[U-Boot] [Patch] soft_i2c.c compiler/linker error
This patch fix the compiler/linker errors
common/cmd_i2c.c:1252: undefined reference to `i2c_get_bus_speed' common/cmd_i2c.c:1256: undefined reference to `i2c_set_bus_speed'
if board use CONFIG_I2C_CMD_TREE and CONFIG_I2C_MULTI_BUS is not uesd/undef
Signed-off-by: Jens Scharsig esw@bus-elektronik.de ---
diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index ed5f5b2..68b267f 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -246,6 +246,7 @@ int i2c_set_bus_num(unsigned int bus) #endif return 0; } +#endif
/* TODO: add 100/400k switching */ unsigned int i2c_get_bus_speed(void) @@ -260,7 +261,7 @@ int i2c_set_bus_speed(unsigned int speed)
return 0; } -#endif +
/*----------------------------------------------------------------------- * if ack == I2C_ACK, ACK the byte so can continue reading, else
NACK
you must implement it
Best Regards, J.
NACK
Pleace a liltle bit more informations
What exactly must I implement?
I2C_MULTI_BUS or i2c_get_bus_speed / i2c_set_bus_speed
Is the driver (soft_i2c.c) not the right pleace for i2c_set/get_bus_speed?
Best Regards, Jens Scharsig
Hello Jean-Christophe
NACK
It is implemented in the driver, but not activated, because wrong define order ... I think this patch is OK.
bye Heiko
NACK
bye Heiko
Thanks for the confirmation. That was my thought. Only my description was bad or not completely.
regards Jens
Hello Jens,
return 0; } -#endif
no need to add an empty line.
thanks for catching Heiko
if board use CONFIG_I2C_CMD_TREE and CONFIG_I2C_MULTI_BUS is not uesd/undef (wrong define order)
and
removes additional empty lines
diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index ed5f5b2..185634d 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -51,14 +51,12 @@ DECLARE_GLOBAL_DATA_PTR; #endif
- /*----------------------------------------------------------------------- * Definitions */
#define RETRIES 0
- #define I2C_ACK 0 /* PD_SDA level to ack a byte */ #define I2C_NOACK 1 /* PD_SDA level to noack a byte */
@@ -154,7 +152,6 @@ static void send_stop(void) I2C_TRISTATE; }
- /*----------------------------------------------------------------------- * ack should be I2C_ACK or I2C_NOACK */ @@ -174,7 +171,6 @@ static void send_ack(int ack) I2C_DELAY; }
- /*----------------------------------------------------------------------- * Send 8 bits and look for an acknowledgement. */ @@ -246,6 +242,7 @@ int i2c_set_bus_num(unsigned int bus) #endif return 0; } +#endif
/* TODO: add 100/400k switching */ unsigned int i2c_get_bus_speed(void) @@ -260,7 +257,6 @@ int i2c_set_bus_speed(unsigned int speed)
return 0; } -#endif
Hello Jens,
This line is too long also s/uesd/used should be done ... I fix this, when apply this patch (or you send me a new one)
bye Heiko
and
#define RETRIES 0
return 0; } -#endif
Hello Jens,
and
Applied to u-boot-i2c.git
thanks Heiko
Heiko Schocher
Jens Scharsig
