[U-Boot-Users] [git patch] pci
Please pull from 'pci' branch of git.kernel.org:/pub/scm/boot/u-boot/u-boot.git
to receive the following updates:
CHANGELOG | 18 +++++++++++++++ drivers/pci.c | 1 drivers/pci_auto.c | 58 ++++++++++++++++++++++++++++++++++++++++--------- drivers/pci_indirect.c | 16 +++++++++++++ include/pci.h | 4 ++- 5 files changed, 86 insertions(+), 11 deletions(-)
Kumar Gala: Added support for PCI prefetchable region and BARs Report back PCI bus when doing table based device config Fixed PCI indirect config ops to handle multiple PCI controllers
diff --git a/CHANGELOG b/CHANGELOG index c1da98f..9ed9dff 100644 --- a/CHANGELOG +++ b/CHANGELOG @@ -2,6 +2,24 @@ Changes since U-Boot 1.1.4: ======================================================================
+* Fixed PCI indirect config ops to handle multiple PCI controllers + We need to adjust the bus number we are trying to access based + on which PCI controller its on + Patch by Kumar Gala 12 Jan 2006 + +* Report back PCI bus when doing table based device config + Patch by Kumar Gala 11 Jan 2006 + +* Added support for PCI prefetchable region and BARs + If a host controller sets up a region as prefetchable and + a device's BAR denotes it as prefetchable, allocate the + BAR into the prefetch region. + + If a BAR is prefetchable and no prefetchable region has + been setup by the controller we fall back to allocating + the BAR into the normally memory region. + Patch by Kumar Gala 11 Jan 2006 + * Add support for 28F256J3A flah (=> 64 MB) on PM520 board
* Fix compiler problem with at91rm9200dk board. diff --git a/drivers/pci.c b/drivers/pci.c index 5360030..3c24b99 100644 --- a/drivers/pci.c +++ b/drivers/pci.c @@ -459,6 +459,7 @@ int pci_hose_scan_bus(struct pci_control PCI_BUS(dev), PCI_DEV(dev), PCI_FUNC(dev)); if (cfg) { cfg->config_device(hose, dev, cfg); + sub_bus = max(sub_bus, hose->current_busno); #ifdef CONFIG_PCI_PNP } else { int n = pciauto_config_device(hose, dev); diff --git a/drivers/pci_auto.c b/drivers/pci_auto.c index 3302457..15f7432 100644 --- a/drivers/pci_auto.c +++ b/drivers/pci_auto.c @@ -77,6 +77,7 @@ int pciauto_region_allocate(struct pci_r void pciauto_setup_device(struct pci_controller *hose, pci_dev_t dev, int bars_num, struct pci_region *mem, + struct pci_region *prefetch, struct pci_region *io) { unsigned int bar_value, bar_response, bar_size; @@ -111,7 +112,10 @@ void pciauto_setup_device(struct pci_con found_mem64 = 1;
bar_size = ~(bar_response & PCI_BASE_ADDRESS_MEM_MASK) + 1; - bar_res = mem; + if (prefetch && (bar_response & PCI_BASE_ADDRESS_MEM_PREFETCH)) + bar_res = prefetch; + else + bar_res = mem;
DEBUGF("PCI Autoconfig: BAR %d, Mem, size=0x%x, ", bar_nr, bar_size); } @@ -148,6 +152,7 @@ static void pciauto_prescan_setup_bridge pci_dev_t dev, int sub_bus) { struct pci_region *pci_mem = hose->pci_mem; + struct pci_region *pci_prefetch = hose->pci_prefetch; struct pci_region *pci_io = hose->pci_io; unsigned int cmdstat;
@@ -169,6 +174,21 @@ static void pciauto_prescan_setup_bridge cmdstat |= PCI_COMMAND_MEMORY; }
+ if (pci_prefetch) { + /* Round memory allocator to 1MB boundary */ + pciauto_region_align(pci_prefetch, 0x100000); + + /* Set up memory and I/O filter limits, assume 32-bit I/O space */ + pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_BASE, + (pci_prefetch->bus_lower & 0xfff00000) >> 16); + + cmdstat |= PCI_COMMAND_MEMORY; + } else { + /* We don't support prefetchable memory for now, so disable */ + pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_BASE, 0x1000); + pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_LIMIT, 0x1000); + } + if (pci_io) { /* Round I/O allocator to 4KB boundary */ pciauto_region_align(pci_io, 0x1000); @@ -181,10 +201,6 @@ static void pciauto_prescan_setup_bridge cmdstat |= PCI_COMMAND_IO; }
- /* We don't support prefetchable memory for now, so disable */ - pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_BASE, 0x1000); - pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_LIMIT, 0x1000); - /* Enable memory and I/O accesses, enable bus master */ pci_hose_write_config_dword(hose, dev, PCI_COMMAND, cmdstat | PCI_COMMAND_MASTER); } @@ -193,6 +209,7 @@ static void pciauto_postscan_setup_bridg pci_dev_t dev, int sub_bus) { struct pci_region *pci_mem = hose->pci_mem; + struct pci_region *pci_prefetch = hose->pci_prefetch; struct pci_region *pci_io = hose->pci_io;
/* Configure bus number registers */ @@ -206,6 +223,14 @@ static void pciauto_postscan_setup_bridg (pci_mem->bus_lower-1) >> 16); }
+ if (pci_prefetch) { + /* Round memory allocator to 1MB boundary */ + pciauto_region_align(pci_prefetch, 0x100000); + + pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_LIMIT, + (pci_prefetch->bus_lower-1) >> 16); + } + if (pci_io) { /* Round I/O allocator to 4KB boundary */ pciauto_region_align(pci_io, 0x1000); @@ -239,6 +264,11 @@ void pciauto_config_init(struct pci_cont hose->pci_mem->size < hose->regions[i].size) hose->pci_mem = hose->regions + i; break; + case (PCI_REGION_MEM | PCI_REGION_PREFETCH): + if (!hose->pci_prefetch || + hose->pci_prefetch->size < hose->regions[i].size) + hose->pci_prefetch = hose->regions + i; + break; } }
@@ -251,6 +281,14 @@ void pciauto_config_init(struct pci_cont hose->pci_mem->bus_start + hose->pci_mem->size - 1); }
+ if (hose->pci_prefetch) { + pciauto_region_init(hose->pci_prefetch); + + DEBUGF("PCI Autoconfig: Prefetchable Memory region: [%lx-%lx]\n", + hose->pci_prefetch->bus_start, + hose->pci_prefetch->bus_start + hose->pci_prefetch->size - 1); + } + if (hose->pci_io) { pciauto_region_init(hose->pci_io);
@@ -275,7 +313,7 @@ int pciauto_config_device(struct pci_con switch(class) { case PCI_CLASS_BRIDGE_PCI: hose->current_busno++; - pciauto_setup_device(hose, dev, 2, hose->pci_mem, hose->pci_io); + pciauto_setup_device(hose, dev, 2, hose->pci_mem, hose->pci_prefetch, hose->pci_io);
DEBUGF("PCI Autoconfig: Found P2P bridge, device %d\n", PCI_DEV(dev));
@@ -301,12 +339,12 @@ int pciauto_config_device(struct pci_con return sub_bus; }
- pciauto_setup_device(hose, dev, 6, hose->pci_mem, hose->pci_io); + pciauto_setup_device(hose, dev, 6, hose->pci_mem, hose->pci_prefetch, hose->pci_io); break;
case PCI_CLASS_BRIDGE_CARDBUS: /* just do a minimal setup of the bridge, let the OS take care of the rest */ - pciauto_setup_device(hose, dev, 0, hose->pci_mem, hose->pci_io); + pciauto_setup_device(hose, dev, 0, hose->pci_mem, hose->pci_prefetch, hose->pci_io);
DEBUGF("PCI Autoconfig: Found P2CardBus bridge, device %d\n", PCI_DEV(dev));
@@ -328,11 +366,11 @@ int pciauto_config_device(struct pci_con * the PIMMR window to be allocated (BAR0 - 1MB size) */ DEBUGF("PCI Autoconfig: Broken bridge found, only minimal config\n"); - pciauto_setup_device(hose, dev, 0, hose->pci_mem, hose->pci_io); + pciauto_setup_device(hose, dev, 0, hose->pci_mem, hose->pci_prefetch, hose->pci_io); break; #endif default: - pciauto_setup_device(hose, dev, 6, hose->pci_mem, hose->pci_io); + pciauto_setup_device(hose, dev, 6, hose->pci_mem, hose->pci_prefetch, hose->pci_io); break; }
diff --git a/drivers/pci_indirect.c b/drivers/pci_indirect.c index e8f19f5..f0c4a1c 100644 --- a/drivers/pci_indirect.c +++ b/drivers/pci_indirect.c @@ -36,6 +36,10 @@ static int \ indirect_##rw##_config_##size(struct pci_controller *hose, \ pci_dev_t dev, int offset, type val) \ { \ + u32 b, d,f; \ + b = PCI_BUS(dev); d = PCI_DEV(dev); f = PCI_FUNC(dev); \ + b = b - hose->first_busno; \ + dev = PCI_BDF(b, d, f); \ out_le32(hose->cfg_addr, dev | (offset & 0xfc) | 0x80000000); \ sync(); \ cfg_##rw(val, hose->cfg_data + (offset & mask), type, op); \ @@ -47,6 +51,10 @@ static int indirect_##rw##_config_##size(struct pci_controller *hose, \ pci_dev_t dev, int offset, type val) \ { \ + u32 b, d,f; \ + b = PCI_BUS(dev); d = PCI_DEV(dev); f = PCI_FUNC(dev); \ + b = b - hose->first_busno; \ + dev = PCI_BDF(b, d, f); \ *(hose->cfg_addr) = dev | (offset & 0xfc) | 0x80000000; \ sync(); \ cfg_##rw(val, hose->cfg_data + (offset & mask), type, op); \ @@ -58,6 +66,10 @@ static int \ indirect_##rw##_config_##size(struct pci_controller *hose, \ pci_dev_t dev, int offset, type val) \ { \ + u32 b, d,f; \ + b = PCI_BUS(dev); d = PCI_DEV(dev); f = PCI_FUNC(dev); \ + b = b - hose->first_busno; \ + dev = PCI_BDF(b, d, f); \ if (PCI_BUS(dev) > 0) \ out_le32(hose->cfg_addr, dev | (offset & 0xfc) | 0x80000001); \ else \ @@ -71,6 +83,10 @@ static int \ indirect_##rw##_config_##size(struct pci_controller *hose, \ pci_dev_t dev, int offset, type val) \ { \ + u32 b, d,f; \ + b = PCI_BUS(dev); d = PCI_DEV(dev); f = PCI_FUNC(dev); \ + b = b - hose->first_busno; \ + dev = PCI_BDF(b, d, f); \ out_le32(hose->cfg_addr, dev | (offset & 0xfc) | 0x80000000); \ cfg_##rw(val, hose->cfg_data + (offset & mask), type, op); \ return 0; \ diff --git a/include/pci.h b/include/pci.h index 8f19997..f78a769 100644 --- a/include/pci.h +++ b/include/pci.h @@ -309,6 +309,7 @@ struct pci_region { #define PCI_REGION_MEM 0x00000000 /* PCI memory space */ #define PCI_REGION_IO 0x00000001 /* PCI IO space */ #define PCI_REGION_TYPE 0x00000001 +#define PCI_REGION_PREFETCH 0x00000008 /* prefetchable PCI memory */
#define PCI_REGION_MEMORY 0x00000100 /* System memory */ #define PCI_REGION_RO 0x00000200 /* Read-only memory */ @@ -386,7 +387,7 @@ struct pci_controller { int (*write_dword)(struct pci_controller*, pci_dev_t, int where, u32);
/* Used by auto config */ - struct pci_region *pci_mem, *pci_io; + struct pci_region *pci_mem, *pci_io, *pci_prefetch;
/* Used by ppc405 autoconfig*/ struct pci_region *pci_fb; @@ -472,6 +473,7 @@ extern int pciauto_region_allocate(struc extern void pciauto_setup_device(struct pci_controller *hose, pci_dev_t dev, int bars_num, struct pci_region *mem, + struct pci_region *prefetch, struct pci_region *io); int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev);
In message Pine.LNX.4.44.0601231745000.21555-100000@gate.crashing.org you wrote:
Done. Thanks.
Kumar Gala
