Multi DTB selection in SPL FIT image
I'm trying to implement multi DTB selection via SPL FIT image in iMX8QXP MEK and it is not working. I have the DTB selection code in board_fit_config_name_match but it doesn't even get to this call, if fails on fit_find_config_node: fit_find_config_node: Cannot find /configurations node: -1
Everything seems fine with the generated u-boot-spl.multidtb.fit file but the code cannot find the configurations node. I've also tried LZO and GZIP compression and the results were the same. Final SPL image size is small enough so it won't overwrite BSS.
Changes in imx8qxp_mek_defconfig: CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_OF_LIST="fsl-imx8qxp-mek fsl-imx8qxp-mek-1" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y
Are there any suggestions on what can be happening here?
Thanks! Vanessa
Vanessa Ayumi Maegima
