[U-Boot] [PATCH] fastboot: Add USB cable detect check
Add a check for USB cable attached and only enter fastboot when a cable is attached.
Signed-off-by: Rob Herring robh@kernel.org --- common/cmd_fastboot.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/common/cmd_fastboot.c b/common/cmd_fastboot.c index b72f4f3..346ab80 100644 --- a/common/cmd_fastboot.c +++ b/common/cmd_fastboot.c @@ -20,6 +20,12 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) if (ret) return ret;
+ if (!g_dnl_board_usb_cable_connected()) { + puts("\rUSB cable not detected.\n" \ + "Command exit.\n"); + return CMD_RET_FAILURE; + } + while (1) { if (g_dnl_detach()) break;
Hi Rob,
- if (!g_dnl_board_usb_cable_connected()) {
"Command exit.\n");
- while (1) { if (g_dnl_detach()) break;
Reviewed-by: Lukasz Majewski l.majewski@samsung.com
"Command exit.\n");
(question: the leading "\r" ?!?!)
Reviewed-by: Steve Rae srae@broadcom.com
Thanks, Steve
"Command exit.\n");
Humm, good question. It's copy and paste from USB MS implementation.
Rob
Thanks, Steve
Hi Rob,
"Command exit.\n");
Rob
Thanks, Steve
Queued for u-boot-dfu branch.
Thanks for development and sorry for delay.
Lukasz Majewski
Rob Herring
Steve Rae
