[U-Boot] [PATCH] i.mx: i.mx5: update imx_get_mac_from_fuse function
FEC does not work on the i.mx51/53evk board, it will hangup In: serial Out: serial Err: serial Net:
After bisect, it due to the following commit: be252b6 net: imx: Add multi-FEC support for imx_get_mac_from_fuse has change the imx_get_mac_from_fuse fucntion prototype, but fail to update i.mx5, here it does it.
After apply this patch, u-boot works again on i.mx51/53 evk boards.
Signed-off-by: Jason Liu jason.hui@linaro.org Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/mx5/soc.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/soc.c b/arch/arm/cpu/armv7/mx5/soc.c index 1533dd8..3f5a4f7 100644 --- a/arch/arm/cpu/armv7/mx5/soc.c +++ b/arch/arm/cpu/armv7/mx5/soc.c @@ -72,7 +72,7 @@ u32 get_cpu_rev(void) }
#if defined(CONFIG_FEC_MXC) -void imx_get_mac_from_fuse(unsigned char *mac) +void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) { int i; struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE;
Acked-by: Fabio Estevam fabio.estevam@freescale.com
Acked-by: Stefano Babic sbabic@denx.de
Thanks for fixing !
Best regards, Stefano Babic
Applied to u-boot-imx, thanks.
Fabio Estevam
Jason Liu
Stefano Babic
