[PATCH] include: configs: am64x_evm: Change to using .env
Move to using .env file for setting up environment variables for am65x.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- board/ti/am64x/am64x.env | 63 +++++++++++++++++++++++++++ include/configs/am64x_evm.h | 85 ------------------------------------- 2 files changed, 63 insertions(+), 85 deletions(-) create mode 100644 board/ti/am64x/am64x.env
diff --git a/board/ti/am64x/am64x.env b/board/ti/am64x/am64x.env new file mode 100644 index 0000000000..c3960be38e --- /dev/null +++ b/board/ti/am64x/am64x.env @@ -0,0 +1,63 @@ +#include <environment/ti/ti_armv7_common.env> +#include <environment/ti/mmc.env> +#include <environment/ti/k3_dfu.env> + +findfdt= + if test $board_name = am64x_gpevm; then + setenv name_fdt k3-am642-evm.dtb; fi; + if test $board_name = am64x_skevm; then + setenv name_fdt k3-am642-sk.dtb; fi; + if test $name_fdt = undefined; then + echo WARNING: Could not determine device tree to use; fi; +name_kern=Image +console=ttyS2,115200n8 +args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000 ${mtdparts} +run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr} + +boot=mmc +mmcdev=1 +bootpart=1:2 +bootdir=/boot +rd_spec=- +init_mmc=run args_all args_mmc +get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt} +get_overlay_mmc= + fdt address ${fdtaddr}; + fdt resize 0x100000; + for overlay in $name_overlays; + do; + load mmc ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && + fdt apply ${dtboaddr}; + done; +get_kern_mmc=load mmc ${bootpart} ${loadaddr} + ${bootdir}/${name_kern} +get_fit_mmc=load mmc ${bootpart} ${addr_fit} + ${bootdir}/${name_fit} +partitions=name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs} + +args_usb=run finduuid;setenv bootargs console=${console} + ${optargs} + root=PARTUUID=${uuid} rw + rootfstype=${mmcrootfstype} +init_usb=run args_all args_usb +get_fdt_usb=load usb ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt} +get_overlay_usb= + fdt address ${fdtaddr}; + fdt resize 0x100000; + for overlay in $name_overlays; + do; + load usb ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply + ${dtboaddr}; + done; +get_kern_usb=load usb ${bootpart} ${loadaddr} + ${bootdir}/${name_kern} +get_fit_usb=load usb ${bootpart} ${addr_fit} + ${bootdir}/${name_fit} +usbboot=setenv boot usb; + setenv bootpart 0:2; + usb start; + run findfdt; + run init_usb; + run get_kern_usb; + run get_fdt_usb; + run run_kern; diff --git a/include/configs/am64x_evm.h b/include/configs/am64x_evm.h index 26a7f2521e..1e37ab47b9 100644 --- a/include/configs/am64x_evm.h +++ b/include/configs/am64x_evm.h @@ -18,91 +18,6 @@ /* DDR Configuration */ #define CFG_SYS_SDRAM_BASE1 0x880000000
-#define PARTS_DEFAULT \ - /* Linux partitions */ \ - "name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs}\0" - -/* U-Boot general configuration */ -#define EXTRA_ENV_AM642_BOARD_SETTINGS \ - "findfdt=" \ - "if test $board_name = am64x_gpevm; then " \ - "setenv fdtfile k3-am642-evm.dtb; fi; " \ - "if test $board_name = am64x_skevm; then " \ - "setenv fdtfile k3-am642-sk.dtb; fi;" \ - "if test $fdtfile = undefined; then " \ - "echo WARNING: Could not determine device tree to use; fi; \0" \ - "name_kern=Image\0" \ - "console=ttyS2,115200n8\0" \ - "args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000 " \ - "${mtdparts}\0" \ - "run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}\0" - -/* U-Boot MMC-specific configuration */ -#define EXTRA_ENV_AM642_BOARD_SETTINGS_MMC \ - "boot=mmc\0" \ - "mmcdev=1\0" \ - "bootpart=1:2\0" \ - "bootdir=/boot\0" \ - "rd_spec=-\0" \ - "init_mmc=run args_all args_mmc\0" \ - "get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ - "get_overlay_mmc=" \ - "fdt address ${fdtaddr};" \ - "fdt resize 0x100000;" \ - "for overlay in $name_overlays;" \ - "do;" \ - "load mmc ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && " \ - "fdt apply ${dtboaddr};" \ - "done;\0" \ - "get_kern_mmc=load mmc ${bootpart} ${loadaddr} " \ - "${bootdir}/${name_kern}\0" \ - "get_fit_mmc=load mmc ${bootpart} ${addr_fit} " \ - "${bootdir}/${name_fit}\0" \ - "partitions=" PARTS_DEFAULT - -#define EXTRA_ENV_AM642_BOARD_SETTING_USBMSC \ - "args_usb=run finduuid;setenv bootargs console=${console} " \ - "${optargs} " \ - "root=PARTUUID=${uuid} rw " \ - "rootfstype=${mmcrootfstype}\0" \ - "init_usb=run args_all args_usb\0" \ - "get_fdt_usb=load usb ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ - "get_overlay_usb=" \ - "fdt address ${fdtaddr};" \ - "fdt resize 0x100000;" \ - "for overlay in $name_overlays;" \ - "do;" \ - "load usb ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && " \ - "fdt apply ${dtboaddr};" \ - "done;\0" \ - "get_kern_usb=load usb ${bootpart} ${loadaddr} " \ - "${bootdir}/${name_kern}\0" \ - "get_fit_usb=load usb ${bootpart} ${addr_fit} " \ - "${bootdir}/${name_fit}\0" \ - "usbboot=setenv boot usb;" \ - "setenv bootpart 0:2;" \ - "usb start;" \ - "run findfdt;" \ - "run init_usb;" \ - "run get_kern_usb;" \ - "run get_fdt_usb;" \ - "run run_kern\0" - -#define EXTRA_ENV_DFUARGS \ - DFU_ALT_INFO_MMC \ - DFU_ALT_INFO_EMMC \ - DFU_ALT_INFO_RAM \ - DFU_ALT_INFO_OSPI - -/* Incorporate settings into the U-Boot environment */ -#define CFG_EXTRA_ENV_SETTINGS \ - DEFAULT_LINUX_BOOT_ENV \ - DEFAULT_MMC_TI_ARGS \ - EXTRA_ENV_AM642_BOARD_SETTINGS \ - EXTRA_ENV_AM642_BOARD_SETTINGS_MMC \ - EXTRA_ENV_DFUARGS \ - EXTRA_ENV_AM642_BOARD_SETTING_USBMSC - /* Now for the remaining common defines */ #include <configs/ti_armv7_common.h>
Hi Nikhil,
On 30/03/23 14:12, Nikhil M Jain wrote:
Move to using .env file for setting up environment variables for am65x.This should be AM64 SK
Regards Devarsh
+findfdt=
- if test $board_name = am64x_gpevm; then
- if test $board_name = am64x_skevm; then
- if test $name_fdt = undefined; then
- fdt address ${fdtaddr};
- fdt resize 0x100000;
- for overlay in $name_overlays;
- do;
- load mmc ${bootpart} ${dtboaddr} ${bootdir}/${overlay} &&
- fdt apply ${dtboaddr};
- done;
- ${bootdir}/${name_kern}
- ${bootdir}/${name_fit}
- ${optargs}
- root=PARTUUID=${uuid} rw
- rootfstype=${mmcrootfstype}
- do;
- load usb ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply
- ${dtboaddr};
- done;
- setenv bootpart 0:2;
- usb start;
- run findfdt;
- run init_usb;
- run get_kern_usb;
- run get_fdt_usb;
- run run_kern;
- "findfdt=" \
"${mtdparts}\0" \
- "boot=mmc\0" \
- "mmcdev=1\0" \
- "rd_spec=-\0" \
"do;" \
"done;\0" \
"${optargs} " \
"do;" \
"done;\0" \
"usb start;" \
"run findfdt;" \
"run init_usb;" \
"run run_kern\0"
- DFU_ALT_INFO_OSPI
Devarsh Thakkar
Nikhil M Jain
