[PATCH] net: miiphybb: configs: Drop CONFIG_BITBANGMII_MULTI
It seems that every remaining system which enables BITBANGMII also enables BITBANGMII_MULTI . Remove the BITBANGMII_MULTI symbol and assume it is always enabled. This allows removal of a bit of legacy code. No functional change intended.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Adam Ford aford173@gmail.com Cc: Hai Pham hai.pham.ud@renesas.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org Cc: Jerome Forissier jerome.forissier@linaro.org Cc: Joe Hershberger joe.hershberger@ni.com Cc: Mario Six mario.six@gdsys.cc Cc: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Peter Robinson pbrobinson@gmail.com Cc: Ramon Fried rfried.dev@gmail.com Cc: Sumit Garg sumit.garg@linaro.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- configs/alt_defconfig | 1 - configs/controlcenterdc_defconfig | 1 - configs/gose_defconfig | 1 - configs/grpeach_defconfig | 1 - configs/koelsch_defconfig | 1 - configs/lager_defconfig | 1 - configs/porter_defconfig | 1 - configs/r8a779a0_falcon_defconfig | 1 - configs/r8a779g0_whitehawk_defconfig | 1 - configs/r8a779h0_grayhawk_defconfig | 1 - configs/renesas_rcar3.config | 1 - configs/silk_defconfig | 1 - configs/stout_defconfig | 1 - doc/README.bitbangMII | 25 ++------ drivers/net/phy/Kconfig | 4 -- drivers/net/phy/miiphybb.c | 89 ---------------------------- include/miiphy.h | 2 - 17 files changed, 4 insertions(+), 129 deletions(-)
diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 488115d9a5c..7b16923e34d 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -38,7 +38,6 @@ CONFIG_SH_MMCIF=y CONFIG_DM_MTD=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 2d6c83a5d5f..e6242e22509 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -85,7 +85,6 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MV=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_ANEG_TIMEOUT=8000 CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index d212f91bf83..b53f2f37409 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -36,7 +36,6 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_DM_MTD=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y diff --git a/configs/grpeach_defconfig b/configs/grpeach_defconfig index a4005438c19..d2cc1cf7981 100644 --- a/configs/grpeach_defconfig +++ b/configs/grpeach_defconfig @@ -52,7 +52,6 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_SMSC=y CONFIG_DM_ETH_PHY=y CONFIG_SH_ETHER=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 9bce9e33104..eeb97474b2a 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -36,7 +36,6 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_DM_MTD=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 0d4eed0ddf7..b5682526c8c 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -38,7 +38,6 @@ CONFIG_SH_MMCIF=y CONFIG_DM_MTD=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 98a67bee3e0..cb18024da12 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -36,7 +36,6 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_DM_MTD=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y diff --git a/configs/r8a779a0_falcon_defconfig b/configs/r8a779a0_falcon_defconfig index aae4406bf04..f4f5c57451f 100644 --- a/configs/r8a779a0_falcon_defconfig +++ b/configs/r8a779a0_falcon_defconfig @@ -17,7 +17,6 @@ CONFIG_DEFAULT_FDT_FILE="r8a779a0-falcon.dtb" CONFIG_SYS_PBSIZE=2068 CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_RENESAS_RAVB=y diff --git a/configs/r8a779g0_whitehawk_defconfig b/configs/r8a779g0_whitehawk_defconfig index c74051d1af9..b49a81dcd49 100644 --- a/configs/r8a779g0_whitehawk_defconfig +++ b/configs/r8a779g0_whitehawk_defconfig @@ -19,7 +19,6 @@ CONFIG_SYS_CBSIZE=2048 CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_MMC_ENV_PART=2 CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_RENESAS_RAVB=y diff --git a/configs/r8a779h0_grayhawk_defconfig b/configs/r8a779h0_grayhawk_defconfig index ef709214f03..5b9ad93a596 100644 --- a/configs/r8a779h0_grayhawk_defconfig +++ b/configs/r8a779h0_grayhawk_defconfig @@ -16,7 +16,6 @@ CONFIG_SYS_CBSIZE=2048 CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_MMC_ENV_PART=2 CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_RENESAS_RAVB=y diff --git a/configs/renesas_rcar3.config b/configs/renesas_rcar3.config index 7f7fab7df1d..9f2413ae928 100644 --- a/configs/renesas_rcar3.config +++ b/configs/renesas_rcar3.config @@ -1,5 +1,4 @@ #include <configs/renesas_rcar64.config>
CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_SYS_PBSIZE=2068 diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 53597e9dd4d..1c70a16bf5b 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -38,7 +38,6 @@ CONFIG_SH_MMCIF=y CONFIG_DM_MTD=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index a25a5627c2c..59bb7075013 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -36,7 +36,6 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_DM_MTD=y CONFIG_SPI_FLASH_MTD=y CONFIG_BITBANGMII=y -CONFIG_BITBANGMII_MULTI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_SH_ETHER=y diff --git a/doc/README.bitbangMII b/doc/README.bitbangMII index 0a2fa48a56f..05ab20376f3 100644 --- a/doc/README.bitbangMII +++ b/doc/README.bitbangMII @@ -7,28 +7,11 @@ The driver requires that the following macros should be defined into the board configuration file:
CONFIG_BITBANGMII - Enable the miiphybb driver -CONFIG_BITBANGMII_MULTI - Enable the multi bus support
-If the CONFIG_BITBANGMII_MULTI is not defined, the board's config file needs -to define at least the following macros: - -MII_INIT - Generic code to enable the MII bus (optional) -MDIO_DECLARE - Declaration needed to access to the MDIO pin (optional) -MDIO_ACTIVE - Activate the MDIO pin as out pin -MDIO_TRISTATE - Activate the MDIO pin as input/tristate pin -MDIO_READ - Read the MDIO pin -MDIO(v) - Write v on the MDIO pin -MDC_DECLARE - Declaration needed to access to the MDC pin (optional) -MDC(v) - Write v on the MDC pin - -The previous macros make the driver compatible with the previous version -(that didn't support the multi-bus). - -When the CONFIG_BITBANGMII_MULTI is also defined, the board code needs to fill -the bb_miiphy_buses[] array with a record for each required bus and declare -the bb_miiphy_buses_num variable with the number of mii buses. -The record (struct bb_miiphy_bus) has the following fields/callbacks (see -miiphy.h for details): +The board code needs to fill the bb_miiphy_buses[] array with a record for +each required bus and declare the bb_miiphy_buses_num variable with the +number of mii buses. The record (struct bb_miiphy_bus) has the following +fields/callbacks (see miiphy.h for details):
char name[] - The symbolic name that must be equal to the MII bus registered name diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 13e73810ad6..3132718e4f8 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -2,10 +2,6 @@ config BITBANGMII bool "Bit-banged ethernet MII management channel support"
-config BITBANGMII_MULTI - bool "Enable the multi bus support" - depends on BITBANGMII - config MV88E6352_SWITCH bool "Marvell 88E6352 switch support"
diff --git a/drivers/net/phy/miiphybb.c b/drivers/net/phy/miiphybb.c index b143137893f..171c1719b5b 100644 --- a/drivers/net/phy/miiphybb.c +++ b/drivers/net/phy/miiphybb.c @@ -17,90 +17,6 @@ #include <miiphy.h> #include <asm/global_data.h>
-#ifndef CONFIG_BITBANGMII_MULTI - -/* - * If CONFIG_BITBANGMII_MULTI is not defined we use a - * compatibility layer with the previous miiphybb implementation - * based on macros usage. - * - */ -static int bb_mii_init_wrap(struct bb_miiphy_bus *bus) -{ -#ifdef MII_INIT - MII_INIT; -#endif - return 0; -} - -static int bb_mdio_active_wrap(struct bb_miiphy_bus *bus) -{ -#ifdef MDIO_DECLARE - MDIO_DECLARE; -#endif - MDIO_ACTIVE; - return 0; -} - -static int bb_mdio_tristate_wrap(struct bb_miiphy_bus *bus) -{ -#ifdef MDIO_DECLARE - MDIO_DECLARE; -#endif - MDIO_TRISTATE; - return 0; -} - -static int bb_set_mdio_wrap(struct bb_miiphy_bus *bus, int v) -{ -#ifdef MDIO_DECLARE - MDIO_DECLARE; -#endif - MDIO(v); - return 0; -} - -static int bb_get_mdio_wrap(struct bb_miiphy_bus *bus, int *v) -{ -#ifdef MDIO_DECLARE - MDIO_DECLARE; -#endif - *v = MDIO_READ; - return 0; -} - -static int bb_set_mdc_wrap(struct bb_miiphy_bus *bus, int v) -{ -#ifdef MDC_DECLARE - MDC_DECLARE; -#endif - MDC(v); - return 0; -} - -static int bb_delay_wrap(struct bb_miiphy_bus *bus) -{ - MIIDELAY; - return 0; -} - -struct bb_miiphy_bus bb_miiphy_buses[] = { - { - .name = BB_MII_DEVNAME, - .init = bb_mii_init_wrap, - .mdio_active = bb_mdio_active_wrap, - .mdio_tristate = bb_mdio_tristate_wrap, - .set_mdio = bb_set_mdio_wrap, - .get_mdio = bb_get_mdio_wrap, - .set_mdc = bb_set_mdc_wrap, - .delay = bb_delay_wrap, - } -}; - -int bb_miiphy_buses_num = sizeof(bb_miiphy_buses) / - sizeof(bb_miiphy_buses[0]); -#endif - int bb_miiphy_init(void) { int i; @@ -114,7 +30,6 @@ int bb_miiphy_init(void)
static inline struct bb_miiphy_bus *bb_miiphy_getbus(const char *devname) { -#ifdef CONFIG_BITBANGMII_MULTI int i;
/* Search the correct bus */ @@ -124,10 +39,6 @@ static inline struct bb_miiphy_bus *bb_miiphy_getbus(const char *devname) } } return NULL; -#else - /* We have just one bitbanging bus */ - return &bb_miiphy_buses[0]; -#endif }
/***************************************************************************** diff --git a/include/miiphy.h b/include/miiphy.h index 5abffd8fb6b..2bb4f62ea76 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -72,9 +72,7 @@ struct bb_miiphy_bus { int (*get_mdio)(struct bb_miiphy_bus *bus, int *v); int (*set_mdc)(struct bb_miiphy_bus *bus, int v); int (*delay)(struct bb_miiphy_bus *bus); -#ifdef CONFIG_BITBANGMII_MULTI void *priv; -#endif };
extern struct bb_miiphy_bus bb_miiphy_buses[];
Thanks for tidying this up!
Reviewed-by: Paul Barker paul.barker.ct@bp.renesas.com
Paul Barker
