[U-Boot] [PATCH v5] TI DaVinci: Driver for the davinci SPI controller
This adds a driver for the SPI controller found on davinci based SoCs from Texas Instruments.
Signed-off-by: Sekhar Nori nsekhar@ti.com Signed-off-by: Sudhakar Rajashekhara sudhakar.raj@ti.com ---
From the previous version, following are the modifications:
1. Argument to sizeof() changed in spi_setup_slave() function. 2. Check for NULL before calling free() is removed in spi_free_slave() function. 3. Check for NULL before calling container_of() function in SPI header file was removed.
drivers/spi/Makefile | 1 + drivers/spi/davinci_spi.c | 223 +++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/davinci_spi.h | 102 +++++++++++++++++++++ 3 files changed, 326 insertions(+), 0 deletions(-) create mode 100644 drivers/spi/davinci_spi.c create mode 100644 drivers/spi/davinci_spi.h
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 824d8e7..f112ed0 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -29,6 +29,7 @@ COBJS-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o COBJS-$(CONFIG_ATMEL_SPI) += atmel_spi.o COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o COBJS-$(CONFIG_CF_SPI) += cf_spi.o +COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o COBJS-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c new file mode 100644 index 0000000..ebc7f80 --- /dev/null +++ b/drivers/spi/davinci_spi.c @@ -0,0 +1,223 @@ +/* + * Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/ + * + * Driver for SPI controller on DaVinci. Based on atmel_spi.c + * by Atmel Corporation + * + * Copyright (C) 2007 Atmel Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <spi.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include "davinci_spi.h" + +void spi_init() +{ + /* do nothing */ +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct davinci_spi_slave *ds; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ds = malloc(sizeof(*ds)); + if (!ds) + return NULL; + + ds->slave.bus = bus; + ds->slave.cs = cs; + ds->regs = (struct davinci_spi_regs *)CONFIG_SYS_SPI_BASE; + ds->freq = max_hz; + + return &ds->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct davinci_spi_slave *ds = to_davinci_spi(slave); + + free(ds); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct davinci_spi_slave *ds = to_davinci_spi(slave); + unsigned int scalar, data1_reg_val = 0; + + /* Enable the SPI hardware */ + writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0); + udelay(1000); + writel(SPIGCR0_SPIENA_MASK, &ds->regs->gcr0); + + /* Set master mode, powered up and not activated */ + writel(SPIGCR1_MASTER_MASK | SPIGCR1_CLKMOD_MASK, &ds->regs->gcr1); + + /* CS, CLK, SIMO and SOMI are functional pins */ + writel((SPIPC0_EN0FUN_MASK | SPIPC0_CLKFUN_MASK | + SPIPC0_DOFUN_MASK | SPIPC0_DIFUN_MASK), &ds->regs->pc0); + + /* setup format */ + scalar = ((CONFIG_SYS_SPI_CLK / ds->freq) - 1) & 0xFF; + + /* + * Use following format: + * character length = 8, + * clock signal delayed by half clk cycle, + * clock low in idle state - Mode 0, + * MSB shifted out first + */ + writel(8 | (scalar << SPIFMT_PRESCALE_SHIFT) | + (1 << SPIFMT_PHASE_SHIFT), &ds->regs->fmt0); + + /* hold cs active at end of transfer until explicitly de-asserted */ + data1_reg_val = (1 << SPIDAT1_CSHOLD_SHIFT) | + (slave->cs << SPIDAT1_CSNR_SHIFT); + writel(data1_reg_val, &ds->regs->dat1); + + /* + * Including a minor delay. No science here. Should be good even with + * no delay + */ + writel((50 << SPI_C2TDELAY_SHIFT) | + (50 << SPI_T2CDELAY_SHIFT), &ds->regs->delay); + + /* default chip select register */ + writel(SPIDEF_CSDEF0_MASK, &ds->regs->def); + + /* no interrupts */ + writel(0, &ds->regs->int0); + writel(0, &ds->regs->lvl); + + /* enable SPI */ + writel((readl(&ds->regs->gcr1) | SPIGCR1_SPIENA_MASK), &ds->regs->gcr1); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct davinci_spi_slave *ds = to_davinci_spi(slave); + + /* Disable the SPI hardware */ + writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct davinci_spi_slave *ds = to_davinci_spi(slave); + unsigned int len, data1_reg_val = readl(&ds->regs->dat1); + int ret, i; + const u8 *txp = dout; /* dout can be NULL for read operation */ + u8 *rxp = din; /* din can be NULL for write operation */ + + ret = 0; + + if (bitlen == 0) + /* Finish any previously submitted transfers */ + goto out; + + /* + * It's not clear how non-8-bit-aligned transfers are supposed to be + * represented as a stream of bytes...this is a limitation of + * the current SPI interface - here we terminate on receiving such a + * transfer request. + */ + if (bitlen % 8) { + /* Errors always terminate an ongoing transfer */ + flags |= SPI_XFER_END; + goto out; + } + + len = bitlen / 8; + + /* do an empty read to clear the current contents */ + readl(&ds->regs->buf); + + /* keep writing and reading 1 byte until done */ + for (i = 0; i < len; i++) { + /* wait till TXFULL is asserted */ + while (readl(&ds->regs->buf) & SPIBUF_TXFULL_MASK); + + /* write the data */ + data1_reg_val &= ~0xFFFF; + if (txp) { + data1_reg_val |= *txp; + txp++; + } + + /* + * Write to DAT1 is required to keep the serial transfer going. + * We just terminate when we reach the end. + */ + if ((i == (len - 1)) && (flags & SPI_XFER_END)) { + /* clear CS hold */ + writel(data1_reg_val & + ~(1 << SPIDAT1_CSHOLD_SHIFT), &ds->regs->dat1); + } else { + /* enable CS hold */ + data1_reg_val |= ((1 << SPIDAT1_CSHOLD_SHIFT) | + (slave->cs << SPIDAT1_CSNR_SHIFT)); + writel(data1_reg_val, &ds->regs->dat1); + } + + /* read the data - wait for data availability */ + while (readl(&ds->regs->buf) & SPIBUF_RXEMPTY_MASK); + + if (rxp) { + *rxp = readl(&ds->regs->buf) & 0xFF; + rxp++; + } else { + /* simply drop the read character */ + readl(&ds->regs->buf); + } + } + return 0; + +out: + if (flags & SPI_XFER_END) { + writel(data1_reg_val & + ~(1 << SPIDAT1_CSHOLD_SHIFT), &ds->regs->dat1); + } + return 0; +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs == 0; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + /* do nothing */ +} + diff --git a/drivers/spi/davinci_spi.h b/drivers/spi/davinci_spi.h new file mode 100644 index 0000000..2b5d1d4 --- /dev/null +++ b/drivers/spi/davinci_spi.h @@ -0,0 +1,102 @@ +/* + * Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/ + * + * Register definitions for the DaVinci SPI Controller + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _DAVINCI_SPI_H_ +#define _DAVINCI_SPI_H_ + +struct davinci_spi_regs { + dv_reg gcr0; /* 0x00 */ + dv_reg gcr1; /* 0x04 */ + dv_reg int0; /* 0x08 */ + dv_reg lvl; /* 0x0c */ + dv_reg flg; /* 0x10 */ + dv_reg pc0; /* 0x14 */ + dv_reg pc1; /* 0x18 */ + dv_reg pc2; /* 0x1c */ + dv_reg pc3; /* 0x20 */ + dv_reg pc4; /* 0x24 */ + dv_reg pc5; /* 0x28 */ + dv_reg rsvd[3]; + dv_reg dat0; /* 0x38 */ + dv_reg dat1; /* 0x3c */ + dv_reg buf; /* 0x40 */ + dv_reg emu; /* 0x44 */ + dv_reg delay; /* 0x48 */ + dv_reg def; /* 0x4c */ + dv_reg fmt0; /* 0x50 */ + dv_reg fmt1; /* 0x54 */ + dv_reg fmt2; /* 0x58 */ + dv_reg fmt3; /* 0x5c */ + dv_reg intvec0; /* 0x60 */ + dv_reg intvec1; /* 0x64 */ +}; + +#define BIT(x) (1 << (x)) + +/* SPIGCR0 */ +#define SPIGCR0_SPIENA_MASK 0x1 +#define SPIGCR0_SPIRST_MASK 0x0 + +/* SPIGCR0 */ +#define SPIGCR1_CLKMOD_MASK BIT(1) +#define SPIGCR1_MASTER_MASK BIT(0) +#define SPIGCR1_SPIENA_MASK BIT(24) + +/* SPIPC0 */ +#define SPIPC0_DIFUN_MASK BIT(11) /* SIMO */ +#define SPIPC0_DOFUN_MASK BIT(10) /* SOMI */ +#define SPIPC0_CLKFUN_MASK BIT(9) /* CLK */ +#define SPIPC0_EN0FUN_MASK BIT(0) + +/* SPIFMT0 */ +#define SPIFMT_SHIFTDIR_SHIFT 20 +#define SPIFMT_POLARITY_SHIFT 17 +#define SPIFMT_PHASE_SHIFT 16 +#define SPIFMT_PRESCALE_SHIFT 8 + +/* SPIDAT1 */ +#define SPIDAT1_CSHOLD_SHIFT 28 +#define SPIDAT1_CSNR_SHIFT 16 + +/* SPIDELAY */ +#define SPI_C2TDELAY_SHIFT 24 +#define SPI_T2CDELAY_SHIFT 16 + +/* SPIBUF */ +#define SPIBUF_RXEMPTY_MASK BIT(31) +#define SPIBUF_TXFULL_MASK BIT(29) + +/* SPIDEF */ +#define SPIDEF_CSDEF0_MASK BIT(0) + +struct davinci_spi_slave { + struct spi_slave slave; + struct davinci_spi_regs *regs; + u32 mr; + unsigned int freq; +}; + +static inline struct davinci_spi_slave *to_davinci_spi(struct spi_slave *slave) +{ + return container_of(slave, struct davinci_spi_slave, slave); +} + +#endif /* _DAVINCI_SPI_H_ */
- Argument to sizeof() changed in spi_setup_slave() function.
- Check for NULL before calling free() is removed in spi_free_slave() function.
- Check for NULL before calling container_of() function in SPI header file was removed.
I believe you have addressed all the outstanding issues. Thank you Ack-ed Tom
Tom
