[U-Boot] [PATCH v2] dm: core: Add dev_get_addr_size_index() to retrieve addr and size
The currently available functions accessing the 'reg' property of a device only retrieve the address. Sometimes its also necessary to retrieve the size described by the 'reg' property. This patch adds the new function dev_get_addr_size_index() which retrieves both, the address and the size described by the 'reg' property.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- v2: - Account 'index' in fdtdec_get_addr_size_auto_noparent() as spotted by Simon
drivers/core/device.c | 22 ++++++++++++++++++++++ include/dm/device.h | 16 ++++++++++++++++ 2 files changed, 38 insertions(+)
diff --git a/drivers/core/device.c b/drivers/core/device.c index dcf5d9df7d..ed553d70a6 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -693,6 +693,28 @@ fdt_addr_t dev_get_addr_index(struct udevice *dev, int index) #endif }
+fdt_addr_t dev_get_addr_size_index(struct udevice *dev, int index, + fdt_size_t *size) +{ +#if CONFIG_IS_ENABLED(OF_CONTROL) + /* + * Only get the size in this first call. We'll get the addr in the + * next call to the exisiting dev_get_xxx function which handles + * all config options. + */ + fdtdec_get_addr_size_auto_noparent(gd->fdt_blob, dev->of_offset, + "reg", index, size, false); + + /* + * Get the base address via the existing function which handles + * all Kconfig cases + */ + return dev_get_addr_index(dev, index); +#else + return FDT_ADDR_T_NONE; +#endif +} + fdt_addr_t dev_get_addr_name(struct udevice *dev, const char *name) { #if CONFIG_IS_ENABLED(OF_CONTROL) diff --git a/include/dm/device.h b/include/dm/device.h index babf8ac8f0..9948bd49fa 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -497,6 +497,22 @@ void *dev_map_physmem(struct udevice *dev, unsigned long size); fdt_addr_t dev_get_addr_index(struct udevice *dev, int index);
/** + * dev_get_addr_size_index() - Get the indexed reg property of a device + * + * Returns the address and size specified in the 'reg' property of a device. + * + * @dev: Pointer to a device + * @index: the 'reg' property can hold a list of <addr, size> pairs + * and @index is used to select which one is required + * @size: Pointer to size varible - this function returns the size + * specified in the 'reg' property here + * + * @return addr + */ +fdt_addr_t dev_get_addr_size_index(struct udevice *dev, int index, + fdt_size_t *size); + +/** * dev_get_addr_name() - Get the reg property of a device, indexed by name * * @dev: Pointer to a device
v2:
But please check below.
fdt_size_t *size)
The return value is not checked here. Is this because the dev_get_addr_index() function will return the same error?
* all Kconfig cases
+#else
+#endif +}
Hi Simon,
v2:
fdt_size_t *size)
Exactly. I didn't check the return value deliberately, as mentioned in the comment above. I thought this would be clear enough but if you don't think so, I can extend the comment a bit more.
Thanks, Stefan
On 30 November 2016 at 22:54, Stefan Roese sr@denx.de wrote:
Hi Simon,
v2:
fdt_size_t *size)
the
Thanks, Stefan
Applied to u-boot-dm, thanks!
Stefan Roese
