[U-Boot] Pull request: nand flash
Note that as discussed at http://patchwork.ozlabs.org/patch/296730/ the "cosmetic" patch is fixing a significant readability regression -- the current indentation is misleading as to the code flow.
The following changes since commit fd44194945714a478fab6407c04453caaef0bac9:
Prepare v2014.01-rc2 (2013-12-16 13:07:05 -0500)
git://git.denx.de/u-boot-nand-flash.git
for you to fetch changes up to 72bb956551ecd592bcf0e6468476f31db86d9361:
powerpc/cms700: limit NAND data structure size (2013-12-17 22:06:05 -0600)
---------------------------------------------------------------- Nikita Kiryanov (3): mtd: nand: omap: fix HAM1_SW ecc using default value for ecc.size mtd: nand: omap: fix sw->hw->sw ecc switch mtd: nand: omap: fix ecc ops assignment when changing ecc
Scott Wood (1): powerpc/cms700: limit NAND data structure size
Stefan Roese (1): mtd: nand: omap_gpmc: cosmetic: Fix indentation
Tom Rini (1): nand_util.c: Use '%zd' for length in nand_unlock debug print
pekon gupta (1): mtd: nand: omap: fix ecc-layout for HAM1 ecc-scheme
drivers/mtd/nand/nand_util.c | 2 +- drivers/mtd/nand/omap_gpmc.c | 108 ++++++++++++++++++++++++------------------- include/configs/CMS700.h | 3 ++ 3 files changed, 65 insertions(+), 48 deletions(-)
Scott Wood
