[U-Boot] [PATCH v2 1/1] ARM: correct detection of thumb mode
When a crash occurs in thumb mode the crash dump is incorrect. This is due to the usage of a non-existing configuration variable CONFIG_ARM_THUMB in the definition of macro thumb_mode(regs).
Use CONFIG_IS_ENABLED(SYS_THUMB_BUILD) to detect that the code has been compiled for thumb mode. Remove ARM_THUMB from config_whitelist.txt.
With the patch crash dumps indicate thumb mode correctly.
On a system with thumb mode:
=> exception unaligned data abort pc : [<8f7a2b52>] lr : [<8f7ab1ef>] reloc pc : [<1780cb52>] lr : [<178151ef>] sp : 8ed8c3f8 ip : 8f7a2b4d fp : 00000002 r10: 8f7f8228 r9 : 8ed95ea8 r8 : 8ed99488 r7 : 8f7ab141 r6 : 00000000 r5 : 8ed8c3f9 r4 : 8f7f6390 r3 : 8ed9948c r2 : 00000001 r1 : 00000000 r0 : 8f7f6390 Flags: nzCv IRQs off FIQs off Mode SVC_32 (T) Code: 8f7e 466d f105 0501 (e9d5) 6700
The Flags line has '(T)' and in the Code line the output is in u16 groups.
On a system without thumb mode:
=> exception breakpoint prefetch abort pc : [<7ff5a5c8>] lr : [<7ff675ec>] reloc pc : [<0000e5c8>] lr : [<0001b5ec>] sp : 7ee0ad80 ip : 7ff5a5cc fp : 7ff674cc r10: 00000002 r9 : 7ef0bed8 r8 : 7ffd6214 r7 : 7ef0e080 r6 : 00000000 r5 : 7ffd4090 r4 : 00000000 r3 : 7ef0e084 r2 : 00000001 r1 : 00000000 r0 : 7ffd4090 Flags: nzCv IRQs off FIQs off Mode SVC_32 Code: e1a0500d e2855001 e1c560d0 e3a00001 (e12fff1e)
The Flags line does not show '(T)' and in the Code line the output is in u32 groups.
Reported-by: Marek Vasut marex@denx.de Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2 remove ARM_THUMB from config_whitelist.txt fix typos in commit message --- arch/arm/include/asm/proc-armv/ptrace.h | 2 +- scripts/config_whitelist.txt | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/proc-armv/ptrace.h b/arch/arm/include/asm/proc-armv/ptrace.h index 183b00a087..e37ad8fd1f 100644 --- a/arch/arm/include/asm/proc-armv/ptrace.h +++ b/arch/arm/include/asm/proc-armv/ptrace.h @@ -86,7 +86,7 @@ struct pt_regs { #define user_mode(regs) \ (((regs)->ARM_cpsr & 0xf) == 0)
-#ifdef CONFIG_ARM_THUMB +#if CONFIG_IS_ENABLED(SYS_THUMB_BUILD) #define thumb_mode(regs) \ (((regs)->ARM_cpsr & T_BIT)) #else diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d252045d80..d6bef69a16 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -61,7 +61,6 @@ CONFIG_ARM_FREQ CONFIG_ARM_GIC_BASE_ADDRESS CONFIG_ARM_PL180_MMCI_BASE CONFIG_ARM_PL180_MMCI_CLOCK_FREQ -CONFIG_ARM_THUMB CONFIG_ARP_TIMEOUT CONFIG_ASTRO_COFDMDUOS2 CONFIG_ASTRO_TWIN7S2 -- 2.20.1
Reported-by: Marek Vasut marex@denx.de Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Marek Vasut marex@denx.de
