[U-Boot] [PATCH] cmd_usage: Use ignored return value
cmd_usage returns 1, so its return value can be used as return value.
Some functions ignore the return value of cmd_usage and return a "1" in the next line. This patch changes these calls so that the return value of cmd_usage is used as return value.
Signed-off-by: Thomas Weber weber@corscience.de --- arch/powerpc/cpu/ppc4xx/cmd_ecctest.c | 6 ++---- board/gdsys/common/osd.c | 6 ++---- common/cmd_nvedit.c | 18 ++++++------------ 3 files changed, 10 insertions(+), 20 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/cmd_ecctest.c b/arch/powerpc/cpu/ppc4xx/cmd_ecctest.c index fd81b70..542ab69 100644 --- a/arch/powerpc/cpu/ppc4xx/cmd_ecctest.c +++ b/arch/powerpc/cpu/ppc4xx/cmd_ecctest.c @@ -190,15 +190,13 @@ static int do_ecctest(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) int error;
if (argc < 3) { - cmd_usage(cmdtp); - return 1; + return cmd_usage(cmdtp); }
ptr = (u32 *)simple_strtoul(argv[1], NULL, 16); error = simple_strtoul(argv[2], NULL, 16); if ((error < 1) || (error > 2)) { - cmd_usage(cmdtp); - return 1; + return cmd_usage(cmdtp); }
printf("Using address %p for %d bit ECC error injection\n", diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index 05800ff..239c870 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -142,8 +142,7 @@ static int osd_print(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) char *text;
if (argc < 5) { - cmd_usage(cmdtp); - return 1; + return cmd_usage(cmdtp); }
x = simple_strtoul(argv[1], NULL, 16); @@ -204,8 +203,7 @@ int osd_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) unsigned count = (argc > 4) ? simple_strtoul(argv[4], NULL, 16) : 1;
if ((argc < 4) || (strlen(argv[3]) % 4)) { - cmd_usage(cmdtp); - return 1; + return cmd_usage(cmdtp); }
x = simple_strtoul(argv[1], NULL, 16); diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 3fd8abc..cd19cc6 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -545,8 +545,7 @@ int envmatch (uchar *s1, int i2) static int do_env_default(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) { if ((argc != 2) || (strcmp(argv[1], "-f") != 0)) { - cmd_usage(cmdtp); - return 1; + return cmd_usage(cmdtp); } set_default_env("## Resetting to default environment\n"); return 0; @@ -633,15 +632,13 @@ static int do_env_export(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv sep = '\n'; break; default: - cmd_usage(cmdtp); - return 1; + return cmd_usage(cmdtp); } } }
if (argc < 1) { - cmd_usage(cmdtp); - return 1; + return cmd_usage(cmdtp); }
addr = (char *)simple_strtoul(argv[0], NULL, 16); @@ -744,15 +741,13 @@ static int do_env_import(cmd_tbl_t * cmdtp, int flag, int argc, char * const arg del = 1; break; default: - cmd_usage(cmdtp); - return 1; + return cmd_usage(cmdtp); } } }
if (!fmt) @@ -857,8 +852,7 @@ static int do_env (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (cp) return cp->cmd(cmdtp, flag, argc, argv);
U_BOOT_CMD(
your summary implies that "cmd_usage" is being changed when in reality, random commands are being changed to use cmd_usage.
seems like these should be split up ... -mike
Mike Frysinger
Thomas Weber
