[PATCH 0/2] Rockchip: Add option to prevent boot on plug-in
Sometimes it is desirable to prevent a board from automatically booting as soon as the power cable is plugged in. For boards with an rk8xx PMIC, (excluding the rk808) we can actually query the power up source.
Chris Morgan (2): power: pmic: rk8xx: Support sysreset shutdown method rockchip: Add option to prevent booting on power plug-in
arch/arm/mach-rockchip/Kconfig | 10 ++++ drivers/power/pmic/rk8xx.c | 92 +++++++++++++++++++++++++++++++++- include/power/rk8xx_pmic.h | 3 ++ 3 files changed, 104 insertions(+), 1 deletion(-)
Add support for sysreset shutdown for this PMIC. The values were pulled from the various datasheets, but for now it has only been tested on the rk817 (for an Odroid Go Advance).
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- drivers/power/pmic/rk8xx.c | 50 +++++++++++++++++++++++++++++++++++++- 1 file changed, 49 insertions(+), 1 deletion(-)
diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index 5f442fea68..1ffbecc02a 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -6,10 +6,50 @@
#include <common.h> #include <dm.h> +#include <dm/lists.h> #include <errno.h> #include <log.h> #include <power/rk8xx_pmic.h> #include <power/pmic.h> +#include <sysreset.h> + +static int rk8xx_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + struct rk8xx_priv *priv = dev_get_priv(dev->parent); + + if (type != SYSRESET_POWER_OFF) + return -EPROTONOSUPPORT; + + switch (priv->variant) { + case RK805_ID: + case RK808_ID: + case RK816_ID: + case RK818_ID: + pmic_clrsetbits(dev->parent, REG_DEVCTRL, 0, BIT(0)); + break; + case RK809_ID: + case RK817_ID: + pmic_clrsetbits(dev->parent, RK817_REG_SYS_CFG3, 0, + BIT(0)); + break; + default: + printf("Unknown PMIC RK%x: Cannot shutdown\n", + priv->variant); + return -EPROTONOSUPPORT; + }; + + return -EINPROGRESS; +} + +static struct sysreset_ops rk8xx_sysreset_ops = { + .request = rk8xx_sysreset_request, +}; + +U_BOOT_DRIVER(rk8xx_sysreset) = { + .name = "rk8xx_sysreset", + .id = UCLASS_SYSRESET, + .ops = &rk8xx_sysreset_ops, +};
static struct reg_data rk817_init_reg[] = { /* enable the under-voltage protection, @@ -61,7 +101,7 @@ static int rk8xx_read(struct udevice *dev, uint reg, uint8_t *buff, int len) static int rk8xx_bind(struct udevice *dev) { ofnode regulators_node; - int children; + int children, ret;
regulators_node = dev_read_subnode(dev, "regulators"); if (!ofnode_valid(regulators_node)) { @@ -72,6 +112,14 @@ static int rk8xx_bind(struct udevice *dev)
debug("%s: '%s' - found regulators subnode\n", __func__, dev->name);
+ if (CONFIG_IS_ENABLED(SYSRESET)) { + ret = device_bind_driver_to_node(dev, "rk8xx_sysreset", + "rk8xx_sysreset", + dev_ofnode(dev), NULL); + if (ret) + return ret; + } + children = pmic_bind_children(dev, regulators_node, pmic_children_info); if (!children) debug("%s: %s - no child found\n", __func__, dev->name);
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- struct rk8xx_priv *priv = dev_get_priv(dev->parent);
- if (type != SYSRESET_POWER_OFF)
- switch (priv->variant) {
- case RK805_ID:
- case RK808_ID:
- case RK816_ID:
- case RK818_ID:
break;
- case RK809_ID:
- case RK817_ID:
BIT(0));
break;
- default:
priv->variant);
- return -EINPROGRESS;
- .request = rk8xx_sysreset_request,
- .name = "rk8xx_sysreset",
- .id = UCLASS_SYSRESET,
- .ops = &rk8xx_sysreset_ops,
- int children;
int children, ret;
- if (CONFIG_IS_ENABLED(SYSRESET)) {
"rk8xx_sysreset",
if (ret)
return ret;
- children = pmic_bind_children(dev, regulators_node, pmic_children_info); if (!children) debug("%s: %s - no child found\n", __func__, dev->name);
Hi Chris,
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks,
- Kever
- case RK805_ID:
- case RK808_ID:
- case RK816_ID:
- case RK818_ID:
break;
- case RK809_ID:
- case RK817_ID:
BIT(0));
break;
- default:
priv->variant);
- int children;
int children, ret;
"rk8xx_sysreset",
if (ret)
return ret;
For Rockchip boards with the all rk8xx series PMICs (excluding the rk808), it is sometimes desirable to not boot whenever the device is plugged in. An example would be for the Odroid Go Advance.
This provides a configurable option to check the PMIC says it was powered because of a plug-in event. If the value is 1 and this option is selected, the device shuts down shortly after printing a message to console stating the reason why it's shutting down. Powering up the board with the power button is not affected.
This patch parallels the work done in the following patch series: https://lore.kernel.org/u-boot/20220121133732.2397273-1-andre.przywara@arm.c...
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- arch/arm/mach-rockchip/Kconfig | 10 +++++++++ drivers/power/pmic/rk8xx.c | 37 ++++++++++++++++++++++++++++++++++ include/power/rk8xx_pmic.h | 3 +++ 3 files changed, 50 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 18aff5480b..c561a77e6a 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -361,6 +361,16 @@ config ROCKCHIP_BOOT_MODE_REG The Soc will enter to different boot mode(defined in asm/arch-rockchip/boot_mode.h) according to the value from this register.
+config ROCKCHIP_RK8XX_DISABLE_BOOT_ON_POWERON + bool "Disable device boot on power plug-in" + depends on PMIC_RK8XX + default n + ---help--- + Say Y here to prevent the device from booting up because of a plug-in + event. When set, the device will boot briefly to determine why it was + powered on, and if it was determined because of a plug-in event + instead of a button press event it will shut back off. + config ROCKCHIP_STIMER bool "Rockchip STIMER support" default y diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index 1ffbecc02a..b59675a10e 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -51,6 +51,41 @@ U_BOOT_DRIVER(rk8xx_sysreset) = { .ops = &rk8xx_sysreset_ops, };
+void rk8xx_off_for_plugin(struct udevice *dev) +/* In the event of a plug-in and the appropriate option has been + * selected, we simply shutdown instead of continue the normal boot + * process. Please note the rk808 is not supported as it doesn't + * have the appropriate register. + */ +{ + struct rk8xx_priv *priv = dev_get_priv(dev); + bool plug_in = 0; + + switch (priv->variant) { + case RK805_ID: + case RK816_ID: + case RK818_ID: + plug_in = pmic_reg_read(dev, RK8XX_ON_SOURCE) & RK8XX_ON_PLUG_IN; + if (plug_in) { + printf("Power Off due to plug-in event\n"); + pmic_clrsetbits(dev, REG_DEVCTRL, 0, BIT(0)); + } + break; + case RK809_ID: + case RK817_ID: + plug_in = pmic_reg_read(dev, RK817_ON_SOURCE) & RK8XX_ON_PLUG_IN; + if (plug_in) { + printf("Power Off due to plug-in event\n"); + pmic_clrsetbits(dev, RK817_REG_SYS_CFG3, 0, + BIT(0)); + } + break; + default: + printf("PMIC RK%x: Cannot read boot reason.\n", + priv->variant); + } +} + static struct reg_data rk817_init_reg[] = { /* enable the under-voltage protection, * the under-voltage protection will shutdown the LDO3 and reset the PMIC @@ -211,6 +246,8 @@ static int rk8xx_probe(struct udevice *dev) pmic_reg_read(dev, on_source), pmic_reg_read(dev, off_source)); printf("\n"); + if (CONFIG_IS_ENABLED(ROCKCHIP_RK8XX_DISABLE_BOOT_ON_POWERON)) + rk8xx_off_for_plugin(dev);
return 0; } diff --git a/include/power/rk8xx_pmic.h b/include/power/rk8xx_pmic.h index 8ff0af35c5..3cbfc02195 100644 --- a/include/power/rk8xx_pmic.h +++ b/include/power/rk8xx_pmic.h @@ -214,6 +214,9 @@ enum { #define RK817_ON_SOURCE 0xf5 #define RK817_OFF_SOURCE 0xf6
+#define RK8XX_ON_PWRON BIT(7) +#define RK8XX_ON_PLUG_IN BIT(6) + struct reg_data { u8 reg; u8 val;
- bool "Disable device boot on power plug-in"
- depends on PMIC_RK8XX
- default n
- ---help---
- selected, we simply shutdown instead of continue the normal boot
- process. Please note the rk808 is not supported as it doesn't
- have the appropriate register.
Could you move comment to above or into function?
- struct rk8xx_priv *priv = dev_get_priv(dev);
- bool plug_in = 0;
- case RK805_ID:
- case RK816_ID:
- case RK818_ID:
if (plug_in) {
It seems that doesn't need to use plug_in. Can't use "if (pmic_reg_read() & RK8XX_ON_PLUG_IN)"?
break;
- case RK809_ID:
- case RK817_ID:
if (plug_in) {
BIT(0));
break;
- default:
priv->variant);
- the under-voltage protection will shutdown the LDO3 and reset the PMIC
Chris Morgan
Jaehoon Chung
Kever Yang
