[PATCH 0/7] stm32mp1: enable simple framebuffer node for splashscreen
Use simple framebuffer node in the Linux kernel device tree to preserved the resources (clock, memory) used by the stm32 video driver to display the splashscreen.
See Linux documentation for details: Documentation/devicetree/bindings/display/simple-framebuffer.yaml
The 3 first commits of the series are cleanup steps: migration to Kconfig and rename files and function to fdt_simplefb_ (it seems like a good time time as this function is only used today in RPI boards)
patch 4 is a preliminary step = add video_is_active function
patch 5 add a new API fdt_simplefb_enable_and_mem_rsv to activate node and add reserved memory for video memory
patch 6 avoid a issue in kernel when the reserved video memory by LTDC driver is not aligned with Linux kernel MMU_SECTION_SIZE
patch 7 use this new function in stm32mp1 code for STMicroelectronics boards when the simple-framebuffer node is present in Linux device tree
Patrick Delaunay (7): Convert CONFIG_LCD_DT_SIMPLEFB to Kconfig common: rename lcd_simplefb.c file to fdt_simplefb.c common: rename functions lcd_dt_simplefb to fdt_simplefb video: Add video_is_active function common: add fdt_simplefb_enable_and_mem_rsv function video: stm32: stm32_ltdc: align framebuffer on 2MB board: stm32mp1: enable simple framebuffer node for splashscreen
board/raspberrypi/rpi/rpi.c | 2 +- board/st/stm32mp1/stm32mp1.c | 4 +++ common/Kconfig | 9 ++++++ common/Makefile | 2 +- common/{lcd_simplefb.c => fdt_simplefb.c} | 37 ++++++++++++++++++++--- configs/rpi_0_w_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_b_plus_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + configs/rpi_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + drivers/video/stm32/stm32_ltdc.c | 5 ++- drivers/video/video-uclass.c | 14 +++++++++ include/configs/rpi.h | 1 - include/fdt_simplefb.h | 5 +-- include/video.h | 7 +++++ scripts/config_whitelist.txt | 1 - 23 files changed, 87 insertions(+), 12 deletions(-) rename common/{lcd_simplefb.c => fdt_simplefb.c} (65%)
This converts the following to Kconfig: CONFIG_LCD_DT_SIMPLEFB
This patch also renames this config to CONFIG_FDT_SIMPLEFB as the code in common/lcd_simplefb.c support CONFIG_LCD and CONFIG_VIDEO.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
common/Kconfig | 9 +++++++++ common/Makefile | 2 +- configs/rpi_0_w_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_b_plus_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + configs/rpi_defconfig | 1 + include/configs/rpi.h | 1 - scripts/config_whitelist.txt | 1 - 13 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index fdcf4536d0..c97814c6ad 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -766,3 +766,12 @@ config SPL_IMAGE_SIGN_INFO Enable image_sign_info helper functions in SPL.
endif + +config FDT_SIMPLEFB + bool "FDT tools for simplefb support" + depends on OF_LIBFDT + help + Enable the fdt tools to manage the simple fb nodes in device tree. + These functions can be used by board to indicate to the OS + the presence of the simple frame buffer with associated reserved + memory diff --git a/common/Makefile b/common/Makefile index c500bcd7d8..fed7e482e6 100644 --- a/common/Makefile +++ b/common/Makefile @@ -40,7 +40,7 @@ ifndef CONFIG_DM_VIDEO obj-$(CONFIG_LCD) += lcd.o lcd_console.o endif obj-$(CONFIG_LCD_ROTATION) += lcd_console_rotation.o -obj-$(CONFIG_LCD_DT_SIMPLEFB) += lcd_simplefb.o +obj-$(CONFIG_FDT_SIMPLEFB) += lcd_simplefb.o obj-$(CONFIG_MENU) += menu.o obj-$(CONFIG_UPDATE_COMMON) += update.o obj-$(CONFIG_USB_KEYBOARD) += usb_kbd.o diff --git a/configs/rpi_0_w_defconfig b/configs/rpi_0_w_defconfig index 6d76d12910..195541c6e7 100644 --- a/configs/rpi_0_w_defconfig +++ b/configs/rpi_0_w_defconfig @@ -13,6 +13,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 1931607132..eb63fbdd8d 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -14,6 +14,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 060fd36da5..46102899f0 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -15,6 +15,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/configs/rpi_3_b_plus_defconfig b/configs/rpi_3_b_plus_defconfig index 0a69f97342..91b63b6272 100644 --- a/configs/rpi_3_b_plus_defconfig +++ b/configs/rpi_3_b_plus_defconfig @@ -14,6 +14,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 8016fe1d55..528b12ea5b 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -14,6 +14,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index 990589de64..88f7504a60 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -12,6 +12,7 @@ CONFIG_PREBOOT="pci enum; usb start;" # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 0720505c6a..59a7103154 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -12,6 +12,7 @@ CONFIG_PREBOOT="pci enum; usb start;" # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y diff --git a/configs/rpi_arm64_defconfig b/configs/rpi_arm64_defconfig index 06ae3e93b2..67dbf094ef 100644 --- a/configs/rpi_arm64_defconfig +++ b/configs/rpi_arm64_defconfig @@ -12,6 +12,7 @@ CONFIG_PREBOOT="pci enum; usb start;" # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 8acf04d0e4..0baef3b6ab 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -13,6 +13,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_MISC_INIT_R=y +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 55768a46da..bc907acd5f 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -44,7 +44,6 @@ /* GPIO */ #define CONFIG_BCM2835_GPIO /* LCD */ -#define CONFIG_LCD_DT_SIMPLEFB #define CONFIG_VIDEO_BCM2835
/* DFU over USB/UDC */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b9c1c61e13..1e1ef76175 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -699,7 +699,6 @@ CONFIG_LBA48 CONFIG_LBDAF CONFIG_LCD_ALIGNMENT CONFIG_LCD_BMP_RLE8 -CONFIG_LCD_DT_SIMPLEFB CONFIG_LCD_INFO CONFIG_LCD_INFO_BELOW_LOGO CONFIG_LCD_IN_PSRAM
Reviewed-by: Matthias Brugger mbrugger@suse.com
endif
- bool "FDT tools for simplefb support"
- depends on OF_LIBFDT
- help
memory
Rename the file lcd_simplefb.c to fdt_simplefb.c to be aligned with the configuration name and with the associated include file ./include/fdt_simplefb.h
common/Makefile | 2 +- common/{lcd_simplefb.c => fdt_simplefb.c} | 0 2 files changed, 1 insertion(+), 1 deletion(-) rename common/{lcd_simplefb.c => fdt_simplefb.c} (100%)
diff --git a/common/Makefile b/common/Makefile index fed7e482e6..24be05c368 100644 --- a/common/Makefile +++ b/common/Makefile @@ -18,6 +18,7 @@ obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o obj-$(CONFIG_DISPLAY_BOARDINFO_LATE) += board_info.o
obj-$(CONFIG_CMD_BEDBUG) += bedbug.o +obj-$(CONFIG_FDT_SIMPLEFB) += fdt_simplefb.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += fdt_support.o obj-$(CONFIG_MII) += miiphyutil.o obj-$(CONFIG_CMD_MII) += miiphyutil.o @@ -40,7 +41,6 @@ ifndef CONFIG_DM_VIDEO obj-$(CONFIG_LCD) += lcd.o lcd_console.o endif obj-$(CONFIG_LCD_ROTATION) += lcd_console_rotation.o -obj-$(CONFIG_FDT_SIMPLEFB) += lcd_simplefb.o obj-$(CONFIG_MENU) += menu.o obj-$(CONFIG_UPDATE_COMMON) += update.o obj-$(CONFIG_USB_KEYBOARD) += usb_kbd.o diff --git a/common/lcd_simplefb.c b/common/fdt_simplefb.c similarity index 100% rename from common/lcd_simplefb.c rename to common/fdt_simplefb.c
Hi Patrick
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Thanks Patrice
Rename the function named lcd_dt_simplefb* to fdt_simplefb* to be aligned with the associated file name fdt_simplefb.h/fdt_simplefb.c
board/raspberrypi/rpi/rpi.c | 2 +- common/fdt_simplefb.c | 10 +++++----- include/fdt_simplefb.h | 4 ++-- 3 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 55afaa54d9..cd7d6df2a5 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -505,7 +505,7 @@ int ft_board_setup(void *blob, struct bd_info *bd)
node = fdt_node_offset_by_compatible(blob, -1, "simple-framebuffer"); if (node < 0) - lcd_dt_simplefb_add_node(blob); + fdt_simplefb_add_node(blob);
#ifdef CONFIG_EFI_LOADER /* Reserve the spin table */ diff --git a/common/fdt_simplefb.c b/common/fdt_simplefb.c index 1650615cdb..32173030ab 100644 --- a/common/fdt_simplefb.c +++ b/common/fdt_simplefb.c @@ -16,7 +16,7 @@
DECLARE_GLOBAL_DATA_PTR;
-static int lcd_dt_simplefb_configure_node(void *blob, int off) +static int fdt_simplefb_configure_node(void *blob, int off) { int xsize, ysize; int bpix; /* log2 of bits per pixel */ @@ -58,7 +58,7 @@ static int lcd_dt_simplefb_configure_node(void *blob, int off) xsize * (1 << bpix) / 8, name); }
-int lcd_dt_simplefb_add_node(void *blob) +int fdt_simplefb_add_node(void *blob) { static const char compat[] = "simple-framebuffer"; static const char disabled[] = "disabled"; @@ -76,10 +76,10 @@ int lcd_dt_simplefb_add_node(void *blob) if (ret < 0) return -1;
- return lcd_dt_simplefb_configure_node(blob, off); + return fdt_simplefb_configure_node(blob, off); }
-int lcd_dt_simplefb_enable_existing_node(void *blob) +int fdt_simplefb_enable_existing_node(void *blob) { int off;
@@ -87,5 +87,5 @@ int lcd_dt_simplefb_enable_existing_node(void *blob) if (off < 0) return -1;
- return lcd_dt_simplefb_configure_node(blob, off); + return fdt_simplefb_configure_node(blob, off); } diff --git a/include/fdt_simplefb.h b/include/fdt_simplefb.h index 7cc305e1fd..7e54723591 100644 --- a/include/fdt_simplefb.h +++ b/include/fdt_simplefb.h @@ -8,6 +8,6 @@
#ifndef _FDT_SIMPLEFB_H_ #define _FDT_SIMPLEFB_H_ -int lcd_dt_simplefb_add_node(void *blob); -int lcd_dt_simplefb_enable_existing_node(void *blob); +int fdt_simplefb_add_node(void *blob); +int fdt_simplefb_enable_existing_node(void *blob); #endif
- return fdt_simplefb_configure_node(blob, off); }
Add the helper function video_is_active() to test if one video device is active.
This function can be used in board code to execute operation only when the display is probed / really used.
drivers/video/video-uclass.c | 14 ++++++++++++++ include/video.h | 7 +++++++ 2 files changed, 21 insertions(+)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 9f8cf6ef2a..43ebb3c565 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -228,6 +228,20 @@ void video_sync_all(void) } }
+bool video_is_active(void) +{ + struct udevice *dev; + + for (uclass_find_first_device(UCLASS_VIDEO, &dev); + dev; + uclass_find_next_device(&dev)) { + if (device_active(dev)) + return true; + } + + return false; +} + int video_get_xsize(struct udevice *dev) { struct video_priv *priv = dev_get_uclass_priv(dev); diff --git a/include/video.h b/include/video.h index f14fb15f84..5ac1387a39 100644 --- a/include/video.h +++ b/include/video.h @@ -276,6 +276,13 @@ static inline int video_sync_copy_all(struct udevice *dev)
#endif
+/** + * video_is_active() - Test if one video device it active + * + * @return true if at least one video device is active, else false. + */ +bool video_is_active(void); + #ifndef CONFIG_DM_VIDEO
/* Video functions */
Hi Patrick
- struct udevice *dev;
- for (uclass_find_first_device(UCLASS_VIDEO, &dev);
dev;
return true;
- return false;
#endif
- video_is_active() - Test if one video device it active
- @return true if at least one video device is active, else false.
Add a new function to activate an existing simple frame buffer node and add the associated reserved memory, with no-map properties.
This device tree update is only done when the video device is active and the video buffer is used.
This patch uses '#if CONFIG_IS_ENABLED(DM_VIDEO)' because gd->video_bottom and gd->video_top are only defined when CONFIG_DM_VIDEO is activated.
common/fdt_simplefb.c | 27 +++++++++++++++++++++++++++ include/fdt_simplefb.h | 1 + 2 files changed, 28 insertions(+)
diff --git a/common/fdt_simplefb.c b/common/fdt_simplefb.c index 32173030ab..c52846f4bc 100644 --- a/common/fdt_simplefb.c +++ b/common/fdt_simplefb.c @@ -89,3 +89,30 @@ int fdt_simplefb_enable_existing_node(void *blob)
return fdt_simplefb_configure_node(blob, off); } + +#if CONFIG_IS_ENABLED(DM_VIDEO) +int fdt_simplefb_enable_and_mem_rsv(void *blob) +{ + struct fdt_memory mem; + int ret; + + /* nothing to do when video is not active */ + if (!video_is_active()) + return 0; + + ret = fdt_simplefb_enable_existing_node(blob); + if (ret) + return ret; + + /* nothing to do when the frame buffer is not defined */ + if (gd->video_bottom == gd->video_top) + return 0; + + /* reserved with no-map tag the video buffer */ + mem.start = gd->video_bottom; + mem.end = gd->video_top - 1; + + return fdtdec_add_reserved_memory(blob, "framebuffer", &mem, NULL, 0, NULL, + FDTDEC_RESERVED_MEMORY_NO_MAP); +} +#endif diff --git a/include/fdt_simplefb.h b/include/fdt_simplefb.h index 7e54723591..41cd740ac0 100644 --- a/include/fdt_simplefb.h +++ b/include/fdt_simplefb.h @@ -10,4 +10,5 @@ #define _FDT_SIMPLEFB_H_ int fdt_simplefb_add_node(void *blob); int fdt_simplefb_enable_existing_node(void *blob); +int fdt_simplefb_enable_and_mem_rsv(void *blob); #endif
Hi Patrick
- struct fdt_memory mem;
- int ret;
- /* nothing to do when video is not active */
- if (!video_is_active())
- ret = fdt_simplefb_enable_existing_node(blob);
- if (ret)
return ret;
- /* nothing to do when the frame buffer is not defined */
- if (gd->video_bottom == gd->video_top)
- /* reserved with no-map tag the video buffer */
- mem.start = gd->video_bottom;
- mem.end = gd->video_top - 1;
- return fdtdec_add_reserved_memory(blob, "framebuffer", &mem, NULL, 0, NULL,
Align the framebuffer size on MMU_SECTION_SIZE in kernel, = max 2MB for LPAE for armV7, to avoid issue with the simple frame buffer activation, when U-Boot add a reserved memory in the kernel device tree to preserve the splash screen until Linux driver initialization.
drivers/video/stm32/stm32_ltdc.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/video/stm32/stm32_ltdc.c b/drivers/video/stm32/stm32_ltdc.c index 65c882d9f1..87e5fd54d9 100644 --- a/drivers/video/stm32/stm32_ltdc.c +++ b/drivers/video/stm32/stm32_ltdc.c @@ -459,7 +459,10 @@ static int stm32_ltdc_bind(struct udevice *dev) uc_plat->size = CONFIG_VIDEO_STM32_MAX_XRES * CONFIG_VIDEO_STM32_MAX_YRES * (CONFIG_VIDEO_STM32_MAX_BPP >> 3); - dev_dbg(dev, "frame buffer max size %d bytes\n", uc_plat->size); + /* align framebuffer on kernel MMU_SECTION_SIZE = max 2MB for LPAE */ + uc_plat->align = SZ_2M; + dev_dbg(dev, "frame buffer max size %d bytes align %x\n", + uc_plat->size, uc_plat->align);
return 0; }
Hi Patrick
Enable an existing simple framebuffer node in the Linux kernel device tree and the add the associated reserved memory node to preserved the resources (clock, memory) used by the stm32 video driver to display the splashscreen = background in exlinux.conf file.
These resources will be released by the Linux driver only when the associated driver is ready to avoid transition issues during the Linux kernel initialization between U-Boot splash screen and the final display.
board/st/stm32mp1/stm32mp1.c | 4 ++++ configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + 4 files changed, 7 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 84592677e4..45f2ca81a6 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -13,6 +13,7 @@ #include <dm.h> #include <env.h> #include <env_internal.h> +#include <fdt_simplefb.h> #include <fdt_support.h> #include <g_dnl.h> #include <generic-phy.h> @@ -914,6 +915,9 @@ int ft_board_setup(void *blob, struct bd_info *bd) if (IS_ENABLED(CONFIG_FDT_FIXUP_PARTITIONS)) fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));
+ if (CONFIG_IS_ENABLED(FDT_SIMPLEFB)) + fdt_simplefb_enable_and_mem_rsv(blob); + return 0; } #endif diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 2cc26d4066..c9ed2239ca 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -34,6 +34,7 @@ CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_POWER=y CONFIG_SPL_SPI_FLASH_MTD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="STM32MP> " CONFIG_CMD_ADTIMG=y CONFIG_CMD_ERASEENV=y diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index 4c6a52fc54..e10f4cedc8 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_FIT=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="STM32MP> " CONFIG_CMD_ADTIMG=y CONFIG_CMD_ERASEENV=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index feca26e973..83bd93e3a1 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_FIT=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" +CONFIG_FDT_SIMPLEFB=y CONFIG_SYS_PROMPT="STM32MP> " CONFIG_CMD_ADTIMG=y CONFIG_CMD_ERASEENV=y
Hi Patrick
- if (CONFIG_IS_ENABLED(FDT_SIMPLEFB))
Hi Patrick
For the series, applied to u-boot-stm32/next Thanks Patrice
Matthias Brugger
Patrice CHOTARD
Patrick Delaunay
