[U-Boot] [PATCH] qe/deep-sleep: add qe deep-sleep for generic board
Deep sleep for generic board is supported now, and it use CONFIG_FSL_DEEP_SLEEP instead of CONFIG_DEEP_SLEEP, so modify it for qe.
Signed-off-by: Zhao Qiang B45475@freescale.com --- drivers/qe/qe.c | 31 +++++++++++++++++++++---------- 1 file changed, 21 insertions(+), 10 deletions(-)
diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 2c5b9bf..8687e73 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -9,12 +9,15 @@
#include "common.h" #include <command.h> +#ifdef CONFIG_LS102XA +#include <asm/arch/immap_ls102xa.h> +#endif #include "asm/errno.h" #include "asm/io.h" #include "linux/immap_qe.h" #include "qe.h"
-#define MPC85xx_DEVDISR_QE_DISABLE 0x1 +#define DEVDISR_QE_DISABLE 0x1
qe_map_t *qe_immr = NULL; static qe_snum_t snums[QE_NUM_OF_SNUM]; @@ -346,7 +349,7 @@ int qe_upload_firmware(const struct qe_firmware *firmware) size_t calc_size = sizeof(struct qe_firmware); size_t length; const struct qe_header *hdr; -#ifdef CONFIG_DEEP_SLEEP +#if defined(CONFIG_FSL_DEEP_SLEEP) && defined(CONFIG_QE) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif if (!firmware) { @@ -361,8 +364,8 @@ int qe_upload_firmware(const struct qe_firmware *firmware) if ((hdr->magic[0] != 'Q') || (hdr->magic[1] != 'E') || (hdr->magic[2] != 'F')) { printf("Not a microcode\n"); -#ifdef CONFIG_DEEP_SLEEP - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_QE_DISABLE); +#if defined(CONFIG_FSL_DEEP_SLEEP) && defined(CONFIG_QE) + setbits_be32(&gur->devdisr, DEVDISR_QE_DISABLE); #endif return -EPERM; } @@ -481,9 +484,13 @@ int u_qe_upload_firmware(const struct qe_firmware *firmware) size_t calc_size = sizeof(struct qe_firmware); size_t length; const struct qe_header *hdr; -#ifdef CONFIG_DEEP_SLEEP +#ifdef CONFIG_FSL_DEEP_SLEEP +#ifdef CONFIG_LS102XA + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; +#else ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif +#endif if (!firmware) { printf("Invalid address\n"); return -EINVAL; @@ -496,8 +503,8 @@ int u_qe_upload_firmware(const struct qe_firmware *firmware) if ((hdr->magic[0] != 'Q') || (hdr->magic[1] != 'E') || (hdr->magic[2] != 'F')) { printf("Not a microcode\n"); -#ifdef CONFIG_DEEP_SLEEP - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_QE_DISABLE); +#ifdef CONFIG_FSL_DEEP_SLEEP + setbits_be32(&gur->devdisr, DEVDISR_QE_DISABLE); #endif return -EPERM; } @@ -588,9 +595,13 @@ int u_qe_firmware_resume(const struct qe_firmware *firmware, qe_map_t *qe_immrr) unsigned int j; const struct qe_header *hdr; const u32 *code; -#ifdef CONFIG_DEEP_SLEEP +#ifdef CONFIG_FSL_DEEP_SLEEP +#ifdef CONFIG_LS102XA + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; +#else ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif +#endif
if (!firmware) return -EINVAL; @@ -600,8 +611,8 @@ int u_qe_firmware_resume(const struct qe_firmware *firmware, qe_map_t *qe_immrr) /* Check the magic */ if ((hdr->magic[0] != 'Q') || (hdr->magic[1] != 'E') || (hdr->magic[2] != 'F')) { -#ifdef CONFIG_DEEP_SLEEP - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_QE_DISABLE); +#ifdef CONFIG_FSL_DEEP_SLEEP + setbits_be32(&gur->devdisr, DEVDISR_QE_DISABLE); #endif return -EPERM; }
Qiang,
Can you rebase this patch and verify it on boards?
Thanks.
York
On 12/13/2014 5:27 AM, York Sun wrote:
-----Original Message----- From: York Sun [mailto:yorksun@freescale.com] Sent: Saturday, December 13, 2014 5:27 AM To: Zhao Qiang-B45475; u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] qe/deep-sleep: add qe deep-sleep for generic board
Qiang,
This patch doesn't needed due to the modify of its based patch from tang yuantian. I will abandon it. Thank you!
Thanks.
York
Best Regards Zhao Qiang
Hi York,
I make mistake in previous email, I have rebased the patch with link http://patchwork.ozlabs.org/patch/420999/. Thank you!
Qiang,
Thanks.
York
qiang.zhao@freescale.com
York Sun
Zhao Qiang
