[U-Boot] [PATCH 1/5] ARM64: zynqmp: Adjust to new SMC interface to get silicon version
The new FW interface returns the IDCODE and version register, leaving extracting bitfields to the caller.
Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Soren Brinkmann soren.brinkmann@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/zynqmp/zynqmp.c | 11 +++++++++++ include/zynqmppl.h | 6 ++++++ 2 files changed, 17 insertions(+)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index ba4dfbb47625..b0acaa5b7721 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -86,6 +86,17 @@ static int chip_id(void)
smc_call(®s);
+ /* + * SMC returns: + * regs[0][31:0] = status of the operation + * regs[0][63:32] = CSU.IDCODE register + * regs[1][31:0] = CSU.version register + */ + regs.regs[0] = upper_32_bits(regs.regs[0]); + regs.regs[0] &= ZYNQMP_CSU_IDCODE_DEVICE_CODE_MASK | + ZYNQMP_CSU_IDCODE_SVD_MASK; + regs.regs[0] >>= ZYNQMP_CSU_IDCODE_SVD_SHIFT; + return regs.regs[0]; }
diff --git a/include/zynqmppl.h b/include/zynqmppl.h index 542ace9a03b9..fb5200ec84a6 100644 --- a/include/zynqmppl.h +++ b/include/zynqmppl.h @@ -16,6 +16,12 @@ #define ZYNQMP_FPGA_OP_LOAD (1 << 1) #define ZYNQMP_FPGA_OP_DONE (1 << 2)
+#define ZYNQMP_CSU_IDCODE_DEVICE_CODE_SHIFT 15 +#define ZYNQMP_CSU_IDCODE_DEVICE_CODE_MASK (0xf << \ + ZYNQMP_CSU_IDCODE_DEVICE_CODE_SHIFT) +#define ZYNQMP_CSU_IDCODE_SVD_SHIFT 12 +#define ZYNQMP_CSU_IDCODE_SVD_MASK (0xe << ZYNQMP_CSU_IDCODE_SVD_SHIFT) + extern struct xilinx_fpga_op zynqmp_op;
#define XILINX_ZYNQMP_DESC \
board/xilinx/zynqmp/zynqmp.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index b0acaa5b7721..7e6728870931 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -422,6 +422,10 @@ int board_usb_init(int index, enum usb_init_type init) { debug("%s: index %x\n", __func__, index);
+#if defined(CONFIG_USB_GADGET_DOWNLOAD) + g_dnl_set_serialnumber(CONFIG_SYS_CONFIG_NAME); +#endif + switch (index) { case 0: return dwc3_uboot_init(&dwc3_device_data0);
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Add support for SD1 with level shifters bootmode.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/include/asm/arch-zynqmp/hardware.h | 1 + board/xilinx/zynqmp/zynqmp.c | 3 +++ 2 files changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 456c1b0902e5..e7738faaf896 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -79,6 +79,7 @@ struct iou_scntr_secure { #define NAND_MODE 0x00000004 #define EMMC_MODE 0x00000006 #define USB_MODE 0x00000007 +#define SD1_LSHFT_MODE 0x0000000E /* SD1 Level shifter */ #define JTAG_MODE 0x00000000 #define BOOT_MODE_USE_ALT 0x100 #define BOOT_MODE_ALT_SHIFT 12 diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 7e6728870931..df72516239dc 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -360,6 +360,9 @@ int board_late_init(void) puts("SD_MODE\n"); mode = "mmc0"; break; + case SD1_LSHFT_MODE: + puts("LVL_SHFT_"); + /* fall through */ case SD_MODE1: puts("SD_MODE1\n"); #if defined(CONFIG_ZYNQ_SDHCI0) && defined(CONFIG_ZYNQ_SDHCI1)
Do not setup use_alt bit which copy alternative boot mode to boot mode. The reason is that this bit is cleared after POR but not after any software reset which will cause that after SW reset bootrom will look for different boot image.
This patch setups alternative boot mode selection (purely SW handling) and extends code to read this alternative boot mode first and use it if it is setup.
arch/arm/cpu/armv8/zynqmp/spl.c | 6 ++++-- board/xilinx/zynqmp/zynqmp.c | 3 +++ 2 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/spl.c b/arch/arm/cpu/armv8/zynqmp/spl.c index 04e190537d15..bdbd61380ab7 100644 --- a/arch/arm/cpu/armv8/zynqmp/spl.c +++ b/arch/arm/cpu/armv8/zynqmp/spl.c @@ -69,12 +69,14 @@ u32 spl_boot_device(void)
#if defined(CONFIG_SPL_ZYNQMP_ALT_BOOTMODE_ENABLED) /* Change default boot mode at run-time */ - writel(BOOT_MODE_USE_ALT | - CONFIG_SPL_ZYNQMP_ALT_BOOTMODE << BOOT_MODE_ALT_SHIFT, + writel(CONFIG_SPL_ZYNQMP_ALT_BOOTMODE << BOOT_MODE_ALT_SHIFT, &crlapb_base->boot_mode); #endif
reg = readl(&crlapb_base->boot_mode); + if (reg >> BOOT_MODE_ALT_SHIFT) + reg >>= BOOT_MODE_ALT_SHIFT; + bootmode = reg & BOOT_MODES_MASK;
switch (bootmode) { diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index df72516239dc..cef1f6a13aee 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -335,6 +335,9 @@ int board_late_init(void) }
puts("Bootmode: ");
Autogenerated files contain casting issues and missing function declaration and even usleep implementation. Suppress them for now till these files are fixed.
board/xilinx/zynqmp/Makefile | 3 +++ board/xilinx/zynqmp/xil_io.h | 9 +++++++++ 2 files changed, 12 insertions(+)
diff --git a/board/xilinx/zynqmp/Makefile b/board/xilinx/zynqmp/Makefile index 90f00c650a81..efc8edaaf6e6 100644 --- a/board/xilinx/zynqmp/Makefile +++ b/board/xilinx/zynqmp/Makefile @@ -27,3 +27,6 @@ CFLAGS_REMOVE_psu_init_gpl.o := -Wstrict-prototypes
# To include xil_io.h CFLAGS_psu_init_gpl.o := -I$(srctree)/$(src) + +# To suppress "warning: cast to pointer from integer of different size" +CFLAGS_psu_init_gpl.o += -Wno-int-to-pointer-cast diff --git a/board/xilinx/zynqmp/xil_io.h b/board/xilinx/zynqmp/xil_io.h index 57ca4adf11bf..6bbc000da828 100644 --- a/board/xilinx/zynqmp/xil_io.h +++ b/board/xilinx/zynqmp/xil_io.h @@ -7,6 +7,7 @@
/* FIXME remove this when vivado is fixed */ #include <asm/io.h> +#include <common.h>
#define xil_printf(...)
@@ -32,4 +33,12 @@ int Xil_In32(unsigned long addr) return readl(addr); }
+void mask_delay(u32 delay); +void usleep(u32 sleep) +{ + udelay(sleep); +} +int mask_poll(u32 add, u32 mask); +int mask_pollOnValue(u32 add, u32 mask, u32 value); + #endif /* XIL_IO_H */
Michal Simek
