[U-Boot] TI:OMAP: [PATCH 5/7] Add DSS driver for OMAP3
From 968d36271671359fdd724c5410c5264408d9f612 Mon Sep 17 00:00:00 2001
From: Syed Mohammed Khasim khasim@ti.com Date: Tue, 12 Jan 2010 23:57:28 +0530 Subject: [PATCH] Add DSS driver for OMAP3
Supports dynamic panel configuration Supports dynamic tv standard selection Adds support for DSS register access through generic APIs
Incorporated DSS register access using structures.
Previous discussions are here http://www.mail-archive.com/u-boot@lists.denx.de/msg27150.html
Signed-off-by: Syed Mohammed Khasim khasim@ti.com --- drivers/video/Makefile | 1 + drivers/video/omap3_dss.c | 130 ++++++++++++++++++++++++++++ include/asm-arm/arch-omap3/dss.h | 173 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 304 insertions(+), 0 deletions(-) create mode 100644 drivers/video/omap3_dss.c create mode 100644 include/asm-arm/arch-omap3/dss.h
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index bb6b5a0..cb15dc2 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -37,6 +37,7 @@ COBJS-$(CONFIG_SED156X) += sed156x.o COBJS-$(CONFIG_VIDEO_SM501) += sm501.o COBJS-$(CONFIG_VIDEO_SMI_LYNXEM) += smiLynxEM.o COBJS-$(CONFIG_VIDEO_VCXK) += bus_vcxk.o +COBJS-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o COBJS-y += videomodes.o
COBJS := $(COBJS-y) diff --git a/drivers/video/omap3_dss.c b/drivers/video/omap3_dss.c new file mode 100644 index 0000000..69c705a --- /dev/null +++ b/drivers/video/omap3_dss.c @@ -0,0 +1,130 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Syed Mohammed Khasim khasim@ti.com + * + * Referred to Linux DSS driver files for OMAP3 + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation's version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/dss.h> + +/* + * Configure VENC for a given Mode (NTSC / PAL) + */ +void omap3_dss_venc_config(const struct venc_regs *venc_cfg, + u32 height, u32 width) +{ + struct venc_regs *venc = (struct venc_regs *) OMAP3_VENC_BASE; + struct dss_regs *dss = (struct dss_regs *) OMAP3_DSS_BASE; + struct dispc_regs *dispc = (struct dispc_regs *) OMAP3_DISPC_BASE; + + writel(venc_cfg->status, &venc->status); + writel(venc_cfg->f_control, &venc->f_control); + writel(venc_cfg->vidout_ctrl, &venc->vidout_ctrl); + writel(venc_cfg->sync_ctrl, &venc->sync_ctrl); + writel(venc_cfg->llen, &venc->llen); + writel(venc_cfg->flens, &venc->flens); + writel(venc_cfg->hfltr_ctrl, &venc->hfltr_ctrl); + writel(venc_cfg->cc_carr_wss_carr, &venc->cc_carr_wss_carr); + writel(venc_cfg->c_phase, &venc->c_phase); + writel(venc_cfg->gain_u, &venc->gain_u); + writel(venc_cfg->gain_v, &venc->gain_v); + writel(venc_cfg->gain_y, &venc->gain_y); + writel(venc_cfg->black_level, &venc->black_level); + writel(venc_cfg->blank_level, &venc->blank_level); + writel(venc_cfg->x_color, &venc->x_color); + writel(venc_cfg->m_control, &venc->m_control); + writel(venc_cfg->bstamp_wss_data, &venc->bstamp_wss_data); + writel(venc_cfg->s_carr, &venc->s_carr); + writel(venc_cfg->line21, &venc->line21); + writel(venc_cfg->ln_sel, &venc->ln_sel); + writel(venc_cfg->l21__wc_ctl, &venc->l21__wc_ctl); + writel(venc_cfg->htrigger_vtrigger, &venc->htrigger_vtrigger); + writel(venc_cfg->savid__eavid, &venc->savid__eavid); + writel(venc_cfg->flen__fal, &venc->flen__fal); + writel(venc_cfg->lal__phase_reset, &venc->lal__phase_reset); + writel(venc_cfg->hs_int_start_stop_x, + &venc->hs_int_start_stop_x); + writel(venc_cfg->hs_ext_start_stop_x, + &venc->hs_ext_start_stop_x); + writel(venc_cfg->vs_int_start_x, &venc->vs_int_start_x); + writel(venc_cfg->vs_int_stop_x__vs_int_start_y, + &venc->vs_int_stop_x__vs_int_start_y); + writel(venc_cfg->vs_int_stop_y__vs_ext_start_x, + &venc->vs_int_stop_y__vs_ext_start_x); + writel(venc_cfg->vs_ext_stop_x__vs_ext_start_y, + &venc->vs_ext_stop_x__vs_ext_start_y); + writel(venc_cfg->vs_ext_stop_y, &venc->vs_ext_stop_y); + writel(venc_cfg->avid_start_stop_x, &venc->avid_start_stop_x); + writel(venc_cfg->avid_start_stop_y, &venc->avid_start_stop_y); + writel(venc_cfg->fid_int_start_x__fid_int_start_y, + &venc->fid_int_start_x__fid_int_start_y); + writel(venc_cfg->fid_int_offset_y__fid_ext_start_x, + &venc->fid_int_offset_y__fid_ext_start_x); + writel(venc_cfg->fid_ext_start_y__fid_ext_offset_y, + &venc->fid_ext_start_y__fid_ext_offset_y); + writel(venc_cfg->tvdetgp_int_start_stop_x, + &venc->tvdetgp_int_start_stop_x); + writel(venc_cfg->tvdetgp_int_start_stop_y, + &venc->tvdetgp_int_start_stop_y); + writel(venc_cfg->gen_ctrl, &venc->gen_ctrl); + writel(venc_cfg->output_control, &venc->output_control); + writel(venc_cfg->dac_b__dac_c, &venc->dac_b__dac_c); + + /* Configure DSS for VENC Settings */ + writel(VENC_DSS_CONFIG, &dss->control); + + /* Configure height and width for Digital out */ + writel(((height << DIG_LPP_SHIFT) | width), &dispc->size_dig); +} + +/* + * Configure Panel Specific Parameters + */ +void omap3_dss_panel_config(const struct panel_config *panel_cfg) +{ + struct dispc_regs *dispc = (struct dispc_regs *) OMAP3_DISPC_BASE; + + writel(panel_cfg->timing_h, &dispc->timing_h); + writel(panel_cfg->timing_v, &dispc->timing_v); + writel(panel_cfg->pol_freq, &dispc->pol_freq); + writel(panel_cfg->divisor, &dispc->divisor); + writel(panel_cfg->lcd_size, &dispc->size_lcd); + writel((panel_cfg->load_mode << FRAME_MODE_SHIFT), &dispc->config); + writel(((panel_cfg->panel_type << TFTSTN_SHIFT) | + (panel_cfg->data_lines << DATALINES_SHIFT)), &dispc->control); + writel(panel_cfg->panel_color, &dispc->default_color0); +} + +/* + * Enable LCD and DIGITAL OUT in DSS + */ +void omap3_dss_enable(void) +{ + struct dispc_regs *dispc = (struct dispc_regs *) OMAP3_DISPC_BASE; + u32 l = 0; + + l = readl(&dispc->control); + l |= DISPC_ENABLE; + writel(l, &dispc->control); +} diff --git a/include/asm-arm/arch-omap3/dss.h b/include/asm-arm/arch-omap3/dss.h new file mode 100644 index 0000000..e5e3b0d --- /dev/null +++ b/include/asm-arm/arch-omap3/dss.h @@ -0,0 +1,173 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Syed Mohammed Khasim khasim@ti.com + * + * Referred to Linux DSS driver files for OMAP3 + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation's version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef DSS_H +#define DSS_H + +/* + * DSS Base Registers + */ +#define OMAP3_DSS_BASE 0x48050040 +#define OMAP3_DISPC_BASE 0x48050440 +#define OMAP3_VENC_BASE 0x48050C00 + +/* DSS Registers */ +struct dss_regs { + u32 control; /* 0x40 */ + u32 sdi_control; /* 0x44 */ + u32 pll_control; /* 0x48 */ +}; + +/* DISPC Registers */ +struct dispc_regs { + u32 control; /* 0x40 */ + u32 config; /* 0x44 */ + u32 reserve_2; /* 0x48 */ + u32 default_color0; /* 0x4C */ + u32 default_color1; /* 0x50 */ + u32 trans_color0; /* 0x54 */ + u32 trans_color1; /* 0x58 */ + u32 line_status; /* 0x5C */ + u32 line_number; /* 0x60 */ + u32 timing_h; /* 0x64 */ + u32 timing_v; /* 0x68 */ + u32 pol_freq; /* 0x6C */ + u32 divisor; /* 0x70 */ + u32 global_alpha; /* 0x74 */ + u32 size_dig; /* 0x78 */ + u32 size_lcd; /* 0x7C */ +}; + +/* VENC Registers */ +struct venc_regs { + u32 rev_id; /* 0x00 */ + u32 status; /* 0x04 */ + u32 f_control; /* 0x08 */ + u32 reserve_1; /* 0x0C */ + u32 vidout_ctrl; /* 0x10 */ + u32 sync_ctrl; /* 0x14 */ + u32 reserve_2; /* 0x18 */ + u32 llen; /* 0x1C */ + u32 flens; /* 0x20 */ + u32 hfltr_ctrl; /* 0x24 */ + u32 cc_carr_wss_carr; /* 0x28 */ + u32 c_phase; /* 0x2C */ + u32 gain_u; /* 0x30 */ + u32 gain_v; /* 0x34 */ + u32 gain_y; /* 0x38 */ + u32 black_level; /* 0x3C */ + u32 blank_level; /* 0x40 */ + u32 x_color; /* 0x44 */ + u32 m_control; /* 0x48 */ + u32 bstamp_wss_data; /* 0x4C */ + u32 s_carr; /* 0x50 */ + u32 line21; /* 0x54 */ + u32 ln_sel; /* 0x58 */ + u32 l21__wc_ctl; /* 0x5C */ + u32 htrigger_vtrigger; /* 0x60 */ + u32 savid__eavid; /* 0x64 */ + u32 flen__fal; /* 0x68 */ + u32 lal__phase_reset; /* 0x6C */ + u32 hs_int_start_stop_x; /* 0x70 */ + u32 hs_ext_start_stop_x; /* 0x74 */ + u32 vs_int_start_x; /* 0x78 */ + u32 vs_int_stop_x__vs_int_start_y; /* 0x7C */ + u32 vs_int_stop_y__vs_ext_start_x; /* 0x80 */ + u32 vs_ext_stop_x__vs_ext_start_y; /* 0x84 */ + u32 vs_ext_stop_y; /* 0x88 */ + u32 reserve_3; /* 0x8C */ + u32 avid_start_stop_x; /* 0x90 */ + u32 avid_start_stop_y; /* 0x94 */ + u32 reserve_4; /* 0x98 */ + u32 reserve_5; /* 0x9C */ + u32 fid_int_start_x__fid_int_start_y; /* 0xA0 */ + u32 fid_int_offset_y__fid_ext_start_x; /* 0xA4 */ + u32 fid_ext_start_y__fid_ext_offset_y; /* 0xA8 */ + u32 reserve_6; /* 0xAC */ + u32 tvdetgp_int_start_stop_x; /* 0xB0 */ + u32 tvdetgp_int_start_stop_y; /* 0xB4 */ + u32 gen_ctrl; /* 0xB8 */ + u32 reserve_7; /* 0xBC */ + u32 reserve_8; /* 0xC0 */ + u32 output_control; /* 0xC4 */ + u32 dac_b__dac_c; /* 0xC8 */ + u32 height_width; /* 0xCC */ +}; + +/* Few Register Offsets */ +#define FRAME_MODE_SHIFT 1 +#define TFTSTN_SHIFT 3 +#define DATALINES_SHIFT 8 + +/* Enabling Display controller */ +#define LCD_ENABLE 1 +#define DIG_ENABLE (1 << 1) +#define GO_LCD (1 << 5) +#define GO_DIG (1 << 6) +#define GP_OUT0 (1 << 15) +#define GP_OUT1 (1 << 16) + +#define DISPC_ENABLE (LCD_ENABLE | \ + DIG_ENABLE | \ + GO_LCD | \ + GO_DIG | \ + GP_OUT0| \ + GP_OUT1) + +/* Configure VENC DSS Params */ +#define VENC_CLK_ENABLE (1 << 3) +#define DAC_DEMEN (1 << 4) +#define DAC_POWERDN (1 << 5) +#define VENC_OUT_SEL (1 << 6) +#define DIG_LPP_SHIFT 16 +#define VENC_DSS_CONFIG (VENC_CLK_ENABLE | \ + DAC_DEMEN | \ + DAC_POWERDN | \ + VENC_OUT_SEL) +/* + * Panel Configuration + */ +struct panel_config { + u32 timing_h; + u32 timing_v; + u32 pol_freq; + u32 divisor; + u32 lcd_size; + u32 panel_type; + u32 data_lines; + u32 load_mode; + u32 panel_color; +}; + +/* + * Generic DSS Functions + */ +void omap3_dss_venc_config(const struct venc_regs *venc_cfg, + u32 height, u32 width); +void omap3_dss_panel_config(const struct panel_config *panel_cfg); +void omap3_dss_enable(void); + +#endif /* DSS_H */
Khasim Syed Mohammed
