[U-Boot] U-Boot 2015.04 failing to build with GCC 5.1
Hello,
We are working at enabling GCC 5.1 at the Yocto Project and we found a build error:
make -f ../scripts/Makefile.build obj=examples/standalone arm-oel-linux-gnueabi-ld.bfd -pie --gc-sections -Bstatic -Ttext 0x40002000 -o u-boot -T u-boot.lds arch/arm/cpu/arm926ejs/start.o --start-group arch/arm/cpu/built-in.o arch/arm/cpu/arm926ejs/built-in.o arch/arm/imx-common/built-in.o arch/arm/lib/built-in.o board/freescale/common/built-in.o board/freescale/mx28evk/built-in.o common/built-in.o disk/built-in.o drivers/built-in.o drivers/dma/built-in.o drivers/gpio/built-in.o drivers/i2c/built-in.o drivers/mmc/built-in.o drivers/mtd/built-in.o drivers/mtd/nand/built-in.o drivers/mtd/onenand/built-in.o drivers/mtd/spi/built-in.o drivers/mtd/ubi/built-in.o drivers/net/built-in.o drivers/net/phy/built-in.o drivers/pci/built-in.o drivers/power/built-in.o drivers/power/battery/built-in.o drivers/power/fuel_gauge/built-in.o drivers/power/mfd/built-in.o drivers/power/pmic/built-in.o drivers/serial/built-in.o drivers/spi/built-in.o drivers/usb/eth/built-in.o drivers/usb/gadget/built-in.o drivers/usb/host/built-in.o drivers/usb/musb-new/built-in.o drivers/usb/musb/built-in.o drivers/usb/phy/built-in.o drivers/usb/ulpi/built-in.o fs/built-in.o lib/built-in.o net/built-in.o test/built-in.o test/dm/built-in.o --end-group arch/arm/lib/eabi_compat.o -L /home/otavio/src/ossystems/yocto/build/tmp/sysroots/imx28evk/usr/lib/arm-oel-linux-gnueabi/5.1.0 -lgcc -Map u-boot.map arch/arm/cpu/arm926ejs/start.o: In function `flush_dcache': /home/otavio/src/ossystems/yocto/build/tmp/work/imx28evk-oel-linux-gnueabi/u-boot-fslc/v2015.04+gitAUTOINC+b16ec2de8d-r0/git/mx28evk_config/../arch/arm/cpu/arm926ejs/start.S:108: undefined reference to `lowlevel_init' arm-oel-linux-gnueabi-ld.bfd: BFD (GNU Binutils) 2.25.0 assertion fail /home/otavio/src/ossystems/yocto/build/tmp/work/x86_64-oel-linux-gnueabi/binutils-cross-arm/2.25-r0/git/bfd/elf32-arm.c:7827 arm-oel-linux-gnueabi-ld.bfd: error: required section '.rel.plt' not found in the linker script arm-oel-linux-gnueabi-ld.bfd: final link failed: Invalid operation /home/otavio/src/ossystems/yocto/build/tmp/work/imx28evk-oel-linux-gnueabi/u-boot-fslc/v2015.04+gitAUTOINC+b16ec2de8d-r0/git/Makefile:1127: recipe for target 'u-boot' failed make[1]: *** [u-boot] Error 1 make[1]: Leaving directory '/home/otavio/src/ossystems/yocto/build/tmp/work/imx28evk-oel-linux-gnueabi/u-boot-fslc/v2015.04+gitAUTOINC+b16ec2de8d-r0/git/mx28evk_config' Makefile:145: recipe for target 'sub-make' failed make: *** [sub-make] Error 2
Does someone have any idea what is going on?
On Tue, May 12, 2015 at 10:00 PM, Otavio Salvador otavio@ossystems.com.br wrote:
Hello,
On Fedora we've been building with gcc5 for some time, Hans added support for it in the following commit
http://git.denx.de/?p=u-boot.git;a=commit;h=478b02f1a7043b673565075ea5016376...
Peter
Hello,
May it be related to the out of tree build?
Otavio Salvador
Peter Robinson
