[PATCH] imx: fix get_boot_device() for imx8
commit 787f04bb6a0a ("imx: add USB2_BOOT type") broke get_boot_device() for IMX8 which affects booting from SDP due to boot_instance being non-zero.
Fix this by only using boot_instance for imx8ulp and imx9.
Fixes: 787f04bb6a0a ("imx: add USB2_BOOT type") Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/mach-imx/romapi.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-imx/romapi.c b/arch/arm/mach-imx/romapi.c index b49e7f80a286..ff0522c2d117 100644 --- a/arch/arm/mach-imx/romapi.c +++ b/arch/arm/mach-imx/romapi.c @@ -70,6 +70,8 @@ enum boot_device get_boot_device(void) boot_dev = SPI_NOR_BOOT; break; case BT_DEV_TYPE_USB: + if (!is_imx8ulp() && !is_imx9()) + boot_instance = 0; boot_dev = boot_instance + USB_BOOT; break; default:
Reviewed-by: Peng Fan peng.fan@nxp.com
boot_dev = boot_instance + USB_BOOT; break; default:boot_instance = 0;
Hi Tim,
Reviewed-by: Fabio Estevam festevam@denx.de
commit 787f04bb6a0a ("imx: add USB2_BOOT type") broke get_boot_device() for IMX8 which affects booting from SDP due to boot_instance being non-zero. Fix this by only using boot_instance for imx8ulp and imx9. Fixes: 787f04bb6a0a ("imx: add USB2_BOOT type") Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Fabio Estevam
Peng Fan
sbabic@denx.de
Tim Harvey
