[U-Boot] [PATCH] S5P: mmc: Resolved interrupt error during mmc_init
Blocksize was hardcoded to 512 bytes. But the blocksize varies depeding on various mmc subsystem commands (between 8 and 512). This hardcoding was resulting in interrupt error during data transfer.
It is now calculated based upon the request sent by mmc subsystem.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- drivers/mmc/s5p_mmc.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/mmc/s5p_mmc.c b/drivers/mmc/s5p_mmc.c index 195b5be..0323800 100644 --- a/drivers/mmc/s5p_mmc.c +++ b/drivers/mmc/s5p_mmc.c @@ -51,7 +51,7 @@ static void mmc_prepare_data(struct mmc_host *host, struct mmc_data *data) writeb(ctrl, &host->reg->hostctl);
/* We do not handle DMA boundaries, so set it to max (512 KiB) */ - writew((7 << 12) | (512 << 0), &host->reg->blksize); + writew((7 << 12) | (data->blocksize & 0xFFF), &host->reg->blksize); writew(data->blocks, &host->reg->blkcnt); }
Dear Chander Kashyap,
- writew((7 << 12) | (data->blocksize & 0xFFF), &host->reg->blksize);
-- 1.7.1
applied to u-boot-samsung.
Thanks Minkyu Kang
Hi Minkyu,
-- 1.7.1
I have sent some patches about mmc and reviewed one, can you please tell me what to do mainline them?
11 mar : [PATCH 1/3][v3] mmc: checking status after commands with R1b response --> it has one Tested-by
[RFC 2/3][v3] mmc: SEND_OP_COND considers card capabilities (voltage) --> it has one Tested-by [PATCH 3/3][v3] mmc: trace added --> useful for getting information
23 mar : [U-Boot] [PATCH] MMC may wrongly regconize 2GB eMMC as high capacity --> I have reviewed and proposed a different, I think better and simpler, way. There is a curious dependency between capacity and high_capacity variables.
Regards, Raffaele
Dear Raffaele Recalcati,
On 3 April 2011 13:39, Raffaele Recalcati lamiaposta71@gmail.com wrote:
Hi Minkyu,
I'm not a maintainer of mmc. Please ask to Andy Fleming.
Andy, could you please check Raffaele's patches?
Thanks Minkyu Kang.
Hi Andy,
Hi Minkyu,
Thanks Minkyu Kang. -- from. prom. www.promsoft.net
can you please take a look at these patches ?
Regards, Raffaele
Chander Kashyap
Minkyu Kang
Raffaele Recalcati
