[U-Boot] MTD combine/merge flash bank like linux : MPC83xx / u-boot v2016.03
Dear,
I've got a flash split into 2 bank of 32 Mb. From linux view there is only one flash with a size of 64 Mb (define in the DTS). My goal, do the same thing with u-boot to read a ubi file with a size > 32 Mb which contains my uImage, but mtdparts still to see 2 flash device and i can"t open the ubi file.
Linux MTD partitions are : 4 cmdlinepart partitions found on MTD device fc000000.flash Creating 4 MTD partitions on "fc000000.flash": 0x000000000000-0x000000100000 : "Primary" 0x000000100000-0x000000180000 : " uboot" 0x000000180000-0x0000001a0000 : "uboot_var" *0x0000001a0000-0x000004000000* : "rfs"
u-boot config : MTD : #define MTDIDS_DEFAULT "nor0=fc000000.flash,nor1=fe000000.flash" #define MTDPARTS_DEFAULT "mtdparts=fc000000.flash:0x100000(Primary)ro,0x080000(uboot )ro,0x020000( uboot_var),-(RFS)"
CFI config : #define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_BASE 0xFC000000 #define CONFIG_SYS_FLASH_SIZE 64 #define CONFIG_SYS_FLASH_PROTECTION 1 #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE+ ((CONFIG_SYS_FLASH_SIZE*1024*1024)/2)} #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */
u-boot log : mtdparts
device nor0 <fc000000.flash>, # parts = 4 #: name size offset mask_flags 0: Primary 0x00100000 0x00000000 1 1: uboot 0x00080000 0x00100000 1 2: uboot_var 0x00020000 0x00180000 0 3: rfs *0x01e60000* 0x001a0000 0 => Expected to have 0x3CC0000
active partition: nor0,0 - ( Primary ) 0x00100000 @ 0x00000000
defaults: mtdids : nor0=fc000000.flash,nor1=fe000000.flash mtdparts: mtdparts=fc000000.flash:0x100000( Primary )ro,0x080000( uboot )ro,0x020000( uboot_var ),-(rfs)
Only the CONFIG_SYS_LBLAWAR0_PRELIM is used to realized this feature ?
Sébastien.
asebt69
