[U-Boot] EHCI timed out on TD - token=0x80008d80 on U-Boot 2013.04
Hello All,
I am using U-Boot 2013.04. I have tried enabling the USB support at u-boot. Now i get the following log on successful detection of a USB device.
U-Boot > usb start (Re)start USB... USB0: USB EHCI 1.00 scanning bus 0 for devices... 2 USB Device(s) found USB1: USB EHCI 1.00 scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... EHCI timed out on TD - token=0x80008c80 EHCI timed out on TD - token=0x80008d80 EHCI timed out on TD - token=0x80008d80 EHCI timed out on TD - token=0x80008d80 EHCI timed out on TD - token=0x80008d80 EHCI timed out on TD - token=0x80008d80 error in inquiry 1 Storage Device(s) found scanning usb for ethernet devices... 0 Ethernet Device(s) found
Once this error occurs at next boot i am unable to detect the usb. What might be the problem? If there is solution as a patch would be helpful.
Regards, Manju
Manjunath
