[U-Boot] [PATCH 5/5] SECURE_BOOT : enable esbc_validate command for arm platform.
Signed-off-by: Gaurav Rana gaurav.rana@freescale.com --- arch/arm/include/asm/arch-ls102xa/config.h | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 7915518..5d81280 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -27,6 +27,8 @@ #define CONFIG_SYS_FSL_SCFG_ADDR (CONFIG_SYS_IMMR + 0x00570000) #define CONFIG_SYS_FSL_SEC_ADDR (CONFIG_SYS_IMMR + 0x700000) #define CONFIG_SYS_FSL_JR0_ADDR (CONFIG_SYS_IMMR + 0x710000) +#define CONFIG_SYS_SEC_MON_ADDR (CONFIG_SYS_IMMR + 0x00e90000) +#define CONFIG_SYS_SFP_ADDR (CONFIG_SYS_IMMR + 0x00e80200) #define CONFIG_SYS_FSL_SERDES_ADDR (CONFIG_SYS_IMMR + 0x00ea0000) #define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) #define CONFIG_SYS_FSL_LS1_CLK_ADDR (CONFIG_SYS_IMMR + 0x00ee1000) @@ -80,7 +82,25 @@ #define CONFIG_SYS_FSL_DSPI_BE #define CONFIG_SYS_FSL_QSPI_BE #define CONFIG_SYS_FSL_DCU_BE +#define CONFIG_SYS_FSL_SEC_MON_LE #define CONFIG_SYS_FSL_SEC_LE +#define CONFIG_SYS_FSL_SFP_VER_3_2 +#define CONFIG_SYS_FSL_SFP_BE +#define CONFIG_SYS_FSL_SRK_LE +#define CONFIG_KEY_REVOCATION +#define CONFIG_FSL_ISBC_KEY_EXT + +#ifdef CONFIG_SECURE_BOOT +#define CONFIG_CMD_ESBC_VALIDATE +#define CONFIG_FSL_SEC_MON +#define CONFIG_SHA_PROG_HW_ACCEL +#define CONFIG_DM +#define CONFIG_RSA +#define CONFIG_RSA_FREESCALE_EXP +#ifndef CONFIG_FSL_CAAM +#define CONFIG_FSL_CAAM +#endif +#endif
#define DCU_LAYER_MAX_NUM 16
Gaurav Rana
