[U-Boot] [PATCH] arm: zynq: Add support to store environment in EEPROM
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Added support to store environment in EEPROM. Set the mux to select EEPROM during board init so that the env can be read from EEPROM later.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/zynq/board.c | 8 +++++++- include/configs/zynq-common.h | 2 ++ 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index e59038106aa6..28394bef0567 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -34,6 +34,9 @@ static xilinx_desc fpga100 = XILINX_XC7Z100_DESC(0x100);
int board_init(void) { +#if defined(CONFIG_ENV_IS_IN_EEPROM) && !defined(CONFIG_SPL_BUILD) + unsigned char eepromsel = CONFIG_SYS_I2C_MUX_EEPROM_SEL; +#endif #if (defined(CONFIG_FPGA) && !defined(CONFIG_SPL_BUILD)) || \ (defined(CONFIG_SPL_FPGA_SUPPORT) && defined(CONFIG_SPL_BUILD)) u32 idcode; @@ -79,7 +82,10 @@ int board_init(void) fpga_init(); fpga_add(fpga_xilinx, &fpga); #endif - +#if defined(CONFIG_ENV_IS_IN_EEPROM) && !defined(CONFIG_SPL_BUILD) + if (eeprom_write(CONFIG_SYS_I2C_MUX_ADDR, 0, &eepromsel, 1)) + puts("I2C:EEPROM selection failed\n"); +#endif return 0; }
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index b10cb3f57220..547f447a46fd 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -146,6 +146,8 @@ # define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 # define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 # define CONFIG_SYS_EEPROM_SIZE 1024 /* Bytes */ +# define CONFIG_SYS_I2C_MUX_ADDR 0x74 +# define CONFIG_SYS_I2C_MUX_EEPROM_SEL 0x4 #endif
/* Total Size of Environment Sector */
Michal Simek
