[U-Boot] [PATCH v2] am33xx: add SSC enable macro
Signed-off-by: Yegor Yefremov yegorslists@googlemail.com --- Changes: v2: use CM_CLKMODE_DPLL_SSC_EN_MASK in board file of Siemens device
arch/arm/include/asm/arch-am33xx/clock.h | 2 ++ board/siemens/rut/board.c | 2 +- 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-am33xx/clock.h b/arch/arm/include/asm/arch-am33xx/clock.h index 7637457..f00fad3 100644 --- a/arch/arm/include/asm/arch-am33xx/clock.h +++ b/arch/arm/include/asm/arch-am33xx/clock.h @@ -42,6 +42,8 @@ #define MODULE_CLKCTRL_IDLEST_DISABLED 3
/* CM_CLKMODE_DPLL */ +#define CM_CLKMODE_DPLL_SSC_EN_SHIFT 12 +#define CM_CLKMODE_DPLL_SSC_EN_MASK (1 << 12) #define CM_CLKMODE_DPLL_REGM4XEN_SHIFT 11 #define CM_CLKMODE_DPLL_REGM4XEN_MASK (1 << 11) #define CM_CLKMODE_DPLL_LPMODE_EN_SHIFT 10 diff --git a/board/siemens/rut/board.c b/board/siemens/rut/board.c index e0ada3f..1752df2 100644 --- a/board/siemens/rut/board.c +++ b/board/siemens/rut/board.c @@ -400,7 +400,7 @@ static int conf_disp_pll(int m, int n) #if defined(DISPL_PLL_SPREAD_SPECTRUM) writel(0x64, &cmwkup->resv6[3]); /* 0x50 */ writel(0x800, &cmwkup->resv6[2]); /* 0x4c */ - writel(readl(&cmwkup->clkmoddplldisp) | (1 << 12), + writel(readl(&cmwkup->clkmoddplldisp) | CM_CLKMODE_DPLL_SSC_EN_MASK, &cmwkup->clkmoddplldisp); /* 0x98 */ #endif return 0;
Applied to u-boot-ti/master, thanks!
Yegor Yefremov
