[U-Boot] [PATCH 1/1] efi_loader: remove efi_exit_caches()
Since GRUB patch d0c070179d4d ("arm/efi: Switch to arm64 linux loader", 2018-07-09) we do not need a workaround for GRUB on 32bit ARM anymore.
So let's eliminate function efi_exit_caches().
This will require Linux distributions to update grub-efi-arm to the GRUB git HEAD (a tag containing the aforementioned GRUB patch is not available yet).
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 28 ---------------------------- 1 file changed, 28 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 2496608981..97eb19cd14 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -26,14 +26,6 @@ LIST_HEAD(efi_obj_list); /* List of all events */ LIST_HEAD(efi_events);
-/* - * If we're running on nasty systems (32bit ARM booting into non-EFI Linux) - * we need to do trickery with caches. Since we don't want to break the EFI - * aware boot path, only apply hacks when loading exiting directly (breaking - * direct Linux EFI booting along the way - oh well). - */ -static bool efi_is_direct_boot = true; - #ifdef CONFIG_ARM /* * The "gd" pointer lives in a register on ARM and AArch64 that we declare @@ -1686,8 +1678,6 @@ static efi_status_t EFIAPI efi_start_image(efi_handle_t image_handle,
EFI_ENTRY("%p, %p, %p", image_handle, exit_data_size, exit_data);
- efi_is_direct_boot = false; - /* call the image! */ if (setjmp(&image_obj->exit_jmp)) { /* @@ -1795,21 +1785,6 @@ static efi_status_t EFIAPI efi_unload_image(efi_handle_t image_handle) return EFI_EXIT(EFI_SUCCESS); }
-/** - * efi_exit_caches() - fix up caches for EFI payloads if necessary - */ -static void efi_exit_caches(void) -{ -#if defined(CONFIG_ARM) && !defined(CONFIG_ARM64) - /* - * Grub on 32bit ARM needs to have caches disabled before jumping into - * a zImage, but does not know of all cache layers. Give it a hand. - */ - if (efi_is_direct_boot) - cleanup_before_linux(); -#endif -} - /** * efi_exit_boot_services() - stop all boot services * @image_handle: handle of the loaded image @@ -1863,9 +1838,6 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle,
board_quiesce_devices();
- /* Fix up caches for EFI payloads if necessary */ - efi_exit_caches(); - /* This stops all lingering devices */ bootm_disable_interrupts();
OpenBSD/armv7 can no longer boot with U-Boot after this commit as it currently does not explicitly invalidate/flush caches in efiboot.
- If we're running on nasty systems (32bit ARM booting into non-EFI Linux)
- we need to do trickery with caches. Since we don't want to break the EFI
- aware boot path, only apply hacks when loading exiting directly (breaking
- direct Linux EFI booting along the way - oh well).
- The "gd" pointer lives in a register on ARM and AArch64 that we declare
- efi_exit_caches() - fix up caches for EFI payloads if necessary
-#endif -}
- efi_exit_boot_services() - stop all boot services
- @image_handle: handle of the loaded image
-- 2.19.0
Shoot. I thought I had included a revert of this patch for 2018.11, but apparently missed it :(.
I'll revert it for efi-next then. We will have to give this a good bit more thought.
Alex
-#endif -}
-- 2.19.0
Alex
Same problem for FreeBSD/armv{6,7}, I don't think that we should disable the caches but we should at least flush them no ?
-#endif -}
-- 2.19.0
Alexander Graf
Emmanuel Vadot
Jonathan Gray
