[U-Boot] [GIT] Pull request: u-boot-dfu (06.11.2019)
Dear Marek,
The following changes since commit 14d39c9e1dc9397febd58399a70f32e7481bbc27:
travis: Rework how we write the ~/.buildman file (2019-11-05 10:44:16 -0500)
git@gitlab.denx.de:u-boot/custodians/u-boot-dfu.git
BRANCH: master https://gitlab.denx.de/u-boot/custodians/u-boot-dfu/commits/master
Merge TAG: https://gitlab.denx.de/u-boot/custodians/u-boot-dfu/-/tags/u-boot-dfu-06Nov2...
for you to fetch changes up to 8c5df588e89b2bf4aad4c95b17cfc8634b8dcaaf:
usb: composite: add BOS descriptor support to composite framework (2019-11-06 01:01:06 +0100)
My remark:
- Those patches are new code, (like adding the USB 3.0 controller from Cadence) hence IMHO it would be best to add them to your next PR
---------------------------------------------------------------- Sherry Sun (1): usb: udc: Introduce ->udc_set_speed() method
T Karthik Reddy (1): usb: composite: add BOS descriptor support to composite framework
Vignesh Raghavendra (7): list: import list_first_entry_or_null() bitmaps: import for_each_set_bit() macro usb: gadget: Add match_ep() op to usb_gadget_ops usb: Add Cadence USB3 host and gadget driver usb: cdns3: gadget: Implement udc_set_speed() callback usb: cdns3: Add TI wrapper driver for CDNS USB3 controller usb: gadget: Add gadget_is_cdns3() macro
Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/607937090
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 11/6/19 10:21 AM, Lukasz Majewski wrote:
Dear Marek,
My remark:
We are already in -rc cycle, so fixes only. Should this PR be for -next ?
Hi Marek,
Dear Marek,
My remark:
The BOS support is a fix do SS USB.
And the Cadence USB support is a new code, which is not touching any relevant parts of USB (and IMHO it applies to the same category as adding new boards outside the merge window).
However, if you believe that this code is not eligible for u-boot-usb/master ,then yes please pull it into -next.
Lukasz Majewski
On 11/6/19 12:27 PM, Lukasz Majewski wrote:
Hi Marek,
Dear Marek,
My remark:
That decision is up to you. If you think this is safe to pull in RC1, I don't mind either way.
Hi Marek,
Hi Marek,
Dear Marek,
My remark:
Ok. Lets then pull it in RC1. Thanks for understanding :-)
Lukasz Majewski
On 11/6/19 1:27 PM, Lukasz Majewski wrote:
Hi Marek,
Hi Marek,
Dear Marek,
My remark:
Pulled, thanks.
Lukasz Majewski
