[U-Boot] [PATCH] video: mxc_ipuv3_fb: stash frame buffer pointer in global data.
This patch updates the i.MX video driver to store the frame-buffer address in the fb_base field of the global data structure *gd.
By doing this, you can find the frame buffer address using the 'bdinfo' command:
U-Boot > bdinfo arch_number = 0x00000EB9 ... FB base = 0x4F35F1C0
This is very useful when debugging display connections.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- drivers/video/mxc_ipuv3_fb.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/mxc_ipuv3_fb.c index 3e21fb2..08a94c2 100644 --- a/drivers/video/mxc_ipuv3_fb.c +++ b/drivers/video/mxc_ipuv3_fb.c @@ -10,9 +10,9 @@ * * SPDX-License-Identifier: GPL-2.0+ */ - #include <common.h> #include <asm/errno.h> +#include <asm/global_data.h> #include <linux/string.h> #include <linux/list.h> #include <linux/fb.h> @@ -24,6 +24,8 @@ #include "mxcfb.h" #include "ipu_regs.h"
+DECLARE_GLOBAL_DATA_PTR; + static int mxcfb_map_video_memory(struct fb_info *fbi); static int mxcfb_unmap_video_memory(struct fb_info *fbi);
@@ -415,6 +417,7 @@ static int mxcfb_map_video_memory(struct fb_info *fbi)
fbi->screen_size = fbi->fix.smem_len;
+ gd->fb_base = fbi->fix.smem_start; /* Clear the screen */ memset((char *)fbi->screen_base, 0, fbi->fix.smem_len);
Hello Eric,
On Tue, Apr 29, 2014 at 6:13 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
Don't remove lines.
I would add a new line after this. It looks ugly too close of the comment and memset.
Apart from that, please add my Acked-by.
Hi Otavio,
On 04/29/2014 02:26 PM, Otavio Salvador wrote:
Hello Eric,
Don't remove lines.
Oops. That's where my "#define DEBUG" lived...
- static int mxcfb_map_video_memory(struct fb_info *fbi); static int mxcfb_unmap_video_memory(struct fb_info *fbi);
This is the part that keeps me from thinking I can ever get a patch V1 right...
Will do in V2.
Regards,
Eric
Please add proper tags, otherwise patchwork cannot pick this automatically and you are only adding work onto others' shoulders .
Best regards, Marek Vasut
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Acked-by: Otavio Salvador otavio@ossystems.com.br --- drivers/video/mxc_ipuv3_fb.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/mxc_ipuv3_fb.c index 3e21fb2..f75d770 100644 --- a/drivers/video/mxc_ipuv3_fb.c +++ b/drivers/video/mxc_ipuv3_fb.c @@ -13,6 +13,7 @@
#include <common.h> #include <asm/errno.h> +#include <asm/global_data.h> #include <linux/string.h> #include <linux/list.h> #include <linux/fb.h> @@ -24,6 +25,8 @@ #include "mxcfb.h" #include "ipu_regs.h"
@@ -415,6 +418,8 @@ static int mxcfb_map_video_memory(struct fb_info *fbi)
+ gd->fb_base = fbi->fix.smem_start; + /* Clear the screen */ memset((char *)fbi->screen_base, 0, fbi->fix.smem_len);
Acked-by: Marek Vasut marex@denx.de
On Tue, 29 Apr 2014 14:37:56 -0700 Eric Nelson eric.nelson@boundarydevices.com wrote:
applied to u-boot-video/master. Thanks!
Anatolij
Anatolij Gustschin
Eric Nelson
Otavio Salvador
