[U-Boot] [POWERPC] mgcoge: Second Flash on CS5 not on CS1
Signed-off-by: Heiko Schocher hs@denx.de --- board/keymile/mgcoge/mgcoge.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/keymile/mgcoge/mgcoge.c b/board/keymile/mgcoge/mgcoge.c index 099e77b..5931f17 100644 --- a/board/keymile/mgcoge/mgcoge.c +++ b/board/keymile/mgcoge/mgcoge.c @@ -334,7 +334,7 @@ void ft_blob_update (void *blob, bd_t *bd) /* update Flash addr, size */ flash_data[2] = cpu_to_be32 (CFG_FLASH_BASE); flash_data[3] = cpu_to_be32 (CFG_FLASH_SIZE); - flash_data[4] = cpu_to_be32 (1); + flash_data[4] = cpu_to_be32 (5); flash_data[5] = cpu_to_be32 (0); flash_data[6] = cpu_to_be32 (CFG_FLASH_BASE_1); flash_data[7] = cpu_to_be32 (CFG_FLASH_SIZE_1);
Dear Heiko,
Sorry, this patch does not apply:
Applying mgcoge: Second Flash on CS5 not on CS1 error: patch failed: board/keymile/mgcoge/mgcoge.c:334 error: board/keymile/mgcoge/mgcoge.c: patch does not apply fatal: sha1 information is lacking or useless (board/keymile/mgcoge/mgcoge.c). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0001.
Please fix and resubmit.
Heiko Schocher
