[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 595af9db2422fa5ae734cfe615415b17a5098f34:
Merge branch 'master' of git://www.denx.de/git/u-boot-imx (2016-02-21 07:56:16 -0500)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to a08b1921b4a477abe1ac4482fae9ec4bcb3cd27e:
armv7: ls102xa: Move smmu and stream id initialization into the common soc code (2016-02-24 08:51:15 -0800)
---------------------------------------------------------------- Alison Wang (2): arm: ls1021a: Add QSPI or IFC support in SD boot for LS1021AQDS board armv7: ls102xa: Move smmu and stream id initialization into the common soc code
Aneesh Bansal (1): powerpc/SECURE_BOOT: Add PAMU driver
Ashish Kumar (1): armv8: ls2080a: Increase default hugepage count
Mingkai Hu (1): armv8/ls1043a: Implement workaround for erratum A009660
Prabhakar Kushwaha (2): armv8: ls2080: Add mcinitcmd env variable in default env armv8: ls2080: Update bootcmd env variable
Qianyu Gong (5): qe: move drivers/qe/qe.h to include/fsl_qe.h fm: fdt: Move fman ucode fixup to driver code driver/fm: fdt.c: fix fdt_fixup_fman_firmware() to support ARM platforms armv8/fsl-layerscape: fdt: add fixup for Fman ucode armv8/ls1043aqds: Add USB support for ls1043aqds
Ruchika Gupta (1): drivers/crypto/fsl : Allocate output ring with size aligned to CACHELNE SIZE
Shengzhou Liu (1): armv8/ls1043a: enable workaround for errarum A009942
York Sun (2): arm: ls1021aqds: Convert to driver model and enable serial support arm: ls1021aqds: Enable driver model lpuart serial driver
Zhao Qiang (4): driver: qe: Mask the codes not used for micro QE board: ls1043ardb: Add micro QE support for ls1043ardb board: ls1043rdb: Move USB muxing config to config_board_mux board: ls1043ardb: Modify pin-muxing code for USB and QE-HDLC
arch/arm/cpu/armv7/ls102xa/soc.c | 48 +++ arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 7 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 19 + arch/arm/dts/Makefile | 3 +- arch/arm/dts/ls1021a-qds-duart.dts | 16 + arch/arm/dts/ls1021a-qds-lpuart.dts | 16 + arch/arm/dts/{ls1021a-qds.dts => ls1021a-qds.dtsi} | 3 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 2 + arch/arm/include/asm/arch-ls102xa/ls102xa_soc.h | 2 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 20 +- arch/powerpc/cpu/mpc85xx/fdt.c | 125 +----- arch/powerpc/cpu/mpc8xxx/Makefile | 1 + arch/powerpc/cpu/mpc8xxx/fsl_pamu.c | 433 ++++++++++++++++++++ arch/powerpc/cpu/mpc8xxx/pamu_table.c | 55 +++ arch/powerpc/include/asm/fsl_pamu.h | 169 ++++++++ arch/powerpc/include/asm/immap_85xx.h | 19 +- board/freescale/common/arm_sleep.c | 2 +- board/freescale/common/mpc85xx_sleep.c | 2 +- board/freescale/ls1021aqds/MAINTAINERS | 3 +- board/freescale/ls1021aqds/ls1021aqds.c | 48 +-- .../{ls102xa_rcw_sd.cfg => ls102xa_rcw_sd_ifc.cfg} | 0 board/freescale/ls1021aqds/ls102xa_rcw_sd_qspi.cfg | 14 + board/freescale/ls1021atwr/ls1021atwr.c | 45 +- board/freescale/ls1043aqds/ls1043aqds.c | 15 + board/freescale/ls1043ardb/ls1043ardb.c | 71 +++- configs/ls1021aqds_ddr4_nor_defconfig | 4 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 4 + configs/ls1021aqds_nor_defconfig | 4 + configs/ls1021aqds_nor_lpuart_defconfig | 4 + configs/ls1021aqds_qspi_defconfig | 2 +- ...d_defconfig => ls1021aqds_sdcard_ifc_defconfig} | 3 + configs/ls1021aqds_sdcard_qspi_defconfig | 16 + drivers/crypto/fsl/jr.c | 51 ++- drivers/crypto/fsl/jr.h | 2 + drivers/net/fm/Makefile | 1 + drivers/net/fm/fdt.c | 129 ++++++ drivers/net/fm/fm.c | 2 +- drivers/qe/fdt.c | 2 +- drivers/qe/qe.c | 14 +- drivers/qe/uccf.c | 2 +- drivers/qe/uccf.h | 2 +- drivers/qe/uec.c | 2 +- drivers/qe/uec.h | 2 +- drivers/qe/uec_phy.c | 2 +- include/configs/ls1021aqds.h | 23 +- include/configs/ls1043aqds.h | 13 + include/configs/ls1043ardb.h | 7 + include/configs/ls2080a_common.h | 11 +- include/configs/ls2080aqds.h | 4 +- include/configs/ls2080ardb.h | 6 +- include/fsl_fman.h | 1 + drivers/qe/qe.h => include/fsl_qe.h | 0 52 files changed, 1177 insertions(+), 274 deletions(-) create mode 100644 arch/arm/dts/ls1021a-qds-duart.dts create mode 100644 arch/arm/dts/ls1021a-qds-lpuart.dts rename arch/arm/dts/{ls1021a-qds.dts => ls1021a-qds.dtsi} (98%) create mode 100644 arch/powerpc/cpu/mpc8xxx/fsl_pamu.c create mode 100644 arch/powerpc/cpu/mpc8xxx/pamu_table.c create mode 100644 arch/powerpc/include/asm/fsl_pamu.h rename board/freescale/ls1021aqds/{ls102xa_rcw_sd.cfg => ls102xa_rcw_sd_ifc.cfg} (100%) create mode 100644 board/freescale/ls1021aqds/ls102xa_rcw_sd_qspi.cfg rename configs/{ls1021aqds_sdcard_defconfig => ls1021aqds_sdcard_ifc_defconfig} (71%) create mode 100644 configs/ls1021aqds_sdcard_qspi_defconfig create mode 100644 drivers/net/fm/fdt.c rename drivers/qe/qe.h => include/fsl_qe.h (100%)
Thanks.
York
On Wed, Feb 24, 2016 at 05:02:52PM +0000, york sun wrote:
Tom,
york sun
