[U-Boot-Users] [ARM] TI DaVinci support, hopefully final [1/5]
Signed-off-by: Sergey Kubushyn ksi@koi8.net
diff -purN u-boot.git.orig/board/davinci/dv-evm/board_init.S u-boot.git/board/davinci/dv-evm/board_init.S --- u-boot.git.orig/board/davinci/dv-evm/board_init.S 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/dv-evm/board_init.S 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Board-specific low level initialization code. Called at the very end + * of cpu/arm926ejs/davinci/lowlevel_init.S. Just returns if there is no + * initialization required. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> + +.globl dv_board_init +dv_board_init: + + mov pc, lr diff -purN u-boot.git.orig/board/davinci/dv-evm/config.mk u-boot.git/board/davinci/dv-evm/config.mk --- u-boot.git.orig/board/davinci/dv-evm/config.mk 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/dv-evm/config.mk 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,39 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# David Mueller, ELSOFT AG, d.mueller@elsoft.ch +# +# (C) Copyright 2003 +# Texas Instruments, <www.ti.com> +# Swaminathan swami.iyer@ti.com +# +# Davinci EVM board (ARM925EJS) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# Davinci EVM has 1 bank of 256 MB DDR RAM +# Physical Address: +# 8000'0000 to 9000'0000 +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# Visioneering Corp. Sonata board (ARM926EJS) cpu +# +# Sonata board has 1 bank of 128 MB DDR RAM +# Physical Address: +# 8000'0000 to 8800'0000 +# +# Razorstream, LLC. SCHMOOGIE board (ARM926EJS) cpu +# +# Schmoogie board has 1 bank of 128 MB DDR RAM +# Physical Address: +# 8000'0000 to 8800'0000 +# +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) +# +# we load ourself to 8108 '0000 +# +# + +#Provide at least 16MB spacing between us and the Linux Kernel image +TEXT_BASE = 0x81080000 diff -purN u-boot.git.orig/board/davinci/dv-evm/dv_board.c u-boot.git/board/davinci/dv-evm/dv_board.c --- u-boot.git.orig/board/davinci/dv-evm/dv_board.c 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/dv-evm/dv_board.c 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,211 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Parts are shamelessly stolen from various TI sources, original copyright + * follows: + * ----------------------------------------------------------------- + * + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <i2c.h> +#include <asm/arch/hardware.h> +#include <asm/arch/emac_defs.h> + +#define MACH_TYPE_DAVINCI_EVM 901 + +extern void i2c_init(int speed, int slaveaddr); +extern void timer_init(void); +extern int eth_hw_init(void); +extern phy_t phy; + + +/* Works on Always On power domain only (no PD argument) */ +void lpsc_on(unsigned int id) +{ + dv_reg_p mdstat, mdctl; + + if (id >= DAVINCI_LPSC_GEM) + return; /* Don't work on DSP Power Domain */ + + mdstat = REG_P(PSC_MDSTAT_BASE + (id * 4)); + mdctl = REG_P(PSC_MDCTL_BASE + (id * 4)); + + while (REG(PSC_PTSTAT) & 0x01) {;} + + if ((*mdstat & 0x1f) == 0x03) + return; /* Already on and enabled */ + + *mdctl |= 0x03; + + /* Special treatment for some modules as for sprue14 p.7.4.2 */ + if ( (id == DAVINCI_LPSC_VPSSSLV) || + (id == DAVINCI_LPSC_EMAC) || + (id == DAVINCI_LPSC_EMAC_WRAPPER) || + (id == DAVINCI_LPSC_MDIO) || + (id == DAVINCI_LPSC_USB) || + (id == DAVINCI_LPSC_ATA) || + (id == DAVINCI_LPSC_VLYNQ) || + (id == DAVINCI_LPSC_UHPI) || + (id == DAVINCI_LPSC_DDR_EMIF) || + (id == DAVINCI_LPSC_AEMIF) || + (id == DAVINCI_LPSC_MMC_SD) || + (id == DAVINCI_LPSC_MEMSTICK) || + (id == DAVINCI_LPSC_McBSP) || + (id == DAVINCI_LPSC_GPIO) + ) + *mdctl |= 0x200; + + REG(PSC_PTCMD) = 0x01; + + while (REG(PSC_PTSTAT) & 0x03) {;} + while ((*mdstat & 0x1f) != 0x03) {;} /* Probably an overkill... */ +} + +void dsp_on(void) +{ + int i; + + if (REG(PSC_PDSTAT1) & 0x1f) + return; /* Already on */ + + REG(PSC_GBLCTL) |= 0x01; + REG(PSC_PDCTL1) |= 0x01; + REG(PSC_PDCTL1) &= ~0x100; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) |= 0x03; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) &= 0xfffffeff; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) |= 0x03; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) &= 0xfffffeff; + REG(PSC_PTCMD) = 0x02; + + for (i = 0; i < 100; i++) { + if (REG(PSC_EPCPR) & 0x02) + break; + } + + REG(PSC_CHP_SHRTSW) = 0x01; + REG(PSC_PDCTL1) |= 0x100; + REG(PSC_EPCCR) = 0x02; + + for (i = 0; i < 100; i++) { + if (!(REG(PSC_PTSTAT) & 0x02)) + break; + } + + REG(PSC_GBLCTL) &= ~0x1f; +} + + +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + /* arch number of the board */ + gd->bd->bi_arch_number = MACH_TYPE_DAVINCI_EVM; + + /* address of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + /* Workaround for TMS320DM6446 errata 1.3.22 */ + REG(PSC_SILVER_BULLET) = 0; + + /* Power on required peripherals */ + lpsc_on(DAVINCI_LPSC_EMAC); + lpsc_on(DAVINCI_LPSC_EMAC_WRAPPER); + lpsc_on(DAVINCI_LPSC_MDIO); + lpsc_on(DAVINCI_LPSC_I2C); + lpsc_on(DAVINCI_LPSC_UART0); + lpsc_on(DAVINCI_LPSC_TIMER1); + lpsc_on(DAVINCI_LPSC_GPIO); + + /* Powerup the DSP */ + dsp_on(); + + /* Bringup UART0 out of reset */ + REG(UART0_PWREMU_MGMT) = 0x0000e003; + + /* Enable GIO3.3V cells used for EMAC */ + REG(VDD3P3V_PWDN) = 0; + + /* Enable UART0 MUX lines */ + REG(PINMUX1) |= 1; + + /* Enable EMAC and AEMIF pins */ + REG(PINMUX0) = 0x80000c1f; + + /* Enable I2C pin Mux */ + REG(PINMUX1) |= (1 << 7); + + /* Set the Bus Priority Register to appropriate value */ + REG(VBPR) = 0x20; + + timer_init(); + + return(0); +} + +int misc_init_r (void) +{ + u_int8_t tmp[20], buf[10]; + int i = 0; + int clk = 0; + + clk = ((REG(PLL2_PLLM) + 1) * 27) / ((REG(PLL2_DIV2) & 0x1f) + 1); + + printf ("ARM Clock : %dMHz\n", ((REG(PLL1_PLLM) + 1) * 27 ) / 2); + printf ("DDR Clock : %dMHz\n", (clk / 2)); + + /* Set Ethernet MAC address from EEPROM */ + if (i2c_read(CFG_I2C_EEPROM_ADDR, 0x7f00, CFG_I2C_EEPROM_ADDR_LEN, buf, 6)) { + printf("\nEEPROM @ 0x%02x read FAILED!!!\n", CFG_I2C_EEPROM_ADDR); + } else { + tmp[0] = 0xff; + for (i = 0; i < 6; i++) + tmp[0] &= buf[i]; + + if ((tmp[0] != 0xff) && (getenv("ethaddr") == NULL)) { + sprintf((char *)&tmp[0], "%02hhx:%02hhx:%02hhx:%02hhx:%02hhx:%02hhx", + buf[0], buf[1], buf[2], buf[3], buf[4], buf[5]); + setenv("ethaddr", (char *)&tmp[0]); + } + } + + if (!eth_hw_init()) { + printf("ethernet init failed!\n"); + } else { + printf("ETH PHY : %s\n", phy.name); + } + + i2c_read (0x39, 0x00, 1, (u_int8_t *)&i, 1); + + setenv ("videostd", ((i & 0x80) ? "pal" : "ntsc")); + + return(0); +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return(0); +} diff -purN u-boot.git.orig/board/davinci/dv-evm/Makefile u-boot.git/board/davinci/dv-evm/Makefile --- u-boot.git.orig/board/davinci/dv-evm/Makefile 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/dv-evm/Makefile 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,52 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := dv_board.o +SOBJS := board_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak *~ .depend + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff -purN u-boot.git.orig/board/davinci/dv-evm/u-boot.lds u-boot.git/board/davinci/dv-evm/u-boot.lds --- u-boot.git.orig/board/davinci/dv-evm/u-boot.lds 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/dv-evm/u-boot.lds 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + . = ALIGN(4); + .text : + { + cpu/arm926ejs/start.o (.text) + *(.text) + } + . = ALIGN(4); + .rodata : { *(.rodata) } + . = ALIGN(4); + .data : { *(.data) } + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff -purN u-boot.git.orig/board/davinci/schmoogie/board_init.S u-boot.git/board/davinci/schmoogie/board_init.S --- u-boot.git.orig/board/davinci/schmoogie/board_init.S 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/schmoogie/board_init.S 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Board-specific low level initialization code. Called at the very end + * of cpu/arm926ejs/davinci/lowlevel_init.S. Just returns if there is no + * initialization required. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> + +.globl dv_board_init +dv_board_init: + + mov pc, lr diff -purN u-boot.git.orig/board/davinci/schmoogie/config.mk u-boot.git/board/davinci/schmoogie/config.mk --- u-boot.git.orig/board/davinci/schmoogie/config.mk 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/schmoogie/config.mk 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,39 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# David Mueller, ELSOFT AG, d.mueller@elsoft.ch +# +# (C) Copyright 2003 +# Texas Instruments, <www.ti.com> +# Swaminathan swami.iyer@ti.com +# +# Davinci EVM board (ARM925EJS) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# Davinci EVM has 1 bank of 256 MB DDR RAM +# Physical Address: +# 8000'0000 to 9000'0000 +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# Visioneering Corp. Sonata board (ARM926EJS) cpu +# +# Sonata board has 1 bank of 128 MB DDR RAM +# Physical Address: +# 8000'0000 to 8800'0000 +# +# Razorstream, LLC. SCHMOOGIE board (ARM926EJS) cpu +# +# Schmoogie board has 1 bank of 128 MB DDR RAM +# Physical Address: +# 8000'0000 to 8800'0000 +# +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) +# +# we load ourself to 8108 '0000 +# +# + +#Provide at least 16MB spacing between us and the Linux Kernel image +TEXT_BASE = 0x81080000 diff -purN u-boot.git.orig/board/davinci/schmoogie/dv_board.c u-boot.git/board/davinci/schmoogie/dv_board.c --- u-boot.git.orig/board/davinci/schmoogie/dv_board.c 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/schmoogie/dv_board.c 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,253 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Parts are shamelessly stolen from various TI sources, original copyright + * follows: + * ----------------------------------------------------------------- + * + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <i2c.h> +#include <asm/arch/hardware.h> +#include <asm/arch/emac_defs.h> + +#define MACH_TYPE_SCHMOOGIE 1255 + +extern void i2c_init(int speed, int slaveaddr); +extern void timer_init(void); +extern int eth_hw_init(void); +extern phy_t phy; + + +/* Works on Always On power domain only (no PD argument) */ +void lpsc_on(unsigned int id) +{ + dv_reg_p mdstat, mdctl; + + if (id >= DAVINCI_LPSC_GEM) + return; /* Don't work on DSP Power Domain */ + + mdstat = REG_P(PSC_MDSTAT_BASE + (id * 4)); + mdctl = REG_P(PSC_MDCTL_BASE + (id * 4)); + + while (REG(PSC_PTSTAT) & 0x01) {;} + + if ((*mdstat & 0x1f) == 0x03) + return; /* Already on and enabled */ + + *mdctl |= 0x03; + + /* Special treatment for some modules as for sprue14 p.7.4.2 */ + if ( (id == DAVINCI_LPSC_VPSSSLV) || + (id == DAVINCI_LPSC_EMAC) || + (id == DAVINCI_LPSC_EMAC_WRAPPER) || + (id == DAVINCI_LPSC_MDIO) || + (id == DAVINCI_LPSC_USB) || + (id == DAVINCI_LPSC_ATA) || + (id == DAVINCI_LPSC_VLYNQ) || + (id == DAVINCI_LPSC_UHPI) || + (id == DAVINCI_LPSC_DDR_EMIF) || + (id == DAVINCI_LPSC_AEMIF) || + (id == DAVINCI_LPSC_MMC_SD) || + (id == DAVINCI_LPSC_MEMSTICK) || + (id == DAVINCI_LPSC_McBSP) || + (id == DAVINCI_LPSC_GPIO) + ) + *mdctl |= 0x200; + + REG(PSC_PTCMD) = 0x01; + + while (REG(PSC_PTSTAT) & 0x03) {;} + while ((*mdstat & 0x1f) != 0x03) {;} /* Probably an overkill... */ +} + +void dsp_on(void) +{ + int i; + + if (REG(PSC_PDSTAT1) & 0x1f) + return; /* Already on */ + + REG(PSC_GBLCTL) |= 0x01; + REG(PSC_PDCTL1) |= 0x01; + REG(PSC_PDCTL1) &= ~0x100; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) |= 0x03; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) &= 0xfffffeff; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) |= 0x03; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) &= 0xfffffeff; + REG(PSC_PTCMD) = 0x02; + + for (i = 0; i < 100; i++) { + if (REG(PSC_EPCPR) & 0x02) + break; + } + + REG(PSC_CHP_SHRTSW) = 0x01; + REG(PSC_PDCTL1) |= 0x100; + REG(PSC_EPCCR) = 0x02; + + for (i = 0; i < 100; i++) { + if (!(REG(PSC_PTSTAT) & 0x02)) + break; + } + + REG(PSC_GBLCTL) &= ~0x1f; +} + + +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + /* arch number of the board */ + gd->bd->bi_arch_number = MACH_TYPE_SCHMOOGIE; + + /* address of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + /* Workaround for TMS320DM6446 errata 1.3.22 */ + REG(PSC_SILVER_BULLET) = 0; + + /* Power on required peripherals */ + lpsc_on(DAVINCI_LPSC_EMAC); + lpsc_on(DAVINCI_LPSC_EMAC_WRAPPER); + lpsc_on(DAVINCI_LPSC_MDIO); + lpsc_on(DAVINCI_LPSC_I2C); + lpsc_on(DAVINCI_LPSC_UART0); + lpsc_on(DAVINCI_LPSC_TIMER1); + lpsc_on(DAVINCI_LPSC_GPIO); + + /* Powerup the DSP */ + dsp_on(); + + /* Bringup UART0 out of reset */ + REG(UART0_PWREMU_MGMT) = 0x0000e003; + + /* Enable GIO3.3V cells used for EMAC */ + REG(VDD3P3V_PWDN) = 0; + + /* Enable UART0 MUX lines */ + REG(PINMUX1) |= 1; + + /* Enable EMAC and AEMIF pins */ + REG(PINMUX0) = 0x80000c1f; + + /* Enable I2C pin Mux */ + REG(PINMUX1) |= (1 << 7); + + /* Set the Bus Priority Register to appropriate value */ + REG(VBPR) = 0x20; + + timer_init(); + + return(0); +} + +int misc_init_r (void) +{ + u_int8_t tmp[20], buf[10]; + int i = 0; + int clk = 0; + + /* Set serial number from UID chip */ + u_int8_t crc_tbl[256] = { + 0x00, 0x5e, 0xbc, 0xe2, 0x61, 0x3f, 0xdd, 0x83, + 0xc2, 0x9c, 0x7e, 0x20, 0xa3, 0xfd, 0x1f, 0x41, + 0x9d, 0xc3, 0x21, 0x7f, 0xfc, 0xa2, 0x40, 0x1e, + 0x5f, 0x01, 0xe3, 0xbd, 0x3e, 0x60, 0x82, 0xdc, + 0x23, 0x7d, 0x9f, 0xc1, 0x42, 0x1c, 0xfe, 0xa0, + 0xe1, 0xbf, 0x5d, 0x03, 0x80, 0xde, 0x3c, 0x62, + 0xbe, 0xe0, 0x02, 0x5c, 0xdf, 0x81, 0x63, 0x3d, + 0x7c, 0x22, 0xc0, 0x9e, 0x1d, 0x43, 0xa1, 0xff, + 0x46, 0x18, 0xfa, 0xa4, 0x27, 0x79, 0x9b, 0xc5, + 0x84, 0xda, 0x38, 0x66, 0xe5, 0xbb, 0x59, 0x07, + 0xdb, 0x85, 0x67, 0x39, 0xba, 0xe4, 0x06, 0x58, + 0x19, 0x47, 0xa5, 0xfb, 0x78, 0x26, 0xc4, 0x9a, + 0x65, 0x3b, 0xd9, 0x87, 0x04, 0x5a, 0xb8, 0xe6, + 0xa7, 0xf9, 0x1b, 0x45, 0xc6, 0x98, 0x7a, 0x24, + 0xf8, 0xa6, 0x44, 0x1a, 0x99, 0xc7, 0x25, 0x7b, + 0x3a, 0x64, 0x86, 0xd8, 0x5b, 0x05, 0xe7, 0xb9, + 0x8c, 0xd2, 0x30, 0x6e, 0xed, 0xb3, 0x51, 0x0f, + 0x4e, 0x10, 0xf2, 0xac, 0x2f, 0x71, 0x93, 0xcd, + 0x11, 0x4f, 0xad, 0xf3, 0x70, 0x2e, 0xcc, 0x92, + 0xd3, 0x8d, 0x6f, 0x31, 0xb2, 0xec, 0x0e, 0x50, + 0xaf, 0xf1, 0x13, 0x4d, 0xce, 0x90, 0x72, 0x2c, + 0x6d, 0x33, 0xd1, 0x8f, 0x0c, 0x52, 0xb0, 0xee, + 0x32, 0x6c, 0x8e, 0xd0, 0x53, 0x0d, 0xef, 0xb1, + 0xf0, 0xae, 0x4c, 0x12, 0x91, 0xcf, 0x2d, 0x73, + 0xca, 0x94, 0x76, 0x28, 0xab, 0xf5, 0x17, 0x49, + 0x08, 0x56, 0xb4, 0xea, 0x69, 0x37, 0xd5, 0x8b, + 0x57, 0x09, 0xeb, 0xb5, 0x36, 0x68, 0x8a, 0xd4, + 0x95, 0xcb, 0x29, 0x77, 0xf4, 0xaa, 0x48, 0x16, + 0xe9, 0xb7, 0x55, 0x0b, 0x88, 0xd6, 0x34, 0x6a, + 0x2b, 0x75, 0x97, 0xc9, 0x4a, 0x14, 0xf6, 0xa8, + 0x74, 0x2a, 0xc8, 0x96, 0x15, 0x4b, 0xa9, 0xf7, + 0xb6, 0xe8, 0x0a, 0x54, 0xd7, 0x89, 0x6b, 0x35 + }; + + clk = ((REG(PLL2_PLLM) + 1) * 27) / ((REG(PLL2_DIV2) & 0x1f) + 1); + + printf ("ARM Clock : %dMHz\n", ((REG(PLL1_PLLM) + 1) * 27 ) / 2); + printf ("DDR Clock : %dMHz\n", (clk / 2)); + + /* Set serial number from UID chip */ + if (i2c_read(CFG_UID_ADDR, 0, 1, buf, 8)) { + printf("\nUID @ 0x%02x read FAILED!!!\n", CFG_UID_ADDR); + forceenv("serial#", "FAILED"); + } else { + if (buf[0] != 0x70) { /* Device Family Code */ + printf("\nUID @ 0x%02x read FAILED!!!\n", CFG_UID_ADDR); + forceenv("serial#", "FAILED"); + } + } + /* Now check CRC */ + tmp[0] = 0; + for (i = 0; i < 8; i++) + tmp[0] = crc_tbl[tmp[0] ^ buf[i]]; + + if (tmp[0] != 0) { + printf("\nUID @ 0x%02x - BAD CRC!!!\n", CFG_UID_ADDR); + forceenv("serial#", "FAILED"); + } else { + /* CRC OK, set "serial" env variable */ + sprintf((char *)&tmp[0], "%02hhx%02hhx%02hhx%02hhx%02hhx%02hhx", + buf[6], buf[5], buf[4], buf[3], buf[2], buf[1]); + forceenv("serial#", (char *)&tmp[0]); + } + + if (!eth_hw_init()) { + printf("ethernet init failed!\n"); + } else { + printf("ETH PHY : %s\n", phy.name); + } + + return(0); +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return(0); +} diff -purN u-boot.git.orig/board/davinci/schmoogie/Makefile u-boot.git/board/davinci/schmoogie/Makefile --- u-boot.git.orig/board/davinci/schmoogie/Makefile 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/schmoogie/Makefile 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,52 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := dv_board.o +SOBJS := board_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak *~ .depend + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff -purN u-boot.git.orig/board/davinci/schmoogie/u-boot.lds u-boot.git/board/davinci/schmoogie/u-boot.lds --- u-boot.git.orig/board/davinci/schmoogie/u-boot.lds 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/schmoogie/u-boot.lds 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + . = ALIGN(4); + .text : + { + cpu/arm926ejs/start.o (.text) + *(.text) + } + . = ALIGN(4); + .rodata : { *(.rodata) } + . = ALIGN(4); + .data : { *(.data) } + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff -purN u-boot.git.orig/board/davinci/sonata/board_init.S u-boot.git/board/davinci/sonata/board_init.S --- u-boot.git.orig/board/davinci/sonata/board_init.S 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/sonata/board_init.S 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,100 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Board-specific low level initialization code. Called at the very end + * of cpu/arm926ejs/davinci/lowlevel_init.S. Just returns if there is no + * initialization required. + * + * For _OLDER_ Sonata boards sets up GPIO4 to control NAND WP line. Newer + * Sonata boards, AFAIK, don't use this so it's just return by default. Ask + * Visioneering if they reinvented the wheel once again to make sure :) + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> + +.globl dv_board_init +dv_board_init: +#ifdef SONATA_BOARD_GPIOWP + /* Set PINMUX0 to enable GPIO4 */ + ldr r0, _PINMUX0 + ldr r1, GPIO4_EN_MASK + ldr r2, [r0] + and r2, r2, r1 + str r2, [r0] + + /* Enable GPIO LPSC module */ + ldr r0, PTSTAT + +gpio_ptstat_loop1: + ldr r2, [r0] + tst r2, $0x00000001 + bne gpio_ptstat_loop1 + + ldr r1, MDCTL_GPIO + ldr r2, [r1] + and r2, r2, $0xfffffff8 + orr r2, r2, $0x00000003 + str r2, [r1] + + orr r2, r2, $0x00000200 + str r2, [r1] + + ldr r1, PTCMD + mov r2, $0x00000001 + str r2, [r1] + +gpio_ptstat_loop2: + ldr r2, [r0] + tst r2, $0x00000001 + bne gpio_ptstat_loop2 + + ldr r0, MDSTAT_GPIO +gpio_mdstat_loop: + ldr r2, [r0] + and r2, r2, $0x0000001f + teq r2, $0x00000003 + bne gpio_mdstat_loop + + /* GPIO4 -> output */ + ldr r0, GPIO_DIR01 + mov r1, $0x10 + ldr r2, [r0] + bic r2, r2, r0 + str r2, [r0] + + /* Set it to 0 (Write Protect) */ + ldr r0, GPIO_CLR_DATA01 + str r1, [r0] +#endif + + mov pc, lr + +#ifdef SONATA_BOARD_GPIOWP +.ltorg + +GPIO4_EN_MASK: + .word 0xf77fffff +MDCTL_GPIO: + .word 0x01c41a68 +MDSTAT_GPIO: + .word 0x01c41868 +GPIO_DIR01: + .word 0x01c67010 +GPIO_CLR_DATA01: + .word 0x01c6701c +#endif diff -purN u-boot.git.orig/board/davinci/sonata/config.mk u-boot.git/board/davinci/sonata/config.mk --- u-boot.git.orig/board/davinci/sonata/config.mk 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/sonata/config.mk 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,39 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# David Mueller, ELSOFT AG, d.mueller@elsoft.ch +# +# (C) Copyright 2003 +# Texas Instruments, <www.ti.com> +# Swaminathan swami.iyer@ti.com +# +# Davinci EVM board (ARM925EJS) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# Davinci EVM has 1 bank of 256 MB DDR RAM +# Physical Address: +# 8000'0000 to 9000'0000 +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# Visioneering Corp. Sonata board (ARM926EJS) cpu +# +# Sonata board has 1 bank of 128 MB DDR RAM +# Physical Address: +# 8000'0000 to 8800'0000 +# +# Razorstream, LLC. SCHMOOGIE board (ARM926EJS) cpu +# +# Schmoogie board has 1 bank of 128 MB DDR RAM +# Physical Address: +# 8000'0000 to 8800'0000 +# +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) +# +# we load ourself to 8108 '0000 +# +# + +#Provide at least 16MB spacing between us and the Linux Kernel image +TEXT_BASE = 0x81080000 diff -purN u-boot.git.orig/board/davinci/sonata/dv_board.c u-boot.git/board/davinci/sonata/dv_board.c --- u-boot.git.orig/board/davinci/sonata/dv_board.c 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/sonata/dv_board.c 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,208 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Parts are shamelessly stolen from various TI sources, original copyright + * follows: + * ----------------------------------------------------------------- + * + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <i2c.h> +#include <asm/arch/hardware.h> +#include <asm/arch/emac_defs.h> + +#define MACH_TYPE_SONATA 1254 + +extern void i2c_init(int speed, int slaveaddr); +extern void timer_init(void); +extern int eth_hw_init(void); +extern phy_t phy; + + +/* Works on Always On power domain only (no PD argument) */ +void lpsc_on(unsigned int id) +{ + dv_reg_p mdstat, mdctl; + + if (id >= DAVINCI_LPSC_GEM) + return; /* Don't work on DSP Power Domain */ + + mdstat = REG_P(PSC_MDSTAT_BASE + (id * 4)); + mdctl = REG_P(PSC_MDCTL_BASE + (id * 4)); + + while (REG(PSC_PTSTAT) & 0x01) {;} + + if ((*mdstat & 0x1f) == 0x03) + return; /* Already on and enabled */ + + *mdctl |= 0x03; + + /* Special treatment for some modules as for sprue14 p.7.4.2 */ + if ( (id == DAVINCI_LPSC_VPSSSLV) || + (id == DAVINCI_LPSC_EMAC) || + (id == DAVINCI_LPSC_EMAC_WRAPPER) || + (id == DAVINCI_LPSC_MDIO) || + (id == DAVINCI_LPSC_USB) || + (id == DAVINCI_LPSC_ATA) || + (id == DAVINCI_LPSC_VLYNQ) || + (id == DAVINCI_LPSC_UHPI) || + (id == DAVINCI_LPSC_DDR_EMIF) || + (id == DAVINCI_LPSC_AEMIF) || + (id == DAVINCI_LPSC_MMC_SD) || + (id == DAVINCI_LPSC_MEMSTICK) || + (id == DAVINCI_LPSC_McBSP) || + (id == DAVINCI_LPSC_GPIO) + ) + *mdctl |= 0x200; + + REG(PSC_PTCMD) = 0x01; + + while (REG(PSC_PTSTAT) & 0x03) {;} + while ((*mdstat & 0x1f) != 0x03) {;} /* Probably an overkill... */ +} + +void dsp_on(void) +{ + int i; + + if (REG(PSC_PDSTAT1) & 0x1f) + return; /* Already on */ + + REG(PSC_GBLCTL) |= 0x01; + REG(PSC_PDCTL1) |= 0x01; + REG(PSC_PDCTL1) &= ~0x100; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) |= 0x03; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) &= 0xfffffeff; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) |= 0x03; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) &= 0xfffffeff; + REG(PSC_PTCMD) = 0x02; + + for (i = 0; i < 100; i++) { + if (REG(PSC_EPCPR) & 0x02) + break; + } + + REG(PSC_CHP_SHRTSW) = 0x01; + REG(PSC_PDCTL1) |= 0x100; + REG(PSC_EPCCR) = 0x02; + + for (i = 0; i < 100; i++) { + if (!(REG(PSC_PTSTAT) & 0x02)) + break; + } + + REG(PSC_GBLCTL) &= ~0x1f; +} + + +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + /* arch number of the board */ + gd->bd->bi_arch_number = MACH_TYPE_SONATA; + + /* address of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + /* Workaround for TMS320DM6446 errata 1.3.22 */ + REG(PSC_SILVER_BULLET) = 0; + + /* Power on required peripherals */ + lpsc_on(DAVINCI_LPSC_EMAC); + lpsc_on(DAVINCI_LPSC_EMAC_WRAPPER); + lpsc_on(DAVINCI_LPSC_MDIO); + lpsc_on(DAVINCI_LPSC_I2C); + lpsc_on(DAVINCI_LPSC_UART0); + lpsc_on(DAVINCI_LPSC_TIMER1); + lpsc_on(DAVINCI_LPSC_GPIO); + + /* Powerup the DSP */ + dsp_on(); + + /* Bringup UART0 out of reset */ + REG(UART0_PWREMU_MGMT) = 0x0000e003; + + /* Enable GIO3.3V cells used for EMAC */ + REG(VDD3P3V_PWDN) = 0; + + /* Enable UART0 MUX lines */ + REG(PINMUX1) |= 1; + + /* Enable EMAC and AEMIF pins */ + REG(PINMUX0) = 0x80000c1f; + + /* Enable I2C pin Mux */ + REG(PINMUX1) |= (1 << 7); + + /* Set the Bus Priority Register to appropriate value */ + REG(VBPR) = 0x20; + + timer_init(); + + return(0); +} + +int misc_init_r (void) +{ + u_int8_t tmp[20], buf[10]; + int i = 0; + int clk = 0; + + + clk = ((REG(PLL2_PLLM) + 1) * 27) / ((REG(PLL2_DIV2) & 0x1f) + 1); + + printf ("ARM Clock : %dMHz\n", ((REG(PLL1_PLLM) + 1) * 27 ) / 2); + printf ("DDR Clock : %dMHz\n", (clk / 2)); + + /* Set Ethernet MAC address from EEPROM */ + if (i2c_read(CFG_I2C_EEPROM_ADDR, 0x7f00, CFG_I2C_EEPROM_ADDR_LEN, buf, 6)) { + printf("\nEEPROM @ 0x%02x read FAILED!!!\n", CFG_I2C_EEPROM_ADDR); + } else { + tmp[0] = 0xff; + for (i = 0; i < 6; i++) + tmp[0] &= buf[i]; + + if ((tmp[0] != 0xff) && (getenv("ethaddr") == NULL)) { + sprintf((char *)&tmp[0], "%02hhx:%02hhx:%02hhx:%02hhx:%02hhx:%02hhx", + buf[0], buf[1], buf[2], buf[3], buf[4], buf[5]); + setenv("ethaddr", (char *)&tmp[0]); + } + } + + if (!eth_hw_init()) { + printf("ethernet init failed!\n"); + } else { + printf("ETH PHY : %s\n", phy.name); + } + + return(0); +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return(0); +} diff -purN u-boot.git.orig/board/davinci/sonata/Makefile u-boot.git/board/davinci/sonata/Makefile --- u-boot.git.orig/board/davinci/sonata/Makefile 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/sonata/Makefile 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,52 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := dv_board.o +SOBJS := board_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak *~ .depend + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff -purN u-boot.git.orig/board/davinci/sonata/u-boot.lds u-boot.git/board/davinci/sonata/u-boot.lds --- u-boot.git.orig/board/davinci/sonata/u-boot.lds 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/board/davinci/sonata/u-boot.lds 2007-08-07 10:15:34.000000000 -0700 @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + . = ALIGN(4); + .text : + { + cpu/arm926ejs/start.o (.text) + *(.text) + } + . = ALIGN(4); + .rodata : { *(.rodata) } + . = ALIGN(4); + .data : { *(.data) } + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +}
Acked-by: Dirk Behme dirk.behme@gmail.com
[...] cut to not exceed list limit of 40k.
Dirk
Dirk Behme
ksi@koi8.net
