[U-Boot] [PATCH] Add UBI README
This patch adds a small README to describe the usage of the U-Boot UBI commands.
Signed-off-by: Stefan Roese sr@denx.de --- doc/README.ubi | 144 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 144 insertions(+), 0 deletions(-) create mode 100644 doc/README.ubi
diff --git a/doc/README.ubi b/doc/README.ubi new file mode 100644 index 0000000..da2dfac --- /dev/null +++ b/doc/README.ubi @@ -0,0 +1,144 @@ +------------------- +UBI usage in U-Boot +------------------- + +Here the list of the currently implemented UBI commands: + +=> help ubi +ubi - ubi commands + +Usage: +ubi part [part] [offset] + - Show or set current partition (with optional VID header offset) +ubi info [l[ayout]] - Display volume and ubi layout information +ubi create[vol] volume [size] [type] - create volume name with size +ubi write[vol] address volume size - Write volume from address with size +ubi read[vol] address volume [size] - Read volume to address with size +ubi remove[vol] volume - Remove volume +[Legends] + volume: character name + size: specified in bytes + type: s[tatic] or d[ynamic] (default=dynamic) + + +The first command that is needed to be issues is "ubi part" to connect +one mtd partition to the UBI subsystem. This command will either create +a new UBI device on the requested MTD partition. Or it will attach a +previously created UBI device. The other UBI commands will only work +when such a UBI device is attached (via "ubi part"). Here an example: + +=> mtdparts + +device nor0 <1fc000000.nor_flash>, # parts = 6 + #: name size offset mask_flags + 0: kernel 0x00200000 0x00000000 0 + 1: dtb 0x00040000 0x00200000 0 + 2: root 0x00200000 0x00240000 0 + 3: user 0x01ac0000 0x00440000 0 + 4: env 0x00080000 0x01f00000 0 + 5: u-boot 0x00080000 0x01f80000 0 + +active partition: nor0,0 - (kernel) 0x00200000 @ 0x00000000 + +defaults: +mtdids : nor0=1fc000000.nor_flash +mtdparts: mtdparts=1fc000000.nor_flash:2m(kernel),256k(dtb),2m(root),27392k(user),512k(env),512k(u-boot) + +=> ubi part root +Creating 1 MTD partitions on "nor0": +0x000000240000-0x000000440000 : "mtd=2" +UBI: attaching mtd1 to ubi0 +UBI: physical eraseblock size: 262144 bytes (256 KiB) +UBI: logical eraseblock size: 262016 bytes +UBI: smallest flash I/O unit: 1 +UBI: VID header offset: 64 (aligned 64) +UBI: data offset: 128 +UBI: attached mtd1 to ubi0 +UBI: MTD device name: "mtd=2" +UBI: MTD device size: 2 MiB +UBI: number of good PEBs: 8 +UBI: number of bad PEBs: 0 +UBI: max. allowed volumes: 128 +UBI: wear-leveling threshold: 4096 +UBI: number of internal volumes: 1 +UBI: number of user volumes: 1 +UBI: available PEBs: 0 +UBI: total number of reserved PEBs: 8 +UBI: number of PEBs reserved for bad PEB handling: 0 +UBI: max/mean erase counter: 2/1 + + +Now that the UBI device is attached, this device can be modified +using the following commands: + +ubi info Display volume and ubi layout information +ubi createvol Create UBI volume on UBI device +ubi removevol Remove UBI volume from UBI device +ubi read Read data from UBI volume to memory +ubi write Write data from memory to UBI volume + + +Here a few examples on the usage: + +=> ubi create testvol +Creating dynamic volume testvol of size 1048064 + +=> ubi info l +UBI: volume information dump: +UBI: vol_id 0 +UBI: reserved_pebs 4 +UBI: alignment 1 +UBI: data_pad 0 +UBI: vol_type 3 +UBI: name_len 7 +UBI: usable_leb_size 262016 +UBI: used_ebs 4 +UBI: used_bytes 1048064 +UBI: last_eb_bytes 262016 +UBI: corrupted 0 +UBI: upd_marker 0 +UBI: name testvol + +UBI: volume information dump: +UBI: vol_id 2147479551 +UBI: reserved_pebs 2 +UBI: alignment 1 +UBI: data_pad 0 +UBI: vol_type 3 +UBI: name_len 13 +UBI: usable_leb_size 262016 +UBI: used_ebs 2 +UBI: used_bytes 524032 +UBI: last_eb_bytes 2 +UBI: corrupted 0 +UBI: upd_marker 0 +UBI: name layout volume + +=> ubi info +UBI: MTD device name: "mtd=2" +UBI: MTD device size: 2 MiB +UBI: physical eraseblock size: 262144 bytes (256 KiB) +UBI: logical eraseblock size: 262016 bytes +UBI: number of good PEBs: 8 +UBI: number of bad PEBs: 0 +UBI: smallest flash I/O unit: 1 +UBI: VID header offset: 64 (aligned 64) +UBI: data offset: 128 +UBI: max. allowed volumes: 128 +UBI: wear-leveling threshold: 4096 +UBI: number of internal volumes: 1 +UBI: number of user volumes: 1 +UBI: available PEBs: 0 +UBI: total number of reserved PEBs: 8 +UBI: number of PEBs reserved for bad PEB handling: 0 +UBI: max/mean erase counter: 4/1 + +=> ubi write 800000 testvol 80000 +Volume "testvol" found at volume id 0 + +=> ubi read 900000 testvol 80000 +Volume testvol found at volume id 0 +read 524288 bytes from volume 0 to 900000(buf address) + +=> cmp.b 800000 900000 80000 +Total of 524288 bytes were the same
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
