[U-Boot] Add CONFIG_API to config_distribution
Since the goal of the common include is to boot many distros, also include the api to boot distro's relying on the api, like GRUB / ubldr / vxWorks.
Jeroen Hofstee (2): api: fix build without CMD_NET support config_distro_defaults.h: add CONFIG_API
api/api_net.c | 30 ++++++++++++++++++++++++++++++ include/config_distro_defaults.h | 4 ++++ 2 files changed, 34 insertions(+)
Provide stubs in case that no NET interface is supported.
Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- api/api_net.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/api/api_net.c b/api/api_net.c index 3f52d71..7b3805e 100644 --- a/api/api_net.c +++ b/api/api_net.c @@ -25,6 +25,7 @@ DECLARE_GLOBAL_DATA_PTR;
#define errf(fmt, args...) do { printf("ERROR @ %s(): ", __func__); printf(fmt, ##args); } while (0)
+#ifdef CONFIG_CMD_NET
static int dev_valid_net(void *cookie) { @@ -85,3 +86,32 @@ int dev_read_net(void *cookie, void *buf, int len)
return eth_receive(buf, len); } + +#else + +int dev_open_net(void *cookie) +{ + return API_ENODEV; +} + +int dev_close_net(void *cookie) +{ + return API_ENODEV; +} + +int dev_enum_net(struct device_info *di) +{ + return 0; +} + +int dev_write_net(void *cookie, void *buf, int len) +{ + return API_ENODEV; +} + +int dev_read_net(void *cookie, void *buf, int len) +{ + return API_ENODEV; +} + +#endif
Grub, FreeBSD ubldr, vxworks etc depend on the API
Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- include/config_distro_defaults.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index 5d18a4b..b4f6f3c 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -53,4 +53,8 @@ #define CONFIG_SUPPORT_RAW_INITRD #define CONFIG_SYS_HUSH_PARSER
+/* Grub, FreeBSD ubldr, vxworks etc depend on the API */ +#define CONFIG_API +#define CONFIG_SYS_MMC_MAX_DEVICE 4 + #endif /* _CONFIG_CMD_DISTRO_DEFAULTS_H */
So I'm not 100% sold on this. A while back (it's in the archives) we had said no to CONFIG_API. Grub wasn't a good use-case (esp since we're handling extlinux.conf files), VxWorks is bootm/bootelf.
I am open to hearing how/why we need this for ubldr.
Hello Tom,
ok, lets start with I hope what I hope config_distro_defaults is. At the moment, if you buy a demo board and try to run a custom image on it, chances are big it won't boot. Either because it searches for a wrong file, commands are not supported, they have different syntax, different image formats etc. It is not uncommon that I need to update u-boot before I can run a simple custom image. It would of course be a lot better if you can stick an image in a demo board, which actually boots and even better optionally ask you what to boot. And I am in the impression / hope config_distro_defaults is for that purpose. Not the smallest / fastest u-boot, but one which can actually boot different distro's, images, demos etc. (or at least an attempt to do so). For completeness, this already holds for linux distro's / images / buildtools.
The typical bootpath for FreeBSD images is:
[something] -> loader[1] -> FreeBSD
In case of u-boot "something" is u-boot and loader is ubldr (which is loader to talk with u-boot by its API). It would be nice if this just worked without modifying u-boot, as the image might be in nand etc.
I couldn't find a good reason why grub is not an use-case. (besides some complaining and no-funding)
I am still in the dark with respect to extlinux.conf. There is no documentation nor users for it in u-boot it seems. But even if an FreeBSD boot would use a FreeBSD.conf or similiar it would still need CONFIG_API to work correctly.
grep said:
/* Boot FreeBSD/vxWorks from an ELF image */ #if defined(CONFIG_ZYNQ_BOOT_FREEBSD) # define CONFIG_API # define CONFIG_CMD_ELF # define CONFIG_SYS_MMC_MAX_DEVICE 1 #endif
hence I assumed it needs the api as well.
ublr depends on a u-boot with CONFIG_API enabled. It won't work otherwise.
[2] contains some background about the boot process from u-boot.
Regards, Jeroen
[1] https://www.freebsd.org/cgi/man.cgi?loader(8) [2] http://www.bsdcan.org/2008/schedule/attachments/49_2008_uboot_freebsd.pdf
Jeroen Hofstee
