[U-Boot] [PATCH] Devkit8000: Switch over to enable_gpmc_cs_config
Use enable_gpmc_cs_config instead of local writing timing configuration for GPMC.
Signed-off-by: Thomas Weber weber@corscience.de --- board/timll/devkit8000/devkit8000.c | 19 ++++++++++++------- 1 files changed, 12 insertions(+), 7 deletions(-)
diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index bcadfc4..dd46c35 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -48,6 +48,16 @@
DECLARE_GLOBAL_DATA_PTR;
+static u32 gpmc_net_config[GPMC_MAX_REG] = { + NET_GPMC_CONFIG1, + NET_GPMC_CONFIG2, + NET_GPMC_CONFIG3, + NET_GPMC_CONFIG4, + NET_GPMC_CONFIG5, + NET_GPMC_CONFIG6, + NET_GPMC_CONFIG7, +}; + /* * Routine: board_init * Description: Early hardware init. @@ -82,13 +92,8 @@ int misc_init_r(void)
#ifdef CONFIG_DRIVER_DM9000 /* Configure GPMC registers for DM9000 */ - writel(NET_GPMC_CONFIG1, &gpmc_cfg->cs[6].config1); - writel(NET_GPMC_CONFIG2, &gpmc_cfg->cs[6].config2); - writel(NET_GPMC_CONFIG3, &gpmc_cfg->cs[6].config3); - writel(NET_GPMC_CONFIG4, &gpmc_cfg->cs[6].config4); - writel(NET_GPMC_CONFIG5, &gpmc_cfg->cs[6].config5); - writel(NET_GPMC_CONFIG6, &gpmc_cfg->cs[6].config6); - writel(NET_GPMC_CONFIG7, &gpmc_cfg->cs[6].config7); + enable_gpmc_cs_config(gpmc_net_config, &gpmc_cfg->cs[6], + CONFIG_DM9000_BASE, GPMC_SIZE_16M);
/* Use OMAP DIE_ID as MAC address */ if (!eth_getenv_enetaddr("ethaddr", enetaddr)) {
- NET_GPMC_CONFIG1,
- NET_GPMC_CONFIG2,
- NET_GPMC_CONFIG3,
- NET_GPMC_CONFIG4,
- NET_GPMC_CONFIG5,
- NET_GPMC_CONFIG6,
- NET_GPMC_CONFIG7,
Value 7 is computed in enable_gpmc_cs_config() so it should be a 0 in the struct (or just a comment for clarity, I've seen both I think).
Hello Tom,
NET_GPMC_CONFIG1,
NET_GPMC_CONFIG2,
NET_GPMC_CONFIG3,
NET_GPMC_CONFIG4,
NET_GPMC_CONFIG5,
NET_GPMC_CONFIG6,
NET_GPMC_CONFIG7,
The calculated value in enable_gpmc_cs_config() is same as NET_GPMC_CONFIG7. The gpmc_net_config[6] is ignored and not used in enable_gpmc_cs_config(). If you want a 0 at this position I will send a second version with a 0 for NET_GPMC_CONFIG7.
Thomas
On Tue, Dec 13, 2011 at 12:57 AM, Thomas Weber thomas.weber.linux@googlemail.com wrote:
Hello Tom,
- NET_GPMC_CONFIG1,
- NET_GPMC_CONFIG2,
- NET_GPMC_CONFIG3,
- NET_GPMC_CONFIG4,
- NET_GPMC_CONFIG5,
- NET_GPMC_CONFIG6,
- NET_GPMC_CONFIG7,
Yes, please send a v2, thanks
Thomas Weber
Thomas Weber
