[PATCH 1/1] mvebu: fix end-of-array check
Properly seek the end of default_environment variables.
The current algorithm overwrites from the second variable. This replacement finds the end of the array of strings.
Stomped variables include "board", "soc", "loadaddr". These can be seen on a "env default -a" after patch, but they are not seen with a version before the patch.
Signed-off-by: Derek LaHousse derek@seaofdirac.org --- board/Marvell/mvebu_armada-37xx/board.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index c6ecc323bb..ac29ac5b95 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -100,8 +100,11 @@ int board_late_init(void) return 0;
/* Find free buffer in default_environment[] for new variables */ - while (*ptr != '\0' && *(ptr+1) != '\0') ptr++; - ptr += 2; + if (*ptr != '\0') { // Defending against empty default env + while ((i = strlen(ptr)) != 0) { + ptr += i + 1; + } + }
/* * Ensure that 'env default -a' does not erase permanent MAC addresses
________________________________ From: Derek LaHousse derek@seaofdirac.org Sent: Wednesday, November 30, 2022 20:33 To: u-boot@lists.denx.de u-boot@lists.denx.de Cc: sr@denx.de sr@denx.de; Kostya Porotchkin kostap@marvell.com; pali@kernel.org pali@kernel.org Subject: [EXT] [PATCH 1/1] mvebu: fix end-of-array check
External Email
---------------------------------------------------------------------- Properly seek the end of default_environment variables.
Acked-by: Konstantin Porotchkin kostap@marvell.com
-- 2.30.2
Hello!
I would suggest to change description of the patch from
"mvebu: fix end-of-array check"
to something like:
"arm: mvebu: Espressobin: fix end-of-array check in env"
as it affects only Espressobin boards (not other mvebu).
Stefan, please look below as this issue/fix is important.
This is a real issue which I introduced in the past. So it some fix for this issue should be pulled into the v2023.01 release.
- ptr += 2;
- if (*ptr != '\0') { // Defending against empty default env
ptr += i + 1;
If I'm looking at the outer-if condition correctly then it is not needed. strlen("") returns zero and so inner-while loop stops immediately.
My proposed fix for this issue was just changing correct while loop check to ensure that ptr is set after the _last_ variable.
- while (*ptr != '\0' && *(ptr+1) != '\0') ptr++; - ptr += 2; + while (*ptr != '\0' || *(ptr+1) != '\0') ptr++; + ptr++;
Both changes should be equivalent, but I'm not sure which one is more readable. The original issue was introduced really by non-readable code...
Stefan, do you have a preference which one fix is better / more readable?
It would be really a good idea if you try to check if any of those proposed fixes/patches are now really correct.
/* * Ensure that 'env default -a' does not erase permanent MAC addresses -- 2.30.2
Hi!
On 12/4/22 11:39, Pali Rohár wrote:
Hello!
to something like:
Yes, please update the commit subject here.
Yes.
Understood.
- ptr += 2;
ptr += i + 1;
- ptr += 2;
- while (*ptr != '\0' || *(ptr+1) != '\0') ptr++;
- ptr++;
I would prefer to get Pali's corrected version included. Could you please prepare a v2 patch with this update and also with the added or changed patch subject.
Yes, please do.
Thanks, Stefan
On Monday 05 December 2022 12:42:44 Stefan Roese wrote:
Hi!
Hello!
to something like:
Yes.
Understood.
diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index c6ecc323bb..ac29ac5b95 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -100,8 +100,11 @@ int board_late_init(void) return 0; /* Find free buffer in default_environment[] for new variables */
- ptr += 2;
ptr += i + 1;
- ptr += 2;
- ptr++;
Originally this issue was reported half year ago on the armbian forum: https://forum.armbian.com/topic/19564-making-espressobin-v7-work-in-2022/?do...
U-Boot "changed" variable name scriptaddr to criptaddr (without leading s) and broke booting.
Details are later in comments: https://forum.armbian.com/topic/19564-making-espressobin-v7-work-in-2022/?do... https://forum.armbian.com/topic/19564-making-espressobin-v7-work-in-2022/?do...
If you prefer my variant, I can prepare a v2 patch.
Please let me know.
Yes, please do.
Thanks, Stefan
Hi Pali,
Hi!
Hello!
to something like:
Yes.
Understood.
- ptr += 2;
ptr += i + 1;
- ptr += 2;
- ptr++;
Yes, please do. That's easiest for me. I'll push this quickly then.
Thanks, Stefan
On Tuesday 06 December 2022 07:10:15 Stefan Roese wrote:
Hi Pali,
Hi!
Hello!
to something like:
Yes.
Understood.
- ptr += 2;
ptr += i + 1;
- ptr += 2;
- ptr++;
Thanks, Stefan
Hello Stefan! During discussion on the forum, Derek pointed that my "fix" does not work for another edge case when *ptr is '\0' before entering into while-loop. That is a valid point and code needs to be adjusted.
With Derek we do not have an agreement how to write this peace of the code in readable way, which should move ptr pointer to the end of env list - find two nul bytes which indicates end of the env list and then set ptr to the second nul byte, so at this position can be put another new variable. Plus handle special case nul byte is at the beginning.
My idea was to use single while loop to find this location to have code minimal in its size. Derek thinks that code is better readable if iteration is done via strlen() calls in while-loop, like it is in this version.
Stefan, do you have an idea how to write this code in a way that is fast and also readable and maintainable?
Hi Pali, Hi Derek,
Hi Pali,
Hi!
Hello!
to something like:
Yes.
Understood.
- ptr += 2;
ptr += i + 1;
- ptr += 2;
- ptr++;
Thanks, Stefan
Sorry, I don't have an "idea" quickly that might be "better" than your suggested version(s) without diving into this deeper. You are both experienced developers I assume. I have no real problem using Derek's version if this solves the problem and is a bit slower. The code patch we are talking about is not accessed frequently I assume.
Thanks, Stefan
It seems odd to update the default environment, but if we want to do this, it should really be done in a function in env/ along with some tests in test/env
Well, this is just a temporary solution until Marek's env patch series is merged: https://lore.kernel.org/u-boot/20211103232332.2737-1-kabel@kernel.org/
But I agree that tests would prevent these bugs.
Hi Pali,
OK I see.
participants (5)
Derek LaHousse
Kostya Porotchkin
Pali Rohár
Stefan Roese
