[PATCH 0/2] rockchip: add support for Theobroma Systems SOM-RK3588-Q7 Tiger module
The RK3588-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230 connector) system-on-module from Theobroma Systems, featuring the Rockchip RK3588.
It provides the following feature set: * up to 16GB LPDDR4x * on-module eMMC * SD card (on a baseboard) via edge connector * Gigabit Ethernet with on-module GbE PHY * HDMI/eDP * MIPI-DSI * 4x MIPI-CSI (3x on FPC connectors, 1x over Q7) * HDMI input over FPC connector * CAN * USB - 1x USB 3.0 dual-role (direct connection) - 2x USB 3.0 host + 1x USB 2.0 host * PCIe - 1x PCIe 2.1 Gen3, 4 lanes - 2xSATA / 2x PCIe 2.1 Gen1, 2 lanes * on-module ATtiny816 companion controller, implementing: - low-power RTC functionality (ISL1208 emulation) - fan controller (AMC6821 emulation) * on-module Secure Element with Global Platform 2.2.1 compliant JavaCard environment
The support is added for Tiger on Haikou devkit, similarly to RK3399 Puma and PX30 Ringneck.
The DTS and DTSI are taken from upstream Linux kernel v6.9-rc4.
Because Tiger doesn't use the same mux for the debug console as all other RK3588 devices currently supported in U-Boot, an additional patch is required to be able to interact with the device properly.
This has a light dependency on https://lore.kernel.org/u-boot/20240415-rk35xx-dram-atags-v3-0-5bc5475b3c0d@... (the Tiger defconfig can be updated to remove the dependency if required)
Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- Quentin Schulz (2): rockchip: rk3588: add support for UART2 M1 and M2 in SPL rockchip: add support for Theobroma Systems SOM-RK3588-Q7 Tiger module
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588-tiger-haikou-u-boot.dtsi | 54 ++ arch/arm/dts/rk3588-tiger-haikou.dts | 266 ++++++++ arch/arm/dts/rk3588-tiger.dtsi | 690 +++++++++++++++++++++ arch/arm/mach-rockchip/rk3588/Kconfig | 41 ++ arch/arm/mach-rockchip/rk3588/rk3588.c | 36 ++ board/theobroma-systems/tiger_rk3588/Kconfig | 16 + board/theobroma-systems/tiger_rk3588/MAINTAINERS | 13 + board/theobroma-systems/tiger_rk3588/Makefile | 10 + .../theobroma-systems/tiger_rk3588/tiger_rk3588.c | 53 ++ configs/tiger-rk3588_defconfig | 114 ++++ doc/board/rockchip/rockchip.rst | 1 + doc/board/theobroma-systems/index.rst | 1 + doc/board/theobroma-systems/tiger_rk3588.rst | 102 +++ include/configs/tiger_rk3588.h | 15 + 15 files changed, 1413 insertions(+) --- base-commit: 5fb840ed8339cae3915ea1528a4bfa3e587540e6 change-id: 20240418-tiger-d1531308c9a0
From: Quentin Schulz quentin.schulz@theobroma-systems.com
UART2 controller is the controller in the reference design for debug console. The default mux is M0 in that reference design. Until now, all boards seemed to be using UART2M0 but RK3588 Tiger for example will be using UART2M2 instead.
Therefore, let's add support for UART2M1 and M2 as possible muxes for the UART2 controller used as debug console. UART2M1 support was not tested.
The default value is M0 to match the one used currently by all devices and the reference design.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/mach-rockchip/rk3588/Kconfig | 10 ++++++++++ arch/arm/mach-rockchip/rk3588/rk3588.c | 36 ++++++++++++++++++++++++++++++++++ 2 files changed, 46 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index d7e4af31f24..cacdb0459c9 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -221,6 +221,16 @@ config ROCKCHIP_COMMON_STACK_ADDR config TEXT_BASE default 0x00a00000
+config DEBUG_UART_CHANNEL + int "Mux channel to use for debug UART2" + depends on DEBUG_UART_BOARD_INIT + default 0 + range 0 2 + help + UART2 can use three different set of pins to route the output. + For using the UART for early debugging the route to use needs + to be declared (0, 1 or 2). + source board/edgeble/neural-compute-module-6/Kconfig source board/friendlyelec/nanopc-t6-rk3588/Kconfig source board/pine64/quartzpro64-rk3588/Kconfig diff --git a/arch/arm/mach-rockchip/rk3588/rk3588.c b/arch/arm/mach-rockchip/rk3588/rk3588.c index eb65dafe3a2..e330ad6a697 100644 --- a/arch/arm/mach-rockchip/rk3588/rk3588.c +++ b/arch/arm/mach-rockchip/rk3588/rk3588.c @@ -94,9 +94,32 @@ enum { GPIO0B6_UART2_RX_M0 = 10, };
+/* GPIO3B_IOMUX_SEL_L */ +enum { + GPIO3B1_SHIFT = 4, + GPIO3B1_MASK = GENMASK(7, 4), + GPIO3B1_UART2_TX_M2 = 10, + + GPIO3B2_SHIFT = 8, + GPIO3B2_MASK = GENMASK(11, 8), + GPIO3B2_UART2_RX_M2 = 10, +}; + +/* GPIO4D_IOMUX_SEL_L */ +enum { + GPIO4D0_SHIFT = 0, + GPIO4D0_MASK = GENMASK(3, 0), + GPIO4D0_UART2_TX_M1 = 10, + + GPIO4D1_SHIFT = 4, + GPIO4D1_MASK = GENMASK(7, 4), + GPIO4D1_UART2_RX_M1 = 10, +}; + void board_debug_uart_init(void) { __maybe_unused static struct rk3588_bus_ioc * const bus_ioc = (void *)BUS_IOC_BASE; +#if (CONFIG_DEBUG_UART_CHANNEL == 0) static struct rk3588_pmu2_ioc * const pmu2_ioc = (void *)PMU2_IOC_BASE;
/* Refer to BUS_IOC */ @@ -110,6 +133,19 @@ void board_debug_uart_init(void) GPIO0B6_MASK | GPIO0B5_MASK, GPIO0B6_UART2_RX_M0 << GPIO0B6_SHIFT | GPIO0B5_UART2_TX_M0 << GPIO0B5_SHIFT); +#elif (CONFIG_DEBUG_UART_CHANNEL == 1) + /* UART2_M1 Switch iomux */ + rk_clrsetreg(&bus_ioc->gpio4d_iomux_sel_l, + GPIO4D0_MASK | GPIO4D1_MASK, + GPIO4D0_UART2_TX_M1 << GPIO4D0_UART2_TX_M1 | + GPIO4D1_UART2_RX_M1 << GPIO4D1_SHIFT); +#else + /* UART2_M2 Switch iomux */ + rk_clrsetreg(&bus_ioc->gpio3b_iomux_sel_l, + GPIO3B1_MASK | GPIO3B2_MASK, + GPIO3B1_UART2_TX_M2 << GPIO3B1_SHIFT | + GPIO3B2_UART2_RX_M2 << GPIO3B2_SHIFT); +#endif /* CONFIG_DEBUG_UART_CHANNEL */ }
#ifdef CONFIG_SPL_BUILD
Hi Quentin,
Is this really necessary?
Use of board_debug_uart_init() should typically only be needed in TPL on Rockchip platform, and with ROCKCHIP_TPL being used it should be enough to use rkbin/ddrbin_tool to change uart config and just ensure correct pinctrl is used for uart node, and that the uart node is included in SPL for correct serial console use.
May I suggest you try adding following to defconfig and drop this patch?
# CONFIG_DEBUG_UART_BOARD_INIT is not set
I would expect that should result in same/working behavior without having to add any new code.
Regards, Jonas
- int "Mux channel to use for debug UART2"
- depends on DEBUG_UART_BOARD_INIT
- default 0
- range 0 2
- help
- GPIO3B1_SHIFT = 4,
- GPIO3B1_MASK = GENMASK(7, 4),
- GPIO3B1_UART2_TX_M2 = 10,
- GPIO3B2_SHIFT = 8,
- GPIO3B2_MASK = GENMASK(11, 8),
- GPIO3B2_UART2_RX_M2 = 10,
- GPIO4D0_SHIFT = 0,
- GPIO4D0_MASK = GENMASK(3, 0),
- GPIO4D0_UART2_TX_M1 = 10,
- GPIO4D1_SHIFT = 4,
- GPIO4D1_MASK = GENMASK(7, 4),
- GPIO4D1_UART2_RX_M1 = 10,
- /* UART2_M1 Switch iomux */
- rk_clrsetreg(&bus_ioc->gpio4d_iomux_sel_l,
+#else
- /* UART2_M2 Switch iomux */
- rk_clrsetreg(&bus_ioc->gpio3b_iomux_sel_l,
Hi Jonas,
On 4/22/24 19:41, Jonas Karlman wrote:
Hi Quentin,
ddrbin_tool is a blob that Rockchip refuses to provide sources of. Running a blob on the target is one thing, requiring our users to run a blob on their build machine is another thing (though I document it in the rST).
However... I don't think we have another way around because I just remembered that if you have two muxes selected for the same UART controller, RX won't work. So while we would have UART output for U-Boot if Rockchip's TPL is one mux (e.g. m0, the default) and upstream U-Boot another one, we wouldn't be able to interact with it.
It'll be necessary the day we have an open-source DRAM init though (I had to do this for PX30 for example).
The issue is that since ddrbin_tool is a blob, it's not possible to use it in Yocto for automatically generating the appropriate ddr bin blob based on uart controller, mux and baudrate. So that will be my cross to bear.
It does work, thanks for the suggestion, will send a v2.
Cheers, Quentin
Hi Quentin,
This feature already been supported, please use CONFIG_DEBUG_UART_BASE and CONFIG_ROCKCHIP_UART_MUX_SEL_M to select your output channel.
Thanks, - Kever
- default 0
- range 0 2
- help
- source board/edgeble/neural-compute-module-6/Kconfig source board/friendlyelec/nanopc-t6-rk3588/Kconfig source board/pine64/quartzpro64-rk3588/Kconfig
- void board_debug_uart_init(void) { __maybe_unused static struct rk3588_bus_ioc * const bus_ioc = (void *)BUS_IOC_BASE;
+#else
Hi Kever,
On 4/23/24 03:09, Kever Yang wrote:
Hi Quentin,
CONFIG_ROCKCHIP_UART_MUX_SEL_M is only available in Rockchip's downstream U-Boot.
git log -p -S ROCKCHIP_UART_MUX_SEL_M
returns nothing upstream, neither does git grep.
I used the same mechanism as for PX30.
This patch will be removed though as it's not needed until we have an open-source DRAM init. Until then we have to rely on the DDR bin to setup the UART.
Cheers, Quentin
Hi Quentin,
On 2024/4/23 17:31, Quentin Schulz wrote:
Hi Kever,
Hi Quentin,
Sorry, my mistake, I'm searching the wrong code.
I though we should already have solution for this, it should be DEBUG_UART_CHANNEL then.
Thanks,
- Kever
Cheers, Quentin
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588-tiger-haikou-u-boot.dtsi | 54 ++ arch/arm/dts/rk3588-tiger-haikou.dts | 266 ++++++++ arch/arm/dts/rk3588-tiger.dtsi | 690 +++++++++++++++++++++ arch/arm/mach-rockchip/rk3588/Kconfig | 31 + board/theobroma-systems/tiger_rk3588/Kconfig | 16 + board/theobroma-systems/tiger_rk3588/MAINTAINERS | 13 + board/theobroma-systems/tiger_rk3588/Makefile | 10 + .../theobroma-systems/tiger_rk3588/tiger_rk3588.c | 53 ++ configs/tiger-rk3588_defconfig | 114 ++++ doc/board/rockchip/rockchip.rst | 1 + doc/board/theobroma-systems/index.rst | 1 + doc/board/theobroma-systems/tiger_rk3588.rst | 102 +++ include/configs/tiger_rk3588.h | 15 + 14 files changed, 1367 insertions(+)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b1c9c6222e5..ef901642a0a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -180,6 +180,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588-quartzpro64.dtb \ rk3588s-rock-5a.dtb \ rk3588-rock-5b.dtb \ + rk3588-tiger-haikou.dtb \ rk3588-turing-rk1.dtb
dtb-$(CONFIG_ROCKCHIP_RV1108) += \ diff --git a/arch/arm/dts/rk3588-tiger-haikou-u-boot.dtsi b/arch/arm/dts/rk3588-tiger-haikou-u-boot.dtsi new file mode 100644 index 00000000000..4259399193a --- /dev/null +++ b/arch/arm/dts/rk3588-tiger-haikou-u-boot.dtsi @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024 Theobroma Systems Design und Consulting GmbH + */ + +#include "rk3588-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; + }; +}; + +&emmc_pwrseq { + bootph-pre-ram; + bootph-some-ram; +}; + +&emmc_reset { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio2 { + bootph-pre-ram; + bootph-some-ram; +}; + +&sdhci { + /* U-Boot currently cannot handle anything below HS200 for eMMC on RK3588 */ + /delete-property/ mmc-ddr-1_8v; + /delete-property/ cap-mmc-highspeed; +}; + +/* Q7 USB P0 */ +&u2phy1 { + status = "okay"; +}; + +&u2phy1_otg { + status = "okay"; +}; + +&usbdp_phy1 { + status = "okay"; +}; + +&usbdp_phy1_u3 { + status = "okay"; +}; + +&usb_host1_xhci { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3588-tiger-haikou.dts b/arch/arm/dts/rk3588-tiger-haikou.dts new file mode 100644 index 00000000000..d672198c6b6 --- /dev/null +++ b/arch/arm/dts/rk3588-tiger-haikou.dts @@ -0,0 +1,266 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Theobroma Systems Design und Consulting GmbH + */ + +/dts-v1/; +#include <dt-bindings/input/input.h> +#include "rk3588-tiger.dtsi" + +/ { + model = "Theobroma Systems RK3588-Q7 SoM on Haikou devkit"; + compatible = "tsd,rk3588-tiger-haikou", "tsd,rk3588-tiger", "rockchip,rk3588"; + + aliases { + ethernet0 = &gmac0; + mmc1 = &sdmmc; + }; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + dc_12v: dc-12v-regulator { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&haikou_keys_pin>; + + button-batlow-n { + label = "BATLOW#"; + linux,code = <KEY_BATTERY>; + gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_LOW>; + }; + + button-slp-btn-n { + label = "SLP_BTN#"; + linux,code = <KEY_SLEEP>; + gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_LOW>; + }; + + button-wake-n { + label = "WAKE#"; + linux,code = <KEY_WAKEUP>; + gpios = <&gpio3 RK_PC6 GPIO_ACTIVE_LOW>; + wakeup-source; + }; + + switch-lid-btn-n { + label = "LID_BTN#"; + linux,code = <SW_LID>; + linux,input-type = <EV_SW>; + gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_LOW>; + }; + }; + + i2s3-sound { + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + simple-audio-card,name = "Haikou,I2S-codec"; + simple-audio-card,mclk-fs = <512>; + simple-audio-card,frame-master = <&sgtl5000_codec>; + simple-audio-card,bitclock-master = <&sgtl5000_codec>; + + sgtl5000_codec: simple-audio-card,codec { + sound-dai = <&sgtl5000>; + }; + + simple-audio-card,cpu { + sound-dai = <&i2s3_2ch>; + }; + }; + + sgtl5000_clk: sgtl5000-oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24576000>; + }; + + vcc3v3_baseboard: vcc3v3-baseboard-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_baseboard"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_12v>; + }; + + vcc3v3_low_noise: vcc3v3-low-noise-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_low_noise"; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_baseboard: vcc5v0-baseboard-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_baseboard"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vcc5v0_usb: vcc5v0-usb-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vddd_audio_1v6: vddd-audio-1v6-regulator { + compatible = "regulator-fixed"; + regulator-name = "vddd_audio_1v6"; + regulator-boot-on; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <1600000>; + vin-supply = <&vcc5v0_usb>; + }; +}; + +&combphy2_psu { + status = "okay"; +}; + +&gmac0 { + status = "okay"; +}; + +&i2c1 { + status = "okay"; + + eeprom@50 { + reg = <0x50>; + compatible = "atmel,24c01"; + pagesize = <8>; + size = <128>; + vcc-supply = <&vcc3v3_baseboard>; + }; +}; + +&i2c5 { + clock-frequency = <400000>; + status = "okay"; + + sgtl5000: codec@a { + compatible = "fsl,sgtl5000"; + reg = <0x0a>; + clocks = <&sgtl5000_clk>; + #sound-dai-cells = <0>; + VDDA-supply = <&vcc3v3_low_noise>; + VDDIO-supply = <&vcc3v3_baseboard>; + VDDD-supply = <&vddd_audio_1v6>; + }; +}; + +&i2c8 { + status = "okay"; +}; + +&i2s3_2ch { + status = "okay"; +}; + +&pcie30phy { + status = "okay"; +}; + +&pcie3x4 { + vpcie3v3-supply = <&vcc3v3_baseboard>; + status = "okay"; +}; + +&pinctrl { + haikou { + haikou_keys_pin: haikou-keys-pin { + rockchip,pins = + /* BATLOW# */ + <3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>, + /* SLP_BTN# */ + <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>, + /* WAKE# */ + <3 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>, + /* LID_BTN */ + <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&sdmmc { + /* while the same pin, sdmmc_det does not detect card changes */ + cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; + disable-wp; + pinctrl-0 = <&sdmmc_bus4 &sdmmc_cmd &sdmmc_clk>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vcc3v3_baseboard>; + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy2_host { + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy3_host { + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m2_xfer>; + status = "okay"; +}; + +&uart5 { + rts-gpios = <&gpio3 RK_PB3 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +/* host0 on Q7_USB_P2, lower usb3 port */ +&usb_host0_ehci { + status = "okay"; +}; + +/* host0 on Q7_USB_P2, lower usb3 port */ +&usb_host0_ohci { + status = "okay"; +}; + +/* host1 on Q7_USB_P3, usb2 port */ +&usb_host1_ehci { + status = "okay"; +}; + +/* host1 on Q7_USB_P3, usb2 port */ +&usb_host1_ohci { + status = "okay"; +}; + +/* host2 on Q7_USB_P2, lower usb3 port */ +&usb_host2_xhci { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3588-tiger.dtsi b/arch/arm/dts/rk3588-tiger.dtsi new file mode 100644 index 00000000000..1eb2543a5fd --- /dev/null +++ b/arch/arm/dts/rk3588-tiger.dtsi @@ -0,0 +1,690 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Theobroma Systems Design und Consulting GmbH + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3588.dtsi" + +/ { + compatible = "tsd,rk3588-tiger", "rockchip,rk3588"; + + aliases { + mmc0 = &sdhci; + rtc0 = &rtc_twi; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + pinctrl-0 = <&emmc_reset>; + pinctrl-names = "default"; + reset-gpios = <&gpio2 RK_PA3 GPIO_ACTIVE_HIGH>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&module_led_pin>; + + /* Named LED1 on the board */ + led-1 { + gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_HEARTBEAT; + linux,default-trigger = "heartbeat"; + color = <LED_COLOR_ID_AMBER>; + }; + }; + + /* + * 100MHz reference clock for PCIe peripherals from PI6C557-05BLE + * clock generator. + * The clock output is gated via the OE pin on the clock generator. + * This is modeled as a fixed-clock plus a gpio-gate-clock. + */ + pcie_refclk_gen: pcie-refclk-gen-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <1000000000>; + }; + + pcie_refclk: pcie-refclk-clock { + compatible = "gpio-gate-clock"; + clocks = <&pcie_refclk_gen>; + #clock-cells = <0>; + enable-gpios = <&gpio4 RK_PB4 GPIO_ACTIVE_HIGH>; /* PCIE30X4_CLKREQN_M1_L */ + }; + + vcc_1v1_nldo_s3: vcc-1v1-nldo-s3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_1v1_nldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc_1v2_s3: vcc-1v2-s3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_1v2_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_baseboard>; + }; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&gmac0 { + clock_in_out = "output"; + phy-handle = <&rgmii_phy>; + phy-mode = "rgmii"; + phy-supply = <&vcc_1v2_s3>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac0_miim + &gmac0_rx_bus2 + &gmac0_tx_bus2 + &gmac0_rgmii_clk + &gmac0_rgmii_bus + ð0_pins + ð_reset>; + tx_delay = <0x10>; + rx_delay = <0x10>; + snps,reset-gpio = <&gpio4 RK_PC3 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 100000>; +}; + +&i2c1 { + pinctrl-0 = <&i2c1m0_xfer>; +}; + +&i2c1m0_xfer { + rockchip,pins = + /* i2c1_scl_m0 */ + <0 RK_PB5 9 &pcfg_pull_none_drv_level_0>, + /* i2c1_sda_m0 */ + <0 RK_PB6 9 &pcfg_pull_none_drv_level_0>; +}; + +&i2c2 { + pinctrl-0 = <&i2c2m3_xfer>; + status = "okay"; +}; + +&i2c2m3_xfer { + rockchip,pins = + /* i2c2_scl_m3 */ + <1 RK_PC5 9 &pcfg_pull_none_drv_level_0>, + /* i2c2_sda_m3 */ + <1 RK_PC4 9 &pcfg_pull_none_drv_level_0>; +}; + +&i2c3 { + pinctrl-0 = <&i2c3m0_xfer>; +}; + +&i2c4 { + pinctrl-0 = <&i2c4m4_xfer>; + status = "okay"; + + vdd_npu_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_npu_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c5 { + pinctrl-0 = <&i2c5m1_xfer>; +}; + +&i2c5m1_xfer { + rockchip,pins = + /* i2c5_scl_m1 */ + <4 RK_PB6 9 &pcfg_pull_none_drv_level_0>, + /* i2c5_sda_m1 */ + <4 RK_PB7 9 &pcfg_pull_none_drv_level_0>; +}; + +&i2c6 { + /* + * Mule-ATtiny can handle up to Fast mode Plus (1MHz) on I2C bus, + * but SOC can handle only up to (400kHz). + */ + clock-frequency = <400000>; + status = "okay"; + + fan@18 { + compatible = "ti,amc6821"; + reg = <0x18>; + }; + + rtc_twi: rtc@6f { + compatible = "isil,isl1208"; + reg = <0x6f>; + }; +}; + +&i2c6m0_xfer { + rockchip,pins = + /* i2c6_scl_m0 */ + <0 RK_PD0 9 &pcfg_pull_none_drv_level_0>, + /* i2c6_sda_m0 */ + <0 RK_PC7 9 &pcfg_pull_none_drv_level_0>; +}; + +&i2c7 { + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c7m0_xfer { + rockchip,pins = + /* i2c7_scl_m0 */ + <1 RK_PD0 9 &pcfg_pull_none_drv_level_0>, + /* i2c7_sda_m0 */ + <1 RK_PD1 9 &pcfg_pull_none_drv_level_0>; +}; + +&i2c8 { + pinctrl-0 = <&i2c8m2_xfer>; +}; + +&mdio0 { + rgmii_phy: ethernet-phy@6 { + /* KSZ9031 or KSZ9131 */ + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0x6>; + clocks = <&cru REFCLKO25M_ETH0_OUT>; + }; +}; + +&pcie3x4 { + /* + * The board has a gpio-controlled "pcie_refclk" generator, + * so add it to the list of clocks. + */ + clocks = <&cru ACLK_PCIE_4L_MSTR>, <&cru ACLK_PCIE_4L_SLV>, + <&cru ACLK_PCIE_4L_DBI>, <&cru PCLK_PCIE_4L>, + <&cru CLK_PCIE_AUX0>, <&cru CLK_PCIE4L_PIPE>, + <&pcie_refclk>; + clock-names = "aclk_mst", "aclk_slv", + "aclk_dbi", "pclk", + "aux", "pipe", + "ref"; + reset-gpios = <&gpio3 RK_PB6 GPIO_ACTIVE_HIGH>; +}; + +&pinctrl { + emmc { + emmc_reset: emmc-reset { + rockchip,pins = <2 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + ethernet { + eth_reset: eth-reset { + rockchip,pins = <4 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + leds { + module_led_pin: module-led-pin { + rockchip,pins = <1 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&saradc { + vref-supply = <&vcc_1v8_s0>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + mmc-pwrseq = <&emmc_pwrseq>; + no-sdio; + no-sd; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_cmd &emmc_clk &emmc_data_strobe>; + supports-cqe; + vmmc-supply = <&vcc_3v3_s3>; + vqmmc-supply = <&vcc_1v8_s3>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <150000000>; + vqmmc-supply = <&vccio_sd_s0>; +}; + +&spi0 { + pinctrl-0 = <&spi0m1_cs0 &spi0m1_cs1 &spi0m3_pins>; +}; + +&spi2 { + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + num-cs = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; + status = "okay"; + + pmic@0 { + compatible = "rockchip,rk806"; + reg = <0x0>; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + gpio-controller; + #gpio-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + spi-max-frequency = <1000000>; + system-power-controller; + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc5v0_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc5v0_sys>; + vcc13-supply = <&vcc_1v1_nldo_s3>; + vcc14-supply = <&vcc_1v1_nldo_s3>; + vcca-supply = <&vcc5v0_sys>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: dcdc-reg1 { + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_gpu_s0"; + regulator-enable-ramp-delay = <400>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: dcdc-reg2 { + regulator-name = "vdd_cpu_lit_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_log_s0: dcdc-reg3 { + regulator-name = "vdd_log_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: dcdc-reg4 { + regulator-name = "vdd_vdenc_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg5 { + regulator-name = "vdd_ddr_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdd2_ddr_s3: dcdc-reg6 { + regulator-name = "vdd2_ddr_s3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-name = "vcc_2v0_pldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vcc_3v3_s3: dcdc-reg8 { + regulator-name = "vcc_3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-name = "vddq_ddr_s0"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s3: dcdc-reg10 { + regulator-name = "vcc_1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca_1v8_s0: pldo-reg1 { + regulator-name = "vcca_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s0: pldo-reg2 { + regulator-name = "vcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdda_1v2_s0: pldo-reg3 { + regulator-name = "vdda_1v2_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca_3v3_s0: pldo-reg4 { + regulator-name = "vcca_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-name = "vccio_sd_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + pldo6_s3: pldo-reg6 { + regulator-name = "pldo6_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-name = "vdd_0v75_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdda_ddr_pll_s0: nldo-reg2 { + regulator-name = "vdda_ddr_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdda_0v75_s0: nldo-reg3 { + regulator-name = "vdda_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v85_s0: nldo-reg4 { + regulator-name = "vdda_0v85_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v75_s0: nldo-reg5 { + regulator-name = "vdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +/* Mule-ATtiny UPDI */ +&uart4 { + pinctrl-0 = <&uart4m2_xfer>; + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index cacdb0459c9..35868d73dd5 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -159,6 +159,36 @@ config TARGET_QUARTZPRO64_RK3588 Pine64 QuartzPro64 is a Rockchip RK3588 based SBC (Single Board Computer) by Pine64.
+config TARGET_TIGER_RK3588 + bool "Theobroma Systems SOM-RK3588-Q7 (Tiger)" + select BOARD_LATE_INIT + help + The RK3588-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230 + connector) system-on-module from Theobroma Systems, featuring the + Rockchip RK3588. + + It provides the following feature set: + * up to 16GB LPDDR4x + * on-module eMMC + * SD card (on a baseboard) via edge connector + * Gigabit Ethernet with on-module GbE PHY + * HDMI/eDP + * MIPI-DSI + * 4x MIPI-CSI (3x on FPC connectors, 1x over Q7) + * HDMI input over FPC connector + * CAN + * USB + - 1x USB 3.0 dual-role (direct connection) + - 2x USB 3.0 host + 1x USB 2.0 host + * PCIe + - 1x PCIe 2.1 Gen3, 4 lanes + - 2xSATA / 2x PCIe 2.1 Gen1, 2 lanes + * on-module ATtiny816 companion controller, implementing: + - low-power RTC functionality (ISL1208 emulation) + - fan controller (AMC6821 emulation) + * on-module Secure Element with Global Platform 2.2.1 compliant + JavaCard environment + config TARGET_TURINGRK1_RK3588 bool "Turing Machines RK1 RK3588 board" select BOARD_LATE_INIT @@ -240,5 +270,6 @@ source board/radxa/rock5b-rk3588/Kconfig source board/rockchip/evb_rk3588/Kconfig source board/rockchip/toybrick_rk3588/Kconfig source board/theobroma-systems/jaguar_rk3588/Kconfig +source board/theobroma-systems/tiger_rk3588/Kconfig
endif diff --git a/board/theobroma-systems/tiger_rk3588/Kconfig b/board/theobroma-systems/tiger_rk3588/Kconfig new file mode 100644 index 00000000000..2c6ac6a9a83 --- /dev/null +++ b/board/theobroma-systems/tiger_rk3588/Kconfig @@ -0,0 +1,16 @@ +if TARGET_TIGER_RK3588 + +config SYS_BOARD + default "tiger_rk3588" + +config SYS_VENDOR + default "theobroma-systems" + +config SYS_CONFIG_NAME + default "tiger_rk3588" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select ENV_IS_NOWHERE + +endif diff --git a/board/theobroma-systems/tiger_rk3588/MAINTAINERS b/board/theobroma-systems/tiger_rk3588/MAINTAINERS new file mode 100644 index 00000000000..02a2d09fe69 --- /dev/null +++ b/board/theobroma-systems/tiger_rk3588/MAINTAINERS @@ -0,0 +1,13 @@ +TIGER-RK3588 (SOM-RK3588-Q7) +M: Klaus Goger klaus.goger@theobroma-systems.com +M: Quentin Schulz quentin.schulz@theobroma-systems.com +M: Heiko Stuebner heiko.stuebner@cherry.de +S: Maintained +F: board/theobroma-systems/tiger_rk3588 +F: board/theobroma-systems/common +F: doc/board/theobroma-systems/ +F: include/configs/tiger_rk3588.h +F: arch/arm/dts/rk3588-tiger* +F: configs/tiger-rk3588_defconfig +W: https://theobroma-systems.com/product/tiger-som-rk3588-q7/ +T: git git://git.theobroma-systems.com/tiger-u-boot.git diff --git a/board/theobroma-systems/tiger_rk3588/Makefile b/board/theobroma-systems/tiger_rk3588/Makefile new file mode 100644 index 00000000000..5c4c484657a --- /dev/null +++ b/board/theobroma-systems/tiger_rk3588/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (c) 2024 Theobroma Systems Design und Consulting GmbH +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += tiger_rk3588.o +ifneq ($(CONFIG_SPL_BUILD),y) +obj-y += ../common/common.o +endif diff --git a/board/theobroma-systems/tiger_rk3588/tiger_rk3588.c b/board/theobroma-systems/tiger_rk3588/tiger_rk3588.c new file mode 100644 index 00000000000..a6d44f10db3 --- /dev/null +++ b/board/theobroma-systems/tiger_rk3588/tiger_rk3588.c @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 Theobroma Systems Design und Consulting GmbH + */ + +#include <phy.h> +#include <eth_phy.h> + +#include <asm/types.h> +#include <asm/arch-rockchip/cru_rk3588.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/ioc_rk3588.h> +#include <asm-generic/u-boot.h> +#include <dm/device.h> +#include <dm/uclass-id.h> +#include <linux/bitfield.h> + +#include "../common/common.h" + +#define GPIO2C3_SEL_MASK GENMASK(15, 12) +#define GPIO2C3_ETH0_REFCLKO_25M FIELD_PREP(GPIO2C3_SEL_MASK, 1) + +#define REFCLKO25M_ETH0_OUT_SEL_MASK BIT(15) +#define REFCLKO25M_ETH0_OUT_SEL_CPLL FIELD_PREP(REFCLKO25M_ETH0_OUT_SEL_MASK, 1) +#define REFCLKO25M_ETH0_OUT_DIV_MASK GENMASK(14, 8) +#define REFCLKO25M_ETH0_OUT_DIV(x) FIELD_PREP(REFCLKO25M_ETH0_OUT_DIV_MASK, (x) - 1) + +#define REFCLKO25M_ETH0_OUT_EN BIT(4) + +void setup_eth0refclko(void) +{ + /* Configure and enable ETH0_REFCLKO_25MHz */ + static struct rk3588_bus_ioc * const bus_ioc = (void *)BUS_IOC_BASE; + static struct rk3588_cru * const cru = (void *)CRU_BASE; + + /* 1. Pinmux */ + rk_clrsetreg(&bus_ioc->gpio2c_iomux_sel_l, GPIO2C3_SEL_MASK, GPIO2C3_ETH0_REFCLKO_25M); + /* 2. Parent clock selection + divider => CPLL (1.5GHz) / 60 => 25MHz */ + rk_clrsetreg(&cru->clksel_con[15], + REFCLKO25M_ETH0_OUT_SEL_MASK | REFCLKO25M_ETH0_OUT_DIV_MASK, + REFCLKO25M_ETH0_OUT_SEL_CPLL | REFCLKO25M_ETH0_OUT_DIV(60)); + /* 3. Enable clock */ + rk_clrreg(&cru->clkgate_con[5], REFCLKO25M_ETH0_OUT_EN); +} + +int rockchip_early_misc_init_r(void) +{ + setup_boottargets(); + + setup_eth0refclko(); + + return 0; +} diff --git a/configs/tiger-rk3588_defconfig b/configs/tiger-rk3588_defconfig new file mode 100644 index 00000000000..6545445bba1 --- /dev/null +++ b/configs/tiger-rk3588_defconfig @@ -0,0 +1,114 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SPL_GPIO=y +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_ENV_SIZE=0x1f000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-tiger-haikou" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_ROCKCHIP_BOOT_MODE_REG=0x0 +CONFIG_SPL_SERIAL=y +CONFIG_DEBUG_UART_CHANNEL=2 +CONFIG_TARGET_TIGER_RK3588=y +CONFIG_DEBUG_UART_BASE=0xfeb50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTMETH_VBE is not set +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-tiger-haikou.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_CYCLIC=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_ELF is not set +CONFIG_CMD_ADC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SF is not set +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_MII is not set +# CONFIG_CMD_BLOCK_CACHE is not set +# CONFIG_CMD_EFICONFIG is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EROFS=y +CONFIG_CMD_SQUASHFS=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +# CONFIG_OF_TAG_MIGRATE is not set +CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_BUTTON=y +CONFIG_BUTTON_GPIO=y +CONFIG_SPL_CLK=y +CONFIG_CLK_GPIO=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_SPL_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_SPL_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_SPL_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +# CONFIG_SPI_FLASH is not set +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 5dd5ea7f1e2..f5a05596f57 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -128,6 +128,7 @@ List of mainline supported Rockchip boards: - Radxa ROCK 5B (rock5b-rk3588) - Rockchip Toybrick TB-RK3588X (toybrick-rk3588) - Theobroma Systems RK3588-SBC Jaguar (jaguar-rk3588) + - Theobroma Systems SOM-RK3588-Q7 - Tiger (tiger-rk3588) - Turing Machines RK1 (turing-rk1-rk3588) - Xunlong Orange Pi 5 (orangepi-5-rk3588s) - Xunlong Orange Pi 5 Plus (orangepi-5-plus-rk3588) diff --git a/doc/board/theobroma-systems/index.rst b/doc/board/theobroma-systems/index.rst index b4da2616c37..73e07f7ebfa 100644 --- a/doc/board/theobroma-systems/index.rst +++ b/doc/board/theobroma-systems/index.rst @@ -9,3 +9,4 @@ Theobroma Systems jaguar_rk3588 puma_rk3399 ringneck_px30 + tiger_rk3588 diff --git a/doc/board/theobroma-systems/tiger_rk3588.rst b/doc/board/theobroma-systems/tiger_rk3588.rst new file mode 100644 index 00000000000..a73eec7fb9b --- /dev/null +++ b/doc/board/theobroma-systems/tiger_rk3588.rst @@ -0,0 +1,102 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +SOM-RK3588-Q7 Tiger +=================== + +The RK3588-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230 +connector) system-on-module from Theobroma Systems, featuring the +Rockchip RK3588. + +It provides the following feature set: + * up to 16GB LPDDR4x + * on-module eMMC + * SD card (on a baseboard) via edge connector + * Gigabit Ethernet with on-module GbE PHY + * HDMI/eDP + * MIPI-DSI + * 4x MIPI-CSI (3x on FPC connectors, 1x over Q7) + * HDMI input over FPC connector + * CAN + * USB + - 1x USB 3.0 dual-role (direct connection) + - 2x USB 3.0 host + 1x USB 2.0 host + * PCIe + - 1x PCIe 2.1 Gen3, 4 lanes + - 2xSATA / 2x PCIe 2.1 Gen1, 2 lanes + * on-module ATtiny816 companion controller, implementing: + - low-power RTC functionality (ISL1208 emulation) + - fan controller (AMC6821 emulation) + * on-module Secure Element with Global Platform 2.2.1 compliant + JavaCard environment + +Here is the step-by-step to boot to U-Boot on SOM-RK3588-Q7 Tiger from Theobroma +Systems. + +Get the TF-A and DDR init (TPL) binaries +---------------------------------------- + +.. prompt:: bash + + git clone https://github.com/rockchip-linux/rkbin + cd rkbin + export RKBIN=$(pwd) + export BL31=$RKBIN/bin/rk35/rk3588_bl31_v1.38.elf + export ROCKCHIP_TPL=$RKBIN/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2736MHz_v1.11.bin + sed -i 's/^uart baudrate=.*$/uart baudrate=115200/' tools/ddrbin_param.txt + sed -i 's/^uart iomux=.*$/uart iomux=2/' tools/ddrbin_param.txt + ./tools/ddrbin_tool tools/ddrbin_param.txt "$ROCKCHIP_TPL" + ./tools/boot_merger RKBOOT/RK3588MINIALL.ini + export RKDB=$RKBIN/rk3588_spl_loader_v1.11.112.bin + +This will setup all required external dependencies for compiling U-Boot. This will +be updated in the future once upstream Trusted-Firmware-A supports RK3588 or U-Boot +gains support for open-source DRAM initialization in TPL. + +Build U-Boot +------------ + +.. prompt:: bash + + cd ../u-boot + make CROSS_COMPILE=aarch64-linux-gnu- tiger-rk3588_defconfig all + +This will build ``u-boot-rockchip.bin`` which can be written to an MMC device +(eMMC or SD card). + +Flash the image +--------------- + +Copy ``u-boot-rockchip.bin`` to offset 32k for SD/eMMC. + +SD-Card +~~~~~~~ + +.. prompt:: bash + + dd if=u-boot-rockchip.bin of=/dev/sdX seek=64 + +.. note:: + + Replace ``/dev/sdX`` to match your SD card kernel device. + +eMMC +~~~~ + +``rkdeveloptool`` allows to flash the on-board eMMC via the USB OTG interface +with help of the Rockchip loader binary. + +To enter the USB flashing mode on Haikou baseboard, remove any SD card, insert a +micro-USB cable in the ``Q7 USB P1`` connector (P8), move ``SW5`` switch into +``BIOS Disable`` mode, power cycle or reset the board and move ``SW5`` switch +back to ``Normal Boot`` mode. A new USB device should have appeared on your PC +(check with ``lsusb -d 2207:350b``). + +To flash U-Boot on the eMMC with ``rkdeveloptool``: + +.. prompt:: bash + + git clone https://github.com/rockchip-linux/rkdeveloptool + cd rkdeveloptool + autoreconf -i && CPPFLAGS=-Wno-format-truncation ./configure && make + ./rkdeveloptool db "$RKDB" + ./rkdeveloptool wl 64 ../u-boot-rockchip.bin diff --git a/include/configs/tiger_rk3588.h b/include/configs/tiger_rk3588.h new file mode 100644 index 00000000000..7a32adfaf2a --- /dev/null +++ b/include/configs/tiger_rk3588.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2023 Theobroma Systems Design und Consulting GmbH + */ + +#ifndef __TIGER_RK3588_H +#define __TIGER_RK3588_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3588_common.h> + +#endif /* __TIGER_RK3588_H */
Hi Quentin,
- up to 16GB LPDDR4x
- on-module eMMC
- SD card (on a baseboard) via edge connector
- Gigabit Ethernet with on-module GbE PHY
- HDMI/eDP
- MIPI-DSI
- 4x MIPI-CSI (3x on FPC connectors, 1x over Q7)
- HDMI input over FPC connector
- CAN
- USB
- PCIe
- on-module ATtiny816 companion controller, implementing:
- on-module Secure Element with Global Platform 2.2.1 compliant JavaCard environment
- rk3588-tiger-haikou.dtb \ rk3588-turing-rk1.dtb
- Copyright (c) 2024 Theobroma Systems Design und Consulting GmbH
- chosen {
+&emmc_pwrseq {
- bootph-pre-ram;
- bootph-some-ram;
+&emmc_reset {
- bootph-pre-ram;
- bootph-some-ram;
+&gpio2 {
- bootph-pre-ram;
- bootph-some-ram;
+&sdhci {
- /* U-Boot currently cannot handle anything below HS200 for eMMC on RK3588 */
- /delete-property/ mmc-ddr-1_8v;
- /delete-property/ cap-mmc-highspeed;
- status = "okay";
+&u2phy1_otg {
- status = "okay";
+&usbdp_phy1 {
- status = "okay";
+&usbdp_phy1_u3 {
- status = "okay";
+&usb_host1_xhci {
- status = "okay";
Following should be added to possible fix uart2 pinctrl in SPL:
&uart2m2_xfer { bootph-all; };
[snip]
Please use USB_DWC3_GENERIC instead of USB_XHCI_DWC3.
Regards, Jonas
[snip]
Hi Jonas,
On 4/22/24 19:54, Jonas Karlman wrote:
Hi Quentin,
Would only be useful once we get rid of DDR bin, but will do it now because I have a feeling I would forget otherwise :)
Thanks for catching this though.
[snip]
Dang, I thought I was using "the correct one".
It's very difficult to know which one to pick right now, would it be possible to update the help message to guide the users a bit more in their choice? I don't really have a clue why one is "better" than the other so wouldn't be able to suggest something.
Cheers, Quentin
Jonas Karlman
Kever Yang
Quentin Schulz
Quentin Schulz
