[U-Boot-Users] ethernet on FCC
Hi: While tring to bring up my mpc8270 based board, I found out the u-boot is not receiving packets (It's sending correct packet when i use ethereal for sniffing). When trying "ping", it generated an ARP packet first, the other host replied with , but the board never seems to receive it. When digging into the code, in cpu/mpc8260/ether_fcc.c file, it tries to initialize the parameter ram by :
pram_ptr = (fcc_enet_t *)&(immr->im_dprambase[info->proff_enet]);
However, I can't seems to find where the info->proff_enet got initialized. I am using u-boot-1.1.4, but the 1.1.6 code does the same thing. The ether_scc.c file seems doing the right thing, because it defined PROFF_ENET as a macro.
A bug ?
Another thing, I loaded the uImage into memory using JTAG, but the "bootm" command failed when it tries to uncompressing the kernel, error message is "inflate() returned -3". I am running u-boot in ram directly , not from the flash, I have found some posts which saids if u-boot is running from RAM, it can't uncompressing the kernel, but without any explaination on why.
Thanks lei
In message f9a7e7a80611080907tb85267cr136d624bcb7daa91@mail.gmail.com you wrote:
Check your memopry map. You might have loaded the kernel (and/or U-Boot) to a too low address.
No, this is wrong. If you manage to get U-Boot starting from RAM, and it is working correctly, then it can boot and uncompress kernel images, too.
Lei Sun
