[PATCH] Makefile: Do not call useless command 'true'
Macro 'cmd_objcopy_uboot' currently does not work with passed empty command expanded from 'cmd_static_rela' and therefore dummy command 'true' is set in 'cmd_static_rela' to workaround this issue.
Eliminate it now by fixing 'cmd_objcopy_uboot' macro to work also with empty 'cmd_static_rela' macro and remove useless invocation of command 'true'.
Signed-off-by: Pali Rohár pali@kernel.org --- Makefile | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index b90fe8b865..aeb2c17a9b 100644 --- a/Makefile +++ b/Makefile @@ -885,7 +885,7 @@ cmd_static_rela = \ tools/relocate-rela $(3) $(4) $$start $$end else quiet_cmd_static_rela = -cmd_static_rela = true +cmd_static_rela = endif
# Always append INPUTS so that arch config.mk's can add custom ones @@ -1312,7 +1312,11 @@ endif shell_cmd = { $(call echo-cmd,$(1)) $(cmd_$(1)); }
quiet_cmd_objcopy_uboot = OBJCOPY $@ +ifdef cmd_static_rela cmd_objcopy_uboot = $(cmd_objcopy) && $(call shell_cmd,static_rela,$<,$@,$(CONFIG_SYS_TEXT_BASE)) || { rm -f $@; false; } +else +cmd_objcopy_uboot = $(cmd_objcopy) +endif
u-boot-nodtb.bin: u-boot FORCE $(call if_changed,objcopy_uboot)
Hello! Could you please review this patch?
u-boot-nodtb.bin: u-boot FORCE $(call if_changed,objcopy_uboot) -- 2.20.1
Hi Pali,
I don't know much about that and your patch looks reasonable, but what is the motivation? Is it a code clean-up or a bug?
On Tuesday 19 January 2021 11:06:12 Simon Glass wrote:
Hi Pali,
Hello! I do not know about any bugs here, so it is just code clean-up.
Hi Pali,
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Simon Glass sjg@chromium.org
Pali Rohár
