Re: [PATCH v2 0/6] rockchip: rk3328: sync dts and add ROC-RK3328-CC board
On Thu, Apr 16, 2020 at 5:53 AM Loic Devulder LDevulder@suse.com wrote:
Hi Chen,
I tested your patches and all work pretty well. I just had issues with USB2 that doesn't recognize any of my USB keys (it's OK on USB3).
I also had these issues with XHCI driver: => usb reset resetting USB... BUG at drivers/usb/host/xhci-mem.c:84/xhci_ring_free()! BUG! �esetting ...
=> usb stop stopping USB.. Host not halted after 16000 microseconds. XHCI: failed to set VBus supply device_remove: Device 'usb@ff600000' failed to remove, but children are gone
But for the whole series: Tested-by: Loic Devulder ldevulder@suse.com
On Sun, 2020-04-05 at 10:25 +0800, Chen-Yu Tsai wrote:
Hi everyone,
This is v2 of my ROC-RK3328-CC series. Changes from v1 are mainly dropping the custom board target, and dealing with the pinmuxing through proper use of DM regulators / GPIO / pinctrl in SPL.
This series adds proper support for Firefly / Libre Computer ROC- RK3328-CC single board computer.
The ROC-RK3328-CC from Firefly and Libre Computer Project is a credit card size development board based on the Rockchip RK3328 SoC, with:
- 1/2/4 GB DDR4 DRAM
- eMMC connector for optional module
- micro SD card slot
- 1 x USB 3.0 host port
- 2 x USB 2.0 host port
- 1 x USB 2.0 OTG port
- HDMI video output
- TRRS connector with audio and composite video output
- gigabit Ethernet
- consumer IR receiver
- debug UART pins
Originally I started with Loic's patches, and syncing the device tree files from Linux. That didn't get very far, with SPL failing to detect the SD card. Examining the schematics and internal state of GRF and GPIOs, I realized that the logic for the SD card power enable switch is opposite that of what the SD card controller's SDMMC0_PWREN pin would use. Instead, directly using the GPIO is required.
To deal with this, DM regulator and GPIO are enabled in SPL, and various device nodes are marked with u-boot,dm-spl to have them work. pinctrl properties are not stripped, so as to have the SDMMC0_PWREN pin muxed over to GPIO.
Along the way, there are some clean-ups of existing dts files, moving U-boot only features to -u-boot.dtsi files, and then a wholesale sync from Linux. Only boards already existing in U-boot are synced. DT binding header files are synced separately as there is already one patch floating around. The DT sync also includes clean-up changes only recently posted, and likely won't make it in for at least a few weeks.
Please have a look, and test if possible. I cc-ed a couple people that showed interest in this board on mailing lists recently.
Regards ChenYu
Chen-Yu Tsai (6): rockchip: dts: rk3328-evb: Move vcc5v0-host-xhci-drv to -u- boot.dtsi rockchip: dts: rk3328-evb: Move gmac2io related nodes to -u- boot.dtsi dt-bindings: clock: rk3328: sync from upstream Linux kernel dt-bindings: power: rk3328-power: sync from upstream Linux kernel rockchip: dts: rk3328: Sync device tree files from Linux rockchip: rk3328: Add support for ROC-RK3328-CC board
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3328-evb-u-boot.dtsi | 39 + arch/arm/dts/rk3328-evb.dts | 220 +-- arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 38 + .../{rk3328-rock64.dts => rk3328-roc-cc.dts} | 135 +- arch/arm/dts/rk3328-rock64.dts | 132 +- arch/arm/dts/rk3328.dtsi | 1420 +++++++++++--
board/rockchip/evb_rk3328/MAINTAINERS | 7 + configs/roc-cc-rk3328_defconfig | 103 ++ doc/README.rockchip | 4 +- include/dt-bindings/clock/rk3328-cru.h | 212 +-- include/dt-bindings/power/rk3328-power.h | 19 + 12 files changed, 1578 insertions(+), 752 deletions(-) create mode 100644 arch/arm/dts/rk3328-roc-cc-u-boot.dtsi copy arch/arm/dts/{rk3328-rock64.dts => rk3328-roc-cc.dts} (68%) create mode 100644 configs/roc-cc-rk3328_defconfig create mode 100644 include/dt-bindings/power/rk3328-power.h
-- Loic Devulder ldevulder@suse.com | ldevulder@irc 0x175A963893C85F55 | D220 DEF5 56A3 DE00 9DAA 78BA 175A 9638 93C8 5F55 Senior QA Engineer | Container & Storage Solutions Quality Assurance team (qa-css) SUSE Linux GmbH, Maxfeldstr. 5, 90409 Nuernberg, Germany GF: Felix Imendörffer, Mary Higgins, Sri Rasiah HRB, 21284 (AG Nuernberg)
Good Afternoon,
I have tested this patch set against u-boot git as of 20 April 2020 and have some feedback. The issue of booting off the sdmmc is fixed, thanks!
The USB issues above come from a few issues: vcc_host1_5v is set to regulator-always-on, which prevents USB from resetting properly, remove this option allows xhci to clean up. USB 2.0 Host does not work because there is no rockchip,rk3328-usb2phy yet. This causes the generic ohci and ehci drivers to fail, removing CONFIG_PHY from your defconfig resolves this. The USB-OTG port appears to not work because it's stuck in peripheral mode. The vbus-supply = <&vcc_host1_5v> should be on all three USB controllers, as it powers all three ports.
Overall, excellent work! For the whole series: Tested-by: Peter Geis pgwipeout@gmail.com
Hi Chen,
Hi everyone,
- HDMI video output
- gigabit Ethernet
- debug UART pins
Regards ChenYu
Good Afternoon,
This seems a little odd. I suppose it's because of how U-boot's USB stack works. On Linux, the XHCI is not supported. There seems to be an issue in that the controller never detects disconnects.
Removing CONFIG_PHY stops XHCI from working.
It seems easier to remove the phy properties using the -u-boot.dtsi file.
I tried setting dr_mode = "host" in the device tree but it still timeouts. Setting vbus-supply doesn't help either as it is timing out during the initializing phase in the driver, before vbus is enabled. Since it worked before my patchset, I'm guessing it might be related to the assigned-clocks changes. I have to do some more tests to narrow it down.
Some thoughts carried over from Linux regarding the always-on setting:
For this particular board, since all ports share the same GPIO to control USB VCC, having it not always-on might result in other devices getting power cycled, since U-boot doesn't do reference counting for regulators.
Another thing is that the bindings only allow the VBUS regulator to be tied to the USB PHY, which is not supported in U-boot, and not the host.
To me it seems to make more sense to make enable/disable no-ops for always-on regulators, instead of returning errors.
Regards ChenYu
Hi Chen,
Hi everyone,
- HDMI video output
- gigabit Ethernet
- debug UART pins
Regards ChenYu
Good Afternoon,
Mainline Linux is missing the PHY driver, so you can enable the USB3 controller, but yes, connects/disconnects are not detected. I've tried to port the downstream driver, but it is a mess and doesn't trigger interrupts for 3.0 devices.
Odd, I never encountered that issue, maybe because I tagged all of the phys to all of their devices.
I didn't test it, but it seemed to be the logical place to check.
Yes, but at least from my limited testing it seems U-Boot enables them all en-mass during usb start. It then shuts them all down during usb reset or usb stop. It doesn't appear to implement runtime power management.
If you implement no-ops does that solve the issue of it not cleaning up xhci on shutdown?
Regards ChenYu
Hi Chen,
Hi everyone,
- HDMI video output
- gigabit Ethernet
- debug UART pins
Regards ChenYu
Good Afternoon,
OK. I figured out the failure pattern was that the USB 3.0 port only gets USB 2.0 working.
At this point it's starting to get weird. If I only tie the regulator to XHCI, then the OTG 2.0 port doesn't detect anything. If I tie the regulator to all three hosts (EHCI+OHCI counted as one), or only the OTG device, then the USB 3.0 port only works with USB 2.0 devices.
This seems like a preexisting issue.
On the Rock64 the regulator is set to "always-on" and the same issue with XHCI not working with USB 3.0 exists as well.
Given the trade off, I believe having USB 3.0 is more useful than USB OTG in host mode.
Ah, it looks like some other issue, unrelated to CONFIG_PHY.
Looks like it just needed "hnp-srp-disable" set in the OTG node.
I'd prefer not changing core behavior that requires a whole lot of testing.
Regards ChenYu
Regards ChenYu
Chen-Yu Tsai
Peter Geis
