Please pull u-boot-dm
Hi Tom,
https://source.denx.de/u-boot/custodians/u-boot-dm/-/pipelines/9692
The following changes since commit 50bff6a6f86669a8652e2bf271eeb04f77911274:
Merge branch '2021-10-31-assorted-platform-updates' (2021-10-31 12:21:12 -0400)
git://git.denx.de/u-boot-dm.git tags/dm-pull-boo21
for you to fetch changes up to b55881ddb455af31b64038cf3b67f781909971cc:
bootstage: Add SPL support (2021-10-31 12:26:44 -0600)
---------------------------------------------------------------- Environment tidy-ups patman 'postfix' support fix binman test race condition causing a timeout error
---------------------------------------------------------------- Alistair Delva (1): x86: Fix linking u-boot with ld.lld
Hannu Lounento (1): image.h: make image_sign_info.fit point to const
Marek Behún (14): env: sf: Cosmetic fix in env_sf_init_addr() env: sf: Use ENV_VALID enum names instead of literals env: sf: Put ENV_INVALID into gd->env_valid on CRC failure env: nand: Put ENV_INVALID into gd->env_valid if default environment env: nvram: Let generic env_init() assign default environment env: nvram: Cosmetic fix in env_nvram_init() env: nowhere: Let generic env_init() assign default environment env: nowhere: Cosmetic fix env: flash: Let generic env_init() assign default environment env: flash: Cosmetic fix board: synquacer: developerbox: Don't set gd->env_addr to default_environment board: freescale: various boards: Let env subsystem set gd->env_addr env: Always use char for default_environment env: Use static_assert() to check if default_environment is too large
Marek Vasut (1): bootstage: Add SPL support
Sean Anderson (1): patman: Add "postfix" support to patch subjects
Simon Glass (1): binman: Allow timeout to occur in the image or its section
Tom Rini (1): sandbox: Migrate ARCH_MAP_SYSMEM to Kconfig
Makefile | 3 +++ arch/sandbox/Kconfig | 3 +++ arch/sandbox/config.mk | 1 - arch/x86/cpu/cpu.c | 2 +- board/Marvell/mvebu_armada-37xx/board.c | 2 +- board/freescale/ls1012afrdm/ls1012afrdm.c | 4 ---- board/freescale/ls1012aqds/ls1012aqds.c | 4 ---- board/freescale/ls1012ardb/ls1012ardb.c | 4 ---- board/freescale/ls1028a/ls1028a.c | 4 ---- board/freescale/ls1088a/ls1088a.c | 4 ---- board/freescale/ls2080aqds/ls2080aqds.c | 3 --- board/freescale/ls2080ardb/ls2080ardb.c | 3 --- board/freescale/lx2160a/lx2160a.c | 3 --- board/siemens/iot2050/board.c | 2 +- board/socionext/developerbox/developerbox.c | 2 -- common/Kconfig.boot | 9 +++++++++ common/image-fit-sig.c | 2 +- common/init/board_init.c | 2 +- common/spl/spl.c | 2 +- env/common.c | 11 +++-------- env/flash.c | 5 +---- env/nand.c | 3 +-- env/nowhere.c | 5 ++--- env/nvram.c | 7 +++---- env/sf.c | 7 +++---- include/bootstage.h | 2 +- include/env_default.h | 10 ++++++++-- include/env_internal.h | 4 ++-- include/image.h | 2 +- tools/binman/ftest.py | 3 +-- tools/patman/README | 5 +++++ tools/patman/func_test.py | 6 ++++-- tools/patman/patchstream.py | 2 ++ tools/patman/series.py | 9 +++++++-- tools/patman/test/test01.txt | 1 + 35 files changed, 66 insertions(+), 75 deletions(-)
Regards, SImon
On Sun, Oct 31, 2021 at 01:40:48PM -0600, Simon Glass wrote:
Hi Tom,
