[U-Boot] [PATCH 00/11 V11] EXYNOS5420: Add SMDK5420 board support
This patch adds basic board support for SMDK5420 board. These patches are tested for booting fine on EVT1 SMDK5420.
Changes in V2: - Corrected a compilation issue for SMDK5420.
Changes in V3: - Add patch to support variable size SPL support - Add patch to disable SMU for eMMC.
Changes in V4: - Added check for MAX77686 pmic compilation. - Added correct calculation of gpio based addresses. - Rebased on the latest u-boot code. - Removed patches for UART and TZPC changes as they were not needed. - Added flag to disable SMU for eMMC.
Changes in V5: - Moved functions board_mmc_init and board_eth_init to common/board.c in case of device tree support.
Changes in V6: - Rebased on the latest mainline branch. - Moved the definitions for SMU to arch/arm dwmmc.h
Changes in V7: - Removed below patch as it is already merged "DWMMC: SMDK5420: Disable SMU for eMMC" - Corrected the multi line comments and removal of blank spaces and lines. - Corrected the license.
Changes in V8: - corrected the if loops with if conditions of pro_id and cpu_id.
Changes in V9: - Added macros to get the base address - Rebased on latest code.
Changes in V10: - Added new structures for Power and DMC registers for 5420. - Changed the input parameters for common dmc functions. - Removed unnecesarry blank lines and added where ever required.
Changes in V11: -Rebased on latest u-boot-samsung branch.
Rajeshwari S Shinde (11): EXYNOS5: Create a common board file Exynos5420: Add base addresses for 5420 EXYNOS5420: Add power register structure. EXYNOS5420: Add dmc and phy_control register structure Exynos5420: Add clock initialization for 5420 Exynos5420: Add DDR3 initialization for 5420 Exynos5420: Add support for 5420 in pinmux and gpio Exynos5420: Add base patch for SMDK5420 DTS: Add dts support for SMDK5420 Config: Add initial config for SMDK5420 SPL: EXYNOS: Prepare for variable size SPL support
arch/arm/cpu/armv7/exynos/clock.c | 279 ++++++++- arch/arm/cpu/armv7/exynos/clock_init.h | 17 + arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 352 ++++++++++- arch/arm/cpu/armv7/exynos/dmc_common.c | 60 +- arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 439 ++++++++++++- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 764 ++++++++++++++++------ arch/arm/cpu/armv7/exynos/pinmux.c | 260 +++++++- arch/arm/dts/exynos5.dtsi | 198 ++++++ arch/arm/dts/exynos5250.dtsi | 194 +----- arch/arm/dts/exynos5420.dtsi | 70 +++ arch/arm/include/asm/arch-exynos/board.h | 17 + arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/clock.h | 494 +++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 52 +- arch/arm/include/asm/arch-exynos/dmc.h | 177 ++++++ arch/arm/include/asm/arch-exynos/gpio.h | 143 ++++- arch/arm/include/asm/arch-exynos/periph.h | 3 + arch/arm/include/asm/arch-exynos/power.h | 837 +++++++++++++++++++++++++ board/samsung/common/Makefile | 4 + board/samsung/common/board.c | 410 ++++++++++++ board/samsung/dts/exynos5420-smdk5420.dts | 169 +++++ board/samsung/smdk5250/exynos5-dt.c | 352 +---------- board/samsung/smdk5250/smdk5250.c | 182 +----- board/samsung/smdk5420/Makefile | 11 + board/samsung/smdk5420/smdk5420.c | 159 +++++ board/samsung/smdk5420/smdk5420_spl.c | 52 ++ boards.cfg | 1 + include/configs/arndale.h | 1 + include/configs/exynos5-dt.h | 289 +++++++++ include/configs/exynos5250-dt.h | 283 +-------- include/configs/smdk5420.h | 56 ++ spl/Makefile | 7 +- tools/Makefile | 3 +- tools/mkexynosspl.c | 167 +++-- 34 files changed, 5188 insertions(+), 1315 deletions(-) create mode 100644 arch/arm/dts/exynos5.dtsi create mode 100644 arch/arm/dts/exynos5420.dtsi create mode 100644 arch/arm/include/asm/arch-exynos/board.h create mode 100644 board/samsung/common/board.c create mode 100644 board/samsung/dts/exynos5420-smdk5420.dts create mode 100644 board/samsung/smdk5420/Makefile create mode 100644 board/samsung/smdk5420/smdk5420.c create mode 100644 board/samsung/smdk5420/smdk5420_spl.c create mode 100644 include/configs/exynos5-dt.h create mode 100644 include/configs/smdk5420.h
Create a common board.c file for all functions which are common across all EXYNOS5 platforms.
exynos_init function is provided for platform specific code.
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com --- Changes in V2: - None Changes in V3: - None Changes in V4: - Added check for the compilation of MAX77686 pmic. Changes in V5: - Moved board_eth_init and board_mmc_init in case of device tree support Changes in V6: - None. Changes in V7: - None Changes in V8: - None Changes in V9: - Reabsed on latest code. Changes in V10: - Corrected coding style nits. Changes in V11: -Rebased on latest u-boot-samsung tree arch/arm/include/asm/arch-exynos/board.h | 17 ++ board/samsung/common/Makefile | 4 + board/samsung/common/board.c | 408 +++++++++++++++++++++++++++++++ board/samsung/smdk5250/exynos5-dt.c | 352 +------------------------- board/samsung/smdk5250/smdk5250.c | 182 +------------- include/configs/exynos5250-dt.h | 2 + 6 files changed, 436 insertions(+), 529 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/board.h create mode 100644 board/samsung/common/board.c
diff --git a/arch/arm/include/asm/arch-exynos/board.h b/arch/arm/include/asm/arch-exynos/board.h new file mode 100644 index 0000000..243fb12 --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/board.h @@ -0,0 +1,17 @@ +/* + * (C) Copyright 2013 Samsung Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _EXYNOS_BOARD_H +#define _EXYNOS_BOARD_H + +/* + * Exynos baord specific changes for + * board_init + */ +int exynos_init(void); + +#endif /* EXYNOS_BOARD_H */ diff --git a/board/samsung/common/Makefile b/board/samsung/common/Makefile index 501d974..22bd6b1 100644 --- a/board/samsung/common/Makefile +++ b/board/samsung/common/Makefile @@ -8,3 +8,7 @@ obj-$(CONFIG_SOFT_I2C_MULTI_BUS) += multi_i2c.o obj-$(CONFIG_THOR_FUNCTION) += thor.o obj-$(CONFIG_CMD_USB_MASS_STORAGE) += ums.o + +ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_BOARD_COMMON) += board.o +endif diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c new file mode 100644 index 0000000..95df346 --- /dev/null +++ b/board/samsung/common/board.c @@ -0,0 +1,408 @@ +/* + * (C) Copyright 2013 SAMSUNG Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <cros_ec.h> +#include <errno.h> +#include <fdtdec.h> +#include <spi.h> +#include <tmu.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/board.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dwmmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mmc.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/power.h> +#include <power/pmic.h> +#include <asm/arch/sromc.h> +#include <power/max77686_pmic.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct local_info { + struct cros_ec_dev *cros_ec_dev; /* Pointer to cros_ec device */ + int cros_ec_err; /* Error for cros_ec, 0 if ok */ +}; + +static struct local_info local; + +#if defined CONFIG_EXYNOS_TMU +/* Boot Time Thermal Analysis for SoC temperature threshold breach */ +static void boot_temp_check(void) +{ + int temp; + + switch (tmu_monitor(&temp)) { + case TMU_STATUS_NORMAL: + break; + case TMU_STATUS_TRIPPED: + /* Status TRIPPED ans WARNING means corresponding threshold breach */ + puts("EXYNOS_TMU: TRIPPING! Device power going down ...\n"); + set_ps_hold_ctrl(); + hang(); + break; + case TMU_STATUS_WARNING: + puts("EXYNOS_TMU: WARNING! Temperature very high\n"); + break; + case TMU_STATUS_INIT: + /* + * TMU_STATUS_INIT means something is wrong with temperature sensing + * and TMU status was changed back from NORMAL to INIT. + */ + puts("EXYNOS_TMU: WARNING! Temperature sensing not done\n"); + break; + default: + debug("EXYNOS_TMU: Unknown TMU state\n"); + } +} +#endif + +int board_init(void) +{ + gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); +#if defined CONFIG_EXYNOS_TMU + if (tmu_init(gd->fdt_blob) != TMU_STATUS_NORMAL) { + debug("%s: Failed to init TMU\n", __func__); + return -1; + } + boot_temp_check(); +#endif + +#ifdef CONFIG_EXYNOS_SPI + spi_init(); +#endif + return exynos_init(); +} + +int dram_init(void) +{ + int i; + u32 addr; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); + gd->ram_size += get_ram_size((long *)addr, SDRAM_BANK_SIZE); + } + return 0; +} + +void dram_init_banksize(void) +{ + int i; + u32 addr, size; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); + size = get_ram_size((long *)addr, SDRAM_BANK_SIZE); + + gd->bd->bi_dram[i].start = addr; + gd->bd->bi_dram[i].size = size; + } +} + +static int board_uart_init(void) +{ + int err, uart_id, ret = 0; + + for (uart_id = PERIPH_ID_UART0; uart_id <= PERIPH_ID_UART3; uart_id++) { + err = exynos_pinmux_config(uart_id, PINMUX_FLAG_NONE); + if (err) { + debug("UART%d not configured\n", + (uart_id - PERIPH_ID_UART0)); + ret |= err; + } + } + return ret; +} + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + int err; + + err = board_uart_init(); + if (err) { + debug("UART init failed\n"); + return err; + } + +#ifdef CONFIG_SYS_I2C_INIT_BOARD + board_i2c_init(gd->fdt_blob); +#endif + + return err; +} +#endif + +struct cros_ec_dev *board_get_cros_ec_dev(void) +{ + return local.cros_ec_dev; +} + +static int board_init_cros_ec_devices(const void *blob) +{ + local.cros_ec_err = cros_ec_init(blob, &local.cros_ec_dev); + if (local.cros_ec_err) + return -1; /* Will report in board_late_init() */ + + return 0; +} + +#if defined(CONFIG_POWER) +#ifdef CONFIG_POWER_MAX77686 +static int pmic_reg_update(struct pmic *p, int reg, uint regval) +{ + u32 val; + int ret = 0; + + ret = pmic_reg_read(p, reg, &val); + if (ret) { + debug("%s: PMIC %d register read failed\n", __func__, reg); + return -1; + } + val |= regval; + ret = pmic_reg_write(p, reg, val); + if (ret) { + debug("%s: PMIC %d register write failed\n", __func__, reg); + return -1; + } + return 0; +} + +static int max77686_init(void) +{ + struct pmic *p; + + if (pmic_init(I2C_PMIC)) + return -1; + + p = pmic_get("MAX77686_PMIC"); + if (!p) + return -ENODEV; + + if (pmic_probe(p)) + return -1; + + if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) + return -1; + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, + MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) + return -1; + + /* VDD_MIF */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, + MAX77686_BUCK1OUT_1V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK1OUT); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, + MAX77686_BUCK1CTRL_EN)) + return -1; + + /* VDD_ARM */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, + MAX77686_BUCK2DVS1_1_3V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK2DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, + MAX77686_BUCK2CTRL_ON)) + return -1; + + /* VDD_INT */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, + MAX77686_BUCK3DVS1_1_0125V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK3DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, + MAX77686_BUCK3CTRL_ON)) + return -1; + + /* VDD_G3D */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, + MAX77686_BUCK4DVS1_1_2V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK4DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, + MAX77686_BUCK3CTRL_ON)) + return -1; + + /* VDD_LDO2 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, + MAX77686_LD02CTRL1_1_5V | EN_LDO)) + return -1; + + /* VDD_LDO3 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, + MAX77686_LD03CTRL1_1_8V | EN_LDO)) + return -1; + + /* VDD_LDO5 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, + MAX77686_LD05CTRL1_1_8V | EN_LDO)) + return -1; + + /* VDD_LDO10 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, + MAX77686_LD10CTRL1_1_8V | EN_LDO)) + return -1; + + return 0; +} +#endif + +int power_init_board(void) +{ + int ret = 0; + + set_ps_hold_ctrl(); + + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + +#ifdef CONFIG_POWER_MAX77686 + ret = max77686_init(); +#endif + + return ret; +} +#endif + +#ifdef CONFIG_OF_CONTROL +static int decode_sromc(const void *blob, struct fdt_sromc *config) +{ + int err; + int node; + + node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS5_SROMC); + if (node < 0) { + debug("Could not find SROMC node\n"); + return node; + } + + config->bank = fdtdec_get_int(blob, node, "bank", 0); + config->width = fdtdec_get_int(blob, node, "width", 2); + + err = fdtdec_get_int_array(blob, node, "srom-timing", config->timing, + FDT_SROM_TIMING_COUNT); + if (err < 0) { + debug("Could not decode SROMC configuration Error: %s\n", + fdt_strerror(err)); + return -FDT_ERR_NOTFOUND; + } + return 0; +} + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_SMC911X + u32 smc_bw_conf, smc_bc_conf; + struct fdt_sromc config; + fdt_addr_t base_addr; + int node; + + node = decode_sromc(gd->fdt_blob, &config); + if (node < 0) { + debug("%s: Could not find sromc configuration\n", __func__); + return 0; + } + node = fdtdec_next_compatible(gd->fdt_blob, node, COMPAT_SMSC_LAN9215); + if (node < 0) { + debug("%s: Could not find lan9215 configuration\n", __func__); + return 0; + } + + /* We now have a node, so any problems from now on are errors */ + base_addr = fdtdec_get_addr(gd->fdt_blob, node, "reg"); + if (base_addr == FDT_ADDR_T_NONE) { + debug("%s: Could not find lan9215 address\n", __func__); + return -1; + } + + /* Ethernet needs data bus width of 16 bits */ + if (config.width != 2) { + debug("%s: Unsupported bus width %d\n", __func__, + config.width); + return -1; + } + smc_bw_conf = SROMC_DATA16_WIDTH(config.bank) + | SROMC_BYTE_ENABLE(config.bank); + + smc_bc_conf = SROMC_BC_TACS(config.timing[FDT_SROM_TACS]) | + SROMC_BC_TCOS(config.timing[FDT_SROM_TCOS]) | + SROMC_BC_TACC(config.timing[FDT_SROM_TACC]) | + SROMC_BC_TCOH(config.timing[FDT_SROM_TCOH]) | + SROMC_BC_TAH(config.timing[FDT_SROM_TAH]) | + SROMC_BC_TACP(config.timing[FDT_SROM_TACP]) | + SROMC_BC_PMC(config.timing[FDT_SROM_PMC]); + + /* Select and configure the SROMC bank */ + exynos_pinmux_config(PERIPH_ID_SROMC, config.bank); + s5p_config_sromc(config.bank, smc_bw_conf, smc_bc_conf); + return smc911x_initialize(0, base_addr); +#endif + return 0; +} + +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + int ret; + + /* dwmmc initializattion for available channels */ + ret = exynos_dwmmc_init(gd->fdt_blob); + if (ret) + debug("dwmmc init failed\n"); + + return ret; +} +#endif +#endif + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + stdio_print_current_devices(); + + if (local.cros_ec_err) { + /* Force console on */ + gd->flags &= ~GD_FLG_SILENT; + + printf("cros-ec communications failure %d\n", + local.cros_ec_err); + puts("\nPlease reset with Power+Refresh\n\n"); + panic("Cannot init cros-ec device"); + return -1; + } + return 0; +} +#endif + +int arch_early_init_r(void) +{ +#ifdef CONFIG_CROS_EC + if (board_init_cros_ec_devices(gd->fdt_blob)) { + printf("%s: Failed to init EC\n", __func__); + return 0; + } +#endif + + return 0; +} diff --git a/board/samsung/smdk5250/exynos5-dt.c b/board/samsung/smdk5250/exynos5-dt.c index 6bcc883..5fb8664 100644 --- a/board/samsung/smdk5250/exynos5-dt.c +++ b/board/samsung/smdk5250/exynos5-dt.c @@ -25,44 +25,8 @@
-#if defined CONFIG_EXYNOS_TMU -/* - * Boot Time Thermal Analysis for SoC temperature threshold breach - */ -static void boot_temp_check(void) -{ - int temp; - - switch (tmu_monitor(&temp)) { - /* Status TRIPPED ans WARNING means corresponding threshold breach */ - case TMU_STATUS_TRIPPED: - puts("EXYNOS_TMU: TRIPPING! Device power going down ...\n"); - set_ps_hold_ctrl(); - hang(); - break; - case TMU_STATUS_WARNING: - puts("EXYNOS_TMU: WARNING! Temperature very high\n"); - break; - /* - * TMU_STATUS_INIT means something is wrong with temperature sensing - * and TMU status was changed back from NORMAL to INIT. - */ - case TMU_STATUS_INIT: - default: - debug("EXYNOS_TMU: Unknown TMU state\n"); - } -} -#endif - -struct local_info { - struct cros_ec_dev *cros_ec_dev; /* Pointer to cros_ec device */ - int cros_ec_err; /* Error for cros_ec, 0 if ok */ -}; - -static struct local_info local; - #ifdef CONFIG_SOUND_MAX98095 -static void board_enable_audio_codec(void) +static void board_enable_audio_codec(void) { struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); @@ -73,263 +37,14 @@ static void board_enable_audio_codec(void) } #endif
-struct cros_ec_dev *board_get_cros_ec_dev(void) -{ - return local.cros_ec_dev; -} - -static int board_init_cros_ec_devices(const void *blob) -{ - local.cros_ec_err = cros_ec_init(blob, &local.cros_ec_dev); - if (local.cros_ec_err) - return -1; /* Will report in board_late_init() */ - - return 0; -} - -int board_init(void) +int exynos_init(void) { - gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); - -#if defined CONFIG_EXYNOS_TMU - if (tmu_init(gd->fdt_blob) != TMU_STATUS_NORMAL) { - debug("%s: Failed to init TMU\n", __func__); - return -1; - } - boot_temp_check(); -#endif - -#ifdef CONFIG_EXYNOS_SPI - spi_init(); -#endif - - if (board_init_cros_ec_devices(gd->fdt_blob)) - return -1; - #ifdef CONFIG_SOUND_MAX98095 board_enable_audio_codec(); #endif return 0; }
-int dram_init(void) -{ - int i; - u32 addr; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); - gd->ram_size += get_ram_size((long *)addr, SDRAM_BANK_SIZE); - } - return 0; -} - -#if defined(CONFIG_POWER) -static int pmic_reg_update(struct pmic *p, int reg, uint regval) -{ - u32 val; - int ret = 0; - - ret = pmic_reg_read(p, reg, &val); - if (ret) { - debug("%s: PMIC %d register read failed\n", __func__, reg); - return -1; - } - val |= regval; - ret = pmic_reg_write(p, reg, val); - if (ret) { - debug("%s: PMIC %d register write failed\n", __func__, reg); - return -1; - } - return 0; -} - -int power_init_board(void) -{ - struct pmic *p; - - set_ps_hold_ctrl(); - - i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - - if (pmic_init(I2C_PMIC)) - return -1; - - p = pmic_get("MAX77686_PMIC"); - if (!p) - return -ENODEV; - - if (pmic_probe(p)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, - MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) - return -1; - - /* VDD_MIF */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, - MAX77686_BUCK1OUT_1V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK1OUT); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, - MAX77686_BUCK1CTRL_EN)) - return -1; - - /* VDD_ARM */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, - MAX77686_BUCK2DVS1_1_3V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK2DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, - MAX77686_BUCK2CTRL_ON)) - return -1; - - /* VDD_INT */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, - MAX77686_BUCK3DVS1_1_0125V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK3DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_G3D */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, - MAX77686_BUCK4DVS1_1_2V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK4DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_LDO2 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, - MAX77686_LD02CTRL1_1_5V | EN_LDO)) - return -1; - - /* VDD_LDO3 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, - MAX77686_LD03CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO5 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, - MAX77686_LD05CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO10 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, - MAX77686_LD10CTRL1_1_8V | EN_LDO)) - return -1; - - return 0; -} -#endif - -void dram_init_banksize(void) -{ - int i; - u32 addr, size; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); - size = get_ram_size((long *)addr, SDRAM_BANK_SIZE); - - gd->bd->bi_dram[i].start = addr; - gd->bd->bi_dram[i].size = size; - } -} - -static int decode_sromc(const void *blob, struct fdt_sromc *config) -{ - int err; - int node; - - node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS5_SROMC); - if (node < 0) { - debug("Could not find SROMC node\n"); - return node; - } - - config->bank = fdtdec_get_int(blob, node, "bank", 0); - config->width = fdtdec_get_int(blob, node, "width", 2); - - err = fdtdec_get_int_array(blob, node, "srom-timing", config->timing, - FDT_SROM_TIMING_COUNT); - if (err < 0) { - debug("Could not decode SROMC configuration Error: %s\n", - fdt_strerror(err)); - return -FDT_ERR_NOTFOUND; - } - return 0; -} - -int board_eth_init(bd_t *bis) -{ -#ifdef CONFIG_SMC911X - u32 smc_bw_conf, smc_bc_conf; - struct fdt_sromc config; - fdt_addr_t base_addr; - int node; - - node = decode_sromc(gd->fdt_blob, &config); - if (node < 0) { - debug("%s: Could not find sromc configuration\n", __func__); - return 0; - } - node = fdtdec_next_compatible(gd->fdt_blob, node, COMPAT_SMSC_LAN9215); - if (node < 0) { - debug("%s: Could not find lan9215 configuration\n", __func__); - return 0; - } - - /* We now have a node, so any problems from now on are errors */ - base_addr = fdtdec_get_addr(gd->fdt_blob, node, "reg"); - if (base_addr == FDT_ADDR_T_NONE) { - debug("%s: Could not find lan9215 address\n", __func__); - return -1; - } - - /* Ethernet needs data bus width of 16 bits */ - if (config.width != 2) { - debug("%s: Unsupported bus width %d\n", __func__, - config.width); - return -1; - } - smc_bw_conf = SROMC_DATA16_WIDTH(config.bank) - | SROMC_BYTE_ENABLE(config.bank); - - smc_bc_conf = SROMC_BC_TACS(config.timing[FDT_SROM_TACS]) | - SROMC_BC_TCOS(config.timing[FDT_SROM_TCOS]) | - SROMC_BC_TACC(config.timing[FDT_SROM_TACC]) | - SROMC_BC_TCOH(config.timing[FDT_SROM_TCOH]) | - SROMC_BC_TAH(config.timing[FDT_SROM_TAH]) | - SROMC_BC_TACP(config.timing[FDT_SROM_TACP]) | - SROMC_BC_PMC(config.timing[FDT_SROM_PMC]); - - /* Select and configure the SROMC bank */ - exynos_pinmux_config(PERIPH_ID_SROMC, config.bank); - s5p_config_sromc(config.bank, smc_bw_conf, smc_bc_conf); - return smc911x_initialize(0, base_addr); -#endif - return 0; -} - #ifdef CONFIG_DISPLAY_BOARDINFO int checkboard(void) { @@ -345,50 +60,6 @@ int checkboard(void) } #endif
-#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - int ret; - /* dwmmc initializattion for available channels */ - ret = exynos_dwmmc_init(gd->fdt_blob); - if (ret) - debug("dwmmc init failed\n"); - - return ret; -} -#endif - -static int board_uart_init(void) -{ - int err, uart_id, ret = 0; - - for (uart_id = PERIPH_ID_UART0; uart_id <= PERIPH_ID_UART3; uart_id++) { - err = exynos_pinmux_config(uart_id, PINMUX_FLAG_NONE); - if (err) { - debug("UART%d not configured\n", - (uart_id - PERIPH_ID_UART0)); - ret |= err; - } - } - return ret; -} - -#ifdef CONFIG_BOARD_EARLY_INIT_F -int board_early_init_f(void) -{ - int err; - err = board_uart_init(); - if (err) { - debug("UART init failed\n"); - return err; - } -#ifdef CONFIG_SYS_I2C_INIT_BOARD - board_i2c_init(gd->fdt_blob); -#endif - return err; -} -#endif - #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) { @@ -412,22 +83,3 @@ void exynos_set_dp_phy(unsigned int onoff) set_dp_phy_ctrl(onoff); } #endif - -#ifdef CONFIG_BOARD_LATE_INIT -int board_late_init(void) -{ - stdio_print_current_devices(); - - if (local.cros_ec_err) { - /* Force console on */ - gd->flags &= ~GD_FLG_SILENT; - - printf("cros-ec communications failure %d\n", - local.cros_ec_err); - puts("\nPlease reset with Power+Refresh\n\n"); - panic("Cannot init cros-ec device"); - return -1; - } - return 0; -} -#endif diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index 97fe0ad..943c29a 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <cros_ec.h> #include <fdtdec.h> #include <asm/io.h> #include <errno.h> @@ -26,7 +27,7 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_USB_EHCI_EXYNOS -int board_usb_vbus_init(void) +static int board_usb_vbus_init(void) { struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); @@ -53,13 +54,8 @@ static void board_enable_audio_codec(void) } #endif
-int board_init(void) +int exynos_init(void) { - gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); - -#ifdef CONFIG_EXYNOS_SPI - spi_init(); -#endif #ifdef CONFIG_USB_EHCI_EXYNOS board_usb_vbus_init(); #endif @@ -69,147 +65,6 @@ int board_init(void) return 0; }
-int dram_init(void) -{ - int i; - u32 addr; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); - gd->ram_size += get_ram_size((long *)addr, SDRAM_BANK_SIZE); - } - return 0; -} - -#if defined(CONFIG_POWER) -static int pmic_reg_update(struct pmic *p, int reg, uint regval) -{ - u32 val; - int ret = 0; - - ret = pmic_reg_read(p, reg, &val); - if (ret) { - debug("%s: PMIC %d register read failed\n", __func__, reg); - return -1; - } - val |= regval; - ret = pmic_reg_write(p, reg, val); - if (ret) { - debug("%s: PMIC %d register write failed\n", __func__, reg); - return -1; - } - return 0; -} - -int power_init_board(void) -{ - struct pmic *p; - - set_ps_hold_ctrl(); - - i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - - if (pmic_init(I2C_PMIC)) - return -1; - - p = pmic_get("MAX77686_PMIC"); - if (!p) - return -ENODEV; - - if (pmic_probe(p)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, - MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) - return -1; - - /* VDD_MIF */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, - MAX77686_BUCK1OUT_1_05V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK1OUT); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, - MAX77686_BUCK1CTRL_EN)) - return -1; - - /* VDD_ARM */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, - MAX77686_BUCK2DVS1_1_3V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK2DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, - MAX77686_BUCK2CTRL_ON)) - return -1; - - /* VDD_INT */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, - MAX77686_BUCK3DVS1_1_0125V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK3DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_G3D */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, - MAX77686_BUCK4DVS1_1_2V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK4DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_LDO2 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, - MAX77686_LD02CTRL1_1_5V | EN_LDO)) - return -1; - - /* VDD_LDO3 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, - MAX77686_LD03CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO5 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, - MAX77686_LD05CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO10 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, - MAX77686_LD10CTRL1_1_8V | EN_LDO)) - return -1; - - return 0; -} -#endif - -void dram_init_banksize(void) -{ - int i; - u32 addr, size; - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); - size = get_ram_size((long *)addr, SDRAM_BANK_SIZE); - gd->bd->bi_dram[i].start = addr; - gd->bd->bi_dram[i].size = size; - } -} - int board_eth_init(bd_t *bis) { #ifdef CONFIG_SMC911X @@ -301,21 +156,6 @@ int board_mmc_init(bd_t *bis) } #endif
-static int board_uart_init(void) -{ - int err, uart_id, ret = 0; - - for (uart_id = PERIPH_ID_UART0; uart_id <= PERIPH_ID_UART3; uart_id++) { - err = exynos_pinmux_config(uart_id, PINMUX_FLAG_NONE); - if (err) { - debug("UART%d not configured\n", - (uart_id - PERIPH_ID_UART0)); - ret |= err; - } - } - return ret; -} - void board_i2c_init(const void *blob) { int i; @@ -326,22 +166,6 @@ void board_i2c_init(const void *blob) } }
-#ifdef CONFIG_BOARD_EARLY_INIT_F -int board_early_init_f(void) -{ - int err; - err = board_uart_init(); - if (err) { - debug("UART init failed\n"); - return err; - } -#ifdef CONFIG_SYS_I2C_INIT_BOARD - board_i2c_init(NULL); -#endif - return err; -} -#endif - #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) { diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index dee18a7..c625524 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -21,6 +21,8 @@ #define CONFIG_ARCH_CPU_INIT #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_COMMON +#define CONFIG_ARCH_EARLY_INIT_R
/* Enable fdt support for Exynos5250 */ #define CONFIG_OF_CONTROL
On 16 December 2013 01:42, Rajeshwari S Shinde rajeshwari.s@samsung.com wrote:
Adds base addresses of various IPs and controllers required for Exynos5420.
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - Added base address for TZPC. Changes in V5: - None Chnages in V6: - Rebased on latest samsung mainline branch. Changes in V7: - Corrected the comments Changes in V8: - None Changes in V9: - None Changes in V10: - None Changes in V11: - None arch/arm/include/asm/arch-exynos/cpu.h | 49 +++++++++++++++++++++++++++++++++- 1 file changed, 48 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index b4ef03e..2b44210 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -92,7 +92,7 @@ #define EXYNOS4X12_USB_HOST_XHCI_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4X12_USB3PHY_BASE DEVICE_NOT_AVAILABLE
-/* EXYNOS5 Common*/ +/* EXYNOS5 */ #define EXYNOS5_I2C_SPACING 0x10000
#define EXYNOS5_AUDIOSS_BASE 0x03810000 @@ -130,6 +130,46 @@ #define EXYNOS5_ADC_BASE DEVICE_NOT_AVAILABLE #define EXYNOS5_MODEM_BASE DEVICE_NOT_AVAILABLE
+/* EXYNOS5420 */ +#define EXYNOS5420_AUDIOSS_BASE 0x03810000 +#define EXYNOS5420_GPIO_PART5_BASE 0x03860000 +#define EXYNOS5420_PRO_ID 0x10000000 +#define EXYNOS5420_CLOCK_BASE 0x10010000 +#define EXYNOS5420_POWER_BASE 0x10040000 +#define EXYNOS5420_SWRESET 0x10040400 +#define EXYNOS5420_SYSREG_BASE 0x10050000 +#define EXYNOS5420_TZPC_BASE 0x100E0000 +#define EXYNOS5420_WATCHDOG_BASE 0x101D0000 +#define EXYNOS5420_ACE_SFR_BASE 0x10830000 +#define EXYNOS5420_DMC_PHY_BASE 0x10C00000 +#define EXYNOS5420_DMC_CTRL_BASE 0x10C20000 +#define EXYNOS5420_DMC_TZASC0_BASE 0x10D40000 +#define EXYNOS5420_DMC_TZASC1_BASE 0x10D50000 +#define EXYNOS5420_USB_HOST_EHCI_BASE 0x12110000 +#define EXYNOS5420_MMC_BASE 0x12200000 +#define EXYNOS5420_SROMC_BASE 0x12250000 +#define EXYNOS5420_UART_BASE 0x12C00000 +#define EXYNOS5420_I2C_BASE 0x12C60000 +#define EXYNOS5420_I2C_8910_BASE 0x12E00000 +#define EXYNOS5420_SPI_BASE 0x12D20000 +#define EXYNOS5420_I2S_BASE 0x12D60000 +#define EXYNOS5420_PWMTIMER_BASE 0x12DD0000 +#define EXYNOS5420_SPI_ISP_BASE 0x131A0000 +#define EXYNOS5420_GPIO_PART2_BASE 0x13400000 +#define EXYNOS5420_GPIO_PART3_BASE 0x13410000 +#define EXYNOS5420_GPIO_PART4_BASE 0x14000000 +#define EXYNOS5420_GPIO_PART1_BASE 0x14010000 +#define EXYNOS5420_MIPI_DSIM_BASE 0x14500000 +#define EXYNOS5420_DP_BASE 0x145B0000 + +#define EXYNOS5420_USBPHY_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5420_USBOTG_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5420_FIMD_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5420_ADC_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5420_MODEM_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5420_USB3PHY_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5420_USB_HOST_XHCI_BASE DEVICE_NOT_AVAILABLE + #ifndef __ASSEMBLY__ #include <asm/io.h> /* CPU detection macros */ @@ -163,6 +203,10 @@ static inline void s5p_set_cpu_id(void) /* Exynos5250 */ s5p_cpu_id = 0x5250; break; + case 0x420: + /* Exynos5420 */ + s5p_cpu_id = 0x5420; + break; } }
@@ -190,6 +234,7 @@ static inline int __attribute__((no_instrument_function)) \ IS_EXYNOS_TYPE(exynos4210, 0x4210) IS_EXYNOS_TYPE(exynos4412, 0x4412) IS_EXYNOS_TYPE(exynos5250, 0x5250) +IS_EXYNOS_TYPE(exynos5420, 0x5420)
#define SAMSUNG_BASE(device, base) \ static inline unsigned int __attribute__((no_instrument_function)) \ @@ -200,6 +245,8 @@ static inline unsigned int __attribute__((no_instrument_function)) \ return EXYNOS4X12_##base; \ return EXYNOS4_##base; \ } else if (cpu_is_exynos5()) { \ + if (proid_is_exynos5420()) \ + return EXYNOS5420_##base; \ return EXYNOS5_##base; \ } \ return 0; \
Add structure for power register for Exynos5420
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com --- Changes in V10: - New patch Changes in V11: - None arch/arm/include/asm/arch-exynos/power.h | 837 +++++++++++++++++++++++++++++++ 1 file changed, 837 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/power.h b/arch/arm/include/asm/arch-exynos/power.h index 2bfee18..c9609a2 100644 --- a/arch/arm/include/asm/arch-exynos/power.h +++ b/arch/arm/include/asm/arch-exynos/power.h @@ -831,6 +831,843 @@ struct exynos5_power { unsigned int cmu_reset_mau_option; unsigned char res163[0x24]; }; + +struct exynos5420_power { + unsigned int om_stat; + unsigned int lpi_mask0; + unsigned int lpi_mask1; + unsigned char res1[0x10]; + unsigned int rtc_clko_sel; + unsigned char res2[0x1e0]; + unsigned int central_seq_configuration; + unsigned int central_seq_status; + unsigned int central_seq_option; + unsigned char res3[0x14]; + unsigned int seq_transition0; + unsigned int seq_transition1; + unsigned int seq_transition2; + unsigned int seq_transition3; + unsigned int seq_transition4; + unsigned int seq_transition5; + unsigned int seq_transition6; + unsigned int seq_transition7; + unsigned int central_seq_coreblk_configuration; + unsigned int central_seq_coreblk_status; + unsigned int central_seq_coreblk_option; + unsigned char res4[0x14]; + unsigned int seq_coreblk_transition0; + unsigned int seq_coreblk_transition1; + unsigned int seq_coreblk_transition2; + unsigned int seq_coreblk_transition3; + unsigned int seq_coreblk_transition4; + unsigned int seq_coreblk_transition5; + unsigned int seq_coreblk_transition6; + unsigned int seq_coreblk_transition7; + unsigned char res5[0x180]; + unsigned int swreset; + unsigned int rst_stat; + unsigned int automatic_wdt_reset_disable; + unsigned int mask_wdt_reset_request; + unsigned int mask_wreset_request; + unsigned char res6[0xec]; + unsigned int reset_sequencer_configuration; + unsigned int reset_sequencer_status; + unsigned int reset_sequencer_option; + unsigned char res7[0xf4]; + unsigned int wakeup_stat; + unsigned int eint_wakeup_mask; + unsigned int wakeup_mask; + unsigned int wakeup_interrupt; + unsigned char res8[0x10]; + unsigned int wakeup_stat_coreblk; + unsigned int eint_wakeup_mask_coreblk; + unsigned int wakeup_mask_coreblk; + unsigned int wakeup_interrupt_coreblk; + unsigned char res9[0xd0]; + unsigned int hdmi_phy_control; + unsigned int usbdev_phy_control; + unsigned int usbdev1_phy_control; + unsigned int usbhost_phy_control; + unsigned char res104[0x4]; + unsigned int mipi_phy0_control; + unsigned int mipi_phy1_control; + unsigned int mipi_phy2_control; + unsigned int adc_phy_control; + unsigned int mtcadc_phy_control; + unsigned int dptx_phy_control; + unsigned char res10[0xd4]; + unsigned int inform0; + unsigned int inform1; + unsigned int inform2; + unsigned int inform3; + unsigned int sysip_dat0; + unsigned int sysip_dat1; + unsigned int sysip_dat2; + unsigned int sysip_dat3; + unsigned char res11[0xe0]; + unsigned int pmu_spare0; + unsigned int pmu_spare1; + unsigned int pmu_spare2; + unsigned int pmu_spare3; + unsigned char res12[0x4]; + unsigned int cg_status0; + unsigned int cg_status1; + unsigned int cg_status2; + unsigned int cg_status3; + unsigned int cg_status4; + unsigned char res200[0x58]; + unsigned int irom_data_reg0; + unsigned int irom_data_reg1; + unsigned int irom_data_reg2; + unsigned int irom_data_reg3; + unsigned char res13[0x70]; + unsigned int pmu_debug; + unsigned char res14[0x5fc]; + unsigned int arm_core0_sys_pwr_reg; + unsigned char res500[0xc]; + unsigned int arm_core1_sys_pwr_reg; + unsigned char res501[0xc]; + unsigned int arm_core2_sys_pwr_reg; + unsigned char res502[0xc]; + unsigned int arm_core3_sys_pwr_reg; + unsigned char res503[0xc]; + unsigned int kfc_core0_sys_pwr_reg; + unsigned char res504[0xc]; + unsigned int kfc_core1_sys_pwr_reg; + unsigned char res505[0xc]; + unsigned int kfc_core2_sys_pwr_reg; + unsigned char res506[0xc]; + unsigned int kfc_core3_sys_pwr_reg; + unsigned char res507[0x1c]; + unsigned int isp_arm_sys_pwr_reg; + unsigned char res18[0xc]; + unsigned int arm_common_sys_pwr_reg; + unsigned char res508[0xc]; + unsigned int kfc_common_sys_pwr_reg; + unsigned char res19[0xc]; + unsigned int arm_l2_sys_pwr_reg; + unsigned char res509[0xc]; + unsigned int kfc_l2_sys_pwr_reg; + unsigned char res20[0xc]; + unsigned int cmu_cpu_aclkstop_sys_pwr_reg; + unsigned int cmu_cpu_sclkstop_sys_pwr_reg; + unsigned char res510[0x8]; + unsigned int cmu_kfc_aclkstop_sys_pwr_reg; + unsigned char res511[0xc]; + unsigned int cmu_aclkstop_sys_pwr_reg; + unsigned int cmu_sclkstop_sys_pwr_reg; + unsigned char res21[0x4]; + unsigned int cmu_reset_sys_pwr_reg; + unsigned char res22[0x10]; + unsigned int cmu_aclkstop_coreblk_sys_pwr_reg; + unsigned int cmu_sclkstop_coreblk_sys_pwr_reg; + unsigned char res23[0x4]; + unsigned int cmu_reset_coreblk_sys_pwr_reg; + unsigned int dram_freq_down_sys_pwr_reg; + unsigned int ddrphy_dlloff_sys_pwr_reg; + unsigned int ddrphy_dlllock_sys_pwr_reg; + unsigned char res25[0x4]; + unsigned int apll_sysclk_sys_pwr_reg; + unsigned int mpll_sysclk_sys_pwr_reg; + unsigned int vpll_sysclk_sys_pwr_reg; + unsigned int epll_sysclk_sys_pwr_reg; + unsigned int bpll_sysclk_sys_pwr_reg; + unsigned int cpll_sysclk_sys_pwr_reg; + unsigned int dpll_sysclk_sys_pwr_reg; + unsigned int ipll_sysclk_sys_pwr_reg; + unsigned int kpll_sysclk_sys_pwr_reg; + unsigned int mplluser_sysclk_sys_pwr_reg; + unsigned char res512[0x8]; + unsigned int bplluser_sysclk_sys_pwr_reg; + unsigned int rpll_sysclk_sys_pwr_reg; + unsigned int spll_sysclk_sys_pwr_reg; + unsigned char res26[0x4]; + unsigned int top_bus_sys_pwr_reg; + unsigned int top_retention_sys_pwr_reg; + unsigned int top_pwr_sys_pwr_reg; + unsigned char res29[0x4]; + unsigned int top_bus_coreblk_sys_pwr_reg; + unsigned int top_retention_coreblk_sys_pwr_reg; + unsigned int top_pwr_coreblk_sys_pwr_reg; + unsigned char res30[0x4]; + unsigned int logic_reset_sys_pwr_reg; + unsigned int oscclk_gate_sys_pwr_reg; + unsigned char res31[0x8]; + unsigned int logic_reset_coreblk_sys_pwr_reg; + unsigned int oscclk_gate_coreblk_sys_pwr_reg; + unsigned int intram_mem_sys_pwr_reg; + unsigned int introm_mem_sys_pwr_reg; + unsigned char res32[0x44]; + unsigned int pad_retention_mau_sys_pwr_reg; + unsigned int pad_retention_jtag_sys_pwr_reg; + unsigned char res36[0x4]; + unsigned int pad_retention_dram_sys_pwr_reg; + unsigned int pad_retention_uart_sys_pwr_reg; + unsigned int pad_retention_mmca_sys_pwr_reg; + unsigned int pad_retention_mmcb_sys_pwr_reg; + unsigned int pad_retention_mmcc_sys_pwr_reg; + unsigned int pad_retention_hsi_sys_pwr_reg; + unsigned int pad_retention_ebia_sys_pwr_reg; + unsigned int pad_retention_ebib_sys_pwr_reg; + unsigned int pad_retention_spi_sys_pwr_reg; + unsigned int pad_retention_dram_coreblk_sys_pwr_reg; + unsigned char res28[0x8]; + unsigned int pad_isolation_sys_pwr_reg; + unsigned char res37[0xc]; + unsigned int pad_isolation_coreblk_sys_pwr_reg; + unsigned char res38[0xc]; + unsigned int pad_alv_sel_sys_pwr_reg; + unsigned char res39[0x1c]; + unsigned int xusbxti_sys_pwr_reg; + unsigned int xxti_sys_pwr_reg; + unsigned char res40[0x38]; + unsigned int ext_regulator_sys_pwr_reg; + unsigned char res41[0x3c]; + unsigned int gpio_mode_sys_pwr_reg; + unsigned char res42[0x1c]; + unsigned int gpio_mode_coreblk_sys_pwr_reg; + unsigned char res43[0x1c]; + unsigned int gpio_mode_mau_sys_pwr_reg; + unsigned int top_asb_reset_sys_pwr_reg; + unsigned int top_asb_isolation_sys_pwr_reg; + unsigned char res44[0xb4]; + unsigned int gscl_sys_pwr_reg; + unsigned int isp_sys_pwr_reg; + unsigned int mfc_sys_pwr_reg; + unsigned int g3d_sys_pwr_reg; + unsigned int disp1_sys_pwr_reg; + unsigned int mau_sys_pwr_reg; + unsigned int g2d_sys_pwr_reg; + unsigned int msc_sys_pwr_reg; + unsigned int fsys_sys_pwr_reg; + unsigned int fsys2_sys_pwr_reg; + unsigned int psgen_sys_pwr_reg; + unsigned int peric_sys_pwr_reg; + unsigned int wcore_sys_pwr_reg; + unsigned char res46[0x4c]; + unsigned int cmu_clkstop_gscl_sys_pwr_reg; + unsigned int cmu_clkstop_isp_sys_pwr_reg; + unsigned int cmu_clkstop_mfc_sys_pwr_reg; + unsigned int cmu_clkstop_g3d_sys_pwr_reg; + unsigned int cmu_clkstop_disp1_sys_pwr_reg; + unsigned int cmu_clkstop_mau_sys_pwr_reg; + unsigned int cmu_clkstop_g2d_sys_pwr_reg; + unsigned int cmu_clkstop_msc_sys_pwr_reg; + unsigned int cmu_clkstop_fsys_sys_pwr_reg; + unsigned int cmu_clkstop_fsys2_sys_pwr_reg; + unsigned int cmu_clkstop_psgen_sys_pwr_reg; + unsigned int cmu_clkstop_peric_sys_pwr_reg; + unsigned int cmu_clkstop_wcore_sys_pwr_reg; + unsigned char res48[0x8]; + unsigned int cmu_sysclk_toppwr_sys_pwr_reg; + unsigned int cmu_sysclk_gscl_sys_pwr_reg; + unsigned int cmu_sysclk_isp_sys_pwr_reg; + unsigned int cmu_sysclk_mfc_sys_pwr_reg; + unsigned int cmu_sysclk_g3d_sys_pwr_reg; + unsigned int cmu_sysclk_disp1_sys_pwr_reg; + unsigned int cmu_sysclk_mau_sys_pwr_reg; + unsigned int cmu_sysclk_g2d_sys_pwr_reg; + unsigned int cmu_sysclk_msc_sys_pwr_reg; + unsigned int cmu_sysclk_fsys_sys_pwr_reg; + unsigned int cmu_sysclk_fsys2_sys_pwr_reg; + unsigned int cmu_sysclk_psgen_sys_pwr_reg; + unsigned int cmu_sysclk_peric_sys_pwr_reg; + unsigned int cmu_sysclk_wcore_sys_pwr_reg; + unsigned int cmu_sysclk_coreblk_toppwr_sys_pwr_reg; + unsigned char res50[0x78]; + unsigned int cmu_reset_fsys2_sys_pwr_reg; + unsigned int cmu_reset_psgen_sys_pwr_reg; + unsigned int cmu_reset_peric_sys_pwr_reg; + unsigned int cmu_reset_wcore_sys_pwr_reg; + unsigned int cmu_reset_gscl_sys_pwr_reg; + unsigned int cmu_reset_isp_sys_pwr_reg; + unsigned int cmu_reset_mfc_sys_pwr_reg; + unsigned int cmu_reset_g3d_sys_pwr_reg; + unsigned int cmu_reset_disp1_sys_pwr_reg; + unsigned int cmu_reset_mau_sys_pwr_reg; + unsigned int cmu_reset_g2d_sys_pwr_reg; + unsigned int cmu_reset_msc_sys_pwr_reg; + unsigned int cmu_reset_fsys_sys_pwr_reg; + unsigned char res52[0xa5c]; + unsigned int arm_core0_configuration; + unsigned int arm_core0_status; + unsigned int arm_core0_option; + unsigned char res53[0x14]; + unsigned int dis_irq_arm_core0_local_configuration; + unsigned int dis_irq_arm_core0_local_status; + unsigned int dis_irq_arm_core0_local_option; + unsigned char res54[0x14]; + unsigned int dis_irq_arm_core0_central_configuration; + unsigned int dis_irq_arm_core0_central_status; + unsigned int dis_irq_arm_core0_central_option; + unsigned char res55[0x34]; + unsigned int arm_core1_configuration; + unsigned int arm_core1_status; + unsigned int arm_core1_option; + unsigned char res56[0x14]; + unsigned int dis_irq_arm_core1_local_configuration; + unsigned int dis_irq_arm_core1_local_status; + unsigned int dis_irq_arm_core1_local_option; + unsigned char res57[0x14]; + unsigned int dis_irq_arm_core1_central_configuration; + unsigned int dis_irq_arm_core1_central_status; + unsigned int dis_irq_arm_core1_central_option; + unsigned char res600[0x34]; + unsigned int arm_core2_configuration; + unsigned int arm_core2_status; + unsigned int arm_core2_option; + unsigned char res601[0x14]; + unsigned int dis_irq_arm_core2_local_configuration; + unsigned int dis_irq_arm_core2_local_status; + unsigned int dis_irq_arm_core2_local_option; + unsigned char res602[0x14]; + unsigned int dis_irq_arm_core2_central_configuration; + unsigned int dis_irq_arm_core2_central_status; + unsigned int dis_irq_arm_core2_central_option; + unsigned char res603[0x34]; + unsigned int arm_core3_configuration; + unsigned int arm_core3_status; + unsigned int arm_core3_option; + unsigned char res900[0x14]; + unsigned int dis_irq_arm_core3_local_configuration; + unsigned int dis_irq_arm_core3_local_status; + unsigned int dis_irq_arm_core3_local_option; + unsigned char res901[0x14]; + unsigned int dis_irq_arm_core3_central_configuration; + unsigned int dis_irq_arm_core3_central_status; + unsigned int dis_irq_arm_core3_central_option; + unsigned char res604[0x34]; + unsigned int kfc_core0_configuration; + unsigned int kfc_core0_status; + unsigned int kfc_core0_option; + unsigned char res605[0x14]; + unsigned int dis_irq_kfc_core0_local_configuration; + unsigned int dis_irq_kfc_core0_local_status; + unsigned int dis_irq_kfc_core0_local_option; + unsigned char res606[0x14]; + unsigned int dis_irq_kfc_core0_central_configuration; + unsigned int dis_irq_kfc_core0_central_status; + unsigned int dis_irq_kfc_core0_central_option; + unsigned char res607[0x34]; + unsigned int kfc_core1_configuration; + unsigned int kfc_core1_status; + unsigned int kfc_core1_option; + unsigned char res608[0x14]; + unsigned int dis_irq_kfc_core1_local_configuration; + unsigned int dis_irq_kfc_core1_local_status; + unsigned int dis_irq_kfc_core1_local_option; + unsigned char res609[0x14]; + unsigned int dis_irq_kfc_core1_central_configuration; + unsigned int dis_irq_kfc_core1_central_status; + unsigned int dis_irq_kfc_core1_central_option; + unsigned char res610[0x34]; + unsigned int kfc_core2_configuration; + unsigned int kfc_core2_status; + unsigned int kfc_core2_option; + unsigned char res611[0x14]; + unsigned int dis_irq_kfc_core2_local_configuration; + unsigned int dis_irq_kfc_core2_local_status; + unsigned int dis_irq_kfc_core2_local_option; + unsigned char res612[0x14]; + unsigned int dis_irq_kfc_core2_central_configuration; + unsigned int dis_irq_kfc_core2_central_status; + unsigned int dis_irq_kfc_core2_central_option; + unsigned char res613[0x34]; + unsigned int kfc_core3_configuration; + unsigned int kfc_core3_status; + unsigned int kfc_core3_option; + unsigned char res614[0x14]; + unsigned int dis_irq_kfc_core3_local_configuration; + unsigned int dis_irq_kfc_core3_local_status; + unsigned int dis_irq_kfc_core3_local_option; + unsigned char res615[0x14]; + unsigned int dis_irq_kfc_core3_central_configuration; + unsigned int dis_irq_kfc_core3_central_status; + unsigned int dis_irq_kfc_core3_central_option; + unsigned char res61[0xb4]; + unsigned int isp_arm_configuration; + unsigned int isp_arm_status; + unsigned int isp_arm_option; + unsigned char res62[0x14]; + unsigned int dis_irq_isp_arm_local_configuration; + unsigned int dis_irq_isp_arm_local_status; + unsigned int dis_irq_isp_arm_local_option; + unsigned char res63[0x14]; + unsigned int dis_irq_isp_arm_central_configuration; + unsigned int dis_irq_isp_arm_central_status; + unsigned int dis_irq_isp_arm_central_option; + unsigned char res64[0x34]; + unsigned int arm_common_configuration; + unsigned int arm_common_status; + unsigned int arm_common_option; + unsigned char res616[0x74]; + unsigned int kfc_common_configuration; + unsigned int kfc_common_status; + unsigned int kfc_common_option; + unsigned char res65[0x74]; + unsigned int arm_l2_configuration; + unsigned int arm_l2_status; + unsigned int arm_l2_option; + unsigned char res617[0x74]; + unsigned int kfc_l2_configuration; + unsigned int kfc_l2_status; + unsigned int kfc_l2_option; + unsigned char res66[0x74]; + unsigned int cmu_cpu_aclkstop_configuration; + unsigned int cmu_cpu_aclkstop_status; + unsigned int cmu_cpu_aclkstop_option; + unsigned char res67[0x14]; + unsigned int cmu_cpu_sclkstop_configuration; + unsigned int cmu_cpu_sclkstop_status; + unsigned int cmu_cpu_sclkstop_option; + unsigned char res618[0x4]; + unsigned int cmu_kfc_aclkstop_configuration; + unsigned int cmu_kfc_aclkstop_status; + unsigned int cmu_kfc_aclkstop_option; + unsigned char res619[0xc4]; + unsigned int cmu_aclkstop_configuration; + unsigned int cmu_aclkstop_status; + unsigned int cmu_aclkstop_option; + unsigned char res620[0x14]; + unsigned int cmu_sclkstop_configuration; + unsigned int cmu_sclkstop_status; + unsigned int cmu_sclkstop_option; + unsigned char res68[0x34]; + unsigned int cmu_reset_configuration; + unsigned int cmu_reset_status; + unsigned int cmu_reset_option; + unsigned char res69[0x94]; + unsigned int cmu_aclkstop_coreblk_configuration; + unsigned int cmu_aclkstop_coreblk_status; + unsigned int cmu_aclkstop_coreblk_option; + unsigned char res70[0x14]; + unsigned int cmu_sclkstop_coreblk_configuration; + unsigned int cmu_sclkstop_coreblk_status; + unsigned int cmu_sclkstop_coreblk_option; + unsigned char res71[0x34]; + unsigned int cmu_reset_coreblk_configuration; + unsigned int cmu_reset_coreblk_status; + unsigned int cmu_reset_coreblk_option; + unsigned char res621[0x14]; + unsigned int dram_freq_down_configuration; + unsigned int dram_freq_down_status; + unsigned int dram_freq_down_option; + unsigned char res622[0x14]; + unsigned int ddrphy_dlloff_configuration; + unsigned int ddrphy_dlloff_status; + unsigned int ddrphy_dlloff_option; + unsigned char res72[0x14]; + unsigned int ddrphy_dlllock_configuration; + unsigned int ddrphy_dlllock_status; + unsigned int ddrphy_dlllock_option; + unsigned char res73[0x34]; + unsigned int apll_sysclk_configuration; + unsigned int apll_sysclk_status; + unsigned int apll_sysclk_option; + unsigned char res74[0x18]; + unsigned int mpll_sysclk_status; + unsigned int mpll_sysclk_option; + unsigned char res75[0x14]; + unsigned int vpll_sysclk_configuration; + unsigned int vpll_sysclk_status; + unsigned int vpll_sysclk_option; + unsigned char res76[0x14]; + unsigned int epll_sysclk_configuration; + unsigned int epll_sysclk_status; + unsigned int epll_sysclk_option; + unsigned char res77[0x14]; + unsigned int bpll_sysclk_configuration; + unsigned int bpll_sysclk_status; + unsigned int bpll_sysclk_option; + unsigned char res78[0x14]; + unsigned int cpll_sysclk_configuration; + unsigned int cpll_sysclk_status; + unsigned int cpll_sysclk_option; + unsigned char res79[0x14]; + unsigned int dpll_sysclk_configuration; + unsigned int dpll_sysclk_status; + unsigned int dpll_sysclk_option; + unsigned char res700[0x14]; + unsigned int ipll_sysclk_configuration; + unsigned int ipll_sysclk_status; + unsigned int ipll_sysclk_option; + unsigned char res903[0x14]; + unsigned int kpll_sysclk_configuration; + unsigned int kpll_sysclk_status; + unsigned int kpll_sysclk_option; + unsigned char res80[0x14]; + unsigned int mplluser_sysclk_configuration; + unsigned int mplluser_sysclk_status; + unsigned int mplluser_sysclk_option; + unsigned char res81[0x54]; + unsigned int bplluser_sysclk_configuration; + unsigned int bplluser_sysclk_status; + unsigned int bplluser_sysclk_option; + unsigned char res701[0x14]; + unsigned int rplluser_sysclk_configuration; + unsigned int rplluser_sysclk_status; + unsigned int rplluser_sysclk_option; + unsigned char res702[0x14]; + unsigned int splluser_sysclk_configuration; + unsigned int splluser_sysclk_status; + unsigned int splluser_sysclk_option; + unsigned char res82[0x34]; + unsigned int top_bus_configuration; + unsigned int top_bus_status; + unsigned int top_bus_option; + unsigned char res83[0x14]; + unsigned int top_retention_configuration; + unsigned int top_retention_status; + unsigned int top_retention_option; + unsigned char res84[0x14]; + unsigned int top_pwr_configuration; + unsigned int top_pwr_status; + unsigned int top_pwr_option; + unsigned char res85[0x34]; + unsigned int top_bus_coreblk_configuration; + unsigned int top_bus_coreblk_status; + unsigned int top_bus_coreblk_option; + unsigned char res86[0x14]; + unsigned int top_retention_coreblk_configuration; + unsigned int top_retention_coreblk_status; + unsigned int top_retention_coreblk_option; + unsigned char res87[0x14]; + unsigned int top_pwr_coreblk_configuration; + unsigned int top_pwr_coreblk_status; + unsigned int top_pwr_coreblk_option; + unsigned char res88[0x34]; + unsigned int logic_reset_configuration; + unsigned int logic_reset_status; + unsigned int logic_reset_option; + unsigned char res89[0x14]; + unsigned int oscclk_gate_configuration; + unsigned int oscclk_gate_status; + unsigned int oscclk_gate_option; + unsigned char res90[0x54]; + unsigned int logic_reset_coreblk_configuration; + unsigned int logic_reset_coreblk_status; + unsigned int logic_reset_coreblk_option; + unsigned char res91[0x14]; + unsigned int oscclk_gate_coreblk_configuration; + unsigned int oscclk_gate_coreblk_status; + unsigned int oscclk_gate_coreblk_option; + unsigned char res99[0x174]; + unsigned int intram_mem_configuration; + unsigned int intram_mem_status; + unsigned int intram_mem_option; + unsigned char res100[0x14]; + unsigned int introm_mem_configuration; + unsigned int introm_mem_status; + unsigned int introm_mem_option; + unsigned char res101[0xb4]; + unsigned int pad_retention_dram_configuration; + unsigned int pad_retention_dram_status; + unsigned int pad_retention_dram_option; + unsigned char res106[0x14]; + unsigned int pad_retention_mau_configuration; + unsigned int pad_retention_mau_status; + unsigned int pad_retention_mau_option; + unsigned char res107[0x14]; + unsigned int pad_retention_jtag_configuration; + unsigned int pad_retention_jtag_status; + unsigned int pad_retention_jtag_option; + unsigned char res92[0x74]; + unsigned int pad_retention_dram_configuration_2; + unsigned int pad_retention_dram_status_2; + unsigned int pad_retention_dram_option_2; + unsigned char res111[0x14]; + unsigned int pad_retention_uart_configuration; + unsigned int pad_retention_uart_status; + unsigned int pad_retention_uart_option; + unsigned char res112[0x14]; + unsigned int pad_retention_mmca_configuration; + unsigned int pad_retention_mmca_status; + unsigned int pad_retention_mmca_option; + unsigned char res113[0x14]; + unsigned int pad_retention_mmcb_configuration; + unsigned int pad_retention_mmcb_status; + unsigned int pad_retention_mmcb_option; + unsigned char res93[0x14]; + unsigned int pad_retention_mmcc_configuration; + unsigned int pad_retention_mmcc_status; + unsigned int pad_retention_mmcc_option; + unsigned char res94[0x14]; + unsigned int pad_retention_hsi_configuration; + unsigned int pad_retention_hsi_status; + unsigned int pad_retention_hsi_option; + unsigned char res114[0x14]; + unsigned int pad_retention_ebia_configuration; + unsigned int pad_retention_ebia_status; + unsigned int pad_retention_ebia_option; + unsigned char res115[0x14]; + unsigned int pad_retention_ebib_configuration; + unsigned int pad_retention_ebib_status; + unsigned int pad_retention_ebib_option; + unsigned char res116[0x14]; + unsigned int pad_retention_spi_configuration; + unsigned int pad_retention_spi_status; + unsigned int pad_retention_spi_option; + unsigned char res117[0x14]; + unsigned int pad_retention_dram_coreblk_configuration; + unsigned int pad_retention_dram_coreblk_status; + unsigned int pad_retention_dram_coreblk_option; + unsigned char res118[0x14]; + unsigned int pad_isolation_configuration; + unsigned int pad_isolation_status; + unsigned int pad_isolation_option; + unsigned char res119[0x74]; + unsigned int pad_isolation_coreblk_configuration; + unsigned int pad_isolation_coreblk_status; + unsigned int pad_isolation_coreblk_option; + unsigned char res120[0x74]; + unsigned int pad_alv_sel_configuration; + unsigned int pad_alv_sel_status; + unsigned int pad_alv_sel_option0; + unsigned int ps_hold_control; + unsigned char res130[0xf0]; + unsigned int xusbxti_configuration; + unsigned int xusbxti_status; + unsigned int xusbxti_option; + unsigned char res910[0x10]; + unsigned int xusbxti_duration3; + unsigned int xxti_configuration; + unsigned int xxti_status; + unsigned int xxti_option; + unsigned char res131[0x10]; + unsigned int xxti_duration3; + unsigned char res132[0x1c0]; + unsigned int ext_regulator_configuration; + unsigned int ext_regulator_status; + unsigned int ext_regulator_option; + unsigned char res133[0x10]; + unsigned int ext_regulator_duration3; + unsigned char res134[0x1e0]; + unsigned int gpio_mode_configuration; + unsigned int gpio_mode_status; + unsigned int gpio_mode_option; + unsigned char res135[0xf4]; + unsigned int gpio_mode_coreblk_configuration; + unsigned int gpio_mode_coreblk_status; + unsigned int gpio_mode_coreblk_option; + unsigned char res136[0xd4]; + unsigned int gpio_mode_mau_configuration; + unsigned int gpio_mode_mau_status; + unsigned int gpio_mode_mau_option; + unsigned char res137[0x14]; + unsigned int top_asb_reset_configuration; + unsigned int top_asb_reset_status; + unsigned int top_asb_reset_option; + unsigned char res138[0x14]; + unsigned int top_asb_isolation_configuration; + unsigned int top_asb_isolation_status; + unsigned int top_asb_isolation_option; + unsigned char res139[0x5d4]; + unsigned int gscl_configuration; + unsigned int gscl_status; + unsigned int gscl_option; + unsigned char res140[0x14]; + unsigned int isp_configuration; + unsigned int isp_status; + unsigned int isp_option; + unsigned char res141[0x34]; + unsigned int mfc_configuration; + unsigned int mfc_status; + unsigned int mfc_option; + unsigned char res142[0x14]; + unsigned int g3d_configuration; + unsigned int g3d_status; + unsigned int g3d_option; + unsigned char res143[0x34]; + unsigned int disp1_configuration; + unsigned int disp1_status; + unsigned int disp1_option; + unsigned char res144[0x14]; + unsigned int mau_configuration; + unsigned int mau_status; + unsigned int mau_option; + unsigned char res800[0x14]; + unsigned int g2d_configuration; + unsigned int g2d_status; + unsigned int g2d_option; + unsigned char res801[0x14]; + unsigned int msc_configuration; + unsigned int msc_status; + unsigned int msc_option; + unsigned char res802[0x14]; + unsigned int fsys_configuration; + unsigned int fsys_status; + unsigned int fsys_option; + unsigned char res803[0x14]; + unsigned int fsys2_configuration; + unsigned int fsys2_status; + unsigned int fsys2_option; + unsigned char res804[0x14]; + unsigned int psgen_configuration; + unsigned int psgen_status; + unsigned int psgen_option; + unsigned char res805[0x14]; + unsigned int peric_configuration; + unsigned int peric_status; + unsigned int peric_option; + unsigned char res806[0x14]; + unsigned int wcore_configuration; + unsigned int wcore_status; + unsigned int wcore_option; + unsigned char res145[0x234]; + unsigned int cmu_clkstop_gscl_configuration; + unsigned int cmu_clkstop_gscl_status; + unsigned int cmu_clkstop_gscl_option; + unsigned char res146[0x14]; + unsigned int cmu_clkstop_isp_configuration; + unsigned int cmu_clkstop_isp_status; + unsigned int cmu_clkstop_isp_option; + unsigned char res147[0x34]; + unsigned int cmu_clkstop_mfc_configuration; + unsigned int cmu_clkstop_mfc_status; + unsigned int cmu_clkstop_mfc_option; + unsigned char res148[0x14]; + unsigned int cmu_clkstop_g3d_configuration; + unsigned int cmu_clkstop_g3d_status; + unsigned int cmu_clkstop_g3d_option; + unsigned char res149[0x34]; + unsigned int cmu_clkstop_disp1_configuration; + unsigned int cmu_clkstop_disp1_status; + unsigned int cmu_clkstop_disp1_option; + unsigned char res150[0x14]; + unsigned int cmu_clkstop_mau_configuration; + unsigned int cmu_clkstop_mau_status; + unsigned int cmu_clkstop_mau_option; + unsigned char res807[0x14]; + unsigned int cmu_clkstop_g2d_configuration; + unsigned int cmu_clkstop_g2d_status; + unsigned int cmu_clkstop_g2d_option; + unsigned char res808[0x14]; + unsigned int cmu_clkstop_msc_configuration; + unsigned int cmu_clkstop_msc_status; + unsigned int cmu_clkstop_msc_option; + unsigned char res809[0x14]; + unsigned int cmu_clkstop_fsys_configuration; + unsigned int cmu_clkstop_fsys_status; + unsigned int cmu_clkstop_fsys_option; + unsigned char res810[0x14]; + unsigned int cmu_clkstop_fsys2_configuration; + unsigned int cmu_clkstop_fsys2_status; + unsigned int cmu_clkstop_fsys2_option; + unsigned char res811[0x14]; + unsigned int cmu_clkstop_psgen_configuration; + unsigned int cmu_clkstop_psgen_status; + unsigned int cmu_clkstop_psgen_option; + unsigned char res812[0x14]; + unsigned int cmu_clkstop_peric_configuration; + unsigned int cmu_clkstop_peric_status; + unsigned int cmu_clkstop_peric_option; + unsigned char res813[0x14]; + unsigned int cmu_clkstop_wcore_configuration; + unsigned int cmu_clkstop_wcore_status; + unsigned int cmu_clkstop_wcore_option; + unsigned char res151[0x14]; + unsigned int cmu_sysclk_toppwr_configuration; + unsigned int cmu_sysclk_toppwr_status; + unsigned int cmu_sysclk_toppwr_option; + unsigned char res920[0x18]; + unsigned int cmu_sysclk_gscl_status; + unsigned int cmu_sysclk_gscl_option; + unsigned char res152[0x18]; + unsigned int cmu_sysclk_isp_status; + unsigned int cmu_sysclk_isp_option; + unsigned char res153[0x38]; + unsigned int cmu_sysclk_mfc_status; + unsigned int cmu_sysclk_mfc_option; + unsigned char res154[0x18]; + unsigned int cmu_sysclk_g3d_status; + unsigned int cmu_sysclk_g3d_option; + unsigned char res155[0x38]; + unsigned int cmu_sysclk_disp1_status; + unsigned int cmu_sysclk_disp1_option; + unsigned char res156[0x18]; + unsigned int cmu_sysclk_mau_status; + unsigned int cmu_sysclk_mau_option; + unsigned char res814[0x18]; + unsigned int cmu_sysclk_g2d_status; + unsigned int cmu_sysclk_g2d_option; + unsigned char res815[0x18]; + unsigned int cmu_sysclk_msc_status; + unsigned int cmu_sysclk_msc_option; + unsigned char res922[0x18]; + unsigned int cmu_sysclk_fsys_status; + unsigned int cmu_sysclk_fsys_option; + unsigned char res816[0x18]; + unsigned int cmu_sysclk_fsys2_status; + unsigned int cmu_sysclk_fsys2_option; + unsigned char res817[0x18]; + unsigned int cmu_sysclk_psgen_status; + unsigned int cmu_sysclk_psgen_option; + unsigned char res950[0x18]; + unsigned int cmu_sysclk_peric_status; + unsigned int cmu_sysclk_peric_option; + unsigned char res818[0x18]; + unsigned int cmu_sysclk_wcore_status; + unsigned int cmu_sysclk_wcore_option; + unsigned char res819[0x18]; + unsigned int cmu_sysclk_coreblk_toppwr_status; + unsigned int cmu_sysclk_coreblk_toppwr_option; + unsigned char res157[0x414]; + unsigned int cmu_reset_gscl_configuration; + unsigned int cmu_reset_gscl_status; + unsigned int cmu_reset_gscl_option; + unsigned char res158[0x14]; + unsigned int cmu_reset_isp_configuration; + unsigned int cmu_reset_isp_status; + unsigned int cmu_reset_isp_option; + unsigned char res159[0x34]; + unsigned int cmu_reset_mfc_configuration; + unsigned int cmu_reset_mfc_status; + unsigned int cmu_reset_mfc_option; + unsigned char res160[0x14]; + unsigned int cmu_reset_g3d_configuration; + unsigned int cmu_reset_g3d_status; + unsigned int cmu_reset_g3d_option; + unsigned char res161[0x34]; + unsigned int cmu_reset_disp1_configuration; + unsigned int cmu_reset_disp1_status; + unsigned int cmu_reset_disp1_option; + unsigned char res162[0x14]; + unsigned int cmu_reset_mau_configuration; + unsigned int cmu_reset_mau_status; + unsigned int cmu_reset_mau_option; + unsigned char res163[0x14]; + unsigned int version_info; + unsigned int i2s_bypass; + unsigned int kfc_swreset_mask_from_eagle; + unsigned char res164[0xf4]; + unsigned int cmu_reset_g2d_configuration; + unsigned int cmu_reset_g2d_status; + unsigned int cmu_reset_g2d_option; + unsigned char res165[0x14]; + unsigned int cmu_reset_msc_configuration; + unsigned int cmu_reset_msc_status; + unsigned int cmu_reset_msc_option; + unsigned char res166[0x14]; + unsigned int cmu_reset_fsys_configuration; + unsigned int cmu_reset_fsys_status; + unsigned int cmu_reset_fsys_option; + unsigned char res167[0x14]; + unsigned int cmu_reset_fsys2_configuration; + unsigned int cmu_reset_fsys2_status; + unsigned int cmu_reset_fsys2_option; + unsigned char res168[0x14]; + unsigned int cmu_reset_psgen_configuration; + unsigned int cmu_reset_psgen_status; + unsigned int cmu_reset_psgen_option; + unsigned char res169[0x14]; + unsigned int cmu_reset_peric_configuration; + unsigned int cmu_reset_peric_status; + unsigned int cmu_reset_peric_option; + unsigned char res170[0x14]; + unsigned int cmu_reset_wcore_configuration; + unsigned int cmu_reset_wcore_status; + unsigned int cmu_reset_wcore_option; +}; #endif /* __ASSEMBLY__ */
void set_mipi_phy_ctrl(unsigned int dev_index, unsigned int enable);
Add dmc and phy_control register structure for 5420.
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com --- Changes in V10: - New patch Changes in V11: - None arch/arm/include/asm/arch-exynos/dmc.h | 167 +++++++++++++++++++++++++++++++++ 1 file changed, 167 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/dmc.h b/arch/arm/include/asm/arch-exynos/dmc.h index f65c676..32ad3ae 100644 --- a/arch/arm/include/asm/arch-exynos/dmc.h +++ b/arch/arm/include/asm/arch-exynos/dmc.h @@ -205,6 +205,127 @@ struct exynos5_dmc { unsigned int pmcnt3_ppc_a; };
+struct exynos5420_dmc { + unsigned int concontrol; + unsigned int memcontrol; + unsigned int cgcontrol; + unsigned char res500[0x4]; + unsigned int directcmd; + unsigned int prechconfig0; + unsigned int phycontrol0; + unsigned int prechconfig1; + unsigned char res1[0x8]; + unsigned int pwrdnconfig; + unsigned int timingpzq; + unsigned int timingref; + unsigned int timingrow0; + unsigned int timingdata0; + unsigned int timingpower0; + unsigned int phystatus; + unsigned int etctiming; + unsigned int chipstatus; + unsigned char res3[0x8]; + unsigned int mrstatus; + unsigned char res4[0x8]; + unsigned int qoscontrol0; + unsigned char resr5[0x4]; + unsigned int qoscontrol1; + unsigned char res6[0x4]; + unsigned int qoscontrol2; + unsigned char res7[0x4]; + unsigned int qoscontrol3; + unsigned char res8[0x4]; + unsigned int qoscontrol4; + unsigned char res9[0x4]; + unsigned int qoscontrol5; + unsigned char res10[0x4]; + unsigned int qoscontrol6; + unsigned char res11[0x4]; + unsigned int qoscontrol7; + unsigned char res12[0x4]; + unsigned int qoscontrol8; + unsigned char res13[0x4]; + unsigned int qoscontrol9; + unsigned char res14[0x4]; + unsigned int qoscontrol10; + unsigned char res15[0x4]; + unsigned int qoscontrol11; + unsigned char res16[0x4]; + unsigned int qoscontrol12; + unsigned char res17[0x4]; + unsigned int qoscontrol13; + unsigned char res18[0x4]; + unsigned int qoscontrol14; + unsigned char res19[0x4]; + unsigned int qoscontrol15; + unsigned char res20[0x4]; + unsigned int timing_set_sw; + unsigned int timingrow1; + unsigned int timingdata1; + unsigned int timingpower1; + unsigned char res300[0x4]; + unsigned int wrtra_config; + unsigned int rdlvl_config; + unsigned char res21[0x4]; + unsigned int brbrsvcontrol; + unsigned int brbrsvconfig; + unsigned int brbqosconfig; + unsigned char res301[0x14]; + unsigned int wrlvl_config0; + unsigned int wrlvl_config1; + unsigned int wrlvl_status; + unsigned char res23[0x4]; + unsigned int ppcclockon; + unsigned int perevconfig0; + unsigned int perevconfig1; + unsigned int perevconfig2; + unsigned int perevconfig3; + unsigned char res24[0xc]; + unsigned int control_io_rdata; + unsigned char res240[0xc]; + unsigned int cacal_config0; + unsigned int cacal_config1; + unsigned int cacal_status; + unsigned char res302[0xa4]; + unsigned int bp_control0; + unsigned int bp_config0_r; + unsigned int bp_config0_w; + unsigned char res303[0x4]; + unsigned int bp_control1; + unsigned int bp_config1_r; + unsigned int bp_config1_w; + unsigned char res304[0x4]; + unsigned int bp_control2; + unsigned int bp_config2_r; + unsigned int bp_config2_w; + unsigned char res305[0x4]; + unsigned int bp_control3; + unsigned int bp_config3_r; + unsigned int bp_config3_w; + unsigned char res306[0xddb4]; + unsigned int pmnc_ppc; + unsigned char res25[0xc]; + unsigned int cntens_ppc; + unsigned char res26[0xc]; + unsigned int cntenc_ppc; + unsigned char res27[0xc]; + unsigned int intens_ppc; + unsigned char res28[0xc]; + unsigned int intenc_ppc; + unsigned char res29[0xc]; + unsigned int flag_ppc; + unsigned char res30[0xac]; + unsigned int ccnt_ppc; + unsigned char res31[0xc]; + unsigned int pmcnt0_ppc; + unsigned char res32[0xc]; + unsigned int pmcnt1_ppc; + unsigned char res33[0xc]; + unsigned int pmcnt2_ppc; + unsigned char res34[0xc]; + unsigned int pmcnt3_ppc; +}; + struct exynos5_phy_control { unsigned int phy_con0; unsigned int phy_con1; @@ -252,6 +373,52 @@ struct exynos5_phy_control { unsigned int phy_con42; };
+struct exynos5420_phy_control { + unsigned int phy_con0; + unsigned int phy_con1; + unsigned int phy_con2; + unsigned int phy_con3; + unsigned int phy_con4; + unsigned int phy_con5; + unsigned int phy_con6; + unsigned char res2[0x4]; + unsigned int phy_con8; + unsigned char res5[0x4]; + unsigned int phy_con10; + unsigned int phy_con11; + unsigned int phy_con12; + unsigned int phy_con13; + unsigned int phy_con14; + unsigned int phy_con15; + unsigned int phy_con16; + unsigned char res4[0x4]; + unsigned int phy_con17; + unsigned int phy_con18; + unsigned int phy_con19; + unsigned int phy_con20; + unsigned int phy_con21; + unsigned int phy_con22; + unsigned int phy_con23; + unsigned int phy_con24; + unsigned int phy_con25; + unsigned int phy_con26; + unsigned int phy_con27; + unsigned int phy_con28; + unsigned int phy_con29; + unsigned int phy_con30; + unsigned int phy_con31; + unsigned int phy_con32; + unsigned int phy_con33; + unsigned int phy_con34; + unsigned char res6[0x8]; + unsigned int phy_con37; + unsigned char res7[0x4]; + unsigned int phy_con39; + unsigned int phy_con40; + unsigned int phy_con41; + unsigned int phy_con42; +}; + enum ddr_mode { DDR_MODE_DDR2, DDR_MODE_DDR3,
This patch adds code for clock initialization and clock settings of various IP's and controllers, required for Exynos5420
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- Changes in V2: - None Changes in V3: - None Changes in V4: - Corrected the multiline commenting style Changes in V5: - None Changes in V6: - None Changes in V7: - Correct the logic for exynos5420_set_spi_clk api. Changes in V8: - Chnages the if condition loop for pro_id and cpu_id. Changes in V9: - Used samsung_get_base to get base address of clock. Changes in V10: - Corrected the comments and few coding style nits. Changes in V11: - None arch/arm/cpu/armv7/exynos/clock.c | 279 +++++++++- arch/arm/cpu/armv7/exynos/clock_init.h | 17 + arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 352 +++++++++++- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 738 +++++++++++++++++++------ arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/clock.h | 494 +++++++++++++++++ 6 files changed, 1679 insertions(+), 202 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 84a5047..5bde9d1 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -96,7 +96,7 @@ static int exynos_get_pll_clk(int pllreg, unsigned int r, unsigned int k)
freq = CONFIG_SYS_CLK_FREQ;
- if (pllreg == EPLL) { + if (pllreg == EPLL || pllreg == RPLL) { k = k & 0xffff; /* FOUT = (MDIV + K / 65536) * FIN / (PDIV * 2^SDIV) */ fout = (m + k / PLL_DIV_65536) * (freq / (p * (1 << s))); @@ -117,7 +117,7 @@ static int exynos_get_pll_clk(int pllreg, unsigned int r, unsigned int k) div = PLL_DIV_1024; else if (proid_is_exynos4412()) div = PLL_DIV_65535; - else if (proid_is_exynos5250()) + else if (proid_is_exynos5250() || proid_is_exynos5420()) div = PLL_DIV_65536; else return 0; @@ -362,6 +362,43 @@ unsigned long clock_get_periph_rate(int peripheral) return 0; }
+/* exynos5420: return pll clock frequency */ +static unsigned long exynos5420_get_pll_clk(int pllreg) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned long r, k = 0; + + switch (pllreg) { + case APLL: + r = readl(&clk->apll_con0); + break; + case MPLL: + r = readl(&clk->mpll_con0); + break; + case EPLL: + r = readl(&clk->epll_con0); + k = readl(&clk->epll_con1); + break; + case VPLL: + r = readl(&clk->vpll_con0); + k = readl(&clk->vpll_con1); + break; + case BPLL: + r = readl(&clk->bpll_con0); + break; + case RPLL: + r = readl(&clk->rpll_con0); + k = readl(&clk->rpll_con1); + break; + default: + printf("Unsupported PLL (%d)\n", pllreg); + return 0; + } + + return exynos_get_pll_clk(pllreg, r, k); +} + /* exynos4: return ARM clock frequency */ static unsigned long exynos4_get_arm_clk(void) { @@ -485,6 +522,27 @@ static unsigned long exynos4x12_get_pwm_clk(void) return pclk; }
+/* exynos5420: return pwm clock frequency */ +static unsigned long exynos5420_get_pwm_clk(void) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned long pclk, sclk; + unsigned int ratio; + + /* + * CLK_DIV_PERIC0 + * PWM_RATIO [31:28] + */ + ratio = readl(&clk->div_peric0); + ratio = (ratio >> 28) & 0xf; + sclk = get_pll_clk(MPLL); + + pclk = sclk / (ratio + 1); + + return pclk; +} + /* exynos4: return uart clock frequency */ static unsigned long exynos4_get_uart_clk(int dev_index) { @@ -624,6 +682,53 @@ static unsigned long exynos5_get_uart_clk(int dev_index) return uclk; }
+/* exynos5420: return uart clock frequency */ +static unsigned long exynos5420_get_uart_clk(int dev_index) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned long uclk, sclk; + unsigned int sel; + unsigned int ratio; + + /* + * CLK_SRC_PERIC0 + * UART0_SEL [6:4] + * UART1_SEL [10:8] + * UART2_SEL [14:12] + * UART3_SEL [18:16] + * generalised calculation as follows + * sel = (sel >> ((dev_index * 4) + 4)) & mask; + */ + sel = readl(&clk->src_peric0); + sel = (sel >> ((dev_index * 4) + 4)) & 0x7; + + if (sel == 0x3) + sclk = get_pll_clk(MPLL); + else if (sel == 0x6) + sclk = get_pll_clk(EPLL); + else if (sel == 0x7) + sclk = get_pll_clk(RPLL); + else + return 0; + + /* + * CLK_DIV_PERIC0 + * UART0_RATIO [11:8] + * UART1_RATIO [15:12] + * UART2_RATIO [19:16] + * UART3_RATIO [23:20] + * generalised calculation as follows + * ratio = (ratio >> ((dev_index * 4) + 8)) & mask; + */ + ratio = readl(&clk->div_peric0); + ratio = (ratio >> ((dev_index * 4) + 8)) & 0xf; + + uclk = sclk / (ratio + 1); + + return uclk; +} + static unsigned long exynos4_get_mmc_clk(int dev_index) { struct exynos4_clock *clk = @@ -718,6 +823,47 @@ static unsigned long exynos5_get_mmc_clk(int dev_index) return uclk; }
+static unsigned long exynos5420_get_mmc_clk(int dev_index) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned long uclk, sclk; + unsigned int sel, ratio; + + /* + * CLK_SRC_FSYS + * MMC0_SEL [10:8] + * MMC1_SEL [14:12] + * MMC2_SEL [18:16] + * generalised calculation as follows + * sel = (sel >> ((dev_index * 4) + 8)) & mask + */ + sel = readl(&clk->src_fsys); + sel = (sel >> ((dev_index * 4) + 8)) & 0x7; + + if (sel == 0x3) + sclk = get_pll_clk(MPLL); + else if (sel == 0x6) + sclk = get_pll_clk(EPLL); + else + return 0; + + /* + * CLK_DIV_FSYS1 + * MMC0_RATIO [9:0] + * MMC1_RATIO [19:10] + * MMC2_RATIO [29:20] + * generalised calculation as follows + * ratio = (ratio >> (dev_index * 10)) & mask + */ + ratio = readl(&clk->div_fsys1); + ratio = (ratio >> (dev_index * 10)) & 0x3ff; + + uclk = (sclk / (ratio + 1)); + + return uclk; +} + /* exynos4: set the mmc clock */ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) { @@ -804,6 +950,29 @@ static void exynos5_set_mmc_clk(int dev_index, unsigned int div) writel(val, addr); }
+/* exynos5: set the mmc clock */ +static void exynos5420_set_mmc_clk(int dev_index, unsigned int div) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned int addr; + unsigned int val, shift; + + /* + * CLK_DIV_FSYS1 + * MMC0_RATIO [9:0] + * MMC1_RATIO [19:10] + * MMC2_RATIO [29:20] + */ + addr = (unsigned int)&clk->div_fsys1; + shift = dev_index * 10; + + val = readl(addr); + val &= ~(0x3ff << shift); + val |= (div & 0x3ff) << shift; + writel(val, addr); +} + /* get_lcd_clk: return lcd clock frequency */ static unsigned long exynos4_get_lcd_clk(void) { @@ -1324,6 +1493,71 @@ static int exynos5_set_spi_clk(enum periph_id periph_id, return 0; }
+static int exynos5420_set_spi_clk(enum periph_id periph_id, + unsigned int rate) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + int main; + unsigned int fine; + unsigned shift, pre_shift; + unsigned div_mask = 0xf, pre_div_mask = 0xff; + u32 *reg; + u32 *pre_reg; + + main = clock_calc_best_scalar(4, 8, 400000000, rate, &fine); + if (main < 0) { + debug("%s: Cannot set clock rate for periph %d", + __func__, periph_id); + return -1; + } + main = main - 1; + fine = fine - 1; + + switch (periph_id) { + case PERIPH_ID_SPI0: + reg = &clk->div_peric1; + shift = 20; + pre_reg = &clk->div_peric4; + pre_shift = 8; + break; + case PERIPH_ID_SPI1: + reg = &clk->div_peric1; + shift = 24; + pre_reg = &clk->div_peric4; + pre_shift = 16; + break; + case PERIPH_ID_SPI2: + reg = &clk->div_peric1; + shift = 28; + pre_reg = &clk->div_peric4; + pre_shift = 24; + break; + case PERIPH_ID_SPI3: + reg = &clk->div_isp1; + shift = 16; + pre_reg = &clk->div_isp1; + pre_shift = 0; + break; + case PERIPH_ID_SPI4: + reg = &clk->div_isp1; + shift = 20; + pre_reg = &clk->div_isp1; + pre_shift = 8; + break; + default: + debug("%s: Unsupported peripheral ID %d\n", __func__, + periph_id); + return -1; + } + + clrsetbits_le32(reg, div_mask << shift, (main & div_mask) << shift); + clrsetbits_le32(pre_reg, pre_div_mask << pre_shift, + (fine & pre_div_mask) << pre_shift); + + return 0; +} + static unsigned long exynos4_get_i2c_clk(void) { struct exynos4_clock *clk = @@ -1341,9 +1575,11 @@ static unsigned long exynos4_get_i2c_clk(void)
unsigned long get_pll_clk(int pllreg) { - if (cpu_is_exynos5()) + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) + return exynos5420_get_pll_clk(pllreg); return exynos5_get_pll_clk(pllreg); - else { + } else { if (proid_is_exynos4412()) return exynos4x12_get_pll_clk(pllreg); return exynos4_get_pll_clk(pllreg); @@ -1375,9 +1611,11 @@ unsigned long get_i2c_clk(void)
unsigned long get_pwm_clk(void) { - if (cpu_is_exynos5()) + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) + return exynos5420_get_pwm_clk(); return clock_get_periph_rate(PERIPH_ID_PWM0); - else { + } else { if (proid_is_exynos4412()) return exynos4x12_get_pwm_clk(); return exynos4_get_pwm_clk(); @@ -1386,9 +1624,11 @@ unsigned long get_pwm_clk(void)
unsigned long get_uart_clk(int dev_index) { - if (cpu_is_exynos5()) + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) + return exynos5420_get_uart_clk(dev_index); return exynos5_get_uart_clk(dev_index); - else { + } else { if (proid_is_exynos4412()) return exynos4x12_get_uart_clk(dev_index); return exynos4_get_uart_clk(dev_index); @@ -1397,17 +1637,23 @@ unsigned long get_uart_clk(int dev_index)
unsigned long get_mmc_clk(int dev_index) { - if (cpu_is_exynos5()) + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) + return exynos5420_get_mmc_clk(dev_index); return exynos5_get_mmc_clk(dev_index); - else + } else { return exynos4_get_mmc_clk(dev_index); + } }
void set_mmc_clk(int dev_index, unsigned int div) { - if (cpu_is_exynos5()) - exynos5_set_mmc_clk(dev_index, div); - else { + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) + exynos5420_set_mmc_clk(dev_index, div); + else + exynos5_set_mmc_clk(dev_index, div); + } else { if (proid_is_exynos4412()) exynos4x12_set_mmc_clk(dev_index, div); else @@ -1439,10 +1685,13 @@ void set_mipi_clk(void)
int set_spi_clk(int periph_id, unsigned int rate) { - if (cpu_is_exynos5()) + if (cpu_is_exynos5()) { + if (proid_is_exynos5420()) + return exynos5420_set_spi_clk(periph_id, rate); return exynos5_set_spi_clk(periph_id, rate); - else + } else { return 0; + } }
int set_i2s_clk_prescaler(unsigned int src_frq, unsigned int dst_frq, diff --git a/arch/arm/cpu/armv7/exynos/clock_init.h b/arch/arm/cpu/armv7/exynos/clock_init.h index c28ff3a..a875d0b 100644 --- a/arch/arm/cpu/armv7/exynos/clock_init.h +++ b/arch/arm/cpu/armv7/exynos/clock_init.h @@ -10,7 +10,11 @@ #define __EXYNOS_CLOCK_INIT_H
enum { +#ifdef CONFIG_EXYNOS5420 + MEM_TIMINGS_MSR_COUNT = 5, +#else MEM_TIMINGS_MSR_COUNT = 4, +#endif };
/* These are the ratio's for configuring ARM clock */ @@ -59,6 +63,18 @@ struct mem_timings { unsigned bpll_mdiv; unsigned bpll_pdiv; unsigned bpll_sdiv; + unsigned kpll_mdiv; + unsigned kpll_pdiv; + unsigned kpll_sdiv; + unsigned dpll_mdiv; + unsigned dpll_pdiv; + unsigned dpll_sdiv; + unsigned ipll_mdiv; + unsigned ipll_pdiv; + unsigned ipll_sdiv; + unsigned spll_mdiv; + unsigned spll_pdiv; + unsigned spll_sdiv; unsigned pclk_cdrex_ratio; unsigned direct_cmd_msr[MEM_TIMINGS_MSR_COUNT];
@@ -115,6 +131,7 @@ struct mem_timings { uint8_t send_zq_init; /* 1 to send this command */ unsigned impedance; /* drive strength impedeance */ uint8_t gate_leveling_enable; /* check gate leveling is enabled */ + uint8_t read_leveling_enable; /* check h/w read leveling is enabled */ };
/** diff --git a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c index a24c2f3..1d6977f 100644 --- a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c @@ -24,6 +24,24 @@ DECLARE_GLOBAL_DATA_PTR;
struct arm_clk_ratios arm_clk_ratios[] = { +#ifdef CONFIG_EXYNOS5420 + { + .arm_freq_mhz = 900, + + .apll_mdiv = 0x96, + .apll_pdiv = 0x2, + .apll_sdiv = 0x1, + + .arm2_ratio = 0x0, + .apll_ratio = 0x3, + .pclk_dbg_ratio = 0x6, + .atb_ratio = 0x6, + .periph_ratio = 0x7, + .acp_ratio = 0x0, + .cpud_ratio = 0x2, + .arm_ratio = 0x0, + } +#else { .arm_freq_mhz = 600,
@@ -115,8 +133,133 @@ struct arm_clk_ratios arm_clk_ratios[] = { .cpud_ratio = 0x3, .arm_ratio = 0x0, } +#endif }; + struct mem_timings mem_timings[] = { +#ifdef CONFIG_EXYNOS5420 + { + .mem_manuf = MEM_MANUF_SAMSUNG, + .mem_type = DDR_MODE_DDR3, + .frequency_mhz = 800, + + /* MPLL @800MHz*/ + .mpll_mdiv = 0xc8, + .mpll_pdiv = 0x3, + .mpll_sdiv = 0x1, + /* CPLL @666MHz */ + .cpll_mdiv = 0xde, + .cpll_pdiv = 0x4, + .cpll_sdiv = 0x1, + /* EPLL @600MHz */ + .epll_mdiv = 0x64, + .epll_pdiv = 0x2, + .epll_sdiv = 0x1, + /* VPLL @430MHz */ + .vpll_mdiv = 0xd7, + .vpll_pdiv = 0x3, + .vpll_sdiv = 0x2, + /* BPLL @800MHz */ + .bpll_mdiv = 0xc8, + .bpll_pdiv = 0x3, + .bpll_sdiv = 0x1, + /* KPLL @600MHz */ + .kpll_mdiv = 0x190, + .kpll_pdiv = 0x4, + .kpll_sdiv = 0x2, + /* DPLL @600MHz */ + .dpll_mdiv = 0x190, + .dpll_pdiv = 0x4, + .dpll_sdiv = 0x2, + /* IPLL @370MHz */ + .ipll_mdiv = 0xb9, + .ipll_pdiv = 0x3, + .ipll_sdiv = 0x2, + /* SPLL @400MHz */ + .spll_mdiv = 0xc8, + .spll_pdiv = 0x3, + .spll_sdiv = 0x2, + + .direct_cmd_msr = { + 0x00020018, 0x00030000, 0x00010046, 0x00000d70, + 0x00000c70 + }, + .timing_ref = 0x000000bb, + .timing_row = 0x6836650f, + .timing_data = 0x3630580b, + .timing_power = 0x41000a26, + .phy0_dqs = 0x08080808, + .phy1_dqs = 0x08080808, + .phy0_dq = 0x08080808, + .phy1_dq = 0x08080808, + .phy0_tFS = 0x8, + .phy1_tFS = 0x8, + .phy0_pulld_dqs = 0xf, + .phy1_pulld_dqs = 0xf, + + .lpddr3_ctrl_phy_reset = 0x1, + .ctrl_start_point = 0x10, + .ctrl_inc = 0x10, + .ctrl_start = 0x1, + .ctrl_dll_on = 0x1, + .ctrl_ref = 0x8, + + .ctrl_force = 0x1a, + .ctrl_rdlat = 0x0b, + .ctrl_bstlen = 0x08, + + .fp_resync = 0x8, + .iv_size = 0x7, + .dfi_init_start = 1, + .aref_en = 1, + + .rd_fetch = 0x3, + + .zq_mode_dds = 0x7, + .zq_mode_term = 0x1, + .zq_mode_noterm = 1, + + /* + * Dynamic Clock: Always Running + * Memory Burst length: 8 + * Number of chips: 1 + * Memory Bus width: 32 bit + * Memory Type: DDR3 + * Additional Latancy for PLL: 0 Cycle + */ + .memcontrol = DMC_MEMCONTROL_CLK_STOP_DISABLE | + DMC_MEMCONTROL_DPWRDN_DISABLE | + DMC_MEMCONTROL_DPWRDN_ACTIVE_PRECHARGE | + DMC_MEMCONTROL_TP_DISABLE | + DMC_MEMCONTROL_DSREF_DISABLE | + DMC_MEMCONTROL_ADD_LAT_PALL_CYCLE(0) | + DMC_MEMCONTROL_MEM_TYPE_DDR3 | + DMC_MEMCONTROL_MEM_WIDTH_32BIT | + DMC_MEMCONTROL_NUM_CHIP_1 | + DMC_MEMCONTROL_BL_8 | + DMC_MEMCONTROL_PZQ_DISABLE | + DMC_MEMCONTROL_MRR_BYTE_7_0, + .memconfig = DMC_MEMCONFIG_CHIP_MAP_SPLIT | + DMC_MEMCONFIGX_CHIP_COL_10 | + DMC_MEMCONFIGX_CHIP_ROW_15 | + DMC_MEMCONFIGX_CHIP_BANK_8, + .prechconfig_tp_cnt = 0xff, + .dpwrdn_cyc = 0xff, + .dsref_cyc = 0xffff, + .concontrol = DMC_CONCONTROL_DFI_INIT_START_DISABLE | + DMC_CONCONTROL_TIMEOUT_LEVEL0 | + DMC_CONCONTROL_RD_FETCH_DISABLE | + DMC_CONCONTROL_EMPTY_DISABLE | + DMC_CONCONTROL_AREF_EN_DISABLE | + DMC_CONCONTROL_IO_PD_CON_DISABLE, + .dmc_channels = 1, + .chips_per_channel = 1, + .chips_to_configure = 1, + .send_zq_init = 1, + .gate_leveling_enable = 1, + .read_leveling_enable = 0, + } +#else { .mem_manuf = MEM_MANUF_ELPIDA, .mem_type = DDR_MODE_DDR3, @@ -324,6 +467,7 @@ struct mem_timings mem_timings[] = { .impedance = IMP_OUTPUT_DRV_40_OHM, .gate_leveling_enable = 1, } +#endif };
/** @@ -399,7 +543,7 @@ struct mem_timings *clock_get_mem_timings(void) return NULL; }
-void system_clock_init() +static void exynos5250_system_clock_init(void) { struct exynos5_clock *clk = (struct exynos5_clock *)samsung_get_base_clock(); @@ -436,19 +580,13 @@ void system_clock_init() } while ((val | MUX_BPLL_SEL_MASK) != val);
/* PLL locktime */ - writel(APLL_LOCK_VAL, &clk->apll_lock); - - writel(MPLL_LOCK_VAL, &clk->mpll_lock); - - writel(BPLL_LOCK_VAL, &clk->bpll_lock); - - writel(CPLL_LOCK_VAL, &clk->cpll_lock); - - writel(GPLL_LOCK_VAL, &clk->gpll_lock); - - writel(EPLL_LOCK_VAL, &clk->epll_lock); - - writel(VPLL_LOCK_VAL, &clk->vpll_lock); + writel(mem->apll_pdiv * PLL_LOCK_FACTOR, &clk->apll_lock); + writel(mem->mpll_pdiv * PLL_LOCK_FACTOR, &clk->mpll_lock); + writel(mem->bpll_pdiv * PLL_LOCK_FACTOR, &clk->bpll_lock); + writel(mem->cpll_pdiv * PLL_LOCK_FACTOR, &clk->cpll_lock); + writel(mem->gpll_pdiv * PLL_X_LOCK_FACTOR, &clk->gpll_lock); + writel(mem->epll_pdiv * PLL_X_LOCK_FACTOR, &clk->epll_lock); + writel(mem->vpll_pdiv * PLL_X_LOCK_FACTOR, &clk->vpll_lock);
writel(CLK_REG_DISABLE, &clk->pll_div2_sel);
@@ -640,6 +778,192 @@ void system_clock_init() writel(val, &clk->div_fsys2); }
+static void exynos5420_system_clock_init(void) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + struct mem_timings *mem; + struct arm_clk_ratios *arm_clk_ratio; + u32 val; + + mem = clock_get_mem_timings(); + arm_clk_ratio = get_arm_ratios(); + + /* PLL locktime */ + writel(arm_clk_ratio->apll_pdiv * PLL_LOCK_FACTOR, &clk->apll_lock); + writel(mem->mpll_pdiv * PLL_LOCK_FACTOR, &clk->mpll_lock); + writel(mem->bpll_pdiv * PLL_LOCK_FACTOR, &clk->bpll_lock); + writel(mem->cpll_pdiv * PLL_LOCK_FACTOR, &clk->cpll_lock); + writel(mem->dpll_pdiv * PLL_LOCK_FACTOR, &clk->dpll_lock); + writel(mem->epll_pdiv * PLL_X_LOCK_FACTOR, &clk->epll_lock); + writel(mem->vpll_pdiv * PLL_LOCK_FACTOR, &clk->vpll_lock); + writel(mem->ipll_pdiv * PLL_LOCK_FACTOR, &clk->ipll_lock); + writel(mem->spll_pdiv * PLL_LOCK_FACTOR, &clk->spll_lock); + writel(mem->kpll_pdiv * PLL_LOCK_FACTOR, &clk->kpll_lock); + + setbits_le32(&clk->src_cpu, MUX_HPM_SEL_MASK); + + writel(0, &clk->src_top6); + + writel(0, &clk->src_cdrex); + writel(SRC_KFC_HPM_SEL, &clk->src_kfc); + writel(HPM_RATIO, &clk->div_cpu1); + writel(CLK_DIV_CPU0_VAL, &clk->div_cpu0); + + /* switch A15 clock source to OSC clock before changing APLL */ + clrbits_le32(&clk->src_cpu, APLL_FOUT); + + /* Set APLL */ + writel(APLL_CON1_VAL, &clk->apll_con1); + val = set_pll(arm_clk_ratio->apll_mdiv, + arm_clk_ratio->apll_pdiv, + arm_clk_ratio->apll_sdiv); + writel(val, &clk->apll_con0); + while ((readl(&clk->apll_con0) & PLL_LOCKED) == 0) + ; + + /* now it is safe to switch to APLL */ + setbits_le32(&clk->src_cpu, APLL_FOUT); + + writel(SRC_KFC_HPM_SEL, &clk->src_kfc); + writel(CLK_DIV_KFC_VAL, &clk->div_kfc0); + + /* switch A7 clock source to OSC clock before changing KPLL */ + clrbits_le32(&clk->src_kfc, KPLL_FOUT); + + /* Set KPLL*/ + writel(KPLL_CON1_VAL, &clk->kpll_con1); + val = set_pll(mem->kpll_mdiv, mem->kpll_pdiv, mem->kpll_sdiv); + writel(val, &clk->kpll_con0); + while ((readl(&clk->kpll_con0) & PLL_LOCKED) == 0) + ; + + /* now it is safe to switch to KPLL */ + setbits_le32(&clk->src_kfc, KPLL_FOUT); + + /* Set MPLL */ + writel(MPLL_CON1_VAL, &clk->mpll_con1); + val = set_pll(mem->mpll_mdiv, mem->mpll_pdiv, mem->mpll_sdiv); + writel(val, &clk->mpll_con0); + while ((readl(&clk->mpll_con0) & PLL_LOCKED) == 0) + ; + + /* Set DPLL */ + writel(DPLL_CON1_VAL, &clk->dpll_con1); + val = set_pll(mem->dpll_mdiv, mem->dpll_pdiv, mem->dpll_sdiv); + writel(val, &clk->dpll_con0); + while ((readl(&clk->dpll_con0) & PLL_LOCKED) == 0) + ; + + /* Set EPLL */ + writel(EPLL_CON2_VAL, &clk->epll_con2); + writel(EPLL_CON1_VAL, &clk->epll_con1); + val = set_pll(mem->epll_mdiv, mem->epll_pdiv, mem->epll_sdiv); + writel(val, &clk->epll_con0); + while ((readl(&clk->epll_con0) & PLL_LOCKED) == 0) + ; + + /* Set CPLL */ + writel(CPLL_CON1_VAL, &clk->cpll_con1); + val = set_pll(mem->cpll_mdiv, mem->cpll_pdiv, mem->cpll_sdiv); + writel(val, &clk->cpll_con0); + while ((readl(&clk->cpll_con0) & PLL_LOCKED) == 0) + ; + + /* Set IPLL */ + writel(IPLL_CON1_VAL, &clk->ipll_con1); + val = set_pll(mem->ipll_mdiv, mem->ipll_pdiv, mem->ipll_sdiv); + writel(val, &clk->ipll_con0); + while ((readl(&clk->ipll_con0) & PLL_LOCKED) == 0) + ; + + /* Set VPLL */ + writel(VPLL_CON1_VAL, &clk->vpll_con1); + val = set_pll(mem->vpll_mdiv, mem->vpll_pdiv, mem->vpll_sdiv); + writel(val, &clk->vpll_con0); + while ((readl(&clk->vpll_con0) & PLL_LOCKED) == 0) + ; + + /* Set BPLL */ + writel(BPLL_CON1_VAL, &clk->bpll_con1); + val = set_pll(mem->bpll_mdiv, mem->bpll_pdiv, mem->bpll_sdiv); + writel(val, &clk->bpll_con0); + while ((readl(&clk->bpll_con0) & PLL_LOCKED) == 0) + ; + + /* Set SPLL */ + writel(SPLL_CON1_VAL, &clk->spll_con1); + val = set_pll(mem->spll_mdiv, mem->spll_pdiv, mem->spll_sdiv); + writel(val, &clk->spll_con0); + while ((readl(&clk->spll_con0) & PLL_LOCKED) == 0) + ; + + writel(CLK_DIV_CDREX0_VAL, &clk->div_cdrex0); + writel(CLK_DIV_CDREX1_VAL, &clk->div_cdrex1); + + writel(CLK_SRC_TOP0_VAL, &clk->src_top0); + writel(CLK_SRC_TOP1_VAL, &clk->src_top1); + writel(CLK_SRC_TOP2_VAL, &clk->src_top2); + writel(CLK_SRC_TOP7_VAL, &clk->src_top7); + + writel(CLK_DIV_TOP0_VAL, &clk->div_top0); + writel(CLK_DIV_TOP1_VAL, &clk->div_top1); + writel(CLK_DIV_TOP2_VAL, &clk->div_top2); + + writel(0, &clk->src_top10); + writel(0, &clk->src_top11); + writel(0, &clk->src_top12); + + writel(CLK_SRC_TOP3_VAL, &clk->src_top3); + writel(CLK_SRC_TOP4_VAL, &clk->src_top4); + writel(CLK_SRC_TOP5_VAL, &clk->src_top5); + + /* DISP1 BLK CLK SELECTION */ + writel(CLK_SRC_DISP1_0_VAL, &clk->src_disp10); + writel(CLK_DIV_DISP1_0_VAL, &clk->div_disp10); + + /* AUDIO BLK */ + writel(AUDIO0_SEL_EPLL, &clk->src_mau); + writel(DIV_MAU_VAL, &clk->div_mau); + + /* FSYS */ + writel(CLK_SRC_FSYS0_VAL, &clk->src_fsys); + writel(CLK_DIV_FSYS0_VAL, &clk->div_fsys0); + writel(CLK_DIV_FSYS1_VAL, &clk->div_fsys1); + writel(CLK_DIV_FSYS2_VAL, &clk->div_fsys2); + + writel(CLK_SRC_ISP_VAL, &clk->src_isp); + writel(CLK_DIV_ISP0_VAL, &clk->div_isp0); + writel(CLK_DIV_ISP1_VAL, &clk->div_isp1); + + writel(CLK_SRC_PERIC0_VAL, &clk->src_peric0); + writel(CLK_SRC_PERIC1_VAL, &clk->src_peric1); + + writel(CLK_DIV_PERIC0_VAL, &clk->div_peric0); + writel(CLK_DIV_PERIC1_VAL, &clk->div_peric1); + writel(CLK_DIV_PERIC2_VAL, &clk->div_peric2); + writel(CLK_DIV_PERIC3_VAL, &clk->div_peric3); + writel(CLK_DIV_PERIC4_VAL, &clk->div_peric4); + + writel(CLK_DIV_CPERI1_VAL, &clk->div_cperi1); + + writel(CLK_DIV2_RATIO, &clk->clkdiv2_ratio); + writel(CLK_DIV4_RATIO, &clk->clkdiv4_ratio); + writel(CLK_DIV_G2D, &clk->div_g2d); + + writel(CLK_SRC_TOP6_VAL, &clk->src_top6); + writel(CLK_SRC_CDREX_VAL, &clk->src_cdrex); + writel(CLK_SRC_KFC_VAL, &clk->src_kfc); +} + +void system_clock_init(void) +{ + if (proid_is_exynos5420()) + exynos5420_system_clock_init(); + else + exynos5250_system_clock_init(); +} + void clock_init_dp_clock(void) { struct exynos5_clock *clk = diff --git a/arch/arm/cpu/armv7/exynos/exynos5_setup.h b/arch/arm/cpu/armv7/exynos/exynos5_setup.h index 696b386..c8d6515 100644 --- a/arch/arm/cpu/armv7/exynos/exynos5_setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos5_setup.h @@ -12,42 +12,16 @@ #include <config.h> #include <asm/arch/dmc.h>
-/* APLL_CON1 */ -#define APLL_CON1_VAL (0x00203800) - -/* MPLL_CON1 */ -#define MPLL_CON1_VAL (0x00203800) - -/* CPLL_CON1 */ -#define CPLL_CON1_VAL (0x00203800) - -/* GPLL_CON1 */ -#define GPLL_CON1_VAL (0x00203800) - -/* EPLL_CON1, CON2 */ -#define EPLL_CON1_VAL 0x00000000 -#define EPLL_CON2_VAL 0x00000080 - -/* VPLL_CON1, CON2 */ -#define VPLL_CON1_VAL 0x00000000 -#define VPLL_CON2_VAL 0x00000080 +#define NOT_AVAILABLE 0 +#define DATA_MASK 0xFFFFF
-/* BPLL_CON1 */ -#define BPLL_CON1_VAL 0x00203800 +#define ENABLE_BIT 0x1 +#define DISABLE_BIT 0x0 +#define CA_SWAP_EN (1 << 0)
/* Set PLL */ #define set_pll(mdiv, pdiv, sdiv) (1<<31 | mdiv<<16 | pdiv<<8 | sdiv)
-/* CLK_SRC_CPU */ -/* 0 = MOUTAPLL, 1 = SCLKMPLL */ -#define MUX_HPM_SEL 0 -#define MUX_CPU_SEL 0 -#define MUX_APLL_SEL 1 - -#define CLK_SRC_CPU_VAL ((MUX_HPM_SEL << 20) \ - | (MUX_CPU_SEL << 16) \ - | (MUX_APLL_SEL)) - /* MEMCONTROL register bit fields */ #define DMC_MEMCONTROL_CLK_STOP_DISABLE (0 << 0) #define DMC_MEMCONTROL_DPWRDN_DISABLE (0 << 1) @@ -78,6 +52,7 @@
/* MEMCONFIG0 register bit fields */ #define DMC_MEMCONFIGX_CHIP_MAP_INTERLEAVED (1 << 12) +#define DMC_MEMCONFIG_CHIP_MAP_SPLIT (2 << 12) #define DMC_MEMCONFIGX_CHIP_COL_10 (3 << 8) #define DMC_MEMCONFIGX_CHIP_ROW_14 (2 << 4) #define DMC_MEMCONFIGX_CHIP_ROW_15 (3 << 4) @@ -90,6 +65,17 @@ DMC_MEMBASECONFIGX_CHIP_MASK(0x780) \ )
+/* + * As we use channel interleaving, therefore value of the base address + * register must be set as half of the bus base address + * RAM start addess is 0x2000_0000 which means chip_base is 0x20, so + * we need to set half 0x10 to the membaseconfigx registers + * see exynos5420 UM section 17.17.3.21 for more. + */ +#define DMC_CHIP_BASE_0 0x10 +#define DMC_CHIP_BASE_1 0x50 +#define DMC_CHIP_MASK 0x7C0 + #define DMC_MEMBASECONFIG0_VAL DMC_MEMBASECONFIG_VAL(0x40) #define DMC_MEMBASECONFIG1_VAL DMC_MEMBASECONFIG_VAL(0x80)
@@ -113,29 +99,24 @@
/* COJCONTROL register bit fields */ #define DMC_CONCONTROL_IO_PD_CON_DISABLE (0 << 3) +#define DMC_CONCONTROL_IO_PD_CON_ENABLE (1 << 3) #define DMC_CONCONTROL_AREF_EN_DISABLE (0 << 5) +#define DMC_CONCONTROL_AREF_EN_ENABLE (1 << 5) #define DMC_CONCONTROL_EMPTY_DISABLE (0 << 8) #define DMC_CONCONTROL_EMPTY_ENABLE (1 << 8) #define DMC_CONCONTROL_RD_FETCH_DISABLE (0x0 << 12) #define DMC_CONCONTROL_TIMEOUT_LEVEL0 (0xFFF << 16) #define DMC_CONCONTROL_DFI_INIT_START_DISABLE (0 << 28)
-/* CLK_DIV_CPU0_VAL */ -#define CLK_DIV_CPU0_VAL ((ARM2_RATIO << 28) \ - | (APLL_RATIO << 24) \ - | (PCLK_DBG_RATIO << 20) \ - | (ATB_RATIO << 16) \ - | (PERIPH_RATIO << 12) \ - | (ACP_RATIO << 8) \ - | (CPUD_RATIO << 4) \ - | (ARM_RATIO)) +#define DMC_CONCONTROL_VAL 0x1FFF2101
+#define DREX_CONCONTROL_VAL DMC_CONCONTROL_VAL \ + | DMC_CONCONTROL_AREF_EN_ENABLE \ + | DMC_CONCONTROL_IO_PD_CON_ENABLE
-/* CLK_FSYS */ -#define CLK_SRC_FSYS0_VAL 0x66666 -#define CLK_DIV_FSYS0_VAL 0x0BB00000 +#define DMC_CONCONTROL_IO_PD_CON(x) (x << 6)
-/* CLK_DIV_CPU1 */ +/* CLK_DIV_CPU1 */ #define HPM_RATIO 0x2 #define COPY_RATIO 0x0
@@ -164,10 +145,367 @@ /* CLK_DIV_SYSLFT */ #define CLK_DIV_SYSLFT_VAL 0x00000311
+#define MUX_APLL_SEL_MASK (1 << 0) +#define MUX_MPLL_SEL_MASK (1 << 8) +#define MPLL_SEL_MOUT_MPLLFOUT (2 << 8) +#define MUX_CPLL_SEL_MASK (1 << 8) +#define MUX_EPLL_SEL_MASK (1 << 12) +#define MUX_VPLL_SEL_MASK (1 << 16) +#define MUX_GPLL_SEL_MASK (1 << 28) +#define MUX_BPLL_SEL_MASK (1 << 0) +#define MUX_HPM_SEL_MASK (1 << 20) +#define HPM_SEL_SCLK_MPLL (1 << 21) +#define PLL_LOCKED (1 << 29) +#define APLL_CON0_LOCKED (1 << 29) +#define MPLL_CON0_LOCKED (1 << 29) +#define BPLL_CON0_LOCKED (1 << 29) +#define CPLL_CON0_LOCKED (1 << 29) +#define EPLL_CON0_LOCKED (1 << 29) +#define GPLL_CON0_LOCKED (1 << 29) +#define VPLL_CON0_LOCKED (1 << 29) +#define CLK_REG_DISABLE 0x0 +#define TOP2_VAL 0x0110000 + +/* SCLK_SRC_ISP - set SPI0/1 to 6 = SCLK_MPLL_USER */ +#define SPI0_ISP_SEL 6 +#define SPI1_ISP_SEL 6 +#define SCLK_SRC_ISP_VAL (SPI1_ISP_SEL << 4) \ + | (SPI0_ISP_SEL << 0) + +/* SCLK_DIV_ISP - set SPI0/1 to 0xf = divide by 16 */ +#define SPI0_ISP_RATIO 0xf +#define SPI1_ISP_RATIO 0xf +#define SCLK_DIV_ISP_VAL (SPI1_ISP_RATIO << 12) \ + | (SPI0_ISP_RATIO << 0) + +/* CLK_DIV_FSYS2 */ +#define MMC2_RATIO_MASK 0xf +#define MMC2_RATIO_VAL 0x3 +#define MMC2_RATIO_OFFSET 0 + +#define MMC2_PRE_RATIO_MASK 0xff +#define MMC2_PRE_RATIO_VAL 0x9 +#define MMC2_PRE_RATIO_OFFSET 8 + +#define MMC3_RATIO_MASK 0xf +#define MMC3_RATIO_VAL 0x1 +#define MMC3_RATIO_OFFSET 16 + +#define MMC3_PRE_RATIO_MASK 0xff +#define MMC3_PRE_RATIO_VAL 0x0 +#define MMC3_PRE_RATIO_OFFSET 24 + +/* CLK_SRC_LEX */ +#define CLK_SRC_LEX_VAL 0x0 + +/* CLK_DIV_LEX */ +#define CLK_DIV_LEX_VAL 0x10 + +/* CLK_DIV_R0X */ +#define CLK_DIV_R0X_VAL 0x10 + +/* CLK_DIV_L0X */ +#define CLK_DIV_R1X_VAL 0x10 + +/* CLK_DIV_ISP2 */ +#define CLK_DIV_ISP2_VAL 0x1 + +/* CLK_SRC_KFC */ +#define SRC_KFC_HPM_SEL (1 << 15) + +/* CLK_SRC_KFC */ +#define CLK_SRC_KFC_VAL 0x00008001 + +/* CLK_DIV_KFC */ +#define CLK_DIV_KFC_VAL 0x03300110 + +/* CLK_DIV2_RATIO */ +#define CLK_DIV2_RATIO 0x10111150 + +/* CLK_DIV4_RATIO */ +#define CLK_DIV4_RATIO 0x00000003 + +/* CLK_DIV_G2D */ +#define CLK_DIV_G2D 0x00000010 + +/* + * DIV_DISP1_0 + * For DP, divisor should be 2 + */ +#define CLK_DIV_DISP1_0_FIMD1 (2 << 0) + +/* CLK_GATE_IP_DISP1 */ +#define CLK_GATE_DP1_ALLOW (1 << 4) + +/* AUDIO CLK SEL */ +#define AUDIO0_SEL_EPLL (0x6 << 28) +#define AUDIO0_RATIO 0x5 +#define PCM0_RATIO 0x3 +#define DIV_MAU_VAL (PCM0_RATIO << 24 | AUDIO0_RATIO << 20) + +/* CLK_SRC_CDREX */ +#define MUX_MCLK_CDR_MSPLL (1 << 4) +#define MUX_BPLL_SEL_FOUTBPLL (1 << 0) +#define BPLL_SEL_MASK 0x7 +#define FOUTBPLL 2 + +#define DDR3PHY_CTRL_PHY_RESET (1 << 0) +#define DDR3PHY_CTRL_PHY_RESET_OFF (0 << 0) + +#define PHY_CON0_RESET_VAL 0x17020a40 +#define P0_CMD_EN (1 << 14) +#define BYTE_RDLVL_EN (1 << 13) +#define CTRL_SHGATE (1 << 8) + +#define PHY_CON1_RESET_VAL 0x09210100 +#define RDLVL_PASS_ADJ_VAL 0x6 +#define RDLVL_PASS_ADJ_OFFSET 16 +#define CTRL_GATEDURADJ_MASK (0xf << 20) +#define READ_LEVELLING_DDR3 0x0100 + +#define PHY_CON2_RESET_VAL 0x00010004 +#define INIT_DESKEW_EN (1 << 6) +#define DLL_DESKEW_EN (1 << 12) +#define RDLVL_GATE_EN (1 << 24) +#define RDLVL_EN (1 << 25) +#define RDLVL_INCR_ADJ (0x1 << 16) + +/* DREX_PAUSE */ +#define DREX_PAUSE_EN (1 << 0) + +#define BYPASS_EN (1 << 22) + +/* MEMMORY VAL */ +#define PHY_CON0_VAL 0x17021A00 + +#define PHY_CON12_RESET_VAL 0x10100070 +#define PHY_CON12_VAL 0x10107F50 +#define CTRL_START (1 << 6) +#define CTRL_DLL_ON (1 << 5) +#define CTRL_FORCE_MASK (0x7F << 8) +#define CTRL_LOCK_COARSE_MASK (0x7F << 10) + +#define CTRL_OFFSETD_RESET_VAL 0x8 +#define CTRL_OFFSETD_VAL 0x7F + +#define CTRL_OFFSETR0 0x7F +#define CTRL_OFFSETR1 0x7F +#define CTRL_OFFSETR2 0x7F +#define CTRL_OFFSETR3 0x7F +#define PHY_CON4_VAL (CTRL_OFFSETR0 << 0 | \ + CTRL_OFFSETR1 << 8 | \ + CTRL_OFFSETR2 << 16 | \ + CTRL_OFFSETR3 << 24) +#define PHY_CON4_RESET_VAL 0x08080808 + +#define CTRL_OFFSETW0 0x7F +#define CTRL_OFFSETW1 0x7F +#define CTRL_OFFSETW2 0x7F +#define CTRL_OFFSETW3 0x7F +#define PHY_CON6_VAL (CTRL_OFFSETW0 << 0 | \ + CTRL_OFFSETW1 << 8 | \ + CTRL_OFFSETW2 << 16 | \ + CTRL_OFFSETW3 << 24) +#define PHY_CON6_RESET_VAL 0x08080808 + +#define PHY_CON14_RESET_VAL 0x001F0000 +#define CTRL_PULLD_DQS 0xF +#define CTRL_PULLD_DQS_OFFSET 0 + +/* ZQ Configurations */ +#define PHY_CON16_RESET_VAL 0x08000304 + +#define ZQ_CLK_EN (1 << 27) +#define ZQ_CLK_DIV_EN (1 << 18) +#define ZQ_MANUAL_STR (1 << 1) +#define ZQ_DONE (1 << 0) +#define ZQ_MODE_DDS_OFFSET 24 + +#define CTRL_RDLVL_GATE_ENABLE 1 +#define CTRL_RDLVL_GATE_DISABLE 0 +#define CTRL_RDLVL_DATA_ENABLE 2 + +/* Direct Command */ +#define DIRECT_CMD_NOP 0x07000000 +#define DIRECT_CMD_PALL 0x01000000 +#define DIRECT_CMD_ZQINIT 0x0a000000 +#define DIRECT_CMD_CHANNEL_SHIFT 28 +#define DIRECT_CMD_CHIP_SHIFT 20 +#define DIRECT_CMD_BANK_SHIFT 16 +#define DIRECT_CMD_REFA (5 << 24) +#define DIRECT_CMD_MRS1 0x71C00 +#define DIRECT_CMD_MRS2 0x10BFC +#define DIRECT_CMD_MRS3 0x0050C +#define DIRECT_CMD_MRS4 0x00868 +#define DIRECT_CMD_MRS5 0x00C04 + +/* Drive Strength */ +#define IMPEDANCE_48_OHM 4 +#define IMPEDANCE_40_OHM 5 +#define IMPEDANCE_34_OHM 6 +#define IMPEDANCE_30_OHM 7 +#define PHY_CON39_VAL_48_OHM 0x09240924 +#define PHY_CON39_VAL_40_OHM 0x0B6D0B6D +#define PHY_CON39_VAL_34_OHM 0x0DB60DB6 +#define PHY_CON39_VAL_30_OHM 0x0FFF0FFF + +#define CTRL_BSTLEN_OFFSET 8 +#define CTRL_RDLAT_OFFSET 0 + +#define CMD_DEFAULT_LPDDR3 0xF +#define CMD_DEFUALT_OFFSET 0 +#define T_WRDATA_EN 0x7 +#define T_WRDATA_EN_DDR3 0x8 +#define T_WRDATA_EN_OFFSET 16 +#define T_WRDATA_EN_MASK 0x1f + +#define PHY_CON31_VAL 0x0C183060 +#define PHY_CON32_VAL 0x60C18306 +#define PHY_CON33_VAL 0x00000030 + +#define PHY_CON31_RESET_VAL 0x0 +#define PHY_CON32_RESET_VAL 0x0 +#define PHY_CON33_RESET_VAL 0x0 + +#define SL_DLL_DYN_CON_EN (1 << 1) +#define FP_RESYNC (1 << 3) +#define CTRL_START (1 << 6) + +#define DMC_AREF_EN (1 << 5) +#define DMC_CONCONTROL_EMPTY (1 << 8) +#define DFI_INIT_START (1 << 28) + +#define DMC_MEMCONTROL_VAL 0x00312700 +#define CLK_STOP_EN (1 << 0) +#define DPWRDN_EN (1 << 1) +#define DSREF_EN (1 << 5) + +#define MEMBASECONFIG_CHIP_MASK_VAL 0x7E0 +#define MEMBASECONFIG_CHIP_MASK_OFFSET 0 +#define MEMBASECONFIG0_CHIP_BASE_VAL 0x20 +#define MEMBASECONFIG1_CHIP_BASE_VAL 0x40 +#define CHIP_BASE_OFFSET 16 + +#define MEMCONFIG_VAL 0x1323 +#define PRECHCONFIG_DEFAULT_VAL 0xFF000000 +#define PWRDNCONFIG_DEFAULT_VAL 0xFFFF00FF + +#define TIMINGAREF_VAL 0x5d +#define TIMINGROW_VAL 0x345A8692 +#define TIMINGDATA_VAL 0x3630065C +#define TIMINGPOWER_VAL 0x50380336 +#define DFI_INIT_COMPLETE (1 << 3) + +#define BRBRSVCONTROL_VAL 0x00000033 +#define BRBRSVCONFIG_VAL 0x88778877 + +/* Clock Gating Control (CGCONTROL) register */ +#define MEMIF_CG_EN (1 << 3) /* Memory interface clock gating */ +#define SCG_CG_EN (1 << 2) /* Scheduler clock gating */ +#define BUSIF_WR_CG_EN (1 << 1) /* Bus interface write channel clock gating */ +#define BUSIF_RD_CG_EN (1 << 0) /* Bus interface read channel clock gating */ +#define DMC_INTERNAL_CG (MEMIF_CG_EN | SCG_CG_EN | \ + BUSIF_WR_CG_EN | BUSIF_RD_CG_EN) + +/* DMC PHY Control0 register */ +#define PHY_CONTROL0_RESET_VAL 0x0 +#define MEM_TERM_EN (1 << 31) /* Termination enable for memory */ +#define PHY_TERM_EN (1 << 30) /* Termination enable for PHY */ +#define DMC_CTRL_SHGATE (1 << 29) /* Duration of DQS gating signal */ +#define FP_RSYNC (1 << 3) /* Force DLL resyncronization */ + +/* Driver strength for CK, CKE, CS & CA */ +#define IMP_OUTPUT_DRV_40_OHM 0x5 +#define IMP_OUTPUT_DRV_30_OHM 0x7 +#define DA_3_DS_OFFSET 25 +#define DA_2_DS_OFFSET 22 +#define DA_1_DS_OFFSET 19 +#define DA_0_DS_OFFSET 16 +#define CA_CK_DRVR_DS_OFFSET 9 +#define CA_CKE_DRVR_DS_OFFSET 6 +#define CA_CS_DRVR_DS_OFFSET 3 +#define CA_ADR_DRVR_DS_OFFSET 0 + +#define PHY_CON42_CTRL_BSTLEN_SHIFT 8 +#define PHY_CON42_CTRL_RDLAT_SHIFT 0 + +/* + * Definitions that differ with SoC's. + * Below is the part defining macros for smdk5250. + * Else part introduces macros for smdk5420. + */ +#ifndef CONFIG_SMDK5420 + +/* APLL_CON1 */ +#define APLL_CON1_VAL (0x00203800) + +/* MPLL_CON1 */ +#define MPLL_CON1_VAL (0x00203800) + +/* CPLL_CON1 */ +#define CPLL_CON1_VAL (0x00203800) + +/* DPLL_CON1 */ +#define DPLL_CON1_VAL (NOT_AVAILABLE) + +/* GPLL_CON1 */ +#define GPLL_CON1_VAL (0x00203800) + +/* EPLL_CON1, CON2 */ +#define EPLL_CON1_VAL 0x00000000 +#define EPLL_CON2_VAL 0x00000080 + +/* VPLL_CON1, CON2 */ +#define VPLL_CON1_VAL 0x00000000 +#define VPLL_CON2_VAL 0x00000080 + +/* RPLL_CON1, CON2 */ +#define RPLL_CON1_VAL NOT_AVAILABLE +#define RPLL_CON2_VAL NOT_AVAILABLE + +/* BPLL_CON1 */ +#define BPLL_CON1_VAL 0x00203800 + +/* SPLL_CON1 */ +#define SPLL_CON1_VAL NOT_AVAILABLE + +/* IPLL_CON1 */ +#define IPLL_CON1_VAL NOT_AVAILABLE + +/* KPLL_CON1 */ +#define KPLL_CON1_VAL NOT_AVAILABLE + +/* CLK_SRC_ISP */ +#define CLK_SRC_ISP_VAL NOT_AVAILABLE +#define CLK_DIV_ISP0_VAL 0x31 +#define CLK_DIV_ISP1_VAL 0x0 + +/* CLK_FSYS */ +#define CLK_SRC_FSYS0_VAL 0x66666 +#define CLK_DIV_FSYS0_VAL 0x0BB00000 +#define CLK_DIV_FSYS1_VAL NOT_AVAILABLE +#define CLK_DIV_FSYS2_VAL NOT_AVAILABLE + +/* CLK_SRC_CPU */ +/* 0 = MOUTAPLL, 1 = SCLKMPLL */ +#define MUX_HPM_SEL 0 +#define MUX_CPU_SEL 0 +#define MUX_APLL_SEL 1 + +#define CLK_SRC_CPU_VAL ((MUX_HPM_SEL << 20) \ + | (MUX_CPU_SEL << 16) \ + | (MUX_APLL_SEL)) + /* CLK_SRC_CDREX */ #define CLK_SRC_CDREX_VAL 0x1
/* CLK_DIV_CDREX */ +#define CLK_DIV_CDREX0_VAL NOT_AVAILABLE +#define CLK_DIV_CDREX1_VAL NOT_AVAILABLE + +/* CLK_DIV_CPU0_VAL */ +#define CLK_DIV_CPU0_VAL NOT_AVAILABLE + #define MCLK_CDREX2_RATIO 0x0 #define ACLK_EFCON_RATIO 0x1 #define MCLK_DPHY_RATIO 0x1 @@ -247,6 +585,11 @@ | (MUX_ACLK_300_DISP1_SUB_SEL << 6) \ | (MUX_ACLK_200_DISP1_SUB_SEL << 4))
+#define CLK_SRC_TOP4_VAL NOT_AVAILABLE +#define CLK_SRC_TOP5_VAL NOT_AVAILABLE +#define CLK_SRC_TOP6_VAL NOT_AVAILABLE +#define CLK_SRC_TOP7_VAL NOT_AVAILABLE + /* CLK_DIV_TOP0 */ #define ACLK_300_DISP1_RATIO 0x2 #define ACLK_400_G3D_RATIO 0x0 @@ -279,40 +622,11 @@ | (ACLK_400_IOP_RATIO << 16) \ | (ACLK_300_GSCL_RATIO << 12))
-/* APLL_LOCK */ -#define APLL_LOCK_VAL (0x546) -/* MPLL_LOCK */ -#define MPLL_LOCK_VAL (0x546) -/* CPLL_LOCK */ -#define CPLL_LOCK_VAL (0x546) -/* GPLL_LOCK */ -#define GPLL_LOCK_VAL (0x546) -/* EPLL_LOCK */ -#define EPLL_LOCK_VAL (0x3A98) -/* VPLL_LOCK */ -#define VPLL_LOCK_VAL (0x3A98) -/* BPLL_LOCK */ -#define BPLL_LOCK_VAL (0x546) +#define CLK_DIV_TOP2_VAL NOT_AVAILABLE
-#define MUX_APLL_SEL_MASK (1 << 0) -#define MUX_MPLL_SEL_MASK (1 << 8) -#define MPLL_SEL_MOUT_MPLLFOUT (2 << 8) -#define MUX_CPLL_SEL_MASK (1 << 8) -#define MUX_EPLL_SEL_MASK (1 << 12) -#define MUX_VPLL_SEL_MASK (1 << 16) -#define MUX_GPLL_SEL_MASK (1 << 28) -#define MUX_BPLL_SEL_MASK (1 << 0) -#define MUX_HPM_SEL_MASK (1 << 20) -#define HPM_SEL_SCLK_MPLL (1 << 21) -#define APLL_CON0_LOCKED (1 << 29) -#define MPLL_CON0_LOCKED (1 << 29) -#define BPLL_CON0_LOCKED (1 << 29) -#define CPLL_CON0_LOCKED (1 << 29) -#define EPLL_CON0_LOCKED (1 << 29) -#define GPLL_CON0_LOCKED (1 << 29) -#define VPLL_CON0_LOCKED (1 << 29) -#define CLK_REG_DISABLE 0x0 -#define TOP2_VAL 0x0110000 +/* PLL Lock Value Factor */ +#define PLL_LOCK_FACTOR 250 +#define PLL_X_LOCK_FACTOR 3000
/* CLK_SRC_PERIC0 */ #define PWM_SEL 6 @@ -336,18 +650,6 @@ | (SPI1_SEL << 20) \ | (SPI0_SEL << 16))
-/* SCLK_SRC_ISP - set SPI0/1 to 6 = SCLK_MPLL_USER */ -#define SPI0_ISP_SEL 6 -#define SPI1_ISP_SEL 6 -#define SCLK_SRC_ISP_VAL (SPI1_ISP_SEL << 4) \ - | (SPI0_ISP_SEL << 0) - -/* SCLK_DIV_ISP - set SPI0/1 to 0xf = divide by 16 */ -#define SPI0_ISP_RATIO 0xf -#define SPI1_ISP_RATIO 0xf -#define SCLK_DIV_ISP_VAL (SPI1_ISP_RATIO << 12) \ - | (SPI0_ISP_RATIO << 0) - /* CLK_DIV_PERIL0 */ #define UART5_RATIO 7 #define UART4_RATIO 7 @@ -380,105 +682,200 @@ #define PWM_RATIO 8 #define CLK_DIV_PERIC3_VAL (PWM_RATIO << 0)
-/* CLK_DIV_FSYS2 */ -#define MMC2_RATIO_MASK 0xf -#define MMC2_RATIO_VAL 0x3 -#define MMC2_RATIO_OFFSET 0
-#define MMC2_PRE_RATIO_MASK 0xff -#define MMC2_PRE_RATIO_VAL 0x9 -#define MMC2_PRE_RATIO_OFFSET 8 +/* CLK_DIV_PERIC4 */ +#define CLK_DIV_PERIC4_VAL NOT_AVAILABLE
-#define MMC3_RATIO_MASK 0xf -#define MMC3_RATIO_VAL 0x1 -#define MMC3_RATIO_OFFSET 16 +/* CLK_SRC_DISP1_0 */ +#define CLK_SRC_DISP1_0_VAL 0x6 +#define CLK_DIV_DISP1_0_VAL NOT_AVAILABLE
-#define MMC3_PRE_RATIO_MASK 0xff -#define MMC3_PRE_RATIO_VAL 0x0 -#define MMC3_PRE_RATIO_OFFSET 24 +#define APLL_FOUT (1 << 0) +#define KPLL_FOUT NOT_AVAILABLE
-/* CLK_SRC_LEX */ -#define CLK_SRC_LEX_VAL 0x0 +#define CLK_DIV_CPERI1_VAL NOT_AVAILABLE
-/* CLK_DIV_LEX */ -#define CLK_DIV_LEX_VAL 0x10 +#else
-/* CLK_DIV_R0X */ -#define CLK_DIV_R0X_VAL 0x10 +/* APLL_CON1 */ +#define APLL_CON1_VAL (0x0020F300)
-/* CLK_DIV_L0X */ -#define CLK_DIV_R1X_VAL 0x10 +/* MPLL_CON1 */ +#define MPLL_CON1_VAL (0x0020F300)
-/* CLK_DIV_ISP0 */ -#define CLK_DIV_ISP0_VAL 0x31
-/* CLK_DIV_ISP1 */ -#define CLK_DIV_ISP1_VAL 0x0 +/* CPLL_CON1 */ +#define CPLL_CON1_VAL 0x0020f300
-/* CLK_DIV_ISP2 */ -#define CLK_DIV_ISP2_VAL 0x1 +/* DPLL_CON1 */ +#define DPLL_CON1_VAL (0x0020F300)
-/* CLK_SRC_DISP1_0 */ -#define CLK_SRC_DISP1_0_VAL 0x6 +/* GPLL_CON1 */ +#define GPLL_CON1_VAL (NOT_AVAILABLE)
-/* - * DIV_DISP1_0 - * For DP, divisor should be 2 - */ -#define CLK_DIV_DISP1_0_FIMD1 (2 << 0)
-/* CLK_GATE_IP_DISP1 */ -#define CLK_GATE_DP1_ALLOW (1 << 4) +/* EPLL_CON1, CON2 */ +#define EPLL_CON1_VAL 0x00000000 +#define EPLL_CON2_VAL 0x00000080
-#define DDR3PHY_CTRL_PHY_RESET (1 << 0) -#define DDR3PHY_CTRL_PHY_RESET_OFF (0 << 0) +/* VPLL_CON1, CON2 */ +#define VPLL_CON1_VAL 0x0020f300 +#define VPLL_CON2_VAL NOT_AVAILABLE
-#define PHY_CON0_RESET_VAL 0x17020a40 -#define P0_CMD_EN (1 << 14) -#define BYTE_RDLVL_EN (1 << 13) -#define CTRL_SHGATE (1 << 8) +/* RPLL_CON1, CON2 */ +#define RPLL_CON1_VAL 0x00000000 +#define RPLL_CON2_VAL 0x00000080
-#define PHY_CON1_RESET_VAL 0x09210100 -#define CTRL_GATEDURADJ_MASK (0xf << 20) +/* BPLL_CON1 */ +#define BPLL_CON1_VAL 0x0020f300
-#define PHY_CON2_RESET_VAL 0x00010004 -#define INIT_DESKEW_EN (1 << 6) -#define RDLVL_GATE_EN (1 << 24) +/* SPLL_CON1 */ +#define SPLL_CON1_VAL 0x0020f300
-/*ZQ Configurations */ -#define PHY_CON16_RESET_VAL 0x08000304 +/* IPLL_CON1 */ +#define IPLL_CON1_VAL 0x00000080
-#define ZQ_CLK_DIV_EN (1 << 18) -#define ZQ_MANUAL_STR (1 << 1) -#define ZQ_DONE (1 << 0) +/* KPLL_CON1 */ +#define KPLL_CON1_VAL 0x200000
-#define CTRL_RDLVL_GATE_ENABLE 1 -#define CTRL_RDLVL_GATE_DISABLE 1 +/* CLK_SRC_ISP */ +#define CLK_SRC_ISP_VAL 0x33366000 +#define CLK_DIV_ISP0_VAL 0x13131300 +#define CLK_DIV_ISP1_VAL 0xbb110202
-/* Direct Command */ -#define DIRECT_CMD_NOP 0x07000000 -#define DIRECT_CMD_PALL 0x01000000 -#define DIRECT_CMD_ZQINIT 0x0a000000 -#define DIRECT_CMD_CHANNEL_SHIFT 28 -#define DIRECT_CMD_CHIP_SHIFT 20
-/* DMC PHY Control0 register */ -#define PHY_CONTROL0_RESET_VAL 0x0 -#define MEM_TERM_EN (1 << 31) /* Termination enable for memory */ -#define PHY_TERM_EN (1 << 30) /* Termination enable for PHY */ -#define DMC_CTRL_SHGATE (1 << 29) /* Duration of DQS gating signal */ -#define FP_RSYNC (1 << 3) /* Force DLL resyncronization */ +/* CLK_FSYS */ +#define CLK_SRC_FSYS0_VAL 0x33033300 +#define CLK_DIV_FSYS0_VAL 0x0 +#define CLK_DIV_FSYS1_VAL 0x04f13c4f +#define CLK_DIV_FSYS2_VAL 0x041d0000 + +/* CLK_SRC_CPU */ +/* 0 = MOUTAPLL, 1 = SCLKMPLL */ +#define MUX_HPM_SEL 1 +#define MUX_CPU_SEL 0 +#define MUX_APLL_SEL 1
-/* Driver strength for CK, CKE, CS & CA */ -#define IMP_OUTPUT_DRV_40_OHM 0x5 -#define IMP_OUTPUT_DRV_30_OHM 0x7 -#define CA_CK_DRVR_DS_OFFSET 9 -#define CA_CKE_DRVR_DS_OFFSET 6 -#define CA_CS_DRVR_DS_OFFSET 3 -#define CA_ADR_DRVR_DS_OFFSET 0 +#define CLK_SRC_CPU_VAL ((MUX_HPM_SEL << 20) \ + | (MUX_CPU_SEL << 16) \ + | (MUX_APLL_SEL))
-#define PHY_CON42_CTRL_BSTLEN_SHIFT 8 -#define PHY_CON42_CTRL_RDLAT_SHIFT 0 +/* CLK_SRC_CDREX */ +#define CLK_SRC_CDREX_VAL 0x00000011 + +/* CLK_DIV_CDREX */ +#define CLK_DIV_CDREX0_VAL 0x30010100 +#define CLK_DIV_CDREX1_VAL 0x300 + +#define CLK_DIV_CDREX_VAL 0x17010100 + +/* CLK_DIV_CPU0_VAL */ +#define CLK_DIV_CPU0_VAL 0x01440020 + +/* CLK_SRC_TOP */ +#define CLK_SRC_TOP0_VAL 0x12221222 +#define CLK_SRC_TOP1_VAL 0x00100200 +#define CLK_SRC_TOP2_VAL 0x11101000 +#define CLK_SRC_TOP3_VAL 0x11111111 +#define CLK_SRC_TOP4_VAL 0x11110111 +#define CLK_SRC_TOP5_VAL 0x11111100 +#define CLK_SRC_TOP6_VAL 0x11110111 +#define CLK_SRC_TOP7_VAL 0x00022200 + +/* CLK_DIV_TOP */ +#define CLK_DIV_TOP0_VAL 0x23712311 +#define CLK_DIV_TOP1_VAL 0x13100B00 +#define CLK_DIV_TOP2_VAL 0x11101100 + +/* PLL Lock Value Factor */ +#define PLL_LOCK_FACTOR 200 +#define PLL_X_LOCK_FACTOR 3000 + +/* CLK_SRC_PERIC0 */ +#define SPDIF_SEL 1 +#define PWM_SEL 3 +#define UART4_SEL 3 +#define UART3_SEL 3 +#define UART2_SEL 3 +#define UART1_SEL 3 +#define UART0_SEL 3 +/* SRC_CLOCK = SCLK_RPLL */ +#define CLK_SRC_PERIC0_VAL ((SPDIF_SEL << 28) \ + | (PWM_SEL << 24) \ + | (UART4_SEL << 20) \ + | (UART3_SEL << 16) \ + | (UART2_SEL << 12) \ + | (UART1_SEL << 8) \ + | (UART0_SEL << 4)) + +/* CLK_SRC_PERIC1 */ +/* SRC_CLOCK = SCLK_EPLL */ +#define SPI0_SEL 6 +#define SPI1_SEL 6 +#define SPI2_SEL 6 +#define AUDIO0_SEL 6 +#define AUDIO1_SEL 6 +#define AUDIO2_SEL 6 +#define CLK_SRC_PERIC1_VAL ((SPI2_SEL << 28) \ + | (SPI1_SEL << 24) \ + | (SPI0_SEL << 20) \ + | (AUDIO2_SEL << 16) \ + | (AUDIO2_SEL << 12) \ + | (AUDIO2_SEL << 8)) + +/* CLK_DIV_PERIC0 */ +#define PWM_RATIO 8 +#define UART4_RATIO 9 +#define UART3_RATIO 9 +#define UART2_RATIO 9 +#define UART1_RATIO 9 +#define UART0_RATIO 9 + +#define CLK_DIV_PERIC0_VAL ((PWM_RATIO << 28) \ + | (UART4_RATIO << 24) \ + | (UART3_RATIO << 20) \ + | (UART2_RATIO << 16) \ + | (UART1_RATIO << 12) \ + | (UART0_RATIO << 8)) +/* CLK_DIV_PERIC1 */ +#define SPI2_RATIO 0x1 +#define SPI1_RATIO 0x1 +#define SPI0_RATIO 0x1 +#define CLK_DIV_PERIC1_VAL ((SPI2_RATIO << 28) \ + | (SPI1_RATIO << 24) \ + | (SPI0_RATIO << 20)) + +/* CLK_DIV_PERIC2 */ +#define PCM2_RATIO 0x3 +#define PCM1_RATIO 0x3 +#define CLK_DIV_PERIC2_VAL ((PCM2_RATIO << 24) \ + | (PCM1_RATIO << 16)) + +/* CLK_DIV_PERIC3 */ +#define AUDIO2_RATIO 0x5 +#define AUDIO1_RATIO 0x5 +#define AUDIO0_RATIO 0x5 +#define CLK_DIV_PERIC3_VAL ((AUDIO2_RATIO << 28) \ + | (AUDIO1_RATIO << 24) \ + | (AUDIO0_RATIO << 20)) + +/* CLK_DIV_PERIC4 */ +#define SPI2_PRE_RATIO 0x2 +#define SPI1_PRE_RATIO 0x2 +#define SPI0_PRE_RATIO 0x2 +#define CLK_DIV_PERIC4_VAL ((SPI2_PRE_RATIO << 24) \ + | (SPI1_PRE_RATIO << 16) \ + | (SPI0_PRE_RATIO << 8)) + +/* CLK_SRC_DISP1_0 */ +#define CLK_SRC_DISP1_0_VAL 0x10666600 +#define CLK_DIV_DISP1_0_VAL 0x01050211 + +#define APLL_FOUT (1 << 0) +#define KPLL_FOUT (1 << 0) + +#define CLK_DIV_CPERI1_VAL 0x3f3f0000 +#endif
struct mem_timings;
@@ -490,7 +887,7 @@ enum { };
/* - * Memory variant specific initialization code + * Memory variant specific initialization code for DDR3 * * @param mem Memory timings for this memory type. * @param mem_iv_size Memory interleaving size is a configurable parameter @@ -503,6 +900,9 @@ enum { int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, int reset);
+/* Memory variant specific initialization code for LPDDR3 */ +void lpddr3_mem_ctrl_init(void); + /* * Configure ZQ I/O interface * @@ -532,14 +932,6 @@ void dmc_config_mrs(struct mem_timings *mem, struct exynos5_dmc *dmc); void dmc_config_prech(struct mem_timings *mem, struct exynos5_dmc *dmc);
/* - * Configure the memconfig and membaseconfig registers - * - * @param mem Memory timings for this memory type. - * @param exynos5_dmc Pointer to struct of DMC registers - */ -void dmc_config_memory(struct mem_timings *mem, struct exynos5_dmc *dmc); - -/* * Reset the DLL. This function is common between DDR3 and LPDDR2. * However, the reset value is different. So we are passing a flag * ddr_mode to distinguish between LPDDR2 and DDR3. diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index 1d6fa93..cdeef32 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -14,6 +14,7 @@ #define HPLL 3 #define VPLL 4 #define BPLL 5 +#define RPLL 6
enum pll_src_bit { EXYNOS_SRC_MPLL = 6, diff --git a/arch/arm/include/asm/arch-exynos/clock.h b/arch/arm/include/asm/arch-exynos/clock.h index cf26eef..8259b92 100644 --- a/arch/arm/include/asm/arch-exynos/clock.h +++ b/arch/arm/include/asm/arch-exynos/clock.h @@ -858,6 +858,500 @@ struct exynos5_clock { unsigned char res123[0xf5d8]; };
+struct exynos5420_clock { + unsigned int apll_lock; /* 0x10010000 */ + unsigned char res1[0xfc]; + unsigned int apll_con0; + unsigned int apll_con1; + unsigned char res2[0xf8]; + unsigned int src_cpu; + unsigned char res3[0x1fc]; + unsigned int mux_stat_cpu; + unsigned char res4[0xfc]; + unsigned int div_cpu0; /* 0x10010500 */ + unsigned int div_cpu1; + unsigned char res5[0xf8]; + unsigned int div_stat_cpu0; + unsigned int div_stat_cpu1; + unsigned char res6[0xf8]; + unsigned int gate_bus_cpu; + unsigned char res7[0xfc]; + unsigned int gate_sclk_cpu; + unsigned char res8[0x1fc]; + unsigned int clkout_cmu_cpu; /* 0x10010a00 */ + unsigned int clkout_cmu_cpu_div_stat; + unsigned char res9[0x5f8]; + unsigned int armclk_stopctrl; + unsigned char res10[0x4]; + unsigned int arm_ema_ctrl; + unsigned int arm_ema_status; + unsigned char res11[0x10]; + unsigned int pwr_ctrl; + unsigned int pwr_ctrl2; + unsigned char res12[0xd8]; + unsigned int apll_con0_l8; /* 0x1001100 */ + unsigned int apll_con0_l7; + unsigned int apll_con0_l6; + unsigned int apll_con0_l5; + unsigned int apll_con0_l4; + unsigned int apll_con0_l3; + unsigned int apll_con0_l2; + unsigned int apll_con0_l1; + unsigned int iem_control; + unsigned char res13[0xdc]; + unsigned int apll_con1_l8; /* 0x10011200 */ + unsigned int apll_con1_l7; + unsigned int apll_con1_l6; + unsigned int apll_con1_l5; + unsigned int apll_con1_l4; + unsigned int apll_con1_l3; + unsigned int apll_con1_l2; + unsigned int apll_con1_l1; + unsigned char res14[0xe0]; + unsigned int clkdiv_iem_l8; + unsigned int clkdiv_iem_l7; /* 0x10011304 */ + unsigned int clkdiv_iem_l6; + unsigned int clkdiv_iem_l5; + unsigned int clkdiv_iem_l4; + unsigned int clkdiv_iem_l3; + unsigned int clkdiv_iem_l2; + unsigned int clkdiv_iem_l1; + unsigned char res15[0xe0]; + unsigned int l2_status; + unsigned char res16[0x0c]; + unsigned int cpu_status; /* 0x10011410 */ + unsigned char res17[0x0c]; + unsigned int ptm_status; + unsigned char res18[0xbdc]; + unsigned int cmu_cpu_spare0; + unsigned int cmu_cpu_spare1; + unsigned int cmu_cpu_spare2; + unsigned int cmu_cpu_spare3; + unsigned int cmu_cpu_spare4; + unsigned char res19[0x1fdc]; + unsigned int cmu_cpu_version; + unsigned char res20[0x20c]; + unsigned int src_cperi0; /* 0x10014200 */ + unsigned int src_cperi1; + unsigned char res21[0xf8]; + unsigned int src_mask_cperi; + unsigned char res22[0x100]; + unsigned int mux_stat_cperi1; + unsigned char res23[0xfc]; + unsigned int div_cperi1; + unsigned char res24[0xfc]; + unsigned int div_stat_cperi1; + unsigned char res25[0xf8]; + unsigned int gate_bus_cperi0; /* 0x10014700 */ + unsigned int gate_bus_cperi1; + unsigned char res26[0xf8]; + unsigned int gate_sclk_cperi; + unsigned char res27[0xfc]; + unsigned int gate_ip_cperi; + unsigned char res28[0xfc]; + unsigned int clkout_cmu_cperi; + unsigned int clkout_cmu_cperi_div_stat; + unsigned char res29[0x5f8]; + unsigned int dcgidx_map0; /* 0x10015000 */ + unsigned int dcgidx_map1; + unsigned int dcgidx_map2; + unsigned char res30[0x14]; + unsigned int dcgperf_map0; + unsigned int dcgperf_map1; + unsigned char res31[0x18]; + unsigned int dvcidx_map; + unsigned char res32[0x1c]; + unsigned int freq_cpu; + unsigned int freq_dpm; + unsigned char res33[0x18]; + unsigned int dvsemclk_en; /* 0x10015080 */ + unsigned int maxperf; + unsigned char res34[0x2e78]; + unsigned int cmu_cperi_spare0; + unsigned int cmu_cperi_spare1; + unsigned int cmu_cperi_spare2; + unsigned int cmu_cperi_spare3; + unsigned int cmu_cperi_spare4; + unsigned int cmu_cperi_spare5; + unsigned int cmu_cperi_spare6; + unsigned int cmu_cperi_spare7; + unsigned int cmu_cperi_spare8; + unsigned char res35[0xcc]; + unsigned int cmu_cperi_version; /* 0x10017ff0 */ + unsigned char res36[0x50c]; + unsigned int div_g2d; + unsigned char res37[0xfc]; + unsigned int div_stat_g2d; + unsigned char res38[0xfc]; + unsigned int gate_bus_g2d; + unsigned char res39[0xfc]; + unsigned int gate_ip_g2d; + unsigned char res40[0x1fc]; + unsigned int clkout_cmu_g2d; + unsigned int clkout_cmu_g2d_div_stat; /* 0x10018a04 */ + unsigned char res41[0xf8]; + unsigned int cmu_g2d_spare0; + unsigned int cmu_g2d_spare1; + unsigned int cmu_g2d_spare2; + unsigned int cmu_g2d_spare3; + unsigned int cmu_g2d_spare4; + unsigned char res42[0x34dc]; + unsigned int cmu_g2d_version; + unsigned char res43[0x30c]; + unsigned int div_cmu_isp0; + unsigned int div_cmu_isp1; + unsigned int div_isp2; /* 0x1001c308 */ + unsigned char res44[0xf4]; + unsigned int div_stat_cmu_isp0; + unsigned int div_stat_cmu_isp1; + unsigned int div_stat_isp2; + unsigned char res45[0x2f4]; + unsigned int gate_bus_isp0; + unsigned int gate_bus_isp1; + unsigned int gate_bus_isp2; + unsigned int gate_bus_isp3; + unsigned char res46[0xf0]; + unsigned int gate_ip_isp0; + unsigned int gate_ip_isp1; + unsigned char res47[0xf8]; + unsigned int gate_sclk_isp; + unsigned char res48[0x0c]; + unsigned int mcuisp_pwr_ctrl; /* 0x1001c910 */ + unsigned char res49[0x0ec]; + unsigned int clkout_cmu_isp; + unsigned int clkout_cmu_isp_div_stat; + unsigned char res50[0xf8]; + unsigned int cmu_isp_spare0; + unsigned int cmu_isp_spare1; + unsigned int cmu_isp_spare2; + unsigned int cmu_isp_spare3; + unsigned char res51[0x34e0]; + unsigned int cmu_isp_version; + unsigned char res52[0x2c]; + unsigned int cpll_lock; /* 10020020 */ + unsigned char res53[0xc]; + unsigned int dpll_lock; + unsigned char res54[0xc]; + unsigned int epll_lock; + unsigned char res55[0xc]; + unsigned int rpll_lock; + unsigned char res56[0xc]; + unsigned int ipll_lock; + unsigned char res57[0xc]; + unsigned int spll_lock; + unsigned char res58[0xc]; + unsigned int vpll_lock; + unsigned char res59[0xc]; + unsigned int mpll_lock; + unsigned char res60[0x8c]; + unsigned int cpll_con0; /* 10020120 */ + unsigned int cpll_con1; + unsigned int dpll_con0; + unsigned int dpll_con1; + unsigned int epll_con0; + unsigned int epll_con1; + unsigned int epll_con2; + unsigned char res601[0x4]; + unsigned int rpll_con0; + unsigned int rpll_con1; + unsigned int rpll_con2; + unsigned char res602[0x4]; + unsigned int ipll_con0; + unsigned int ipll_con1; + unsigned char res61[0x8]; + unsigned int spll_con0; + unsigned int spll_con1; + unsigned char res62[0x8]; + unsigned int vpll_con0; + unsigned int vpll_con1; + unsigned char res63[0x8]; + unsigned int mpll_con0; + unsigned int mpll_con1; + unsigned char res64[0x78]; + unsigned int src_top0; /* 0x10020200 */ + unsigned int src_top1; + unsigned int src_top2; + unsigned int src_top3; + unsigned int src_top4; + unsigned int src_top5; + unsigned int src_top6; + unsigned int src_top7; + unsigned char res65[0xc]; + unsigned int src_disp10; /* 0x1002022c */ + unsigned char res66[0x10]; + unsigned int src_mau; + unsigned int src_fsys; + unsigned char res67[0x8]; + unsigned int src_peric0; + unsigned int src_peric1; + unsigned char res68[0x18]; + unsigned int src_isp; + unsigned char res69[0x0c]; + unsigned int src_top10; + unsigned int src_top11; + unsigned int src_top12; + unsigned char res70[0x74]; + unsigned int src_mask_top0; + unsigned int src_mask_top1; + unsigned int src_mask_top2; + unsigned char res71[0x10]; + unsigned int src_mask_top7; + unsigned char res72[0xc]; + unsigned int src_mask_disp10; /* 0x1002032c */ + unsigned char res73[0x4]; + unsigned int src_mask_mau; + unsigned char res74[0x8]; + unsigned int src_mask_fsys; + unsigned char res75[0xc]; + unsigned int src_mask_peric0; + unsigned int src_mask_peric1; + unsigned char res76[0x18]; + unsigned int src_mask_isp; + unsigned char res77[0x8c]; + unsigned int mux_stat_top0; /* 0x10020400 */ + unsigned int mux_stat_top1; + unsigned int mux_stat_top2; + unsigned int mux_stat_top3; + unsigned int mux_stat_top4; + unsigned int mux_stat_top5; + unsigned int mux_stat_top6; + unsigned int mux_stat_top7; + unsigned char res78[0x60]; + unsigned int mux_stat_top10; + unsigned int mux_stat_top11; + unsigned int mux_stat_top12; + unsigned char res79[0x74]; + unsigned int div_top0; /* 0x10020500 */ + unsigned int div_top1; + unsigned int div_top2; + unsigned char res80[0x20]; + unsigned int div_disp10; + unsigned char res81[0x14]; + unsigned int div_mau; + unsigned int div_fsys0; + unsigned int div_fsys1; + unsigned int div_fsys2; + unsigned char res82[0x4]; + unsigned int div_peric0; + unsigned int div_peric1; + unsigned int div_peric2; + unsigned int div_peric3; + unsigned int div_peric4; /* 0x10020568 */ + unsigned char res83[0x14]; + unsigned int div_isp0; + unsigned int div_isp1; + unsigned char res84[0x8]; + unsigned int clkdiv2_ratio; + unsigned char res850[0xc]; + unsigned int clkdiv4_ratio; + unsigned char res85[0x5c]; + unsigned int div_stat_top0; + unsigned int div_stat_top1; + unsigned int div_stat_top2; + unsigned char res86[0x20]; + unsigned int div_stat_disp10; + unsigned char res87[0x14]; + unsigned int div_stat_mau; /* 0x10020644 */ + unsigned int div_stat_fsys0; + unsigned int div_stat_fsys1; + unsigned int div_stat_fsys2; + unsigned char res88[0x4]; + unsigned int div_stat_peric0; + unsigned int div_stat_peric1; + unsigned int div_stat_peric2; + unsigned int div_stat_peric3; + unsigned int div_stat_peric4; + unsigned char res89[0x14]; + unsigned int div_stat_isp0; + unsigned int div_stat_isp1; + unsigned char res90[0x8]; + unsigned int clkdiv2_stat0; + unsigned char res91[0xc]; + unsigned int clkdiv4_stat; + unsigned char res92[0x5c]; + unsigned int gate_bus_top; /* 0x10020700 */ + unsigned char res93[0xc]; + unsigned int gate_bus_gscl0; + unsigned char res94[0xc]; + unsigned int gate_bus_gscl1; + unsigned char res95[0x4]; + unsigned int gate_bus_disp1; + unsigned char res96[0x4]; + unsigned int gate_bus_wcore; + unsigned int gate_bus_mfc; + unsigned int gate_bus_g3d; + unsigned int gate_bus_gen; + unsigned int gate_bus_fsys0; + unsigned int gate_bus_fsys1; + unsigned int gate_bus_fsys2; + unsigned int gate_bus_mscl; + unsigned int gate_bus_peric; + unsigned int gate_bus_peric1; + unsigned char res97[0x8]; + unsigned int gate_bus_peris0; + unsigned int gate_bus_peris1; /* 0x10020764 */ + unsigned char res98[0x8]; + unsigned int gate_bus_noc; + unsigned char res99[0xac]; + unsigned int gate_top_sclk_gscl; + unsigned char res1000[0x4]; + unsigned int gate_top_sclk_disp1; + unsigned char res100[0x10]; + unsigned int gate_top_sclk_mau; + unsigned int gate_top_sclk_fsys; + unsigned char res101[0xc]; + unsigned int gate_top_sclk_peric; + unsigned char res102[0xc]; + unsigned int gate_top_sclk_cperi; + unsigned char res103[0xc]; + unsigned int gate_top_sclk_isp; + unsigned char res104[0x9c]; + unsigned int gate_ip_gscl0; + unsigned char res105[0xc]; + unsigned int gate_ip_gscl1; + unsigned char res106[0x4]; + unsigned int gate_ip_disp1; + unsigned int gate_ip_mfc; + unsigned int gate_ip_g3d; + unsigned int gate_ip_gen; /* 0x10020934 */ + unsigned char res107[0xc]; + unsigned int gate_ip_fsys; + unsigned char res108[0x8]; + unsigned int gate_ip_peric; + unsigned char res109[0xc]; + unsigned int gate_ip_peris; + unsigned char res110[0xc]; + unsigned int gate_ip_mscl; + unsigned char res111[0xc]; + unsigned int gate_ip_block; + unsigned char res112[0xc]; + unsigned int bypass; + unsigned char res113[0x6c]; + unsigned int clkout_cmu_top; + unsigned int clkout_cmu_top_div_stat; + unsigned char res114[0xf8]; + unsigned int clkout_top_spare0; + unsigned int clkout_top_spare1; + unsigned int clkout_top_spare2; + unsigned int clkout_top_spare3; + unsigned char res115[0x34e0]; + unsigned int clkout_top_version; + unsigned char res116[0xc01c]; + unsigned int bpll_lock; /* 0x10030010 */ + unsigned char res117[0xfc]; + unsigned int bpll_con0; + unsigned int bpll_con1; + unsigned char res118[0xe8]; + unsigned int src_cdrex; + unsigned char res119[0x1fc]; + unsigned int mux_stat_cdrex; + unsigned char res120[0xfc]; + unsigned int div_cdrex0; + unsigned int div_cdrex1; + unsigned char res121[0xf8]; + unsigned int div_stat_cdrex; + unsigned char res1211[0xfc]; + unsigned int gate_bus_cdrex; + unsigned int gate_bus_cdrex1; + unsigned char res122[0x1f8]; + unsigned int gate_ip_cdrex; + unsigned char res123[0x10]; + unsigned int dmc_freq_ctrl; /* 0x10030914 */ + unsigned char res124[0x4]; + unsigned int pause; + unsigned int ddrphy_lock_ctrl; + unsigned char res125[0xdc]; + unsigned int clkout_cmu_cdrex; + unsigned int clkout_cmu_cdrex_div_stat; + unsigned char res126[0x8]; + unsigned int lpddr3phy_ctrl; + unsigned int lpddr3phy_con0; + unsigned int lpddr3phy_con1; + unsigned int lpddr3phy_con2; + unsigned int lpddr3phy_con3; + unsigned int lpddr3phy_con4; + unsigned int lpddr3phy_con5; /* 0x10030a28 */ + unsigned int pll_div2_sel; + unsigned char res127[0xd0]; + unsigned int cmu_cdrex_spare0; + unsigned int cmu_cdrex_spare1; + unsigned int cmu_cdrex_spare2; + unsigned int cmu_cdrex_spare3; + unsigned int cmu_cdrex_spare4; + unsigned char res128[0x34dc]; + unsigned int cmu_cdrex_version; /* 0x10033ff0 */ + unsigned char res129[0x400c]; + unsigned int kpll_lock; + unsigned char res130[0xfc]; + unsigned int kpll_con0; + unsigned int kpll_con1; + unsigned char res131[0xf8]; + unsigned int src_kfc; + unsigned char res132[0x1fc]; + unsigned int mux_stat_kfc; /* 0x10038400 */ + unsigned char res133[0xfc]; + unsigned int div_kfc0; + unsigned char res134[0xfc]; + unsigned int div_stat_kfc0; + unsigned char res135[0xfc]; + unsigned int gate_bus_cpu_kfc; + unsigned char res136[0xfc]; + unsigned int gate_sclk_cpu_kfc; + unsigned char res137[0x1fc]; + unsigned int clkout_cmu_kfc; + unsigned int clkout_cmu_kfc_div_stat; /* 0x10038a04 */ + unsigned char res138[0x5f8]; + unsigned int armclk_stopctrl_kfc; + unsigned char res139[0x4]; + unsigned int armclk_ema_ctrl_kfc; + unsigned int armclk_ema_status_kfc; + unsigned char res140[0x10]; + unsigned int pwr_ctrl_kfc; + unsigned int pwr_ctrl2_kfc; + unsigned char res141[0xd8]; + unsigned int kpll_con0_l8; + unsigned int kpll_con0_l7; + unsigned int kpll_con0_l6; + unsigned int kpll_con0_l5; + unsigned int kpll_con0_l4; + unsigned int kpll_con0_l3; + unsigned int kpll_con0_l2; + unsigned int kpll_con0_l1; + unsigned int iem_control_kfc; /* 0x10039120 */ + unsigned char res142[0xdc]; + unsigned int kpll_con1_l8; + unsigned int kpll_con1_l7; + unsigned int kpll_con1_l6; + unsigned int kpll_con1_l5; + unsigned int kpll_con1_l4; + unsigned int kpll_con1_l3; + unsigned int kpll_con1_l2; + unsigned int kpll_con1_l1; + unsigned char res143[0xe0]; + unsigned int clkdiv_iem_l8_kfc; /* 0x10039300 */ + unsigned int clkdiv_iem_l7_kfc; + unsigned int clkdiv_iem_l6_kfc; + unsigned int clkdiv_iem_l5_kfc; + unsigned int clkdiv_iem_l4_kfc; + unsigned int clkdiv_iem_l3_kfc; + unsigned int clkdiv_iem_l2_kfc; + unsigned int clkdiv_iem_l1_kfc; + unsigned char res144[0xe0]; + unsigned int l2_status_kfc; + unsigned char res145[0xc]; + unsigned int cpu_status_kfc; /* 0x10039410 */ + unsigned char res146[0xc]; + unsigned int ptm_status_kfc; + unsigned char res147[0xbdc]; + unsigned int cmu_kfc_spare0; + unsigned int cmu_kfc_spare1; + unsigned int cmu_kfc_spare2; + unsigned int cmu_kfc_spare3; + unsigned int cmu_kfc_spare4; + unsigned char res148[0x1fdc]; + unsigned int cmu_kfc_version; /* 0x1003bff0 */ +}; + /* structure for epll configuration used in audio clock configuration */ struct set_epll_con_val { unsigned int freq_out; /* frequency out */
On 16 December 2013 01:42, Rajeshwari S Shinde rajeshwari.s@samsung.com wrote:
This patch adds code for clock initialization and clock settings of various IP's and controllers, required for Exynos5420
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com
Changes in V2: - None Changes in V3: - None Changes in V4: - Corrected the multiline commenting style Changes in V5: - None Changes in V6: - None Changes in V7: - Correct the logic for exynos5420_set_spi_clk api. Changes in V8: - Chnages the if condition loop for pro_id and cpu_id. Changes in V9: - Used samsung_get_base to get base address of clock. Changes in V10: - Corrected the comments and few coding style nits. Changes in V11: - None arch/arm/cpu/armv7/exynos/clock.c | 279 +++++++++- arch/arm/cpu/armv7/exynos/clock_init.h | 17 + arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 352 +++++++++++- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 738 +++++++++++++++++++------ arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/clock.h | 494 +++++++++++++++++ 6 files changed, 1679 insertions(+), 202 deletions(-)
This patch intends to add DDR3 initialization code for Exynos5420.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com --- Changes in V2: - Corrected a compilation issue for SMDK5250. Changes in V3: - None Changes in V4: - None Changes in V5: - None Changes in V6: - None Changes in V7: - Fixed multi line comment. Changes in V8: - None Changes in V9: - Used samsung_get base to get the dmc base address Changes in V10: - Changed to new 5420 dmc and power resgister structure. - Changed the input parameters for dmc common functions due to changes in the dmc register structure. Changes in V11: - None arch/arm/cpu/armv7/exynos/dmc_common.c | 60 ++-- arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 439 +++++++++++++++++++++++++++++- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 26 +- arch/arm/include/asm/arch-exynos/cpu.h | 7 +- arch/arm/include/asm/arch-exynos/dmc.h | 10 + 5 files changed, 484 insertions(+), 58 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/dmc_common.c b/arch/arm/cpu/armv7/exynos/dmc_common.c index 53cfe6e..520eac5 100644 --- a/arch/arm/cpu/armv7/exynos/dmc_common.c +++ b/arch/arm/cpu/armv7/exynos/dmc_common.c @@ -1,5 +1,5 @@ /* - * Mem setup common file for different types of DDR present on SMDK5250 boards. + * Mem setup common file for different types of DDR present on Exynos boards. * * Copyright (C) 2012 Samsung Electronics * @@ -15,9 +15,9 @@
#define ZQ_INIT_TIMEOUT 10000
-int dmc_config_zq(struct mem_timings *mem, - struct exynos5_phy_control *phy0_ctrl, - struct exynos5_phy_control *phy1_ctrl) +int dmc_config_zq(struct mem_timings *mem, const void *phy0_con16, + const void *phy1_con16, const void *phy0_con17, + const void *phy1_con17) { unsigned long val = 0; int i; @@ -31,19 +31,19 @@ int dmc_config_zq(struct mem_timings *mem, val |= mem->zq_mode_dds << PHY_CON16_ZQ_MODE_DDS_SHIFT; val |= mem->zq_mode_term << PHY_CON16_ZQ_MODE_TERM_SHIFT; val |= ZQ_CLK_DIV_EN; - writel(val, &phy0_ctrl->phy_con16); - writel(val, &phy1_ctrl->phy_con16); + writel(val, phy0_con16); + writel(val, phy1_con16);
/* Disable termination */ if (mem->zq_mode_noterm) val |= PHY_CON16_ZQ_MODE_NOTERM_MASK; - writel(val, &phy0_ctrl->phy_con16); - writel(val, &phy1_ctrl->phy_con16); + writel(val, phy0_con16); + writel(val, phy1_con16);
/* ZQ_MANUAL_START: Enable */ val |= ZQ_MANUAL_STR; - writel(val, &phy0_ctrl->phy_con16); - writel(val, &phy1_ctrl->phy_con16); + writel(val, phy0_con16); + writel(val, phy1_con16);
/* ZQ_MANUAL_START: Disable */ val &= ~ZQ_MANUAL_STR; @@ -53,47 +53,47 @@ int dmc_config_zq(struct mem_timings *mem, * we are looping for the ZQ_init to complete. */ i = ZQ_INIT_TIMEOUT; - while ((readl(&phy0_ctrl->phy_con17) & ZQ_DONE) != ZQ_DONE && i > 0) { + while ((readl(phy0_con17) & ZQ_DONE) != ZQ_DONE && i > 0) { sdelay(100); i--; } if (!i) return -1; - writel(val, &phy0_ctrl->phy_con16); + writel(val, phy0_con16);
i = ZQ_INIT_TIMEOUT; - while ((readl(&phy1_ctrl->phy_con17) & ZQ_DONE) != ZQ_DONE && i > 0) { + while ((readl(phy1_con17) & ZQ_DONE) != ZQ_DONE && i > 0) { sdelay(100); i--; } if (!i) return -1; - writel(val, &phy1_ctrl->phy_con16); + writel(val, phy1_con16);
return 0; }
-void update_reset_dll(struct exynos5_dmc *dmc, enum ddr_mode mode) +void update_reset_dll(const void *phycontrol0, enum ddr_mode mode) { unsigned long val;
if (mode == DDR_MODE_DDR3) { val = MEM_TERM_EN | PHY_TERM_EN | DMC_CTRL_SHGATE; - writel(val, &dmc->phycontrol0); + writel(val, phycontrol0); }
/* Update DLL Information: Force DLL Resyncronization */ - val = readl(&dmc->phycontrol0); + val = readl(phycontrol0); val |= FP_RSYNC; - writel(val, &dmc->phycontrol0); + writel(val, phycontrol0);
/* Reset Force DLL Resyncronization */ - val = readl(&dmc->phycontrol0); + val = readl(phycontrol0); val &= ~FP_RSYNC; - writel(val, &dmc->phycontrol0); + writel(val, phycontrol0); }
-void dmc_config_mrs(struct mem_timings *mem, struct exynos5_dmc *dmc) +void dmc_config_mrs(struct mem_timings *mem, const void *directcmd) { int channel, chip;
@@ -107,7 +107,7 @@ void dmc_config_mrs(struct mem_timings *mem, struct exynos5_dmc *dmc) mask |= chip << DIRECT_CMD_CHIP_SHIFT;
/* Sending NOP command */ - writel(DIRECT_CMD_NOP | mask, &dmc->directcmd); + writel(DIRECT_CMD_NOP | mask, directcmd);
/* * TODO(alim.akhtar@samsung.com): Do we need these @@ -119,14 +119,14 @@ void dmc_config_mrs(struct mem_timings *mem, struct exynos5_dmc *dmc) /* Sending EMRS/MRS commands */ for (i = 0; i < MEM_TIMINGS_MSR_COUNT; i++) { writel(mem->direct_cmd_msr[i] | mask, - &dmc->directcmd); + directcmd); sdelay(0x10000); }
if (mem->send_zq_init) { /* Sending ZQINIT command */ writel(DIRECT_CMD_ZQINIT | mask, - &dmc->directcmd); + directcmd);
sdelay(10000); } @@ -134,7 +134,7 @@ void dmc_config_mrs(struct mem_timings *mem, struct exynos5_dmc *dmc) } }
-void dmc_config_prech(struct mem_timings *mem, struct exynos5_dmc *dmc) +void dmc_config_prech(struct mem_timings *mem, const void *directcmd) { int channel, chip;
@@ -146,20 +146,12 @@ void dmc_config_prech(struct mem_timings *mem, struct exynos5_dmc *dmc) mask |= chip << DIRECT_CMD_CHIP_SHIFT;
/* PALL (all banks precharge) CMD */ - writel(DIRECT_CMD_PALL | mask, &dmc->directcmd); + writel(DIRECT_CMD_PALL | mask, directcmd); sdelay(0x10000); } } }
-void dmc_config_memory(struct mem_timings *mem, struct exynos5_dmc *dmc) -{ - writel(mem->memconfig, &dmc->memconfig0); - writel(mem->memconfig, &dmc->memconfig1); - writel(DMC_MEMBASECONFIG0_VAL, &dmc->membaseconfig0); - writel(DMC_MEMBASECONFIG1_VAL, &dmc->membaseconfig1); -} - void mem_ctrl_init(int reset) { struct spl_machine_param *param = spl_get_machine_params(); diff --git a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c index 5f5914e..487e6f4 100644 --- a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c +++ b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c @@ -1,5 +1,5 @@ /* - * DDR3 mem setup file for SMDK5250 board based on EXYNOS5 + * DDR3 mem setup file for board based on EXYNOS5 * * Copyright (C) 2012 Samsung Electronics * @@ -11,12 +11,14 @@ #include <asm/arch/clock.h> #include <asm/arch/cpu.h> #include <asm/arch/dmc.h> +#include <asm/arch/power.h> #include "common_setup.h" #include "exynos5_setup.h" #include "clock_init.h"
-#define RDLVL_COMPLETE_TIMEOUT 10000 +#define TIMEOUT 10000
+#ifdef CONFIG_EXYNOS5250 static void reset_phy_ctrl(void) { struct exynos5_clock *clk = @@ -57,7 +59,8 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, writel(val, &phy1_ctrl->phy_con42);
/* ZQ Calibration */ - if (dmc_config_zq(mem, phy0_ctrl, phy1_ctrl)) + if (dmc_config_zq(mem, &phy0_ctrl->phy_con16, &phy1_ctrl->phy_con16, + &phy0_ctrl->phy_con17, &phy1_ctrl->phy_con17)) return SETUP_ERR_ZQ_CALIBRATION_FAILURE;
/* DQ Signal */ @@ -68,7 +71,7 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, | (mem->dfi_init_start << CONCONTROL_DFI_INIT_START_SHIFT), &dmc->concontrol);
- update_reset_dll(dmc, DDR_MODE_DDR3); + update_reset_dll(&dmc->phycontrol0, DDR_MODE_DDR3);
/* DQS Signal */ writel(mem->phy0_dqs, &phy0_ctrl->phy_con4); @@ -93,7 +96,7 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, writel(val | (mem->ctrl_start << PHY_CON12_CTRL_START_SHIFT), &phy1_ctrl->phy_con12);
writel(mem->concontrol | (mem->rd_fetch << CONCONTROL_RD_FETCH_SHIFT), &dmc->concontrol); @@ -124,10 +127,10 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, writel(mem->timing_power, &dmc->timingpower);
/* Send PALL command */ - dmc_config_prech(mem, dmc); + dmc_config_prech(mem, &dmc->directcmd);
/* Send NOP, MRS and ZQINIT commands */ - dmc_config_mrs(mem, dmc); + dmc_config_mrs(mem, &dmc->directcmd);
if (mem->gate_leveling_enable) { val = PHY_CON0_RESET_VAL; @@ -174,7 +177,7 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, writel(val, &phy1_ctrl->phy_con1);
writel(CTRL_RDLVL_GATE_ENABLE, &dmc->rdlvl_config); - i = RDLVL_COMPLETE_TIMEOUT; + i = TIMEOUT; while ((readl(&dmc->phystatus) & (RDLVL_COMPLETE_CHO | RDLVL_COMPLETE_CH1)) != (RDLVL_COMPLETE_CHO | RDLVL_COMPLETE_CH1) && i > 0) { @@ -202,11 +205,11 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, writel(val, &phy0_ctrl->phy_con12); writel(val, &phy1_ctrl->phy_con12);
- update_reset_dll(dmc, DDR_MODE_DDR3); + update_reset_dll(&dmc->phycontrol0, DDR_MODE_DDR3); }
writel(mem->memcontrol, &dmc->memcontrol);
@@ -215,3 +218,419 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, | (mem->aref_en << CONCONTROL_AREF_EN_SHIFT), &dmc->concontrol); return 0; } +#endif + +#ifdef CONFIG_EXYNOS5420 +int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, + int reset) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + struct exynos5420_power *power = + (struct exynos5420_power *)samsung_get_base_power(); + struct exynos5420_phy_control *phy0_ctrl, *phy1_ctrl; + struct exynos5420_dmc *drex0, *drex1; + struct exynos5420_tzasc *tzasc0, *tzasc1; + uint32_t val, n_lock_r, n_lock_w_phy0, n_lock_w_phy1; + int chip; + int i; + + phy0_ctrl = (struct exynos5420_phy_control *)samsung_get_base_dmc_phy(); + phy1_ctrl = (struct exynos5420_phy_control *)(samsung_get_base_dmc_phy() + + DMC_OFFSET); + drex0 = (struct exynos5420_dmc *)samsung_get_base_dmc_ctrl(); + drex1 = (struct exynos5420_dmc *)(samsung_get_base_dmc_ctrl() + + DMC_OFFSET); + tzasc0 = (struct exynos5420_tzasc *)samsung_get_base_dmc_tzasc(); + tzasc1 = (struct exynos5420_tzasc *)(samsung_get_base_dmc_tzasc() + + DMC_OFFSET); + + /* Enable PAUSE for DREX */ + setbits_le32(&clk->pause, ENABLE_BIT); + + /* Enable BYPASS mode */ + setbits_le32(&clk->bpll_con1, BYPASS_EN); + + writel(MUX_BPLL_SEL_FOUTBPLL, &clk->src_cdrex); + do { + val = readl(&clk->mux_stat_cdrex); + val &= BPLL_SEL_MASK; + } while (val != FOUTBPLL); + + clrbits_le32(&clk->bpll_con1, BYPASS_EN); + + /* Specify the DDR memory type as DDR3 */ + val = readl(&phy0_ctrl->phy_con0); + val &= ~(PHY_CON0_CTRL_DDR_MODE_MASK << PHY_CON0_CTRL_DDR_MODE_SHIFT); + val |= (DDR_MODE_DDR3 << PHY_CON0_CTRL_DDR_MODE_SHIFT); + writel(val, &phy0_ctrl->phy_con0); + + val = readl(&phy1_ctrl->phy_con0); + val &= ~(PHY_CON0_CTRL_DDR_MODE_MASK << PHY_CON0_CTRL_DDR_MODE_SHIFT); + val |= (DDR_MODE_DDR3 << PHY_CON0_CTRL_DDR_MODE_SHIFT); + writel(val, &phy1_ctrl->phy_con0); + + /* Set Read Latency and Burst Length for PHY0 and PHY1 */ + val = (mem->ctrl_bstlen << PHY_CON42_CTRL_BSTLEN_SHIFT) | + (mem->ctrl_rdlat << PHY_CON42_CTRL_RDLAT_SHIFT); + writel(val, &phy0_ctrl->phy_con42); + writel(val, &phy1_ctrl->phy_con42); + + val = readl(&phy0_ctrl->phy_con26); + val &= ~(T_WRDATA_EN_MASK << T_WRDATA_EN_OFFSET); + val |= (T_WRDATA_EN_DDR3 << T_WRDATA_EN_OFFSET); + writel(val, &phy0_ctrl->phy_con26); + + val = readl(&phy1_ctrl->phy_con26); + val &= ~(T_WRDATA_EN_MASK << T_WRDATA_EN_OFFSET); + val |= (T_WRDATA_EN_DDR3 << T_WRDATA_EN_OFFSET); + writel(val, &phy1_ctrl->phy_con26); + + /* + * Set Driver strength for CK, CKE, CS & CA to 0x7 + * Set Driver strength for Data Slice 0~3 to 0x7 + */ + val = (0x7 << CA_CK_DRVR_DS_OFFSET) | (0x7 << CA_CKE_DRVR_DS_OFFSET) | + (0x7 << CA_CS_DRVR_DS_OFFSET) | (0x7 << CA_ADR_DRVR_DS_OFFSET); + val |= (0x7 << DA_3_DS_OFFSET) | (0x7 << DA_2_DS_OFFSET) | + (0x7 << DA_1_DS_OFFSET) | (0x7 << DA_0_DS_OFFSET); + writel(val, &phy0_ctrl->phy_con39); + writel(val, &phy1_ctrl->phy_con39); + + /* ZQ Calibration */ + if (dmc_config_zq(mem, &phy0_ctrl->phy_con16, &phy1_ctrl->phy_con16, + &phy0_ctrl->phy_con17, &phy1_ctrl->phy_con17)) + return SETUP_ERR_ZQ_CALIBRATION_FAILURE; + + clrbits_le32(&phy0_ctrl->phy_con16, ZQ_CLK_DIV_EN); + clrbits_le32(&phy1_ctrl->phy_con16, ZQ_CLK_DIV_EN); + + /* DQ Signal */ + val = readl(&phy0_ctrl->phy_con14); + val |= mem->phy0_pulld_dqs; + writel(val, &phy0_ctrl->phy_con14); + val = readl(&phy1_ctrl->phy_con14); + val |= mem->phy1_pulld_dqs; + writel(val, &phy1_ctrl->phy_con14); + + val = MEM_TERM_EN | PHY_TERM_EN; + writel(val, &drex0->phycontrol0); + writel(val, &drex1->phycontrol0); + + writel(mem->concontrol | + (mem->dfi_init_start << CONCONTROL_DFI_INIT_START_SHIFT) | + (mem->rd_fetch << CONCONTROL_RD_FETCH_SHIFT), + &drex0->concontrol); + writel(mem->concontrol | + (mem->dfi_init_start << CONCONTROL_DFI_INIT_START_SHIFT) | + (mem->rd_fetch << CONCONTROL_RD_FETCH_SHIFT), + &drex1->concontrol); + + do { + val = readl(&drex0->phystatus); + } while ((val & DFI_INIT_COMPLETE) != DFI_INIT_COMPLETE); + do { + val = readl(&drex1->phystatus); + } while ((val & DFI_INIT_COMPLETE) != DFI_INIT_COMPLETE); + + clrbits_le32(&drex0->concontrol, DFI_INIT_START); + clrbits_le32(&drex1->concontrol, DFI_INIT_START); + + update_reset_dll(&drex0->phycontrol0, DDR_MODE_DDR3); + update_reset_dll(&drex1->phycontrol0, DDR_MODE_DDR3); + + /* + * Set Base Address: + * 0x2000_0000 ~ 0x5FFF_FFFF + * 0x6000_0000 ~ 0x9FFF_FFFF + */ + /* MEMBASECONFIG0 */ + val = DMC_MEMBASECONFIGX_CHIP_BASE(DMC_CHIP_BASE_0) | + DMC_MEMBASECONFIGX_CHIP_MASK(DMC_CHIP_MASK); + writel(val, &tzasc0->membaseconfig0); + writel(val, &tzasc1->membaseconfig0); + + /* MEMBASECONFIG1 */ + val = DMC_MEMBASECONFIGX_CHIP_BASE(DMC_CHIP_BASE_1) | + DMC_MEMBASECONFIGX_CHIP_MASK(DMC_CHIP_MASK); + writel(val, &tzasc0->membaseconfig1); + writel(val, &tzasc1->membaseconfig1); + + /* + * Memory Channel Inteleaving Size + * Ares Channel interleaving = 128 bytes + */ + /* MEMCONFIG0/1 */ + writel(mem->memconfig, &tzasc0->memconfig0); + writel(mem->memconfig, &tzasc1->memconfig0); + writel(mem->memconfig, &tzasc0->memconfig1); + writel(mem->memconfig, &tzasc1->memconfig1); + + /* Precharge Configuration */ + writel(mem->prechconfig_tp_cnt << PRECHCONFIG_TP_CNT_SHIFT, + &drex0->prechconfig0); + writel(mem->prechconfig_tp_cnt << PRECHCONFIG_TP_CNT_SHIFT, + &drex1->prechconfig0); + + /* + * TimingRow, TimingData, TimingPower and Timingaref + * values as per Memory AC parameters + */ + writel(mem->timing_ref, &drex0->timingref); + writel(mem->timing_ref, &drex1->timingref); + writel(mem->timing_row, &drex0->timingrow0); + writel(mem->timing_row, &drex1->timingrow0); + writel(mem->timing_data, &drex0->timingdata0); + writel(mem->timing_data, &drex1->timingdata0); + writel(mem->timing_power, &drex0->timingpower0); + writel(mem->timing_power, &drex1->timingpower0); + + if (reset) { + /* + * Send NOP, MRS and ZQINIT commands + * Sending MRS command will reset the DRAM. We should not be + * reseting the DRAM after resume, this will lead to memory + * corruption as DRAM content is lost after DRAM reset + */ + dmc_config_mrs(mem, &drex0->directcmd); + dmc_config_mrs(mem, &drex1->directcmd); + } else { + /* + * During Suspend-Resume & S/W-Reset, as soon as PMU releases + * pad retention, CKE goes high. This causes memory contents + * not to be retained during DRAM initialization. Therfore, + * there is a new control register(0x100431e8[28]) which lets us + * release pad retention and retain the memory content until the + * initialization is complete. + */ + writel(PAD_RETENTION_DRAM_COREBLK_VAL, + &power->pad_retention_dram_coreblk_option); + do { + val = readl(&power->pad_retention_dram_status); + } while (val != 0x1); + + /* + * CKE PAD retention disables DRAM self-refresh mode. + * Send auto refresh command for DRAM refresh. + */ + for (i = 0; i < 128; i++) { + for (chip = 0; chip < mem->chips_to_configure; chip++) { + writel(DIRECT_CMD_REFA | + (chip << DIRECT_CMD_CHIP_SHIFT), + &drex0->directcmd); + writel(DIRECT_CMD_REFA | + (chip << DIRECT_CMD_CHIP_SHIFT), + &drex1->directcmd); + } + } + } + + if (mem->gate_leveling_enable) { + writel(PHY_CON0_RESET_VAL, &phy0_ctrl->phy_con0); + writel(PHY_CON0_RESET_VAL, &phy1_ctrl->phy_con0); + + setbits_le32(&phy0_ctrl->phy_con0, P0_CMD_EN); + setbits_le32(&phy1_ctrl->phy_con0, P0_CMD_EN); + + val = PHY_CON2_RESET_VAL; + val |= INIT_DESKEW_EN; + writel(val, &phy0_ctrl->phy_con2); + writel(val, &phy1_ctrl->phy_con2); + + val = readl(&phy0_ctrl->phy_con1); + val |= (RDLVL_PASS_ADJ_VAL << RDLVL_PASS_ADJ_OFFSET); + writel(val, &phy0_ctrl->phy_con1); + + val = readl(&phy1_ctrl->phy_con1); + val |= (RDLVL_PASS_ADJ_VAL << RDLVL_PASS_ADJ_OFFSET); + writel(val, &phy1_ctrl->phy_con1); + + n_lock_r = readl(&phy0_ctrl->phy_con13); + n_lock_w_phy0 = (n_lock_r & CTRL_LOCK_COARSE_MASK) >> 2; + n_lock_r = readl(&phy0_ctrl->phy_con12); + n_lock_r &= ~CTRL_DLL_ON; + n_lock_r |= n_lock_w_phy0; + writel(n_lock_r, &phy0_ctrl->phy_con12); + + n_lock_r = readl(&phy1_ctrl->phy_con13); + n_lock_w_phy1 = (n_lock_r & CTRL_LOCK_COARSE_MASK) >> 2; + n_lock_r = readl(&phy1_ctrl->phy_con12); + n_lock_r &= ~CTRL_DLL_ON; + n_lock_r |= n_lock_w_phy1; + writel(n_lock_r, &phy1_ctrl->phy_con12); + + val = (0x3 << DIRECT_CMD_BANK_SHIFT) | 0x4; + for (chip = 0; chip < mem->chips_to_configure; chip++) { + writel(val | (chip << DIRECT_CMD_CHIP_SHIFT), + &drex0->directcmd); + writel(val | (chip << DIRECT_CMD_CHIP_SHIFT), + &drex1->directcmd); + } + + setbits_le32(&phy0_ctrl->phy_con2, RDLVL_GATE_EN); + setbits_le32(&phy1_ctrl->phy_con2, RDLVL_GATE_EN); + + setbits_le32(&phy0_ctrl->phy_con0, CTRL_SHGATE); + setbits_le32(&phy1_ctrl->phy_con0, CTRL_SHGATE); + + val = readl(&phy0_ctrl->phy_con1); + val &= ~(CTRL_GATEDURADJ_MASK); + writel(val, &phy0_ctrl->phy_con1); + + val = readl(&phy1_ctrl->phy_con1); + val &= ~(CTRL_GATEDURADJ_MASK); + writel(val, &phy1_ctrl->phy_con1); + + writel(CTRL_RDLVL_GATE_ENABLE, &drex0->rdlvl_config); + i = TIMEOUT; + while (((readl(&drex0->phystatus) & RDLVL_COMPLETE_CHO) != + RDLVL_COMPLETE_CHO) && (i > 0)) { + /* + * TODO(waihong): Comment on how long this take to + * timeout + */ + sdelay(100); + i--; + } + if (!i) + return SETUP_ERR_RDLV_COMPLETE_TIMEOUT; + writel(CTRL_RDLVL_GATE_DISABLE, &drex0->rdlvl_config); + + writel(CTRL_RDLVL_GATE_ENABLE, &drex1->rdlvl_config); + i = TIMEOUT; + while (((readl(&drex1->phystatus) & RDLVL_COMPLETE_CHO) != + RDLVL_COMPLETE_CHO) && (i > 0)) { + /* + * TODO(waihong): Comment on how long this take to + * timeout + */ + sdelay(100); + i--; + } + if (!i) + return SETUP_ERR_RDLV_COMPLETE_TIMEOUT; + writel(CTRL_RDLVL_GATE_DISABLE, &drex1->rdlvl_config); + + writel(0, &phy0_ctrl->phy_con14); + writel(0, &phy1_ctrl->phy_con14); + + val = (0x3 << DIRECT_CMD_BANK_SHIFT); + for (chip = 0; chip < mem->chips_to_configure; chip++) { + writel(val | (chip << DIRECT_CMD_CHIP_SHIFT), + &drex0->directcmd); + writel(val | (chip << DIRECT_CMD_CHIP_SHIFT), + &drex1->directcmd); + } + + if (mem->read_leveling_enable) { + /* Set Read DQ Calibration */ + val = (0x3 << DIRECT_CMD_BANK_SHIFT) | 0x4; + for (chip = 0; chip < mem->chips_to_configure; chip++) { + writel(val | (chip << DIRECT_CMD_CHIP_SHIFT), + &drex0->directcmd); + writel(val | (chip << DIRECT_CMD_CHIP_SHIFT), + &drex1->directcmd); + } + + val = readl(&phy0_ctrl->phy_con1); + val |= READ_LEVELLING_DDR3; + writel(val, &phy0_ctrl->phy_con1); + val = readl(&phy1_ctrl->phy_con1); + val |= READ_LEVELLING_DDR3; + writel(val, &phy1_ctrl->phy_con1); + + val = readl(&phy0_ctrl->phy_con2); + val |= (RDLVL_EN | RDLVL_INCR_ADJ); + writel(val, &phy0_ctrl->phy_con2); + val = readl(&phy1_ctrl->phy_con2); + val |= (RDLVL_EN | RDLVL_INCR_ADJ); + writel(val, &phy1_ctrl->phy_con2); + + setbits_le32(&drex0->rdlvl_config, + CTRL_RDLVL_DATA_ENABLE); + i = TIMEOUT; + while (((readl(&drex0->phystatus) & RDLVL_COMPLETE_CHO) + != RDLVL_COMPLETE_CHO) && (i > 0)) { + /* + * TODO(waihong): Comment on how long this take + * to timeout + */ + sdelay(100); + i--; + } + if (!i) + return SETUP_ERR_RDLV_COMPLETE_TIMEOUT; + + clrbits_le32(&drex0->rdlvl_config, + CTRL_RDLVL_DATA_ENABLE); + setbits_le32(&drex1->rdlvl_config, + CTRL_RDLVL_DATA_ENABLE); + i = TIMEOUT; + while (((readl(&drex1->phystatus) & RDLVL_COMPLETE_CHO) + != RDLVL_COMPLETE_CHO) && (i > 0)) { + /* + * TODO(waihong): Comment on how long this take + * to timeout + */ + sdelay(100); + i--; + } + if (!i) + return SETUP_ERR_RDLV_COMPLETE_TIMEOUT; + + clrbits_le32(&drex1->rdlvl_config, + CTRL_RDLVL_DATA_ENABLE); + + val = (0x3 << DIRECT_CMD_BANK_SHIFT); + for (chip = 0; chip < mem->chips_to_configure; chip++) { + writel(val | (chip << DIRECT_CMD_CHIP_SHIFT), + &drex0->directcmd); + writel(val | (chip << DIRECT_CMD_CHIP_SHIFT), + &drex1->directcmd); + } + + update_reset_dll(&drex0->phycontrol0, DDR_MODE_DDR3); + update_reset_dll(&drex1->phycontrol0, DDR_MODE_DDR3); + } + + /* Common Settings for Leveling */ + val = PHY_CON12_RESET_VAL; + writel((val + n_lock_w_phy0), &phy0_ctrl->phy_con12); + writel((val + n_lock_w_phy1), &phy1_ctrl->phy_con12); + + setbits_le32(&phy0_ctrl->phy_con2, DLL_DESKEW_EN); + setbits_le32(&phy1_ctrl->phy_con2, DLL_DESKEW_EN); + } + + /* Send PALL command */ + dmc_config_prech(mem, &drex0->directcmd); + dmc_config_prech(mem, &drex1->directcmd); + + writel(mem->memcontrol, &drex0->memcontrol); + writel(mem->memcontrol, &drex1->memcontrol); + + /* + * Set DMC Concontrol: Enable auto-refresh counter, provide + * read data fetch cycles and enable DREX auto set powerdown + * for input buffer of I/O in none read memory state. + */ + writel(mem->concontrol | (mem->aref_en << CONCONTROL_AREF_EN_SHIFT) | + (mem->rd_fetch << CONCONTROL_RD_FETCH_SHIFT)| + DMC_CONCONTROL_IO_PD_CON(0x2), + &drex0->concontrol); + writel(mem->concontrol | (mem->aref_en << CONCONTROL_AREF_EN_SHIFT) | + (mem->rd_fetch << CONCONTROL_RD_FETCH_SHIFT)| + DMC_CONCONTROL_IO_PD_CON(0x2), + &drex1->concontrol); + + /* + * Enable Clock Gating Control for DMC + * this saves around 25 mw dmc power as compared to the power + * consumption without these bits enabled + */ + setbits_le32(&drex0->cgcontrol, DMC_INTERNAL_CG); + setbits_le32(&drex1->cgcontrol, DMC_INTERNAL_CG); + + return 0; +} +#endif diff --git a/arch/arm/cpu/armv7/exynos/exynos5_setup.h b/arch/arm/cpu/armv7/exynos/exynos5_setup.h index c8d6515..c6a49c4 100644 --- a/arch/arm/cpu/armv7/exynos/exynos5_setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos5_setup.h @@ -696,6 +696,7 @@ #define CLK_DIV_CPERI1_VAL NOT_AVAILABLE
#else +#define PAD_RETENTION_DRAM_COREBLK_VAL 0x10000000
/* APLL_CON1 */ #define APLL_CON1_VAL (0x0020F300) @@ -907,37 +908,38 @@ void lpddr3_mem_ctrl_init(void); * Configure ZQ I/O interface * * @param mem Memory timings for this memory type. - * @param phy0_ctrl Pointer to struct containing PHY0 control reg - * @param phy1_ctrl Pointer to struct containing PHY1 control reg + * @param phy0_con16 Register address for dmc_phy0->phy_con16 + * @param phy1_con16 Register address for dmc_phy1->phy_con16 + * @param phy0_con17 Register address for dmc_phy0->phy_con17 + * @param phy1_con17 Register address for dmc_phy1->phy_con17 * @return 0 if ok, -1 on error */ -int dmc_config_zq(struct mem_timings *mem, - struct exynos5_phy_control *phy0_ctrl, - struct exynos5_phy_control *phy1_ctrl); - +int dmc_config_zq(struct mem_timings *mem, const void *phy0_con16, + const void *phy1_con16, const void *phy0_con17, + const void *phy1_con17); /* * Send NOP and MRS/EMRS Direct commands * * @param mem Memory timings for this memory type. - * @param dmc Pointer to struct of DMC registers + * @param directcmd Register address for dmc_phy->directcmd */ -void dmc_config_mrs(struct mem_timings *mem, struct exynos5_dmc *dmc); +void dmc_config_mrs(struct mem_timings *mem, const void *directcmd);
/* * Send PALL Direct commands * * @param mem Memory timings for this memory type. - * @param dmc Pointer to struct of DMC registers + * @param directcmd Register address for dmc_phy->directcmd */ -void dmc_config_prech(struct mem_timings *mem, struct exynos5_dmc *dmc); +void dmc_config_prech(struct mem_timings *mem, const void *directcmd);
/* * Reset the DLL. This function is common between DDR3 and LPDDR2. * However, the reset value is different. So we are passing a flag * ddr_mode to distinguish between LPDDR2 and DDR3. * - * @param exynos5_dmc Pointer to struct of DMC registers + * @param phycontrol0 Register address for dmc_phy->phycontrol0 * @param ddr_mode Type of DDR memory */ -void update_reset_dll(struct exynos5_dmc *, enum ddr_mode); +void update_reset_dll(const void *phycontrol0, enum ddr_mode); #endif diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 2b44210..573f755 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -53,6 +53,7 @@ #define EXYNOS4_AUDIOSS_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4_USB_HOST_XHCI_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4_USB3PHY_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4_DMC_TZASC_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS4X12 */ #define EXYNOS4X12_GPIO_PART3_BASE 0x03860000 @@ -91,6 +92,7 @@ #define EXYNOS4X12_AUDIOSS_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4X12_USB_HOST_XHCI_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4X12_USB3PHY_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4X12_DMC_TZASC_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS5 */ #define EXYNOS5_I2C_SPACING 0x10000 @@ -129,6 +131,7 @@
#define EXYNOS5_ADC_BASE DEVICE_NOT_AVAILABLE #define EXYNOS5_MODEM_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5_DMC_TZASC_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS5420 */ #define EXYNOS5420_AUDIOSS_BASE 0x03810000 @@ -143,8 +146,7 @@ #define EXYNOS5420_ACE_SFR_BASE 0x10830000 #define EXYNOS5420_DMC_PHY_BASE 0x10C00000 #define EXYNOS5420_DMC_CTRL_BASE 0x10C20000 -#define EXYNOS5420_DMC_TZASC0_BASE 0x10D40000 -#define EXYNOS5420_DMC_TZASC1_BASE 0x10D50000 +#define EXYNOS5420_DMC_TZASC_BASE 0x10D40000 #define EXYNOS5420_USB_HOST_EHCI_BASE 0x12110000 #define EXYNOS5420_MMC_BASE 0x12200000 #define EXYNOS5420_SROMC_BASE 0x12250000 @@ -284,6 +286,7 @@ SAMSUNG_BASE(spi_isp, SPI_ISP_BASE) SAMSUNG_BASE(tzpc, TZPC_BASE) SAMSUNG_BASE(dmc_ctrl, DMC_CTRL_BASE) SAMSUNG_BASE(dmc_phy, DMC_PHY_BASE) +SAMSUNG_BASE(dmc_tzasc, DMC_TZASC_BASE) SAMSUNG_BASE(audio_ass, AUDIOSS_BASE) #endif
diff --git a/arch/arm/include/asm/arch-exynos/dmc.h b/arch/arm/include/asm/arch-exynos/dmc.h index 32ad3ae..d78536d 100644 --- a/arch/arm/include/asm/arch-exynos/dmc.h +++ b/arch/arm/include/asm/arch-exynos/dmc.h @@ -419,6 +419,15 @@ struct exynos5420_phy_control { unsigned int phy_con42; };
+struct exynos5420_tzasc { + unsigned char res1[0xf00]; + unsigned int membaseconfig0; + unsigned int membaseconfig1; + unsigned char res2[0x8]; + unsigned int memconfig0; + unsigned int memconfig1; +}; + enum ddr_mode { DDR_MODE_DDR2, DDR_MODE_DDR3, @@ -453,6 +462,7 @@ enum mem_manuf { #define PHY_CON0_T_WRRDCMD_SHIFT 17 #define PHY_CON0_T_WRRDCMD_MASK (0x7 << PHY_CON0_T_WRRDCMD_SHIFT) #define PHY_CON0_CTRL_DDR_MODE_SHIFT 11 +#define PHY_CON0_CTRL_DDR_MODE_MASK 0x3
/* PHY_CON1 register fields */ #define PHY_CON1_RDLVL_RDDATA_ADJ_SHIFT 0
Hi Rajeshwari,
- Mem setup common file for different types of DDR present on SMDK5250 boards.
- Mem setup common file for different types of DDR present on Exynos boards.
- Copyright (C) 2012 Samsung Electronics
@@ -15,9 +15,9 @@
Could these be uint32_t * or similar? Also, why const? It looks like you are writing to them.
writel(val, phy1_con16); /* Disable termination */ if (mem->zq_mode_noterm) val |= PHY_CON16_ZQ_MODE_NOTERM_MASK;
Adds code in pinmux and gpio framework to support Exynos5420.
Signed-off-by: Naveen Krishna Chatradhi ch.naveen@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - Added correct calculation of gpio based addresses. Changes in V5: - None Changes in V6: - None Changes in V7: - Corrected the coding style nits. Chnages in V8: - Corrected the coding style nits pointed by Minkyu Kang. Changes in V9: - None Changes in V10: - None Changes in V11: - None arch/arm/cpu/armv7/exynos/pinmux.c | 260 +++++++++++++++++++++++++++++- arch/arm/include/asm/arch-exynos/gpio.h | 143 ++++++++++++++-- arch/arm/include/asm/arch-exynos/periph.h | 3 + 3 files changed, 390 insertions(+), 16 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 74cc700..904177a 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -46,6 +46,42 @@ static void exynos5_uart_config(int peripheral) } }
+static void exynos5420_uart_config(int peripheral) +{ + struct exynos5420_gpio_part1 *gpio1 = + (struct exynos5420_gpio_part1 *)samsung_get_base_gpio_part1(); + struct s5p_gpio_bank *bank; + int i, start, count; + + switch (peripheral) { + case PERIPH_ID_UART0: + bank = &gpio1->a0; + start = 0; + count = 4; + break; + case PERIPH_ID_UART1: + bank = &gpio1->a0; + start = 4; + count = 4; + break; + case PERIPH_ID_UART2: + bank = &gpio1->a1; + start = 0; + count = 4; + break; + case PERIPH_ID_UART3: + bank = &gpio1->a1; + start = 4; + count = 2; + break; + } + + for (i = start; i < start + count; i++) { + s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); + s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + } +} + static int exynos5_mmc_config(int peripheral, int flags) { struct exynos5_gpio_part1 *gpio1 = @@ -101,6 +137,75 @@ static int exynos5_mmc_config(int peripheral, int flags) return 0; }
+static int exynos5420_mmc_config(int peripheral, int flags) +{ + struct exynos5420_gpio_part3 *gpio3 = + (struct exynos5420_gpio_part3 *)samsung_get_base_gpio_part3(); + struct s5p_gpio_bank *bank = NULL, *bank_ext = NULL; + int i, start; + + switch (peripheral) { + case PERIPH_ID_SDMMC0: + bank = &gpio3->c0; + bank_ext = &gpio3->c3; + start = 0; + break; + case PERIPH_ID_SDMMC1: + bank = &gpio3->c1; + bank_ext = &gpio3->d1; + start = 4; + break; + case PERIPH_ID_SDMMC2: + bank = &gpio3->c2; + bank_ext = NULL; + start = 0; + break; + default: + start = 0; + debug("%s: invalid peripheral %d", __func__, peripheral); + return -1; + } + + if ((flags & PINMUX_FLAG_8BIT_MODE) && !bank_ext) { + debug("SDMMC device %d does not support 8bit mode", + peripheral); + return -1; + } + + if (flags & PINMUX_FLAG_8BIT_MODE) { + for (i = start; i <= (start + 3); i++) { + s5p_gpio_cfg_pin(bank_ext, i, GPIO_FUNC(0x2)); + s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_UP); + s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); + } + } + + for (i = 0; i < 3; i++) { + /* + * MMC0 is intended to be used for eMMC. The + * card detect pin is used as a VDDEN signal to + * power on the eMMC. The 5420 iROM makes + * this same assumption. + */ + if ((peripheral == PERIPH_ID_SDMMC0) && (i == 2)) { + s5p_gpio_set_value(bank, i, 1); + s5p_gpio_cfg_pin(bank, i, GPIO_OUTPUT); + } else { + s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + } + s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); + s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + } + + for (i = 3; i <= 6; i++) { + s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + s5p_gpio_set_pull(bank, i, GPIO_PULL_UP); + s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + } + + return 0; +} + static void exynos5_sromc_config(int flags) { struct exynos5_gpio_part1 *gpio1 = @@ -216,6 +321,59 @@ static void exynos5_i2c_config(int peripheral, int flags) } }
+static void exynos5420_i2c_config(int peripheral) +{ + struct exynos5420_gpio_part1 *gpio1 = + (struct exynos5420_gpio_part1 *)samsung_get_base_gpio_part1(); + + switch (peripheral) { + case PERIPH_ID_I2C0: + s5p_gpio_cfg_pin(&gpio1->b3, 0, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->b3, 1, GPIO_FUNC(0x2)); + break; + case PERIPH_ID_I2C1: + s5p_gpio_cfg_pin(&gpio1->b3, 2, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->b3, 3, GPIO_FUNC(0x2)); + break; + case PERIPH_ID_I2C2: + s5p_gpio_cfg_pin(&gpio1->a0, 6, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a0, 7, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C3: + s5p_gpio_cfg_pin(&gpio1->a1, 2, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a1, 3, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C4: + s5p_gpio_cfg_pin(&gpio1->a2, 0, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a2, 1, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C5: + s5p_gpio_cfg_pin(&gpio1->a2, 2, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a2, 3, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C6: + s5p_gpio_cfg_pin(&gpio1->b1, 3, GPIO_FUNC(0x4)); + s5p_gpio_cfg_pin(&gpio1->b1, 4, GPIO_FUNC(0x4)); + break; + case PERIPH_ID_I2C7: + s5p_gpio_cfg_pin(&gpio1->b2, 2, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->b2, 3, GPIO_FUNC(0x3)); + break; + case PERIPH_ID_I2C8: + s5p_gpio_cfg_pin(&gpio1->b3, 4, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->b3, 5, GPIO_FUNC(0x2)); + break; + case PERIPH_ID_I2C9: + s5p_gpio_cfg_pin(&gpio1->b3, 6, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->b3, 7, GPIO_FUNC(0x2)); + break; + case PERIPH_ID_I2C10: + s5p_gpio_cfg_pin(&gpio1->b4, 0, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->b4, 1, GPIO_FUNC(0x2)); + break; + } +} + static void exynos5_i2s_config(int peripheral) { int i; @@ -279,6 +437,58 @@ void exynos5_spi_config(int peripheral) } }
+void exynos5420_spi_config(int peripheral) +{ + int cfg, pin, i; + struct s5p_gpio_bank *bank = NULL; + struct exynos5420_gpio_part1 *gpio1 = + (struct exynos5420_gpio_part1 *)samsung_get_base_gpio_part1(); + struct exynos5420_gpio_part4 *gpio4 = + (struct exynos5420_gpio_part4 *)samsung_get_base_gpio_part4(); + + switch (peripheral) { + case PERIPH_ID_SPI0: + bank = &gpio1->a2; + cfg = GPIO_FUNC(0x2); + pin = 0; + break; + case PERIPH_ID_SPI1: + bank = &gpio1->a2; + cfg = GPIO_FUNC(0x2); + pin = 4; + break; + case PERIPH_ID_SPI2: + bank = &gpio1->b1; + cfg = GPIO_FUNC(0x5); + pin = 1; + break; + case PERIPH_ID_SPI3: + bank = &gpio4->f1; + cfg = GPIO_FUNC(0x2); + pin = 0; + break; + case PERIPH_ID_SPI4: + cfg = 0; + pin = 0; + break; + default: + cfg = 0; + pin = 0; + debug("%s: invalid peripheral %d", __func__, peripheral); + return; + } + + if (peripheral != PERIPH_ID_SPI4) { + for (i = pin; i < pin + 4; i++) + s5p_gpio_cfg_pin(bank, i, cfg); + } else { + for (i = 0; i < 2; i++) { + s5p_gpio_cfg_pin(&gpio4->f0, i + 2, GPIO_FUNC(0x4)); + s5p_gpio_cfg_pin(&gpio4->e0, i + 4, GPIO_FUNC(0x4)); + } + } +} + static int exynos5_pinmux_config(int peripheral, int flags) { switch (peripheral) { @@ -325,6 +535,48 @@ static int exynos5_pinmux_config(int peripheral, int flags) return 0; }
+static int exynos5420_pinmux_config(int peripheral, int flags) +{ + switch (peripheral) { + case PERIPH_ID_UART0: + case PERIPH_ID_UART1: + case PERIPH_ID_UART2: + case PERIPH_ID_UART3: + exynos5420_uart_config(peripheral); + break; + case PERIPH_ID_SDMMC0: + case PERIPH_ID_SDMMC1: + case PERIPH_ID_SDMMC2: + case PERIPH_ID_SDMMC3: + return exynos5420_mmc_config(peripheral, flags); + case PERIPH_ID_SPI0: + case PERIPH_ID_SPI1: + case PERIPH_ID_SPI2: + case PERIPH_ID_SPI3: + case PERIPH_ID_SPI4: + exynos5420_spi_config(peripheral); + break; + case PERIPH_ID_I2C0: + case PERIPH_ID_I2C1: + case PERIPH_ID_I2C2: + case PERIPH_ID_I2C3: + case PERIPH_ID_I2C4: + case PERIPH_ID_I2C5: + case PERIPH_ID_I2C6: + case PERIPH_ID_I2C7: + case PERIPH_ID_I2C8: + case PERIPH_ID_I2C9: + case PERIPH_ID_I2C10: + exynos5420_i2c_config(peripheral); + break; + default: + debug("%s: invalid peripheral %d", __func__, peripheral); + return -1; + } + + return 0; +} + static void exynos4_i2c_config(int peripheral, int flags) { struct exynos4_gpio_part1 *gpio1 = @@ -475,13 +727,17 @@ static int exynos4_pinmux_config(int peripheral, int flags) int exynos_pinmux_config(int peripheral, int flags) { if (cpu_is_exynos5()) { - return exynos5_pinmux_config(peripheral, flags); + if (proid_is_exynos5420()) + return exynos5420_pinmux_config(peripheral, flags); + else if (proid_is_exynos5250()) + return exynos5_pinmux_config(peripheral, flags); } else if (cpu_is_exynos4()) { return exynos4_pinmux_config(peripheral, flags); } else { debug("pinmux functionality not supported\n"); - return -1; } + + return -1; }
#ifdef CONFIG_OF_CONTROL diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index a1a7439..2a19852 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -127,6 +127,58 @@ struct exynos4x12_gpio_part4 { struct s5p_gpio_bank v4; };
+struct exynos5420_gpio_part1 { + struct s5p_gpio_bank a0; + struct s5p_gpio_bank a1; + struct s5p_gpio_bank a2; + struct s5p_gpio_bank b0; + struct s5p_gpio_bank b1; + struct s5p_gpio_bank b2; + struct s5p_gpio_bank b3; + struct s5p_gpio_bank b4; + struct s5p_gpio_bank h0; +}; + +struct exynos5420_gpio_part2 { + struct s5p_gpio_bank y7; /* 0x1340_0000 */ + struct s5p_gpio_bank res[0x5f]; /* */ + struct s5p_gpio_bank x0; /* 0x1340_0C00 */ + struct s5p_gpio_bank x1; /* 0x1340_0C20 */ + struct s5p_gpio_bank x2; /* 0x1340_0C40 */ + struct s5p_gpio_bank x3; /* 0x1340_0C60 */ +}; + +struct exynos5420_gpio_part3 { + struct s5p_gpio_bank c0; + struct s5p_gpio_bank c1; + struct s5p_gpio_bank c2; + struct s5p_gpio_bank c3; + struct s5p_gpio_bank c4; + struct s5p_gpio_bank d1; + struct s5p_gpio_bank y0; + struct s5p_gpio_bank y1; + struct s5p_gpio_bank y2; + struct s5p_gpio_bank y3; + struct s5p_gpio_bank y4; + struct s5p_gpio_bank y5; + struct s5p_gpio_bank y6; +}; + +struct exynos5420_gpio_part4 { + struct s5p_gpio_bank e0; /* 0x1400_0000 */ + struct s5p_gpio_bank e1; /* 0x1400_0020 */ + struct s5p_gpio_bank f0; /* 0x1400_0040 */ + struct s5p_gpio_bank f1; /* 0x1400_0060 */ + struct s5p_gpio_bank g0; /* 0x1400_0080 */ + struct s5p_gpio_bank g1; /* 0x1400_00A0 */ + struct s5p_gpio_bank g2; /* 0x1400_00C0 */ + struct s5p_gpio_bank j4; /* 0x1400_00E0 */ +}; + +struct exynos5420_gpio_part5 { + struct s5p_gpio_bank z0; /* 0x0386_0000 */ +}; + struct exynos5_gpio_part1 { struct s5p_gpio_bank a0; struct s5p_gpio_bank a1; @@ -259,16 +311,67 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); - EXYNOS5_GPIO_PART3_BASE) / sizeof(struct s5p_gpio_bank)) \ * GPIO_PER_BANK) + pin) + EXYNOS5_GPIO_PART2_MAX)
+ +/* EXYNOS5420 */ +#define exynos5420_gpio_part1_get_nr(bank, pin) \ + ((((((unsigned int) &(((struct exynos5420_gpio_part1 *)\ + EXYNOS5420_GPIO_PART1_BASE)->bank)) \ + - EXYNOS5420_GPIO_PART1_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + +#define EXYNOS5420_GPIO_PART1_MAX ((sizeof(struct exynos5420_gpio_part1) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define exynos5420_gpio_part2_get_nr(bank, pin) \ + (((((((unsigned int) &(((struct exynos5420_gpio_part2 *)\ + EXYNOS5420_GPIO_PART2_BASE)->bank)) \ + - EXYNOS5420_GPIO_PART2_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + EXYNOS5420_GPIO_PART1_MAX) + +#define EXYNOS5420_GPIO_PART2_MAX ((sizeof(struct exynos5420_gpio_part2) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define exynos5420_gpio_part3_get_nr(bank, pin) \ + (((((((unsigned int) &(((struct exynos5420_gpio_part3 *)\ + EXYNOS5420_GPIO_PART3_BASE)->bank)) \ + - EXYNOS5420_GPIO_PART3_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + EXYNOS5420_GPIO_PART2_MAX) + +#define EXYNOS5420_GPIO_PART3_MAX ((sizeof(struct exynos5420_gpio_part3) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define exynos5420_gpio_part4_get_nr(bank, pin) \ + (((((((unsigned int) &(((struct exynos5420_gpio_part4 *)\ + EXYNOS5420_GPIO_PART4_BASE)->bank)) \ + - EXYNOS5420_GPIO_PART4_BASE) / sizeof(struct s5p_gpio_bank)) \ + * GPIO_PER_BANK) + pin) + EXYNOS5420_GPIO_PART3_MAX) + +#define EXYNOS5420_GPIO_PART4_MAX ((sizeof(struct exynos5420_gpio_part4) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + +#define EXYNOS5420_GPIO_PART5_MAX ((sizeof(struct exynos5420_gpio_part5) \ + / sizeof(struct s5p_gpio_bank)) * GPIO_PER_BANK) + static inline unsigned int s5p_gpio_base(int nr) { if (cpu_is_exynos5()) { - if (nr < EXYNOS5_GPIO_PART1_MAX) - return EXYNOS5_GPIO_PART1_BASE; - else if (nr < EXYNOS5_GPIO_PART2_MAX) - return EXYNOS5_GPIO_PART2_BASE; - else - return EXYNOS5_GPIO_PART3_BASE; - + if (proid_is_exynos5420()) { + if (nr < EXYNOS5420_GPIO_PART1_MAX) + return EXYNOS5420_GPIO_PART1_BASE; + else if (nr < EXYNOS5420_GPIO_PART2_MAX) + return EXYNOS5420_GPIO_PART2_BASE; + else if (nr < EXYNOS5420_GPIO_PART3_MAX) + return EXYNOS5420_GPIO_PART3_BASE; + else + return EXYNOS5420_GPIO_PART4_BASE; + } else { + if (nr < EXYNOS5_GPIO_PART1_MAX) + return EXYNOS5_GPIO_PART1_BASE; + else if (nr < EXYNOS5_GPIO_PART2_MAX) + return EXYNOS5_GPIO_PART2_BASE; + else + return EXYNOS5_GPIO_PART3_BASE; + } } else if (cpu_is_exynos4()) { if (nr < EXYNOS4_GPIO_PART1_MAX) return EXYNOS4_GPIO_PART1_BASE; @@ -282,13 +385,25 @@ static inline unsigned int s5p_gpio_base(int nr) static inline unsigned int s5p_gpio_part_max(int nr) { if (cpu_is_exynos5()) { - if (nr < EXYNOS5_GPIO_PART1_MAX) - return 0; - else if (nr < EXYNOS5_GPIO_PART2_MAX) - return EXYNOS5_GPIO_PART1_MAX; - else - return EXYNOS5_GPIO_PART2_MAX; - + if (proid_is_exynos5420()) { + if (nr < EXYNOS5420_GPIO_PART1_MAX) + return 0; + else if (nr < EXYNOS5420_GPIO_PART2_MAX) + return EXYNOS5420_GPIO_PART1_MAX; + else if (nr < EXYNOS5420_GPIO_PART3_MAX) + return EXYNOS5420_GPIO_PART2_MAX; + else if (nr < EXYNOS5420_GPIO_PART4_MAX) + return EXYNOS5420_GPIO_PART3_MAX; + else + return EXYNOS5420_GPIO_PART4_MAX; + } else { + if (nr < EXYNOS5_GPIO_PART1_MAX) + return 0; + else if (nr < EXYNOS5_GPIO_PART2_MAX) + return EXYNOS5_GPIO_PART1_MAX; + else + return EXYNOS5_GPIO_PART2_MAX; + } } else if (cpu_is_exynos4()) { if (proid_is_exynos4412()) { if (nr < EXYNOS4X12_GPIO_PART1_MAX) diff --git a/arch/arm/include/asm/arch-exynos/periph.h b/arch/arm/include/asm/arch-exynos/periph.h index 64bd8b7..30c7f18 100644 --- a/arch/arm/include/asm/arch-exynos/periph.h +++ b/arch/arm/include/asm/arch-exynos/periph.h @@ -34,6 +34,9 @@ enum periph_id { PERIPH_ID_SDMMC1, PERIPH_ID_SDMMC2, PERIPH_ID_SDMMC3, + PERIPH_ID_I2C8 = 87, + PERIPH_ID_I2C9, + PERIPH_ID_I2C10 = 203, PERIPH_ID_I2S0 = 98, PERIPH_ID_I2S1 = 99,
Adding the base patch for Exynos based SMDK5420. This shall enable compilation and basic boot support for SMDK5420.
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- Changes in V2: - None Changes in V3: - None Changes in V4: - Rebased on latest u-boot-samsung tree. Changes in V5: - Removed functions board_eth_init and board_mmc_init as they were moved to common/board.c Changes in V6: - None Changes in V7: - added CONFIG_EXYNOS_SPL to build 5420 and 5250 Changes in V8: - None Changes in V9: - Rebased on latest code. Changes in V10: - Rebased on latest code. Changes in V11: - None board/samsung/common/board.c | 2 + board/samsung/smdk5420/Makefile | 11 +++ board/samsung/smdk5420/smdk5420.c | 159 ++++++++++++++++++++++++++++++++++ board/samsung/smdk5420/smdk5420_spl.c | 52 +++++++++++ boards.cfg | 1 + include/configs/arndale.h | 1 + include/configs/exynos5250-dt.h | 1 + tools/Makefile | 3 +- 8 files changed, 229 insertions(+), 1 deletion(-) create mode 100644 board/samsung/smdk5420/Makefile create mode 100644 board/samsung/smdk5420/smdk5420.c create mode 100644 board/samsung/smdk5420/smdk5420_spl.c
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 95df346..a5cb568 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -146,6 +146,7 @@ struct cros_ec_dev *board_get_cros_ec_dev(void) return local.cros_ec_dev; }
+#ifdef CONFIG_CROS_EC static int board_init_cros_ec_devices(const void *blob) { local.cros_ec_err = cros_ec_init(blob, &local.cros_ec_dev); @@ -154,6 +155,7 @@ static int board_init_cros_ec_devices(const void *blob)
return 0; } +#endif
#if defined(CONFIG_POWER) #ifdef CONFIG_POWER_MAX77686 diff --git a/board/samsung/smdk5420/Makefile b/board/samsung/smdk5420/Makefile new file mode 100644 index 0000000..c2f8886 --- /dev/null +++ b/board/samsung/smdk5420/Makefile @@ -0,0 +1,11 @@ +# +# Copyright (C) 2013 Samsung Electronics +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += smdk5420_spl.o + +ifndef CONFIG_SPL_BUILD +obj-y += smdk5420.o +endif diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c new file mode 100644 index 0000000..3ad2ad0 --- /dev/null +++ b/board/samsung/smdk5420/smdk5420.c @@ -0,0 +1,159 @@ +/* + * Copyright (C) 2013 Samsung Electronics + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <asm/io.h> +#include <i2c.h> +#include <lcd.h> +#include <spi.h> +#include <asm/arch/board.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/dp_info.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_USB_EHCI_EXYNOS +static int board_usb_vbus_init(void) +{ + struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) + samsung_get_base_gpio_part1(); + + /* Enable VBUS power switch */ + s5p_gpio_direction_output(&gpio1->x2, 6, 1); + + /* VBUS turn ON time */ + mdelay(3); + + return 0; +} +#endif + +int exynos_init(void) +{ +#ifdef CONFIG_USB_EHCI_EXYNOS + board_usb_vbus_init(); +#endif + return 0; +} + +#ifdef CONFIG_LCD +void cfg_lcd_gpio(void) +{ + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *)samsung_get_base_gpio_part1(); + + /* For Backlight */ + s5p_gpio_cfg_pin(&gpio1->b2, 0, GPIO_OUTPUT); + s5p_gpio_set_value(&gpio1->b2, 0, 1); + + /* LCD power on */ + s5p_gpio_cfg_pin(&gpio1->x1, 5, GPIO_OUTPUT); + s5p_gpio_set_value(&gpio1->x1, 5, 1); + + /* Set Hotplug detect for DP */ + s5p_gpio_cfg_pin(&gpio1->x0, 7, GPIO_FUNC(0x3)); +} + +vidinfo_t panel_info = { + .vl_freq = 60, + .vl_col = 2560, + .vl_row = 1600, + .vl_width = 2560, + .vl_height = 1600, + .vl_clkp = CONFIG_SYS_LOW, + .vl_hsp = CONFIG_SYS_LOW, + .vl_vsp = CONFIG_SYS_LOW, + .vl_dp = CONFIG_SYS_LOW, + .vl_bpix = 4, /* LCD_BPP = 2^4, for output conosle on LCD */ + + /* wDP panel timing infomation */ + .vl_hspw = 32, + .vl_hbpd = 80, + .vl_hfpd = 48, + + .vl_vspw = 6, + .vl_vbpd = 37, + .vl_vfpd = 3, + .vl_cmd_allow_len = 0xf, + + .win_id = 3, + .cfg_gpio = cfg_lcd_gpio, + .backlight_on = NULL, + .lcd_power_on = NULL, + .reset_lcd = NULL, + .dual_lcd_enabled = 0, + + .init_delay = 0, + .power_on_delay = 0, + .reset_delay = 0, + .interface_mode = FIMD_RGB_INTERFACE, + .dp_enabled = 1, +}; + +static struct edp_device_info edp_info = { + .disp_info = { + .h_res = 2560, + .h_sync_width = 32, + .h_back_porch = 80, + .h_front_porch = 48, + .v_res = 1600, + .v_sync_width = 6, + .v_back_porch = 37, + .v_front_porch = 3, + .v_sync_rate = 60, + }, + .lt_info = { + .lt_status = DP_LT_NONE, + }, + .video_info = { + .master_mode = 0, + .bist_mode = DP_DISABLE, + .bist_pattern = NO_PATTERN, + .h_sync_polarity = 0, + .v_sync_polarity = 0, + .interlaced = 0, + .color_space = COLOR_RGB, + .dynamic_range = VESA, + .ycbcr_coeff = COLOR_YCBCR601, + .color_depth = COLOR_8, + }, +}; + +static struct exynos_dp_platform_data dp_platform_data = { + .phy_enable = set_dp_phy_ctrl, + .edp_dev_info = &edp_info, +}; + +void init_panel_info(vidinfo_t *vid) +{ + vid->rgb_mode = MODE_RGB_P; + + exynos_set_dp_platform_data(&dp_platform_data); +} +#endif + +int board_get_revision(void) +{ + return 0; +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + const char *board_name; + + board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + if (board_name == NULL) + printf("\nUnknown Board\n"); + else + printf("\nBoard: %s\n", board_name); + + return 0; +} +#endif diff --git a/board/samsung/smdk5420/smdk5420_spl.c b/board/samsung/smdk5420/smdk5420_spl.c new file mode 100644 index 0000000..73359f7 --- /dev/null +++ b/board/samsung/smdk5420/smdk5420_spl.c @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2013 The Chromium OS Authors. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/spl.h> +#include <asm/arch/clk.h> + +#define SIGNATURE 0xdeadbeef + +/* Parameters of early board initialization in SPL */ +static struct spl_machine_param machine_param + __attribute__((section(".machine_param"))) = { + .signature = SIGNATURE, + .version = 1, + .params = "vmubfasirM", + .size = sizeof(machine_param), + + .mem_iv_size = 0x1f, + .mem_type = DDR_MODE_DDR3, + + /* + * Set uboot_size to 0x100000 bytes. + * + * This is an overly conservative value chosen to accommodate all + * possible U-Boot image. You are advised to set this value to a + * smaller realistic size via scripts that modifies the .machine_param + * section of output U-Boot image. + */ + .uboot_size = 0x100000, + + .boot_source = BOOT_MODE_OM, + .frequency_mhz = 800, + .arm_freq_mhz = 900, + .serial_base = 0x12c30000, + .i2c_base = 0x12c60000, + .mem_manuf = MEM_MANUF_SAMSUNG, +}; + +struct spl_machine_param *spl_get_machine_params(void) +{ + if (machine_param.signature != SIGNATURE) { + /* Will hang if SIGNATURE dont match */ + while (1) + ; + } + + return &machine_param; +} diff --git a/boards.cfg b/boards.cfg index 2128996..c7376b3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -276,6 +276,7 @@ Active arm armv7 exynos samsung arndale Active arm armv7 exynos samsung origen origen - Chander Kashyap k.chander@samsung.com Active arm armv7 exynos samsung smdk5250 smdk5250 - Chander Kashyap k.chander@samsung.com Active arm armv7 exynos samsung smdk5250 snow - Rajeshwari Shinde rajeshwari.s@samsung.com +Active arm armv7 exynos samsung smdk5420 smdk5420 - Rajeshwari Shinde rajeshwari.s@samsung.com Active arm armv7 exynos samsung smdkv310 smdkv310 - Chander Kashyap k.chander@samsung.com Active arm armv7 exynos samsung trats trats - Lukasz Majewski l.majewski@samsung.com Active arm armv7 exynos samsung trats2 trats2 - Piotr Wilczek p.wilczek@samsung.com diff --git a/include/configs/arndale.h b/include/configs/arndale.h index f0b9f94..f431d20 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -117,6 +117,7 @@ #define CONFIG_USB_STORAGE
/* MMC SPL */ +#define CONFIG_EXYNOS_SPL #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index c625524..51b2623 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -155,6 +155,7 @@ #define CONFIG_TPM_TIS_I2C_SLAVE_ADDR 0x20
diff --git a/tools/Makefile b/tools/Makefile index 14d94e3..d4bc84d 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -53,6 +53,7 @@ BIN_FILES-$(CONFIG_XWAY_SWAP_BYTES) += xway-swap-bytes$(SFX) BIN_FILES-y += mkenvimage$(SFX) BIN_FILES-y += mkimage$(SFX) BIN_FILES-$(CONFIG_EXYNOS5250) += mk$(BOARD)spl$(SFX) +BIN_FILES-$(CONFIG_EXYNOS5420) += mk$(BOARD)spl$(SFX) BIN_FILES-$(CONFIG_MX23) += mxsboot$(SFX) BIN_FILES-$(CONFIG_MX28) += mxsboot$(SFX) BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) @@ -87,7 +88,7 @@ NOPED_OBJ_FILES-y += ublimage.o OBJ_FILES-$(CONFIG_BUILD_ENVCRC) += envcrc.o OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_CMD_NET) += gen_eth_addr.o -OBJ_FILES-$(CONFIG_EXYNOS5250) += mkexynosspl.o +OBJ_FILES-$(CONFIG_EXYNOS_SPL) += mkexynosspl.o OBJ_FILES-$(CONFIG_KIRKWOOD) += kwboot.o OBJ_FILES-$(CONFIG_LCD_LOGO) += bmp_logo.o OBJ_FILES-$(CONFIG_MX23) += mxsboot.o
This patch adds dts support for SMDK5420. exynos5.dtsi created is a common file which has the nodes common to both 5420 and 5250.
Signed-off-by: Akshay Saraswat akshay.s@samsung.com Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - Added /include/ "exynos5420.dtsi Changes in V5: - None Changes in V6: - None Changes in V7: - Corrected the license. Changes in V8: - None Changes in V9: - Rebased on latest code. Changes in V10: - Rebased on latest code. Changes in V11: - None arch/arm/dts/exynos5.dtsi | 198 ++++++++++++++++++++++++++++++ arch/arm/dts/exynos5250.dtsi | 194 +---------------------------- arch/arm/dts/exynos5420.dtsi | 70 +++++++++++ board/samsung/dts/exynos5420-smdk5420.dts | 169 +++++++++++++++++++++++++ 4 files changed, 441 insertions(+), 190 deletions(-) create mode 100644 arch/arm/dts/exynos5.dtsi create mode 100644 arch/arm/dts/exynos5420.dtsi create mode 100644 board/samsung/dts/exynos5420-smdk5420.dts
diff --git a/arch/arm/dts/exynos5.dtsi b/arch/arm/dts/exynos5.dtsi new file mode 100644 index 0000000..f8c8741 --- /dev/null +++ b/arch/arm/dts/exynos5.dtsi @@ -0,0 +1,198 @@ +/* + * Copyright (c) 2013 The Chromium OS Authors + * SAMSUNG EXYNOS5 SoC device tree source + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + compatible = "samsung,exynos5"; + + sromc@12250000 { + compatible = "samsung,exynos-sromc"; + reg = <0x12250000 0x20>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c@12c60000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + reg = <0x12C60000 0x100>; + interrupts = <0 56 0>; + }; + + i2c@12c70000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + reg = <0x12C70000 0x100>; + interrupts = <0 57 0>; + }; + + i2c@12c80000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + reg = <0x12C80000 0x100>; + interrupts = <0 58 0>; + }; + + i2c@12c90000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + reg = <0x12C90000 0x100>; + interrupts = <0 59 0>; + }; + + spi@12d20000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-spi"; + reg = <0x12d20000 0x30>; + interrupts = <0 68 0>; + }; + + spi@12d30000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-spi"; + reg = <0x12d30000 0x30>; + interrupts = <0 69 0>; + }; + + spi@12d40000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-spi"; + reg = <0x12d40000 0x30>; + clock-frequency = <50000000>; + interrupts = <0 70 0>; + }; + + spi@131a0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-spi"; + reg = <0x131a0000 0x30>; + interrupts = <0 129 0>; + }; + + spi@131b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-spi"; + reg = <0x131b0000 0x30>; + interrupts = <0 130 0>; + }; + + ehci@12110000 { + compatible = "samsung,exynos-ehci"; + reg = <0x12110000 0x100>; + #address-cells = <1>; + #size-cells = <1>; + + phy { + compatible = "samsung,exynos-usb-phy"; + reg = <0x12130000 0x100>; + }; + }; + + tmu@10060000 { + compatible = "samsung,exynos-tmu"; + reg = <0x10060000 0x10000>; + }; + + fimd@14400000 { + compatible = "samsung,exynos-fimd"; + reg = <0x14400000 0x10000>; + #address-cells = <1>; + #size-cells = <1>; + }; + + dp@145b0000 { + compatible = "samsung,exynos5-dp"; + reg = <0x145b0000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + }; + + xhci0: xhci@12000000 { + compatible = "samsung,exynos5250-xhci"; + reg = <0x12000000 0x10000>; + #address-cells = <1>; + #size-cells = <1>; + + phy { + compatible = "samsung,exynos5250-usb3-phy"; + reg = <0x12100000 0x100>; + }; + }; + + mmc@12200000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5250-dwmmc"; + reg = <0x12200000 0x1000>; + interrupts = <0 75 0>; + }; + + mmc@12210000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5250-dwmmc"; + reg = <0x12210000 0x1000>; + interrupts = <0 76 0>; + }; + + mmc@12220000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5250-dwmmc"; + reg = <0x12220000 0x1000>; + interrupts = <0 77 0>; + }; + + mmc@12230000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5250-dwmmc"; + reg = <0x12230000 0x1000>; + interrupts = <0 78 0>; + }; + + serial@12C00000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x12C00000 0x100>; + interrupts = <0 51 0>; + id = <0>; + }; + + serial@12C10000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x12C10000 0x100>; + interrupts = <0 52 0>; + id = <1>; + }; + + serial@12C20000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x12C20000 0x100>; + interrupts = <0 53 0>; + id = <2>; + }; + + serial@12C30000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x12C30000 0x100>; + interrupts = <0 54 0>; + id = <3>; + }; + + gpio: gpio { + }; +}; diff --git a/arch/arm/dts/exynos5250.dtsi b/arch/arm/dts/exynos5250.dtsi index 31880eb..0c644e7 100644 --- a/arch/arm/dts/exynos5250.dtsi +++ b/arch/arm/dts/exynos5250.dtsi @@ -1,66 +1,13 @@ /* + * (C) Copyright 2012 SAMSUNG Electronics * SAMSUNG EXYNOS5250 SoC device tree source * - * Copyright (c) 2012 Samsung Electronics Co., Ltd. - * http://www.samsung.com - * - * SAMSUNG EXYNOS5250 SoC device nodes are listed in this file. - * EXYNOS5250 based board files can include this file and provide - * values for board specfic bindings. - * - * Note: This file does not include device nodes for all the controllers in - * EXYNOS5250 SoC. As device tree coverage for EXYNOS5250 increases, - * additional nodes can be added to this file. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. -*/ + * SPDX-License-Identifier: GPL-2.0+ + */
-/include/ "skeleton.dtsi" +/include/ "exynos5.dtsi"
/ { - compatible = "samsung,exynos5250"; - - sromc@12250000 { - compatible = "samsung,exynos-sromc"; - reg = <0x12250000 0x20>; - #address-cells = <1>; - #size-cells = <0>; - }; - - i2c@12c60000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,s3c2440-i2c"; - reg = <0x12C60000 0x100>; - interrupts = <0 56 0>; - }; - - i2c@12c70000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,s3c2440-i2c"; - reg = <0x12C70000 0x100>; - interrupts = <0 57 0>; - }; - - i2c@12c80000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,s3c2440-i2c"; - reg = <0x12C80000 0x100>; - interrupts = <0 58 0>; - }; - - i2c@12c90000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,s3c2440-i2c"; - reg = <0x12C90000 0x100>; - interrupts = <0 59 0>; - }; - i2c@12ca0000 { #address-cells = <1>; #size-cells = <0>; @@ -117,46 +64,6 @@ samsung,i2s-id = <1>; };
- spi@12d20000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos-spi"; - reg = <0x12d20000 0x30>; - interrupts = <0 68 0>; - }; - - spi@12d30000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos-spi"; - reg = <0x12d30000 0x30>; - interrupts = <0 69 0>; - }; - - spi@12d40000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos-spi"; - reg = <0x12d40000 0x30>; - clock-frequency = <50000000>; - interrupts = <0 70 0>; - }; - - spi@131a0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos-spi"; - reg = <0x131a0000 0x30>; - interrupts = <0 129 0>; - }; - - spi@131b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos-spi"; - reg = <0x131b0000 0x30>; - interrupts = <0 130 0>; - };
xhci@12000000 { compatible = "samsung,exynos5250-xhci"; @@ -170,97 +77,4 @@ }; };
- ehci@12110000 { - compatible = "samsung,exynos-ehci"; - reg = <0x12110000 0x100>; - #address-cells = <1>; - #size-cells = <1>; - - phy { - compatible = "samsung,exynos-usb-phy"; - reg = <0x12130000 0x100>; - }; - }; - - tmu@10060000 { - compatible = "samsung,exynos-tmu"; - reg = <0x10060000 0x10000>; - }; - - fimd@14400000 { - compatible = "samsung,exynos-fimd"; - reg = <0x14400000 0x10000>; - #address-cells = <1>; - #size-cells = <1>; - }; - - dp@145b0000 { - compatible = "samsung,exynos5-dp"; - reg = <0x145b0000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - }; - - mmc@12200000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5250-dwmmc"; - reg = <0x12200000 0x1000>; - interrupts = <0 75 0>; - }; - - mmc@12210000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5250-dwmmc"; - reg = <0x12210000 0x1000>; - interrupts = <0 76 0>; - }; - - mmc@12220000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5250-dwmmc"; - reg = <0x12220000 0x1000>; - interrupts = <0 77 0>; - }; - - mmc@12230000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "samsung,exynos5250-dwmmc"; - reg = <0x12230000 0x1000>; - interrupts = <0 78 0>; - }; - - serial@12C00000 { - compatible = "samsung,exynos4210-uart"; - reg = <0x12C00000 0x100>; - interrupts = <0 51 0>; - id = <0>; - }; - - serial@12C10000 { - compatible = "samsung,exynos4210-uart"; - reg = <0x12C10000 0x100>; - interrupts = <0 52 0>; - id = <1>; - }; - - serial@12C20000 { - compatible = "samsung,exynos4210-uart"; - reg = <0x12C20000 0x100>; - interrupts = <0 53 0>; - id = <2>; - }; - - serial@12C30000 { - compatible = "samsung,exynos4210-uart"; - reg = <0x12C30000 0x100>; - interrupts = <0 54 0>; - id = <3>; - }; - - gpio: gpio { - }; }; diff --git a/arch/arm/dts/exynos5420.dtsi b/arch/arm/dts/exynos5420.dtsi new file mode 100644 index 0000000..02ead61 --- /dev/null +++ b/arch/arm/dts/exynos5420.dtsi @@ -0,0 +1,70 @@ +/* + * (C) Copyright 2013 SAMSUNG Electronics + * SAMSUNG EXYNOS5420 SoC device tree source + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "exynos5.dtsi" + +/ { + config { + machine-arch-id = <4151>; + }; + + i2c@12ca0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12CA0000 0x100>; + interrupts = <0 60 0>; + }; + + i2c@12cb0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12CB0000 0x100>; + interrupts = <0 61 0>; + }; + + i2c@12cc0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12CC0000 0x100>; + interrupts = <0 62 0>; + }; + + i2c@12cd0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12CD0000 0x100>; + interrupts = <0 63 0>; + }; + + i2c@12e00000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12E00000 0x100>; + interrupts = <0 87 0>; + }; + + i2c@12e10000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12E10000 0x100>; + interrupts = <0 88 0>; + }; + + i2c@12e20000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos5-hsi2c"; + reg = <0x12E20000 0x100>; + interrupts = <0 203 0>; + }; +}; diff --git a/board/samsung/dts/exynos5420-smdk5420.dts b/board/samsung/dts/exynos5420-smdk5420.dts new file mode 100644 index 0000000..d739763 --- /dev/null +++ b/board/samsung/dts/exynos5420-smdk5420.dts @@ -0,0 +1,169 @@ +/* + * SAMSUNG SMDK5420 board device tree source + * + * Copyright (c) 2013 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos5420.dtsi" + +/ { + model = "SAMSUNG SMDK5420 board based on EXYNOS5420"; + compatible = "samsung,smdk5420", "samsung,exynos5"; + + config { + hwid = "smdk5420 TEST A-A 9382"; + }; + + aliases { + i2c0 = "/i2c@12c60000"; + i2c1 = "/i2c@12c70000"; + i2c2 = "/i2c@12c80000"; + i2c3 = "/i2c@12c90000"; + i2c4 = "/i2c@12ca0000"; + i2c5 = "/i2c@12cb0000"; + i2c6 = "/i2c@12cc0000"; + i2c7 = "/i2c@12cd0000"; + i2c8 = "/i2c@12e00000"; + i2c9 = "/i2c@12e10000"; + i2c10 = "/i2c@12e20000"; + spi0 = "/spi@12d20000"; + spi1 = "/spi@12d30000"; + spi2 = "/spi@12d40000"; + spi3 = "/spi@131a0000"; + spi4 = "/spi@131b0000"; + mmc0 = "/mmc@12200000"; + mmc1 = "/mmc@12210000"; + mmc2 = "/mmc@12220000"; + xhci0 = "/xhci@12000000"; + xhci1 = "/xhci@12400000"; + serial0 = "/serial@12C30000"; + console = "/serial@12C30000"; + }; + + tmu@10060000 { + samsung,min-temp = <25>; + samsung,max-temp = <125>; + samsung,start-warning = <95>; + samsung,start-tripping = <105>; + samsung,hw-tripping = <110>; + samsung,efuse-min-value = <40>; + samsung,efuse-value = <55>; + samsung,efuse-max-value = <100>; + samsung,slope = <274761730>; + samsung,dc-value = <25>; + }; + + /* s2mps11 is on i2c bus 4 */ + i2c@12ca0000 { + #address-cells = <1>; + #size-cells = <0>; + pmic@66 { + reg = <0x66>; + compatible = "samsung,s2mps11-pmic"; + }; + }; + + spi@12d20000 { /* spi0 */ + spi-max-frequency = <50000000>; + firmware_storage_spi: flash@0 { + reg = <0>; + }; + }; + + fimd@14400000 { + samsung,vl-freq = <60>; + samsung,vl-col = <2560>; + samsung,vl-row = <1600>; + samsung,vl-width = <2560>; + samsung,vl-height = <1600>; + + samsung,vl-clkp; + samsung,vl-dp; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <32>; + samsung,vl-hbpd = <80>; + samsung,vl-hfpd = <48>; + samsung,vl-vspw = <6>; + samsung,vl-vbpd = <37>; + samsung,vl-vfpd = <3>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <3>; + samsung,interface-mode = <1>; + samsung,dp-enabled = <1>; + samsung,dual-lcd-enabled = <0>; + }; + + sound@3830000 { + samsung,codec-type = "wm8994"; + }; + + i2c@12c70000 { + soundcodec@1a { + reg = <0x1a>; + compatible = "wolfson,wm8994-codec"; + }; + }; + + mmc@12200000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + samsung,removable = <0>; + samsung,pre-init; + }; + + mmc@12210000 { + status = "disabled"; + }; + + mmc@12220000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + samsung,removable = <1>; + }; + + mmc@12230000 { + status = "disabled"; + }; + + fimd@14400000 { + /* sysmmu is not used in U-Boot */ + samsung,disable-sysmmu; + }; + + dp@145b0000 { + samsung,lt-status = <0>; + + samsung,master-mode = <0>; + samsung,bist-mode = <0>; + samsung,bist-pattern = <0>; + samsung,h-sync-polarity = <0>; + samsung,v-sync-polarity = <0>; + samsung,interlaced = <0>; + samsung,color-space = <0>; + samsung,dynamic-range = <0>; + samsung,ycbcr-coeff = <0>; + samsung,color-depth = <1>; + }; + + dmc { + mem-type = "ddr3"; + }; + + xhci1: xhci@12400000 { + compatible = "samsung,exynos5250-xhci"; + reg = <0x12400000 0x10000>; + #address-cells = <1>; + #size-cells = <1>; + + phy { + compatible = "samsung,exynos5250-usb3-phy"; + reg = <0x12500000 0x100>; + }; + }; +};
Adding initial config for SMDK5420 to build and boot U-Boot over Exynos based SMDK5420.
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - Created a common exynos5-dt.h Changes in V5: - None Changes in V6: - None Chnages in V7: - Corrected the coding style nits. Changes in V8: - None Changes in V9: - Rebased on latest code. Changes in V10: - Rebased on latest code. Changes in V11: - None include/configs/exynos5-dt.h | 289 ++++++++++++++++++++++++++++++++++++++++ include/configs/exynos5250-dt.h | 286 +-------------------------------------- include/configs/smdk5420.h | 50 +++++++ 3 files changed, 346 insertions(+), 279 deletions(-) create mode 100644 include/configs/exynos5-dt.h create mode 100644 include/configs/smdk5420.h
diff --git a/include/configs/exynos5-dt.h b/include/configs/exynos5-dt.h new file mode 100644 index 0000000..4ca883d --- /dev/null +++ b/include/configs/exynos5-dt.h @@ -0,0 +1,289 @@ +/* + * Copyright (C) 2013 Samsung Electronics + * + * Configuration settings for the SAMSUNG EXYNOS5 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_S5P /* S5P Family */ +#define CONFIG_EXYNOS5 /* which is in a Exynos5 Family */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_COMMON +#define CONFIG_ARCH_EARLY_INIT_R +#define CONFIG_EXYNOS_SPL + +/* Enable fdt support for Exynos5250 */ +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +/* Allow tracing to be enabled */ +#define CONFIG_TRACE +#define CONFIG_CMD_TRACE +#define CONFIG_TRACE_BUFFER_SIZE (16 << 20) +#define CONFIG_TRACE_EARLY_SIZE (8 << 20) +#define CONFIG_TRACE_EARLY +#define CONFIG_TRACE_EARLY_ADDR 0x50000000 + +/* Keep L2 Cache Disabled */ +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_SYS_CACHELINE_SIZE 64 + +/* Enable ACE acceleration for SHA1 and SHA256 */ +#define CONFIG_EXYNOS_ACE_SHA +#define CONFIG_SHA_HW_ACCEL + +/* input clock of PLL: SMDK5250 has 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +/* Power Down Modes */ +#define S5P_CHECK_SLEEP 0x00000BAD +#define S5P_CHECK_DIDLE 0xBAD00000 +#define S5P_CHECK_LPA 0xABAD0000 + +/* Offset for inform registers */ +#define INFORM0_OFFSET 0x800 +#define INFORM1_OFFSET 0x804 +#define INFORM2_OFFSET 0x808 +#define INFORM3_OFFSET 0x80c + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (4 << 20)) + +/* select serial console configuration */ +#define CONFIG_BAUDRATE 115200 +#define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 +#define CONFIG_SILENT_CONSOLE + +/* Enable keyboard */ +#define CONFIG_CROS_EC /* CROS_EC protocol */ +#define CONFIG_CROS_EC_SPI /* Support CROS_EC over SPI */ +#define CONFIG_CROS_EC_I2C /* Support CROS_EC over I2C */ +#define CONFIG_CROS_EC_KEYB /* CROS_EC keyboard input */ +#define CONFIG_CMD_CROS_EC +#define CONFIG_KEYBOARD + +/* Console configuration */ +#define CONFIG_CONSOLE_MUX +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define EXYNOS_DEVICE_SETTINGS \ + "stdin=serial,cros-ec-keyb\0" \ + "stdout=serial,lcd\0" \ + "stderr=serial,lcd\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXYNOS_DEVICE_SETTINGS + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_SDHCI +#define CONFIG_S5P_SDHCI +#define CONFIG_DWMMC +#define CONFIG_EXYNOS_DWMMC +#define CONFIG_SUPPORT_EMMC_BOOT + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* PWM */ +#define CONFIG_PWM + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_ELF +#define CONFIG_CMD_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_NET +#define CONFIG_CMD_HASH + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +/* Thermal Management Unit */ +#define CONFIG_EXYNOS_TMU +#define CONFIG_CMD_DTT +#define CONFIG_TMU_CMD_DTT + +/* TPM */ +#define CONFIG_TPM +#define CONFIG_CMD_TPM +#define CONFIG_TPM_TIS_I2C +#define CONFIG_TPM_TIS_I2C_BUS_NUMBER 3 +#define CONFIG_TPM_TIS_I2C_SLAVE_ADDR 0x20 + +/* MMC SPL */ +#define CONFIG_SPL +#define COPY_BL2_FNPTR_ADDR 0x02020030 + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT + +/* specific .lds file */ +#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" +#define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024) + + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) + +#define CONFIG_RD_LVL + +#define CONFIG_NR_DRAM_BANKS 8 +#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) +#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_5 (CONFIG_SYS_SDRAM_BASE + (4 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_5_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_6 (CONFIG_SYS_SDRAM_BASE + (5 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_6_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_7 (CONFIG_SYS_SDRAM_BASE + (6 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_7_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_8 (CONFIG_SYS_SDRAM_BASE + (7 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_8_SIZE SDRAM_BANK_SIZE + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_SECURE_BL1_ONLY + +/* Secure FW size configuration */ +#ifdef CONFIG_SECURE_BL1_ONLY +#define CONFIG_SEC_FW_SIZE (8 << 10) /* 8KB */ +#else +#define CONFIG_SEC_FW_SIZE 0 +#endif + +/* Configuration of BL1, BL2, ENV Blocks on mmc */ +#define CONFIG_RES_BLOCK_SIZE (512) +#define CONFIG_BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#define CONFIG_BL2_SIZE (512UL << 10UL) /* 512 KB */ +#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ + +#define CONFIG_BL1_OFFSET (CONFIG_RES_BLOCK_SIZE + CONFIG_SEC_FW_SIZE) +#define CONFIG_BL2_OFFSET (CONFIG_BL1_OFFSET + CONFIG_BL1_SIZE) +#define CONFIG_ENV_OFFSET (CONFIG_BL2_OFFSET + CONFIG_BL2_SIZE) + +/* U-boot copy size from boot Media to DRAM.*/ +#define BL2_START_OFFSET (CONFIG_BL2_OFFSET/512) +#define BL2_SIZE_BLOC_COUNT (CONFIG_BL2_SIZE/512) + +#define CONFIG_SPI_BOOTING +#define EXYNOS_COPY_SPI_FNPTR_ADDR 0x02020058 +#define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE) + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_PART +#define CONFIG_PARTITION_UUIDS + +/* I2C */ +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_HARD_I2C +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 Kbps */ +#define CONFIG_DRIVER_S3C24X0_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_I2C_EDID + +/* SPI */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_SPI_FLASH +#define CONFIG_ENV_SPI_BASE 0x12D30000 + +#ifdef CONFIG_SPI_FLASH +#define CONFIG_EXYNOS_SPI +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_SPI_FLASH_GIGADEVICE +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 50000000 +#define EXYNOS5_SPI_NUM_CONTROLLERS 5 +#endif + +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_MODE SPI_MODE_0 +#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE +#define CONFIG_ENV_SPI_BUS 1 +#define CONFIG_ENV_SPI_MAX_HZ 50000000 +#endif + +/* PMIC */ +#define CONFIG_POWER +#define CONFIG_POWER_I2C + +/* Ethernet Controllor Driver */ +#ifdef CONFIG_CMD_NET +#define CONFIG_SMC911X +#define CONFIG_SMC911X_BASE 0x5000000 +#define CONFIG_SMC911X_16_BIT +#define CONFIG_ENV_SROM_BANK 1 +#endif /*CONFIG_CMD_NET*/ + +/* Enable PXE Support */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_PXE +#define CONFIG_MENU +#endif + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +/* SHA hashing */ +#define CONFIG_CMD_HASH +#define CONFIG_HASH_VERIFY +#define CONFIG_SHA1 +#define CONFIG_SHA256 + +/* Enable Time Command */ +#define CONFIG_CMD_TIME + +#define CONFIG_CMD_BOOTZ + +#endif /* __CONFIG_H */ diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 51b2623..615df64 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -1,3 +1,4 @@ + /* * Copyright (C) 2012 Samsung Electronics * @@ -6,134 +7,19 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_5250_H +#define __CONFIG_5250_H
-/* High Level Configuration Options */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* S5P Family */ -#define CONFIG_EXYNOS5 /* which is in a Exynos5 Family */ +#include <configs/exynos5-dt.h> #define CONFIG_EXYNOS5250
-#include <asm/arch/cpu.h> /* get chip and board defs */ - -#define CONFIG_SYS_GENERIC_BOARD -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_COMMON -#define CONFIG_ARCH_EARLY_INIT_R - -/* Enable fdt support for Exynos5250 */ -#define CONFIG_OF_CONTROL -#define CONFIG_OF_SEPARATE - -/* Allow tracing to be enabled */ -#define CONFIG_TRACE -#define CONFIG_CMD_TRACE -#define CONFIG_TRACE_BUFFER_SIZE (16 << 20) -#define CONFIG_TRACE_EARLY_SIZE (8 << 20) -#define CONFIG_TRACE_EARLY -#define CONFIG_TRACE_EARLY_ADDR 0x50000000 - -/* Keep L2 Cache Disabled */ -#define CONFIG_SYS_DCACHE_OFF - -#define CONFIG_SYS_CACHELINE_SIZE 64 - -/* Enable ACE acceleration for SHA1 and SHA256 */ -#define CONFIG_EXYNOS_ACE_SHA -#define CONFIG_SHA_HW_ACCEL - #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_TEXT_BASE 0x43E00000
-/* input clock of PLL: SMDK5250 has 24MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 24000000 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING - /* MACH_TYPE_SMDK5250 macro will be removed once added to mach-types */ #define MACH_TYPE_SMDK5250 3774 #define CONFIG_MACH_TYPE MACH_TYPE_SMDK5250
-/* Power Down Modes */ -#define S5P_CHECK_SLEEP 0x00000BAD -#define S5P_CHECK_DIDLE 0xBAD00000 -#define S5P_CHECK_LPA 0xABAD0000 - -/* Offset for inform registers */ -#define INFORM0_OFFSET 0x800 -#define INFORM1_OFFSET 0x804 - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (4 << 20)) - -/* select serial console configuration */ -#define CONFIG_BAUDRATE 115200 -#define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 -#define CONFIG_SILENT_CONSOLE - -/* Enable keyboard */ -#define CONFIG_CROS_EC /* CROS_EC protocol */ -#define CONFIG_CROS_EC_SPI /* Support CROS_EC over SPI */ -#define CONFIG_CROS_EC_I2C /* Support CROS_EC over I2C */ -#define CONFIG_CROS_EC_KEYB /* CROS_EC keyboard input */ -#define CONFIG_CMD_CROS_EC -#define CONFIG_KEYBOARD - -/* Console configuration */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define EXYNOS_DEVICE_SETTINGS \ - "stdin=serial,cros-ec-keyb\0" \ - "stdout=serial,lcd\0" \ - "stderr=serial,lcd\0" - -#define CONFIG_EXTRA_ENV_SETTINGS \ - EXYNOS_DEVICE_SETTINGS - -/* SD/MMC configuration */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI -#define CONFIG_DWMMC -#define CONFIG_EXYNOS_DWMMC -#define CONFIG_SUPPORT_EMMC_BOOT - - -#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_SKIP_LOWLEVEL_INIT - -/* PWM */ -#define CONFIG_PWM - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* Command definition*/ -#include <config_cmd_default.h> - -#define CONFIG_CMD_PING -#define CONFIG_CMD_ELF -#define CONFIG_CMD_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_NET -#define CONFIG_CMD_HASH - -#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK - -/* Thermal Management Unit */ -#define CONFIG_EXYNOS_TMU -#define CONFIG_CMD_DTT -#define CONFIG_TMU_CMD_DTT - /* USB */ #define CONFIG_CMD_USB #define CONFIG_USB_XHCI @@ -147,168 +33,20 @@ #define EXYNOS_USB_SECONDARY_BOOT 0xfeed0002 #define EXYNOS_IRAM_SECONDARY_BASE 0x02020018
-/* TPM */ -#define CONFIG_TPM -#define CONFIG_CMD_TPM -#define CONFIG_TPM_TIS_I2C -#define CONFIG_TPM_TIS_I2C_BUS_NUMBER 3 -#define CONFIG_TPM_TIS_I2C_SLAVE_ADDR 0x20 - -/* MMC SPL */ -#define CONFIG_EXYNOS_SPL -#define CONFIG_SPL -#define COPY_BL2_FNPTR_ADDR 0x02020030 - -#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_GPIO_SUPPORT - -/* specific .lds file */ -#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_TEXT_BASE 0x02023400 -#define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024)
#define CONFIG_BOOTCOMMAND "mmc read 40007000 451 2000; bootm 40007000"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_PROMPT "SMDK5250 # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) - -#define CONFIG_RD_LVL - -#define CONFIG_NR_DRAM_BANKS 8 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_5 (CONFIG_SYS_SDRAM_BASE + (4 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_5_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_6 (CONFIG_SYS_SDRAM_BASE + (5 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_6_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_7 (CONFIG_SYS_SDRAM_BASE + (6 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_7_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_8 (CONFIG_SYS_SDRAM_BASE + (7 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_8_SIZE SDRAM_BANK_SIZE - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 - -/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH -#undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for SMDK5250"
-#define CONFIG_SYS_MMC_ENV_DEV 0 - -#define CONFIG_SECURE_BL1_ONLY - -/* Secure FW size configuration */ -#ifdef CONFIG_SECURE_BL1_ONLY -#define CONFIG_SEC_FW_SIZE (8 << 10) /* 8KB */ -#else -#define CONFIG_SEC_FW_SIZE 0 -#endif - -/* Configuration of BL1, BL2, ENV Blocks on mmc */ -#define CONFIG_RES_BLOCK_SIZE (512) -#define CONFIG_BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ -#define CONFIG_BL2_SIZE (512UL << 10UL) /* 512 KB */ -#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ - -#define CONFIG_BL1_OFFSET (CONFIG_RES_BLOCK_SIZE + CONFIG_SEC_FW_SIZE) -#define CONFIG_BL2_OFFSET (CONFIG_BL1_OFFSET + CONFIG_BL1_SIZE) -#define CONFIG_ENV_OFFSET (CONFIG_BL2_OFFSET + CONFIG_BL2_SIZE) - -/* U-boot copy size from boot Media to DRAM.*/ -#define BL2_START_OFFSET (CONFIG_BL2_OFFSET/512) -#define BL2_SIZE_BLOC_COUNT (CONFIG_BL2_SIZE/512) - -#define CONFIG_SPI_BOOTING -#define EXYNOS_COPY_SPI_FNPTR_ADDR 0x02020058 -#define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE) - -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION -#define CONFIG_CMD_PART -#define CONFIG_PARTITION_UUIDS - - #define CONFIG_IRAM_STACK 0x02050000
#define CONFIG_SYS_INIT_SP_ADDR CONFIG_IRAM_STACK
-/* I2C */ -#define CONFIG_SYS_I2C_INIT_BOARD -#define CONFIG_HARD_I2C -#define CONFIG_CMD_I2C -#define CONFIG_SYS_I2C_SPEED 100000 /* 100 Kbps */ -#define CONFIG_DRIVER_S3C24X0_I2C -#define CONFIG_I2C_MULTI_BUS -#define CONFIG_MAX_I2C_NUM 8 -#define CONFIG_SYS_I2C_SLAVE 0x0 -#define CONFIG_I2C_EDID - /* PMIC */ -#define CONFIG_PMIC -#define CONFIG_PMIC_I2C #define CONFIG_PMIC_MAX77686
-/* SPI */ -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_SPI_FLASH -#define CONFIG_ENV_SPI_BASE 0x12D30000 - -#ifdef CONFIG_SPI_FLASH -#define CONFIG_EXYNOS_SPI -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_SPI_FLASH_WINBOND -#define CONFIG_SPI_FLASH_GIGADEVICE -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SF_DEFAULT_SPEED 50000000 -#define EXYNOS5_SPI_NUM_CONTROLLERS 5 -#endif - -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SPI_MODE SPI_MODE_0 -#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -#define CONFIG_ENV_SPI_BUS 1 -#define CONFIG_ENV_SPI_MAX_HZ 50000000 -#endif - -/* PMIC */ -#define CONFIG_POWER -#define CONFIG_POWER_I2C -#define CONFIG_POWER_MAX77686 - -/* Ethernet Controllor Driver */ -#ifdef CONFIG_CMD_NET -#define CONFIG_SMC911X -#define CONFIG_SMC911X_BASE 0x5000000 -#define CONFIG_SMC911X_16_BIT -#define CONFIG_ENV_SROM_BANK 1 -#endif /*CONFIG_CMD_NET*/ - -/* Enable PXE Support */ -#ifdef CONFIG_CMD_NET -#define CONFIG_CMD_PXE -#define CONFIG_MENU -#endif - /* Sound */ #define CONFIG_CMD_SOUND #ifdef CONFIG_CMD_SOUND @@ -318,14 +56,8 @@ #define CONFIG_SOUND_WM8994 #endif
-/* Enable devicetree support */ -#define CONFIG_OF_LIBFDT - -/* SHA hashing */ -#define CONFIG_CMD_HASH -#define CONFIG_HASH_VERIFY -#define CONFIG_SHA1 -#define CONFIG_SHA256 +/* I2C */ +#define CONFIG_MAX_I2C_NUM 8
/* Display */ #define CONFIG_LCD @@ -336,8 +68,4 @@ #define LCD_YRES 1600 #define LCD_BPP LCD_COLOR16 #endif - -/* Enable Time Command */ -#define CONFIG_CMD_TIME - -#endif /* __CONFIG_H */ +#endif /* __CONFIG_5250_H */ diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h new file mode 100644 index 0000000..9eab7d6 --- /dev/null +++ b/include/configs/smdk5420.h @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2013 Samsung Electronics + * + * Configuration settings for the SAMSUNG EXYNOS5420 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_5420_H +#define __CONFIG_5420_H + +#include <configs/exynos5-dt.h> + +#define CONFIG_EXYNOS5420 /* which is in a Exynos5 Family */ +#define CONFIG_SMDK5420 /* which is in a SMDK5420 */ + +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos5420-smdk5420 + +#define CONFIG_ARCH_DEVICE_TREE exynos5420 + +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_TEXT_BASE 0x23E00000 + +#define CONFIG_BOARD_REV_GPIO_COUNT 2 + +/* MACH_TYPE_SMDK5420 macro will be removed once added to mach-types */ +#define MACH_TYPE_SMDK5420 8002 /* Temporary number */ +#define CONFIG_MACH_TYPE MACH_TYPE_SMDK5420 + +/* select serial console configuration */ +#define CONFIG_SERIAL3 /* use SERIAL 3 */ + +#define CONFIG_SPL_TEXT_BASE 0x02024400 + +#define CONFIG_BOOTCOMMAND "mmc read 20007000 451 2000; bootm 20007000" + +#define CONFIG_SYS_PROMPT "SMDK5420 # " +#define CONFIG_IDENT_STRING " for SMDK5420" + +#define CONFIG_IRAM_TOP 0x02074000 +/* + * Put the initial stack pointer 1KB below this to allow room for the + * SPL marker. This value is arbitrary, but gd_t is placed starting here. + */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_IRAM_TOP - 0x800) + +#define CONFIG_MAX_I2C_NUM 11 + +#endif /* __CONFIG_5420_H */
When variable size SPL is used, the BL1 expects the SPL to be encapsulated differently: instead of putting the checksum at a fixed offset in the SPL blob, prepend the blob with a header including the size and the checksum.
The enhancements include - adding a command line option, '--vs' to indicate the need for the variable size encapsulation - padding the fixed size encapsulated blob with 0xff instead of random memory contents - do not silently truncate the input file, report error instead - no need to explicitly closing files/freeing memory, this all happens on exit; removing cleanups it makes code clearer - profuse commenting - modify Makefile to allow enabling the new feature per board
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - Created a common exynos5-dt.h Changes in V5: - None Changes in V6: - None. Changes in V7: - None. Changes in V8: - None Changes in V9: - Rebased on latest code. Changes in V10: - None Changes in V11: - Rebased on latest code. include/configs/smdk5420.h | 6 ++ spl/Makefile | 7 +- tools/mkexynosspl.c | 167 +++++++++++++++++++++++++++++++++------------ 3 files changed, 136 insertions(+), 44 deletions(-)
diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index 9eab7d6..447f8e5 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -19,6 +19,8 @@
+#define CONFIG_VAR_SIZE_SPL + #define CONFIG_SYS_SDRAM_BASE 0x20000000 #define CONFIG_SYS_TEXT_BASE 0x23E00000
@@ -31,7 +33,11 @@ /* select serial console configuration */ #define CONFIG_SERIAL3 /* use SERIAL 3 */
+#ifdef CONFIG_VAR_SIZE_SPL +#define CONFIG_SPL_TEXT_BASE 0x02024410 +#else #define CONFIG_SPL_TEXT_BASE 0x02024400 +#endif
diff --git a/spl/Makefile b/spl/Makefile index 2a787af..0caa982 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -166,8 +166,13 @@ endif all: $(ALL-y)
ifdef CONFIG_SAMSUNG +ifdef CONFIG_VAR_SIZE_SPL +VAR_SIZE_PARAM = --vs +else +VAR_SIZE_PARAM = +endif $(obj)$(BOARD)-spl.bin: $(obj)u-boot-spl.bin - $(OBJTREE)/tools/mk$(BOARD)spl $< $@ + $(OBJTREE)/tools/mk$(BOARD)spl $(VAR_SIZE_PARAM) $< $@ endif
$(obj)$(SPL_BIN).bin: $(obj)$(SPL_BIN) diff --git a/tools/mkexynosspl.c b/tools/mkexynosspl.c index ef685b7..32b786c 100644 --- a/tools/mkexynosspl.c +++ b/tools/mkexynosspl.c @@ -14,93 +14,174 @@ #include <compiler.h>
#define CHECKSUM_OFFSET (14*1024-4) -#define BUFSIZE (14*1024) #define FILE_PERM (S_IRUSR | S_IWUSR | S_IRGRP \ | S_IWGRP | S_IROTH | S_IWOTH) /* -* Requirement: -* IROM code reads first 14K bytes from boot device. -* It then calculates the checksum of 14K-4 bytes and compare with data at -* 14K-4 offset. -* -* This function takes two filenames: -* IN "u-boot-spl.bin" and -* OUT "$(BOARD)-spl.bin as filenames. -* It reads the "u-boot-spl.bin" in 16K buffer. -* It calculates checksum of 14K-4 Bytes and stores at 14K-4 offset in buffer. -* It writes the buffer to "$(BOARD)-spl.bin" file. -*/ + * Requirement for the fixed size SPL header: + * IROM code reads first (CHECKSUM_OFFSET + 4) bytes from boot device. It then + * calculates the checksum of CHECKSUM_OFFSET bytes and compares with data at + * CHECKSUM_OFFSET location. + * + * Requirement for the variable size SPL header: + + * IROM code reads the below header to find out the size of the blob (total + * size, header size included) and its checksum. Then it reads the rest of the + * blob [i.e size - sizeof(struct var_size_header) bytes], calculates the + * checksum and compares it with value read from the header. + */ +struct var_size_header { + uint32_t spl_size; + uint32_t spl_checksum; + uint32_t reserved[2]; +}; + +static const char *prog_name; + +static void write_to_file(int ofd, void *buffer, int size) +{ + if (write(ofd, buffer, size) == size) + return; + + fprintf(stderr, "%s: Failed to write to output file: %s\n", + prog_name, strerror(errno)); + exit(EXIT_FAILURE); +}
+/* + * The argv is expected to include one optional parameter and two filenames: + * [--vs] IN OUT + * + * --vs - turns on the variable size SPL mode + * IN - the u-boot SPL binary, usually u-boot-spl.bin + * OUT - the prepared SPL blob, usually ${BOARD}-spl.bin + * + * This utility first reads the "u-boot-spl.bin" into a buffer. In case of + * fixed size SPL the buffer size is exactly CHECKSUM_OFFSET (such that + * smaller u-boot-spl.bin gets padded with 0xff bytes, the larger than limit + * u-boot-spl.bin causes an error). For variable size SPL the buffer size is + * eqaul to size of the IN file. + * + * Then it calculates checksum of the buffer by just summing up all bytes. + * Then + * + * - for fixed size SPL the buffer is written into the output file and the + * checksum is appended to the file in little endian format, which results + * in checksum added exactly at CHECKSUM_OFFSET. + * + * - for variable size SPL the checksum and file size are stored in the + * var_size_header structure (again, in little endian format) and the + * structure is written into the output file. Then the buffer is written + * into the output file. + */ int main(int argc, char **argv) { - unsigned char buffer[BUFSIZE]; + unsigned char *buffer; int i, ifd, ofd; uint32_t checksum = 0; off_t len; - ssize_t count; + int var_size_flag, read_size, count; struct stat stat; - - if (argc != 3) { - fprintf(stderr, "Usage: %s <infile> <outfile>\n", argv[0]); + const int if_index = argc - 2; /* Input file name index in argv. */ + const int of_index = argc - 1; /* Output file name index in argv. */ + + /* Strip path off the program name. */ + prog_name = strrchr(argv[0], '/'); + if (prog_name) + prog_name++; + else + prog_name = argv[0]; + + if ((argc < 3) || + (argc > 4) || + ((argc == 4) && strcmp(argv[1], "--vs"))) { + fprintf(stderr, "Usage: %s [--vs] <infile> <outfile>\n", + prog_name); exit(EXIT_FAILURE); }
- ifd = open(argv[1], O_RDONLY); + /* four args mean variable size SPL wrapper is required */ + var_size_flag = (argc == 4); + + ifd = open(argv[if_index], O_RDONLY); if (ifd < 0) { fprintf(stderr, "%s: Can't open %s: %s\n", - argv[0], argv[1], strerror(errno)); + prog_name, argv[if_index], strerror(errno)); exit(EXIT_FAILURE); }
- ofd = open(argv[2], O_WRONLY | O_CREAT | O_TRUNC, FILE_PERM); + ofd = open(argv[of_index], O_WRONLY | O_CREAT | O_TRUNC, FILE_PERM); if (ifd < 0) { fprintf(stderr, "%s: Can't open %s: %s\n", - argv[0], argv[2], strerror(errno)); - close(ifd); + prog_name, argv[of_index], strerror(errno)); exit(EXIT_FAILURE); }
if (fstat(ifd, &stat)) { fprintf(stderr, "%s: Unable to get size of %s: %s\n", - argv[0], argv[1], strerror(errno)); - close(ifd); - close(ofd); + prog_name, argv[if_index], strerror(errno)); exit(EXIT_FAILURE); }
len = stat.st_size;
- count = (len < CHECKSUM_OFFSET) ? len : CHECKSUM_OFFSET; - - if (read(ifd, buffer, count) != count) { - fprintf(stderr, "%s: Can't read %s: %s\n", - argv[0], argv[1], strerror(errno)); + if (var_size_flag) { + read_size = len; + count = len; + } else { + if (len > CHECKSUM_OFFSET) { + fprintf(stderr, + "%s: %s is too big (exceeds %d bytes)\n", + prog_name, argv[if_index], CHECKSUM_OFFSET); + exit(EXIT_FAILURE); + } + count = CHECKSUM_OFFSET; + read_size = len; + }
- close(ifd); - close(ofd); + buffer = malloc(count); + if (!buffer) { + fprintf(stderr, + "%s: Failed to allocate %d bytes to store %s\n", + prog_name, count, argv[if_index]); + exit(EXIT_FAILURE); + }
+ if (read(ifd, buffer, read_size) != read_size) { + fprintf(stderr, "%s: Can't read %s: %s\n", + prog_name, argv[if_index], strerror(errno)); exit(EXIT_FAILURE); }
- for (i = 0, checksum = 0; i < CHECKSUM_OFFSET; i++) - checksum += buffer[i]; + /* Pad if needed with 0xff to make flashing faster. */ + if (read_size < count) + memset((char *)buffer + read_size, 0xff, count - read_size);
+ for (i = 0, checksum = 0; i < count; i++) + checksum += buffer[i]; checksum = cpu_to_le32(checksum);
- memcpy(&buffer[CHECKSUM_OFFSET], &checksum, sizeof(checksum)); - - if (write(ofd, buffer, BUFSIZE) != BUFSIZE) { - fprintf(stderr, "%s: Can't write %s: %s\n", - argv[0], argv[2], strerror(errno)); + if (var_size_flag) { + /* Prepare and write out the variable size SPL header. */ + struct var_size_header vsh; + uint32_t spl_size;
- close(ifd); - close(ofd); + memset(&vsh, 0, sizeof(vsh)); + memcpy(&vsh.spl_checksum, &checksum, sizeof(checksum));
- exit(EXIT_FAILURE); + spl_size = cpu_to_le32(count + sizeof(struct var_size_header)); + memcpy(&vsh.spl_size, &spl_size, sizeof(spl_size)); + write_to_file(ofd, &vsh, sizeof(vsh)); }
+ write_to_file(ofd, buffer, count); + + /* For fixed size SPL checksum is appended in the end. */ + if (!var_size_flag) + write_to_file(ofd, &checksum, sizeof(checksum)); + close(ifd); close(ofd); + free(buffer);
return EXIT_SUCCESS; }
Hi Minkyu,
Can we please, get these patches reviewed and merged.
Regards, Rajeshwari.
On Mon, Dec 16, 2013 at 2:12 PM, Rajeshwari S Shinde rajeshwari.s@samsung.com wrote:
This patch adds basic board support for SMDK5420 board. These patches are tested for booting fine on EVT1 SMDK5420.
Changes in V2: - Corrected a compilation issue for SMDK5420.
Changes in V3: - Add patch to support variable size SPL support - Add patch to disable SMU for eMMC.
Changes in V4: - Added check for MAX77686 pmic compilation. - Added correct calculation of gpio based addresses. - Rebased on the latest u-boot code. - Removed patches for UART and TZPC changes as they were not needed. - Added flag to disable SMU for eMMC.
Changes in V5: - Moved functions board_mmc_init and board_eth_init to common/board.c in case of device tree support.
Changes in V6: - Rebased on the latest mainline branch. - Moved the definitions for SMU to arch/arm dwmmc.h
Changes in V7: - Removed below patch as it is already merged "DWMMC: SMDK5420: Disable SMU for eMMC" - Corrected the multi line comments and removal of blank spaces and lines. - Corrected the license.
Changes in V8: - corrected the if loops with if conditions of pro_id and cpu_id.
Changes in V9: - Added macros to get the base address - Rebased on latest code.
Changes in V10: - Added new structures for Power and DMC registers for 5420. - Changed the input parameters for common dmc functions. - Removed unnecesarry blank lines and added where ever required.
Changes in V11: -Rebased on latest u-boot-samsung branch.
Rajeshwari S Shinde (11): EXYNOS5: Create a common board file Exynos5420: Add base addresses for 5420 EXYNOS5420: Add power register structure. EXYNOS5420: Add dmc and phy_control register structure Exynos5420: Add clock initialization for 5420 Exynos5420: Add DDR3 initialization for 5420 Exynos5420: Add support for 5420 in pinmux and gpio Exynos5420: Add base patch for SMDK5420 DTS: Add dts support for SMDK5420 Config: Add initial config for SMDK5420 SPL: EXYNOS: Prepare for variable size SPL support
arch/arm/cpu/armv7/exynos/clock.c | 279 ++++++++- arch/arm/cpu/armv7/exynos/clock_init.h | 17 + arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 352 ++++++++++- arch/arm/cpu/armv7/exynos/dmc_common.c | 60 +- arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 439 ++++++++++++- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 764 ++++++++++++++++------ arch/arm/cpu/armv7/exynos/pinmux.c | 260 +++++++- arch/arm/dts/exynos5.dtsi | 198 ++++++ arch/arm/dts/exynos5250.dtsi | 194 +----- arch/arm/dts/exynos5420.dtsi | 70 +++ arch/arm/include/asm/arch-exynos/board.h | 17 + arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/clock.h | 494 +++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 52 +- arch/arm/include/asm/arch-exynos/dmc.h | 177 ++++++ arch/arm/include/asm/arch-exynos/gpio.h | 143 ++++- arch/arm/include/asm/arch-exynos/periph.h | 3 + arch/arm/include/asm/arch-exynos/power.h | 837 +++++++++++++++++++++++++ board/samsung/common/Makefile | 4 + board/samsung/common/board.c | 410 ++++++++++++ board/samsung/dts/exynos5420-smdk5420.dts | 169 +++++ board/samsung/smdk5250/exynos5-dt.c | 352 +---------- board/samsung/smdk5250/smdk5250.c | 182 +----- board/samsung/smdk5420/Makefile | 11 + board/samsung/smdk5420/smdk5420.c | 159 +++++ board/samsung/smdk5420/smdk5420_spl.c | 52 ++ boards.cfg | 1 + include/configs/arndale.h | 1 + include/configs/exynos5-dt.h | 289 +++++++++ include/configs/exynos5250-dt.h | 283 +-------- include/configs/smdk5420.h | 56 ++ spl/Makefile | 7 +- tools/Makefile | 3 +- tools/mkexynosspl.c | 167 +++-- 34 files changed, 5188 insertions(+), 1315 deletions(-) create mode 100644 arch/arm/dts/exynos5.dtsi create mode 100644 arch/arm/dts/exynos5420.dtsi create mode 100644 arch/arm/include/asm/arch-exynos/board.h create mode 100644 board/samsung/common/board.c create mode 100644 board/samsung/dts/exynos5420-smdk5420.dts create mode 100644 board/samsung/smdk5420/Makefile create mode 100644 board/samsung/smdk5420/smdk5420.c create mode 100644 board/samsung/smdk5420/smdk5420_spl.c create mode 100644 include/configs/exynos5-dt.h create mode 100644 include/configs/smdk5420.h
-- 1.7.12.4
On 17 December 2013 22:10, Rajeshwari Birje rajeshwari.birje@gmail.com wrote:
Hi Minkyu,
It would certainly help to get this done soon.
Rajeshwari Birje
Rajeshwari S Shinde
