[U-Boot] Pull request: u-boot-net.git master
Hi Tom,
The following changes since commit 46bac66b20da6d50e757bdca74703153f233090b:
sandbox: Move to use live tree (2017-06-01 07:03:17 -0600)
git://git.denx.de/u-boot-net.git master
for you to fetch changes up to 2303bff7d55df47105740e5d635d50ef9f6856b6:
net: pch_gbe: Add cache maintenance (2017-06-02 14:44:20 -0500)
---------------------------------------------------------------- Jacob Chen (1): net: designware: Add phy supply support
Madalin Bucur (2): armv8/ls1043a: RGMII PHY requires internal delay on Tx armv8/ls1046a: RGMII PHY requires internal delay on Tx
Olliver Schinagl (1): net: zynq_gem: Do not return -ENOSYS on success
Paul Burton (4): net: pch_gbe: Reset during probe net: pch_gbe: Fix rx descriptor buffer addresses net: pch_gbe: CPU accessible addresses are virtual net: pch_gbe: Add cache maintenance
Phil Edworthy (1): net: phy: marvell 88e151x: Fix handling of RGMII interface types
Philipp Tomsich (1): net: Kconfig:make PHY_GIGE and individual Micrel PHYs selectable
Sekhar Nori (1): drivers: net: cpsw: abort init() on aneg timeout
Siva Durga Prasad Paladugu (2): net: zynq_gem: Use wait_for_bit with non breakable net: zynq_gem: Dont flush dummy descriptors
Stefan Chulski (1): net: mvpp2.c: Enable 10G support for port 0 (SFI)
Wenyou Yang (1): net: macb: Fix GMAC not work when enable DM_ETH
xypron.glpk@gmx.de (1): net: core: avoid possible NULL pointer dereference
drivers/net/Kconfig | 8 +++++++ drivers/net/cpsw.c | 34 ++++++++++++++++++----------- drivers/net/designware.c | 17 +++++++++++++++ drivers/net/fm/ls1043.c | 4 ++-- drivers/net/fm/ls1046.c | 4 ++-- drivers/net/macb.c | 7 ++---- drivers/net/mvpp2.c | 55 ++++++++++++++++++++++++++++++++++------------- drivers/net/pch_gbe.c | 44 ++++++++++++++++++++++++++----------- drivers/net/phy/Kconfig | 34 +++++++++++++++++++++++++++++ drivers/net/phy/marvell.c | 45 +++++++++++++++++++++++++++++++++++++- drivers/net/zynq_gem.c | 16 +++++--------- net/eth-uclass.c | 3 ++- 12 files changed, 209 insertions(+), 62 deletions(-)
Thanks! -Joe
On Fri, Jun 02, 2017 at 02:45:15PM -0500, Joe Hershberger wrote:
Hi Tom,
Joe Hershberger
