y.b. Lu Cc: Qiang Zhao; York Sun; Grygorii Strashko; Michal Simek; Angelo Dureghello; Kever Yang; Jaehoon Chung; Albert Aribaud; Marcel Ziswiler; Markus Niebel; Z.q. Hou; Sumit Garg; Joe Hershberger; Stefan Roese; Wenbin Song; Simon Glass; Max Krummenacher; Masahiro Yamada; Tomas Melin; Q.y. Gong; Tom Rini; U-Boot Mailing List Subject: Re: [PATCH] blk: Remove various places that do flush cache after read
Hi Yangbo,
cmd/mmc.c
[Lu Yangbo-B47093] Sorry for my misunderstanding. It looks ok to me now. flush_cache is indeed redundant after DMA reading.
Regards, Bin
Tested on LS1043ARDB with SD and NAND boot for PPA and FM.
Tested-by: York Sun york.sun@nxp.com Reviewed-by: York Sun york.sun@nxp.com
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
participants (7)
Bin Meng
Joe Hershberger
Qiang Zhao
Stefan Roese
Y.b. Lu
York Sun
